StdMeshers_MaxElementArea_i.hxx
24// File : StdMeshers_MaxElementArea_i.hxx
25// Moved here from SMESH_MaxElementArea_i.hxx
26// Author : Paul RASCLE, EDF
27// Module : SMESH
28//
29#ifndef _SMESH_MAXELEMENTAREA_I_HXX_
30#define _SMESH_MAXELEMENTAREA_I_HXX_
31
33
34#include <SALOMEconfig.h>
35#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
36
39
40// ======================================================
41// Maximum Element Area hypothesis
42// ======================================================
44 public virtual POA_StdMeshers::StdMeshers_MaxElementArea,
45 public virtual SMESH_Hypothesis_i
46{
47public:
48 // Constructor
49 StdMeshers_MaxElementArea_i( PortableServer::POA_ptr thePOA,
50 ::SMESH_Gen* theGenImpl );
51 // Destructor
53
54 // Set maximum element area
55 void SetMaxElementArea( CORBA::Double theArea );
56 // Get maximum element area
57 CORBA::Double GetMaxElementArea();
58
59 // Get implementation
61
62 // Verify whether hypothesis supports given entity type
63 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
64
65
66
67 // Methods for copying mesh definition to other geometry
68
69 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
70 virtual bool getObjectsDependOn( std::vector< std::string > & /*entryArray*/,
71 std::vector< int > & /*subIDArray*/ ) const { return 0; }
72
73 // Set new geometry instead of that returned by getObjectsDependOn()
74 virtual bool setObjectsDependOn( std::vector< std::string > & /*entryArray*/,
75 std::vector< int > & /*subIDArray*/ ) { return true; }
76
77 protected:
78 virtual std::string getMethodOfParameter(const int paramIndex, int nbVars) const;
79};
80
81#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual std::string getMethodOfParameter(const int, int) const
Definition: SMESH_Hypothesis_i.hxx:134
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
Definition: StdMeshers_MaxElementArea_i.hxx:46
virtual bool setObjectsDependOn(std::vector< std::string > &, std::vector< int > &)
Definition: StdMeshers_MaxElementArea_i.hxx:74
virtual bool getObjectsDependOn(std::vector< std::string > &, std::vector< int > &) const
Definition: StdMeshers_MaxElementArea_i.hxx:70
Definition: StdMeshers_MaxElementArea.hxx:38
Dimension
