28#ifndef _SMESH_ProjectionSource2D_I_HXX_
29#define _SMESH_ProjectionSource2D_I_HXX_
31#include <SALOMEconfig.h>
32#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
33#include CORBA_SERVER_HEADER(SMESH_Mesh)
49 public virtual POA_StdMeshers::StdMeshers_ProjectionSource2D,
85 GEOM::GEOM_Object_ptr sourceVertex2,
86 GEOM::GEOM_Object_ptr targetVertex1,
87 GEOM::GEOM_Object_ptr targetVertex2);
111 virtual void LoadFrom(
const char* theStream );
118 std::vector< int > & subIDArray )
const;
122 std::vector< int > & subIDArray );
Definition: SMESH_Gen.hxx:68
This hypothesis specifies a meshed face to take a mesh pattern from and optionally association of ver...
Definition: StdMeshers_ProjectionSource2D_i.hxx:51
@ SRC_FACE
Definition: StdMeshers_ProjectionSource2D_i.hxx:127
@ SRC_VERTEX1
@ TGT_VERTEX1
@ NB_SHAPES
@ TGT_VERTEX2
@ SRC_VERTEX2
void SetVertexAssociation(GEOM::GEOM_Object_ptr sourceVertex1, GEOM::GEOM_Object_ptr sourceVertex2, GEOM::GEOM_Object_ptr targetVertex1, GEOM::GEOM_Object_ptr targetVertex2)
Sets vertex association between the source face and the target one.
Definition: StdMeshers_ProjectionSource2D_i.cxx:144
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)
Definition: StdMeshers_ProjectionSource2D_i.cxx:334
GEOM::GEOM_Object_ptr GetSourceFace()
Returns the source face.
Definition: StdMeshers_ProjectionSource2D_i.cxx:179
CORBA::Boolean IsDimSupported(SMESH::Dimension type)
Definition: StdMeshers_ProjectionSource2D_i.cxx:239
GEOM::GEOM_Object_ptr GetTargetVertex(CORBA::Long i)
Returns the -th target vertex associated with the -th source vertex.
Definition: StdMeshers_ProjectionSource2D_i.cxx:209
::StdMeshers_ProjectionSource2D * GetImpl()
StdMeshers_ProjectionSource2D_i::GetImpl.
Definition: StdMeshers_ProjectionSource2D_i.cxx:225
virtual void LoadFrom(const char *theStream)
Retrieve parameters from the string.
Definition: StdMeshers_ProjectionSource2D_i.cxx:272
void SetSourceFace(GEOM::GEOM_Object_ptr face)
Sets a source <face> to take a mesh pattern from.
Definition: StdMeshers_ProjectionSource2D_i.cxx:76
virtual char * SaveTo()
Write parameters in a string.
Definition: StdMeshers_ProjectionSource2D_i.cxx:251
SMESH::SMESH_Mesh_var myCorbaMesh
Definition: StdMeshers_ProjectionSource2D_i.hxx:129
GEOM::GEOM_Object_ptr GetSourceVertex(CORBA::Long i)
Returns the -th source vertex associated with the -th target vertex.
Definition: StdMeshers_ProjectionSource2D_i.cxx:194
std::string myShapeEntries[NB_SHAPES]
Definition: StdMeshers_ProjectionSource2D_i.hxx:128
void SetSourceMesh(SMESH::SMESH_Mesh_ptr mesh)
Sets source <mesh> to take a mesh pattern from.
Definition: StdMeshers_ProjectionSource2D_i.cxx:97
SMESH::SMESH_Mesh_ptr GetSourceMesh()
Return source mesh.
Definition: StdMeshers_ProjectionSource2D_i.cxx:130
StdMeshers_ProjectionSource2D_i(PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
StdMeshers_ProjectionSource2D_i::StdMeshers_ProjectionSource2D_i.
Definition: StdMeshers_ProjectionSource2D_i.cxx:50
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const
Definition: StdMeshers_ProjectionSource2D_i.cxx:318
virtual ~StdMeshers_ProjectionSource2D_i()
StdMeshers_ProjectionSource2D_i::~StdMeshers_ProjectionSource2D_i.
Definition: StdMeshers_ProjectionSource2D_i.cxx:66
Definition: StdMeshers_ProjectionSource2D.hxx:49
Dimension
