StdMeshers_SegmentLengthAroundVertex_i.hxx
24// File : StdMeshers_SegmentLengthAroundVertex_i.hxx
25// Module : SMESH
26//
27#ifndef _SMESH_SegmentLengthAroundVertex_I_HXX_
28#define _SMESH_SegmentLengthAroundVertex_I_HXX_
30#include <SALOMEconfig.h>
31#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
32
35
36class SMESH_Gen;
37
43 public virtual POA_StdMeshers::StdMeshers_SegmentLengthAroundVertex,
44 public virtual SMESH_Hypothesis_i
45{
46public:
47 // Constructor
48 StdMeshers_SegmentLengthAroundVertex_i( PortableServer::POA_ptr thePOA,
49 ::SMESH_Gen* theGenImpl );
50 // Destructor
52
53 // Set length
54 void SetLength( CORBA::Double theLength );
55
56 // Get length
57 CORBA::Double GetLength();
58
59 // Get implementation
61
62 // Verify whether hypothesis supports given entity type
63 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
64
65
66 // Methods for copying mesh definition to other geometry
67
68 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
69 virtual bool getObjectsDependOn( std::vector< std::string > & /*entryArray*/,
70 std::vector< int > & /*subIDArray*/ ) const { return 0; }
71
72 // Set new geometry instead of that returned by getObjectsDependOn()
73 virtual bool setObjectsDependOn( std::vector< std::string > & /*entryArray*/,
74 std::vector< int > & /*subIDArray*/ ) { return true; }
75 protected:
76 virtual std::string getMethodOfParameter(const int paramIndex, int nbVars) const;
77};
78
79#endif
80
Definition: SMESH_Gen.hxx:68
This hypothesis specifies length of segments adjacent to the vertex the hypothesis is assigned to.
Definition: StdMeshers_SegmentLengthAroundVertex_i.hxx:45
::StdMeshers_SegmentLengthAroundVertex * GetImpl()
StdMeshers_SegmentLengthAroundVertex_i::GetImpl.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:112
virtual ~StdMeshers_SegmentLengthAroundVertex_i()
StdMeshers_SegmentLengthAroundVertex_i::~StdMeshers_SegmentLengthAroundVertex_i.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:64
virtual bool setObjectsDependOn(std::vector< std::string > &, std::vector< int > &)
Definition: StdMeshers_SegmentLengthAroundVertex_i.hxx:73
void SetLength(CORBA::Double theLength)
StdMeshers_SegmentLengthAroundVertex_i::SetLength.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:76
CORBA::Boolean IsDimSupported(SMESH::Dimension type)
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:127
virtual bool getObjectsDependOn(std::vector< std::string > &, std::vector< int > &) const
Definition: StdMeshers_SegmentLengthAroundVertex_i.hxx:69
StdMeshers_SegmentLengthAroundVertex_i::GetLength.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:98
Return method name corresponding to index of variable parameter.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:138
StdMeshers_SegmentLengthAroundVertex_i(PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
StdMeshers_SegmentLengthAroundVertex_i::StdMeshers_SegmentLengthAroundVertex_i.
Definition: StdMeshers_SegmentLengthAroundVertex_i.cxx:47
Definition: StdMeshers_SegmentLengthAroundVertex.hxx:41
Dimension
