StdMeshers_StartEndLength_i.hxx
24// File : StdMeshers_StartEndLength_i.hxx
25// Moved here from SMESH_LocalLength_i.hxx
26// Author : Paul RASCLE, EDF
27// Module : SMESH
28//
29#ifndef _SMESH_StartEndLength_I_HXX_
30#define _SMESH_StartEndLength_I_HXX_
31
33
34#include <SALOMEconfig.h>
35#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
36
39
40class SMESH_Gen;
41
42// ======================================================
43// Local Length hypothesis
44// ======================================================
46 public virtual POA_StdMeshers::StdMeshers_StartEndLength,
47 public virtual SMESH_Hypothesis_i,
48 public virtual StdMeshers_Reversible1D_i
49{
50public:
51 // Constructor
52 StdMeshers_StartEndLength_i(PortableServer::POA_ptr thePOA,
53 ::SMESH_Gen* theGenImpl );
54 // Destructor
56
57 // Set length
58 // * OBSOLETE *. Avoid such a way of interface design
59 void SetLength( CORBA::Double theLength, CORBA::Boolean theIsStart );
60
61 // Sets <start segment length> parameter value
62 void SetStartLength( CORBA::Double length);
63
64 // Sets <end segment length> parameter value
65 void SetEndLength( CORBA::Double length);
66
67 // Get length
68 CORBA::Double GetLength(CORBA::Boolean theIsStart);
69
70 // Get implementation
72
73 // Verify whether hypothesis supports given entity type
74 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
75
76
77 // Methods for copying mesh definition to other geometry
78
79 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
80 virtual bool getObjectsDependOn( std::vector< std::string > & entryArray,
81 std::vector< int > & subIDArray ) const;
82
83 // Set new geometry instead of that returned by getObjectsDependOn()
84 virtual bool setObjectsDependOn( std::vector< std::string > & entryArray,
85 std::vector< int > & subIDArray );
86
87 protected:
88 virtual std::string getMethodOfParameter(const int paramIndex, int nbVars) const;
89};
90
91#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)=0
virtual std::string getMethodOfParameter(const int, int) const
Definition: SMESH_Hypothesis_i.hxx:134
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const =0
Definition: StdMeshers_Reversible1D_i.hxx:43
Definition: StdMeshers_StartEndLength_i.hxx:49
Definition: StdMeshers_StartEndLength.hxx:39
Dimension
