GeomSelectionTools Class Reference
The GeomSelectionTools class gives high level tools to select Geom (and other objects) A specific attention has been given to analyze selected GEOM objects. More...
#include <GeomSelectionTools.h>
 GeomSelectionTools ()
SALOME_ListIO * getSelectedSalomeObjects ()
 Return the list of the selected Salome Interactive Object (SALOME_ListIO*) More...
 Handle (SALOME_InteractiveObject) getFirstSelectedSalomeObject()
std::string getFirstSelectedEntry ()
 Return the entry of the first selected Object. More...
std::string getEntryOfObject (Handle(SALOME_InteractiveObject))
 Return the entry of a Salome Interactive Object. More...
std::string getNameFromEntry (const std::string &)
 Retrieve the name from the entry of the object. More...
std::string getFirstSelectedComponentDataType ()
 Retrieve the component type of the first selected object, it manages successfully references. More...
TopAbs_ShapeEnum getFirstSelectedShapeType ()
 Gives the ShapeType of the first Selected Object, return TopAbs_SHAPE if the first selected object does not define a shape. More...
TopAbs_ShapeEnum entryToShapeType (const std::string &)
 Retrieve the shape type from the entry. More...
GeomAbs_SurfaceType getFaceInformation (TopoDS_Shape)
 Print information to std output of the face and return the OCC type of face: Plane, Cylinder,Cone, Sphere, Torus, BezierSurface,BSplineSurface, SurfaceOfRevolution,SurfaceOfExtrusion, OtherSurface. More...
static SalomeApp_Application * GetSalomeApplication ()
 Allows to get the Salome Application. More...
static LightApp_SelectionMgr * selectionMgr ()
 Allows to get the selection manager from LightApp. More...
◆ GeomSelectionTools()
GeomSelectionTools::GeomSelectionTools ( )
◆ entryToShapeType()
TopAbs_ShapeEnum GeomSelectionTools::entryToShapeType ( const std::string &  entry)
the shape type from the entry, return TopAbs_SHAPE if the object does not define a shape or a group.
References SMESH::_PTR().
Referenced by getFirstSelectedShapeType().
◆ getEntryOfObject()
std::string GeomSelectionTools::getEntryOfObject ( Handle(SALOME_InteractiveObject)  anIO)
anIOthe Handle of the Salome Interactive Object
the entry of the Salome Interactive Object
Referenced by getFirstSelectedEntry().
◆ getFaceInformation()
GeomAbs_SurfaceType GeomSelectionTools::getFaceInformation ( TopoDS_Shape  S)
TopoDS_ShapeS Face we want information about.
the OCC type of face: Plane, Cylinder,Cone, Sphere, Torus, BezierSurface,BSplineSurface, SurfaceOfRevolution,SurfaceOfExtrusion, OtherSurface return Other_Surface if the selected face is not a face. Information printed is : U and V degrees U and V number of poles U and V number of knots U or V is Rational ?
References Face.
◆ getFirstSelectedComponentDataType()
std::string GeomSelectionTools::getFirstSelectedComponentDataType ( )
References SMESH::_PTR(), and Handle().
◆ getFirstSelectedEntry()
std::string GeomSelectionTools::getFirstSelectedEntry ( )
References getEntryOfObject(), and Handle().
◆ getFirstSelectedShapeType()
TopAbs_ShapeEnum GeomSelectionTools::getFirstSelectedShapeType ( )
References entryToShapeType(), and Handle().
◆ getNameFromEntry()
std::string GeomSelectionTools::getNameFromEntry ( const std::string &  entry)
entrythe entry of the object
the name of the object
◆ GetSalomeApplication()
SalomeApp_Application * GeomSelectionTools::GetSalomeApplication ( )
A LightApp_SelectionMgr Pointer or 0 if it can't get it.
Referenced by selectionMgr().
◆ getSelectedSalomeObjects()
SALOME_ListIO * GeomSelectionTools::getSelectedSalomeObjects ( )
References selectionMgr().
◆ Handle()
GeomSelectionTools::Handle ( SALOME_InteractiveObject  )
◆ selectionMgr()
LightApp_SelectionMgr * GeomSelectionTools::selectionMgr ( )
References GetSalomeApplication().
Referenced by getSelectedSalomeObjects(), and Handle().
