MED::TCSlice< TValueType > Class Template Reference
This class intends to provide a uniform way to handle multidimensional data (const version) More...
#include <MED_SliceArray.hxx>
Inheritance diagram for MED::TCSlice< TValueType >:
typedef TValueType value_type
 TCSlice (const value_type *theValuePtr, size_t theSourceSize, const std::slice &theSlice)
 Construct the class from bare pointer. More...
 TCSlice (const TVector< value_type > &theContainer, const std::slice &theSlice)
 Construct the class from corresponding container. More...
 TCSlice ()
 Default constructor (dangerous) More...
const value_type & operator[] (size_t theId) const
 Get element by its number (const version) More...
const value_type & at (size_t theId) const
size_t size () const
 Get range of the order numbers. More...
void check_id (size_t theId) const
size_t calculate_id (size_t theId) const
 Calculate internal index to get proper element from the source multidimensional data. More...
size_t get_id (size_t theId) const
size_t get_id_at (size_t theId) const
const TValueType * myCValuePtr
 Reference to source multidimensional data. More...
size_t mySourceSize
 Size of the source multidimensional data. More...
std::slice mySlice
 Defines algorithm of index calculation. More...
template<class TValueType>
class MED::TCSlice< TValueType >
It just contains a pointer to real sequence and implement proper calculation of its indexes. This class deals with constant pointer to the sources data and provides const method to read them (data).
◆ value_type
template<class TValueType >
typedef TValueType MED::TCSlice< TValueType >::value_type
◆ TCSlice() [1/3]
MED::TCSlice< TValueType >::TCSlice ( const value_type *  theValuePtr,
const std::slice &  theSlice
◆ TCSlice() [2/3]
MED::TCSlice< TValueType >::TCSlice ( const TVector< value_type > &  theContainer,
◆ TCSlice() [3/3]
MED::TCSlice< TValueType >::TCSlice ( )
◆ at()
const value_type & MED::TCSlice< TValueType >::at ( size_t  theId) const
◆ calculate_id()
size_t MED::TCSlice< TValueType >::calculate_id ( size_t  theId) const
References MED::TCSlice< TValueType >::mySlice.
Referenced by MED::TCSlice< TValueType >::get_id(), and MED::TCSlice< TValueType >::get_id_at().
◆ check_id()
void MED::TCSlice< TValueType >::check_id ( size_t  theId) const
◆ get_id()
size_t MED::TCSlice< TValueType >::get_id ( size_t  theId) const
◆ get_id_at()
size_t MED::TCSlice< TValueType >::get_id_at ( size_t  theId) const
◆ operator[]()
const value_type & MED::TCSlice< TValueType >::operator[] ( size_t  theId) const
References MED::TCSlice< TValueType >::get_id(), and MED::TCSlice< TValueType >::myCValuePtr.
◆ size()
size_t MED::TCSlice< TValueType >::size ( ) const
◆ myCValuePtr
const TValueType* MED::TCSlice< TValueType >::myCValuePtr
Referenced by MED::TCSlice< TValueType >::at(), and MED::TCSlice< TValueType >::operator[]().
◆ mySlice
std::slice MED::TCSlice< TValueType >::mySlice
◆ mySourceSize
size_t MED::TCSlice< TValueType >::mySourceSize
Referenced by MED::TCSlice< TValueType >::check_id().
