MeshJobManager_i Class Reference
#include <MeshJobManager_i.hxx>
Inheritance diagram for MeshJobManager_i:
 MeshJobManager_i (CORBA::ORB_ptr orb, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool checkNS=true, bool regist=true)
 ~MeshJobManager_i ()
bool configure (const char *configId, const MESHJOB::ConfigParameter &configParameter)
CORBA::Long initialize (const MESHJOB::MeshJobFileList &meshJobFileList, const MESHJOB::MeshJobParameterList &meshJobParameterList, const char *configId)
 Initialize a smesh computation job and return the job identifier. More...
bool start (CORBA::Long jobId)
 Submit the job execution and return true if submission is OK. More...
char * getState (CORBA::Long jobId)
 Request the launch manager for the state of the specified job. More...
MESHJOB::MeshJobResults * finalize (CORBA::Long jobId)
MESHJOB::MeshJobPaths * getPaths (CORBA::Long jobId)
bool clean (CORBA::Long jobId)
 Clean all data associated to this job and remove the job from the launch manager. More...
char * getLastErrorMessage ()
Static Public Attributes
static long JOBID_UNDEFINED = -1
const char * _writeDataFile (std::vector< MESHJOB::MeshJobFile > listConcreteMesh, std::vector< MESHJOB::MeshJobFile > listSteelBarMesh, const MESHJOB::MeshJobParameterList &meshJobParameterList)
 This function creates the padder text input file containing the input data (list of filenames and groupnames) and returns the path of the created file. More...
const char * _writeScriptFile (const char *dataFileName, const char *configId)
 This function creates a shell script that runs padder with the specified data file, and returns the path of the created script file. More...
std::vector< std::string > * _getResourceNames ()
Engines::SalomeLauncher_var _salomeLauncher
Engines::ResourcesManager_var _resourcesManager
std::map< std::string, MESHJOB::ConfigParameter > _configMap
std::map< long, long > _jobDateTimeMap
std::map< long, MESHJOB::MeshJobPaths * > _jobPathsMap
std::string _lastErrorMessage
◆ MeshJobManager_i()
MeshJobManager_i::MeshJobManager_i ( CORBA::ORB_ptr  orb,
const char *  instanceName,
const char *  interfaceName,
bool  checkNS = true,
bool  regist = true
◆ ~MeshJobManager_i()
MeshJobManager_i::~MeshJobManager_i ( )
References LOG.
◆ _getResourceNames()
std::vector< std::string > * MeshJobManager_i::_getResourceNames ( )
References _resourcesManager, and LOG.
◆ _writeDataFile()
const char * MeshJobManager_i::_writeDataFile ( std::vector< MESHJOB::MeshJobFile >  listConcreteMesh,
const MESHJOB::MeshJobParameterList &  meshJobParameterList
This function is the one that knows the format of the padder input file. If the input file format changes, then this function (and only this one) should be updated. The file format is the following ([] means that the variable is optional):
[<concreteMeshFile> <concreteGroupName>] nbSteelBarMeshes <N> <steelBarMeshFile_1> <steelBarGroupName_1> <steelBarMeshFile_2> <steelBarGroupName_2> ... <steelBarMeshFile_N> <steelBarGroupName_N> <outputMedFile>
References DATAFILE(), LOCAL_INPUTDIR(), MESHJOB::MeshJobParameter::name, OUTPUTFILE(), SEPARATOR(), and MESHJOB::MeshJobParameter::value.
Referenced by initialize().
◆ _writeScriptFile()
const char * MeshJobManager_i::_writeScriptFile ( const char *  dataFileName,
const char *  configId
The config id is used to retrieve the path to the binary file and other required files.
References _configMap, LOCAL_INPUTDIR(), and SCRIPTFILE().
◆ clean()
bool MeshJobManager_i::clean ( CORBA::Long  jobId)
References getPaths(), MESHJOB::MeshJobPaths::local_inputdir, MESHJOB::MeshJobPaths::local_resultdir, LOG, and myStartsWith().
◆ configure()
bool MeshJobManager_i::configure ( const char *  configId,
const MESHJOB::ConfigParameter &  configParameter
References _configMap, and LOG.
◆ finalize()
◆ getLastErrorMessage()
char * MeshJobManager_i::getLastErrorMessage ( )
References _lastErrorMessage.
◆ getPaths()
MESHJOB::MeshJobPaths * MeshJobManager_i::getPaths ( CORBA::Long  jobId)
References _jobPathsMap, and LOG.
Referenced by clean(), and finalize().
◆ getState()
char * MeshJobManager_i::getState ( CORBA::Long  jobId)
References _lastErrorMessage, _salomeLauncher, and LOG.
◆ initialize()
◆ start()
bool MeshJobManager_i::start ( CORBA::Long  jobId)
◆ _configMap
std::map<std::string, MESHJOB::ConfigParameter> MeshJobManager_i::_configMap
◆ _jobDateTimeMap
std::map<long, long> MeshJobManager_i::_jobDateTimeMap
Referenced by finalize(), and initialize().
◆ _jobPathsMap
std::map<long, MESHJOB::MeshJobPaths*> MeshJobManager_i::_jobPathsMap
Referenced by getPaths(), and initialize().
◆ _lastErrorMessage
std::string MeshJobManager_i::_lastErrorMessage
◆ _resourcesManager
Engines::ResourcesManager_var MeshJobManager_i::_resourcesManager
◆ _salomeLauncher
Engines::SalomeLauncher_var MeshJobManager_i::_salomeLauncher
◆ JOBID_UNDEFINED
long MeshJobManager_i::JOBID_UNDEFINED = -1
