SMESHGUI_BasicProperties Class Reference
basic properties measurement widget. More...
#include <SMESHGUI_Measurements.h>
Inheritance diagram for SMESHGUI_BasicProperties:
enum  Mode { Length , Area , Volume }
 Property type. More...
 SMESHGUI_BasicProperties (QWidget *=0)
 ~SMESHGUI_BasicProperties ()
void setMode (const Mode)
 Sets the measurement mode. More...
void updateSelection ()
 Setup the selection mode. More...
void deactivate ()
 Deactivate widget. More...
Private Slots
void selectionChanged ()
 Called when selection is changed. More...
void modeChanged (int)
 Called when the measurement mode selection is changed. More...
void compute ()
 Calculate length, area or volume for the selected object(s) More...
void clear ()
 Reset the widget to the initial state (nullify the result field) More...
QButtonGroup * myMode
QLineEdit * mySource
QGroupBox * myResultGrp
QLineEdit * myResult
SMESH::SMESH_IDSource_var mySrc
SUIT_SelectionFilter * myFilter
Widget to calculate length, area or volume for the selected object(s).
◆ Mode
Property type.
Length
Area
Volume
◆ SMESHGUI_BasicProperties()
SMESHGUI_BasicProperties::SMESHGUI_BasicProperties ( QWidget *  parent = 0)
◆ ~SMESHGUI_BasicProperties()
SMESHGUI_BasicProperties::~SMESHGUI_BasicProperties ( )
◆ clear
void SMESHGUI_BasicProperties::clear ( )
privateslot
References myResult.
Referenced by compute(), modeChanged(), and selectionChanged().
◆ compute
void SMESHGUI_BasicProperties::compute ( )
privateslot
References Area, clear(), SMESHGUI::GetSMESHGen(), Length, myMode, myResult, mySrc, SMESHGUI::resourceMgr(), and Volume.
Referenced by SMESHGUI_BasicProperties().
◆ deactivate()
void SMESHGUI_BasicProperties::deactivate ( )
Deactivate widget.
References SMESHGUI::selectionMgr().
Referenced by SMESHGUI_MeasureDlg::deactivate().
◆ modeChanged
void SMESHGUI_BasicProperties::modeChanged ( int  theMode)
privateslot
theModethe selected mode
References Area, clear(), Length, myResultGrp, and Volume.
Referenced by setMode(), and SMESHGUI_BasicProperties().
◆ selectionChanged
void SMESHGUI_BasicProperties::selectionChanged ( )
privateslot
References clear(), SMESH::GetNameOfSelectedIObjects(), Handle(), mySource, mySrc, and SMESHGUI::selectionMgr().
Referenced by updateSelection().
◆ setMode()
void SMESHGUI_BasicProperties::setMode ( const Mode  theMode)
theModethe mode to set (length, area or volume meausurement)
References modeChanged(), and myMode.
Referenced by SMESHGUI_BasicProperties(), and SMESHGUI_MeasureDlg::SMESHGUI_MeasureDlg().
◆ updateSelection()
void SMESHGUI_BasicProperties::updateSelection ( )
◆ myFilter
SUIT_SelectionFilter* SMESHGUI_BasicProperties::myFilter
◆ myMode
QButtonGroup* SMESHGUI_BasicProperties::myMode
◆ myResult
QLineEdit* SMESHGUI_BasicProperties::myResult
◆ myResultGrp
QGroupBox* SMESHGUI_BasicProperties::myResultGrp
◆ mySource
QLineEdit* SMESHGUI_BasicProperties::mySource
◆ mySrc
SMESH::SMESH_IDSource_var SMESHGUI_BasicProperties::mySrc
Referenced by compute(), and selectionChanged().
