SMESHGUI_ClippingDlg Class Reference
#include <SMESHGUI_ClippingDlg.h>
Inheritance diagram for SMESHGUI_ClippingDlg:
Public Slots
void onModeAbsolute ()
 Set absolute mode of clipping plane. More...
void onModeRelative ()
 Set relative mode of clipping plane. More...
void ClickOnNew ()
 SLOT on new button click: create a new clipping plane. More...
void ClickOnDelete ()
 SLOT on delete button click: Delete selected clipping plane. More...
void onSelectPlane (int)
 Set current parameters of selected plane. More...
void onSelectAll (int)
 SLOT: called on SelectAll check box toggled. More...
void onActorItemChanged (QListWidgetItem *)
 SLOT: called when actor item was changed. More...
void SetCurrentPlaneParam ()
 Restore parameters of selected plane. More...
void onIsOpenGLClipping (bool)
 SLOT: called on OpenGLClipping check box toggled. More...
void OnPreviewToggle (bool)
 SLOT: called on preview check box toggled. More...
void onAutoApply (bool)
 SLOT: called on Auto Apply check box toggled. More...
void ClickOnOk ()
 SLOT on ok button click: sets cutting plane and closes dialog. More...
void ClickOnApply ()
 SLOT on Apply button click: sets cutting plane and update viewer. More...
void ClickOnHelp ()
 SLOT on help button click: opens a help page. More...
void onSelectAbsoluteOrientation (int)
void onSelectRelativeOrientation (int)
 SLOT: called on orientation of clipping plane in relative mode changed. More...
void onReset ()
 SLOT on reset button click: sets default values. More...
void onInvert ()
 SLOT on invert button click: inverts normal of cutting plane. More...
 SMESHGUI_ClippingDlg (SMESHGUI *, SVTK_ViewWindow *)
 ~SMESHGUI_ClippingDlg ()
 Destructor Destroys the object and frees any allocated resources. More...
static bool AddPlane (SMESH::TActorList theActorList, SMESH::OrientedPlane *thePlane)
 Used in SMESHGUI::restoreVisualParameters() to avoid Declaration of OrientedPlane outside of SMESHGUI_ClippingDlg.cxx. More...
Protected Slots
virtual void reject ()
 SLOT on close button click: rejects dialog. More...
 Custom handling of events. More...
static void ProcessEvents (vtkObject *theObject, unsigned long theEvent, void *theClientData, void *theCallData)
 Handles the char preview widget activation event. More...
double getDistance () const
 Get distance for cutting plane in relative mode. More...
void setDistance (const double)
 Set distance of cutting plane in relative mode. More...
double getRotation1 () const
 Get rotation1 for cutting plane in relative mode. More...
double getRotation2 () const
 Get rotation2 for cutting plane in relative mode. More...
void setRotation (const double, const double)
 Set angles of clipping plane in relative mode. More...
void setOrigin (double theVal[3])
 Set coordinates of origin point in dialog box. More...
void setDirection (double theVal[3])
 Set coordinates of normal vector in dialog box. More...
void initializePlaneData ()
 Initialize the planes's data when the dialog opened. More...
void initParam ()
 Initialization of initial values of widgets. More...
void synchronize ()
 Synchronize dialog's widgets with data. More...
void updateActorList ()
 Update the list of actors. More...
void updateActorItem (QListWidgetItem *theItem, bool theUpdateSelectAll, bool theUpdateClippingPlaneMap)
 Update an actor in actor's list. More...
SMESH::TActorList getCurrentActors ()
 Get the list of current actors. More...
void dumpPlaneData () const
 Dump the parameters of clipping planes. More...
void absolutePlaneToRelative (double theOrigin[3], double theDir[3])
 Convert absolute coordinates of plane to relative mode. More...
void setBoundsForPreviewWidget ()
 Set current bounds for preview widget. More...
vtkImplicitPlaneWidget * createPreviewWidget ()
 Create a new widget for preview clipping plane. More...
SMESHGUI * mySMESHGUI
SVTK_ViewWindow * myViewWindow
SMESH::TPlaneDataVector myPlanes
vtkCallbackCommand * myCallback
vtkImplicitPlaneWidget * myPreviewWidget
double myBounds [6]
QComboBox * ComboBoxPlanes
QCheckBox * isOpenGLClipping
QPushButton * buttonNew
QMenu * MenuMode
QPushButton * buttonDelete
QListWidget * ActorList
QCheckBox * SelectAllCheckBox
QStackedLayout * ModeStackedLayout
QGroupBox * GroupAbsolutePoint
QLabel * TextLabelX
QLabel * TextLabelY
QLabel * TextLabelZ
QtxDoubleSpinBox * SpinBox_X
QtxDoubleSpinBox * SpinBox_Y
QtxDoubleSpinBox * SpinBox_Z
QPushButton * resetButton
QGroupBox * GroupAbsoluteDirection
QLabel * TextLabelDx
QLabel * TextLabelDy
QLabel * TextLabelDz
QtxDoubleSpinBox * SpinBox_Dx
QtxDoubleSpinBox * SpinBox_Dy
QtxDoubleSpinBox * SpinBox_Dz
QPushButton * invertButton
QComboBox * CBAbsoluteOrientation
QGroupBox * GroupRelative
QLabel * TextLabelOrientation
QLabel * TextLabelDistance
QLabel * TextLabelRotation1
QLabel * TextLabelRotation2
QtxDoubleSpinSlider * SpinSliderDistance
QtxIntSpinSlider * SpinSliderRotation1
QtxIntSpinSlider * SpinSliderRotation2
QComboBox * CBRelativeOrientation
QCheckBox * PreviewCheckBox
QCheckBox * AutoApplyCheckBox
QPushButton * buttonOk
QPushButton * buttonCancel
QPushButton * buttonApply
QPushButton * buttonHelp
bool myIsSelectPlane
bool myIsPreviewMoved
QString myHelpFileName
SMESH::Mode CurrentMode
◆ SMESHGUI_ClippingDlg()
◆ ~SMESHGUI_ClippingDlg()
SMESHGUI_ClippingDlg::~SMESHGUI_ClippingDlg ( )
References myCallback, myPlanes, myPreviewWidget, myViewWindow, SMESH::TPlaneData::Plane, and SMESH::RenderViewWindow().
◆ absolutePlaneToRelative()
void SMESHGUI_ClippingDlg::absolutePlaneToRelative ( double  theOrigin[3],
double  theDir[3]
◆ AddPlane()
◆ ClickOnApply
◆ ClickOnDelete
void SMESHGUI_ClippingDlg::ClickOnDelete ( )
slot
References AutoApplyCheckBox, ClickOnApply(), ComboBoxPlanes, myPlanes, myViewWindow, SMESH::TPlaneData::Plane, SMESH::RenderViewWindow(), and synchronize().
Referenced by SMESHGUI_ClippingDlg().
◆ ClickOnHelp
void SMESHGUI_ClippingDlg::ClickOnHelp ( )
slot
References myHelpFileName, and mySMESHGUI.
Referenced by keyPressEvent(), and SMESHGUI_ClippingDlg().
◆ ClickOnNew
◆ ClickOnOk
void SMESHGUI_ClippingDlg::ClickOnOk ( )
slot
References ClickOnApply().
◆ createPreviewWidget()
vtkImplicitPlaneWidget * SMESHGUI_ClippingDlg::createPreviewWidget ( )
References SMESH::GetColor(), myCallback, myViewWindow, and SIZEFACTOR.
◆ dumpPlaneData()
void SMESHGUI_ClippingDlg::dumpPlaneData ( ) const
References SMESH::TPlaneData::ActorList, myPlanes, and SMESH::TPlaneData::Plane.
◆ getCurrentActors()
SMESH::TActorList SMESHGUI_ClippingDlg::getCurrentActors ( )
References ActorList.
◆ getDistance()
double SMESHGUI_ClippingDlg::getDistance ( ) const
References SpinSliderDistance.
Referenced by SetCurrentPlaneParam().
◆ getRotation1()
double SMESHGUI_ClippingDlg::getRotation1 ( ) const
References SpinSliderRotation1.
Referenced by absolutePlaneToRelative(), and SetCurrentPlaneParam().
◆ getRotation2()
double SMESHGUI_ClippingDlg::getRotation2 ( ) const
References SpinSliderRotation2.
◆ initializePlaneData()
void SMESHGUI_ClippingDlg::initializePlaneData ( )
◆ initParam()
void SMESHGUI_ClippingDlg::initParam ( )
◆ keyPressEvent()
void SMESHGUI_ClippingDlg::keyPressEvent ( QKeyEvent *  e)
References ClickOnHelp().
◆ onActorItemChanged
void SMESHGUI_ClippingDlg::onActorItemChanged ( QListWidgetItem *  theItem)
slot
References SetCurrentPlaneParam(), and updateActorItem().
◆ onAutoApply
void SMESHGUI_ClippingDlg::onAutoApply ( bool  toggled)
slot
◆ onInvert
void SMESHGUI_ClippingDlg::onInvert ( )
slot
References ComboBoxPlanes, SMESH::OrientedPlane::IsInvert, myIsSelectPlane, myPlanes, SMESH::TPlaneData::Plane, SetCurrentPlaneParam(), SpinBox_Dx, SpinBox_Dy, and SpinBox_Dz.
◆ onIsOpenGLClipping
void SMESHGUI_ClippingDlg::onIsOpenGLClipping ( bool  toggled)
slot
◆ onModeAbsolute
void SMESHGUI_ClippingDlg::onModeAbsolute ( )
slot
References SMESH::Absolute, ClickOnNew(), CurrentMode, ModeStackedLayout, and SetCurrentPlaneParam().
◆ onModeRelative
void SMESHGUI_ClippingDlg::onModeRelative ( )
slot
References ClickOnNew(), CurrentMode, ModeStackedLayout, SMESH::Relative, and SetCurrentPlaneParam().
◆ OnPreviewToggle
void SMESHGUI_ClippingDlg::OnPreviewToggle ( bool  theIsToggled)
slot
◆ onReset
void SMESHGUI_ClippingDlg::onReset ( )
slot
References myIsSelectPlane, SetCurrentPlaneParam(), SpinBox_X, SpinBox_Y, and SpinBox_Z.
◆ onSelectAbsoluteOrientation
◆ onSelectAll
void SMESHGUI_ClippingDlg::onSelectAll ( int  theState)
slot
References ActorList, SelectAllCheckBox, SetCurrentPlaneParam(), and updateActorItem().
◆ onSelectPlane
◆ onSelectRelativeOrientation
void SMESHGUI_ClippingDlg::onSelectRelativeOrientation ( int  theItem)
slot
References CBRelativeOrientation, myPlanes, SetCurrentPlaneParam(), TextLabelRotation1, and TextLabelRotation2.
Referenced by onSelectPlane(), and SMESHGUI_ClippingDlg().
◆ ProcessEvents()
void SMESHGUI_ClippingDlg::ProcessEvents ( vtkObject *  theObject,
void *  theClientData,
void *  theCallData
staticprotected
◆ reject
void SMESHGUI_ClippingDlg::reject ( )
protectedvirtualslot
◆ setBoundsForPreviewWidget()
void SMESHGUI_ClippingDlg::setBoundsForPreviewWidget ( )
◆ SetCurrentPlaneParam
◆ setDirection()
void SMESHGUI_ClippingDlg::setDirection ( double  theVal[3])
References CBAbsoluteOrientation, SpinBox_Dx, SpinBox_Dy, and SpinBox_Dz.
Referenced by onSelectPlane(), and ProcessEvents().
◆ setDistance()
void SMESHGUI_ClippingDlg::setDistance ( const double  theDistance)
Referenced by onSelectPlane().
◆ setOrigin()
void SMESHGUI_ClippingDlg::setOrigin ( double  theVal[3])
References CBAbsoluteOrientation, SpinBox_X, SpinBox_Y, and SpinBox_Z.
◆ setRotation()
void SMESHGUI_ClippingDlg::setRotation ( const double  theRot1,
const double  theRot2
References SpinSliderRotation1, and SpinSliderRotation2.
◆ synchronize()
◆ updateActorItem()
void SMESHGUI_ClippingDlg::updateActorItem ( QListWidgetItem *  theItem,
◆ updateActorList()
void SMESHGUI_ClippingDlg::updateActorList ( )
◆ ActorList
QListWidget* SMESHGUI_ClippingDlg::ActorList
◆ AutoApplyCheckBox
QCheckBox* SMESHGUI_ClippingDlg::AutoApplyCheckBox
◆ buttonApply
QPushButton* SMESHGUI_ClippingDlg::buttonApply
◆ buttonCancel
QPushButton* SMESHGUI_ClippingDlg::buttonCancel
◆ buttonDelete
QPushButton* SMESHGUI_ClippingDlg::buttonDelete
◆ buttonHelp
QPushButton* SMESHGUI_ClippingDlg::buttonHelp
◆ buttonNew
QPushButton* SMESHGUI_ClippingDlg::buttonNew
◆ buttonOk
QPushButton* SMESHGUI_ClippingDlg::buttonOk
◆ CBAbsoluteOrientation
QComboBox* SMESHGUI_ClippingDlg::CBAbsoluteOrientation
◆ CBRelativeOrientation
◆ ComboBoxPlanes
◆ CurrentMode
◆ GroupAbsoluteDirection
QGroupBox* SMESHGUI_ClippingDlg::GroupAbsoluteDirection
◆ GroupAbsolutePoint
QGroupBox* SMESHGUI_ClippingDlg::GroupAbsolutePoint
◆ GroupRelative
QGroupBox* SMESHGUI_ClippingDlg::GroupRelative
◆ invertButton
QPushButton* SMESHGUI_ClippingDlg::invertButton
◆ isOpenGLClipping
QCheckBox* SMESHGUI_ClippingDlg::isOpenGLClipping
◆ MenuMode
QMenu* SMESHGUI_ClippingDlg::MenuMode
◆ ModeStackedLayout
QStackedLayout* SMESHGUI_ClippingDlg::ModeStackedLayout
◆ myBounds
double SMESHGUI_ClippingDlg::myBounds[6]
◆ myCallback
vtkCallbackCommand* SMESHGUI_ClippingDlg::myCallback
◆ myHelpFileName
QString SMESHGUI_ClippingDlg::myHelpFileName
◆ myIsPreviewMoved
bool SMESHGUI_ClippingDlg::myIsPreviewMoved
◆ myIsSelectPlane
◆ myPlanes
◆ myPreviewWidget
◆ mySMESHGUI
SMESHGUI* SMESHGUI_ClippingDlg::mySMESHGUI
◆ myViewWindow
◆ PreviewCheckBox
QCheckBox* SMESHGUI_ClippingDlg::PreviewCheckBox
◆ resetButton
QPushButton* SMESHGUI_ClippingDlg::resetButton
◆ SelectAllCheckBox
QCheckBox* SMESHGUI_ClippingDlg::SelectAllCheckBox
◆ SpinBox_Dx
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_Dx
◆ SpinBox_Dy
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_Dy
◆ SpinBox_Dz
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_Dz
◆ SpinBox_X
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_X
◆ SpinBox_Y
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_Y
◆ SpinBox_Z
QtxDoubleSpinBox* SMESHGUI_ClippingDlg::SpinBox_Z
◆ SpinSliderDistance
QtxDoubleSpinSlider* SMESHGUI_ClippingDlg::SpinSliderDistance
◆ SpinSliderRotation1
QtxIntSpinSlider* SMESHGUI_ClippingDlg::SpinSliderRotation1
◆ SpinSliderRotation2
QtxIntSpinSlider* SMESHGUI_ClippingDlg::SpinSliderRotation2
◆ TextLabelDistance
QLabel* SMESHGUI_ClippingDlg::TextLabelDistance
◆ TextLabelDx
QLabel* SMESHGUI_ClippingDlg::TextLabelDx
◆ TextLabelDy
QLabel* SMESHGUI_ClippingDlg::TextLabelDy
◆ TextLabelDz
QLabel* SMESHGUI_ClippingDlg::TextLabelDz
◆ TextLabelOrientation
QLabel* SMESHGUI_ClippingDlg::TextLabelOrientation
◆ TextLabelRotation1
QLabel* SMESHGUI_ClippingDlg::TextLabelRotation1
◆ TextLabelRotation2
QLabel* SMESHGUI_ClippingDlg::TextLabelRotation2
◆ TextLabelX
QLabel* SMESHGUI_ClippingDlg::TextLabelX
◆ TextLabelY
QLabel* SMESHGUI_ClippingDlg::TextLabelY
◆ TextLabelZ
QLabel* SMESHGUI_ClippingDlg::TextLabelZ
