SMESHGUI_DuplicateNodesDlg Class Reference
Dialog for duplication of nodes. More...
#include <SMESHGUI_DuplicateNodesDlg.h>
Inheritance diagram for SMESHGUI_DuplicateNodesDlg:
 SMESHGUI_DuplicateNodesDlg (SMESHGUI *)
 ~SMESHGUI_DuplicateNodesDlg ()
Protected Slots
virtual void reject ()
 SLOT called to close the dialog. More...
Private Slots
void onConstructorsClicked (int)
 SLOT called to change the dialog operation mode. More...
void onOk ()
 SLOT called to apply changes and close the dialog. More...
bool onApply ()
 SLOT called to apply changes. More...
void onHelp ()
 Show the dialog help page. More...
void onEditCurrentArgument ()
 SLOT called when selection button clicked. More...
void onSelectionChanged ()
 SLOT called when selection changed. More...
void onDeactivate ()
 SLOT called when dialog should be deactivated. More...
void onGenerate ()
 SLOT called when Generate button is clicked. More...
void updateButtons ()
 Enable/disable "Apply and Close" and "Apply" buttons. More...
void Init ()
bool isValid ()
 Check if the input data is valid. More...
void enterEvent (QEvent *)
 Receive dialog enter events. More...
 Receive key press events. More...
QLineEdit * myCurrentLineEdit
QButtonGroup * myGroupConstructors
QGroupBox * myGroupArguments
QLabel * myTextLabel1
QLabel * myTextLabel2
QLabel * myTextLabel3
QPushButton * mySelectButton1
QPushButton * mySelectButton2
QPushButton * mySelectButton3
QPushButton * myGenerateButton3
QLineEdit * myLineEdit1
QLineEdit * myLineEdit2
QLineEdit * myLineEdit3
QCheckBox * myCheckBox1
QCheckBox * myCheckBox2
QPushButton * myButtonOk
QPushButton * myButtonApply
QPushButton * myButtonClose
QPushButton * myButtonHelp
SMESHGUI * mySMESHGUI
LightApp_SelectionMgr * mySelectionMgr
QList< SMESH::SMESH_GroupBase_var > myGroups1
QList< SMESH::SMESH_GroupBase_var > myGroups2
QList< SMESH::SMESH_GroupBase_var > myGroups3
bool myBusy
QString myHelpFileName
◆ SMESHGUI_DuplicateNodesDlg()
◆ ~SMESHGUI_DuplicateNodesDlg()
SMESHGUI_DuplicateNodesDlg::~SMESHGUI_DuplicateNodesDlg ( )
◆ enterEvent()
void SMESHGUI_DuplicateNodesDlg::enterEvent ( QEvent *  )
Activates the dialog when the mouse cursor enters. Reimplemented from QWidget class.
References SMESHGUI::EmitSignalDeactivateDialog(), SMESH::GetViewWindow(), SMESH::GROUP, mySelectionMgr, mySMESHGUI, and SMESHGUI::SetActiveDialogBox().
◆ Init()
◆ isValid()
bool SMESHGUI_DuplicateNodesDlg::isValid ( )
true if the data is valid
References myCheckBox2, myGroupConstructors, myGroups1, and myGroups3.
Referenced by onApply(), and updateButtons().
◆ keyPressEvent()
void SMESHGUI_DuplicateNodesDlg::keyPressEvent ( QKeyEvent *  e)
References onHelp().
◆ onApply
◆ onConstructorsClicked
void SMESHGUI_DuplicateNodesDlg::onConstructorsClicked ( int  constructorId)
privateslot
constructorIdid of the radio button in mode selector button group
References myCheckBox1, myCheckBox2, myCurrentLineEdit, myGenerateButton3, myGroupArguments, myGroups1, myGroups2, myGroups3, myLineEdit1, myLineEdit2, myLineEdit3, mySelectButton2, mySelectButton3, myTextLabel1, myTextLabel2, myTextLabel3, and onSelectionChanged().
Referenced by Init(), and SMESHGUI_DuplicateNodesDlg().
◆ onDeactivate
void SMESHGUI_DuplicateNodesDlg::onDeactivate ( )
privateslot
References mySelectionMgr, mySMESHGUI, SMESHGUI::ResetState(), and SMESHGUI::SetActiveDialogBox().
Referenced by SMESHGUI_DuplicateNodesDlg().
◆ onEditCurrentArgument
void SMESHGUI_DuplicateNodesDlg::onEditCurrentArgument ( )
privateslot
◆ onGenerate
void SMESHGUI_DuplicateNodesDlg::onGenerate ( )
privateslot
References SMESH::GetName(), SMESHGUI::isStudyLocked(), myBusy, myGroups1, myGroups2, myGroups3, myLineEdit3, mySMESHGUI, and updateButtons().
◆ onHelp
void SMESHGUI_DuplicateNodesDlg::onHelp ( )
privateslot
References myHelpFileName, and mySMESHGUI.
Referenced by keyPressEvent(), and SMESHGUI_DuplicateNodesDlg().
◆ onOk
void SMESHGUI_DuplicateNodesDlg::onOk ( )
privateslot
References onApply(), and reject().
◆ onSelectionChanged
void SMESHGUI_DuplicateNodesDlg::onSelectionChanged ( )
privateslot
◆ reject
void SMESHGUI_DuplicateNodesDlg::reject ( )
protectedvirtualslot
References mySelectionMgr, mySMESHGUI, and SMESHGUI::ResetState().
Referenced by onOk(), and SMESHGUI_DuplicateNodesDlg().
◆ updateButtons
void SMESHGUI_DuplicateNodesDlg::updateButtons ( )
privateslot
References isValid(), myButtonApply, myButtonOk, myGenerateButton3, myGroupConstructors, and myGroups1.
Referenced by onGenerate(), onSelectionChanged(), and SMESHGUI_DuplicateNodesDlg().
◆ myBusy
bool SMESHGUI_DuplicateNodesDlg::myBusy
◆ myButtonApply
QPushButton* SMESHGUI_DuplicateNodesDlg::myButtonApply
◆ myButtonClose
QPushButton* SMESHGUI_DuplicateNodesDlg::myButtonClose
◆ myButtonHelp
QPushButton* SMESHGUI_DuplicateNodesDlg::myButtonHelp
◆ myButtonOk
QPushButton* SMESHGUI_DuplicateNodesDlg::myButtonOk
◆ myCheckBox1
QCheckBox* SMESHGUI_DuplicateNodesDlg::myCheckBox1
◆ myCheckBox2
QCheckBox* SMESHGUI_DuplicateNodesDlg::myCheckBox2
◆ myCurrentLineEdit
QLineEdit* SMESHGUI_DuplicateNodesDlg::myCurrentLineEdit
◆ myGenerateButton3
QPushButton* SMESHGUI_DuplicateNodesDlg::myGenerateButton3
◆ myGroupArguments
QGroupBox* SMESHGUI_DuplicateNodesDlg::myGroupArguments
◆ myGroupConstructors
QButtonGroup* SMESHGUI_DuplicateNodesDlg::myGroupConstructors
◆ myGroups1
QList<SMESH::SMESH_GroupBase_var> SMESHGUI_DuplicateNodesDlg::myGroups1
◆ myGroups2
QList<SMESH::SMESH_GroupBase_var> SMESHGUI_DuplicateNodesDlg::myGroups2
◆ myGroups3
QList<SMESH::SMESH_GroupBase_var> SMESHGUI_DuplicateNodesDlg::myGroups3
◆ myHelpFileName
QString SMESHGUI_DuplicateNodesDlg::myHelpFileName
◆ myLineEdit1
QLineEdit* SMESHGUI_DuplicateNodesDlg::myLineEdit1
◆ myLineEdit2
QLineEdit* SMESHGUI_DuplicateNodesDlg::myLineEdit2
◆ myLineEdit3
QLineEdit* SMESHGUI_DuplicateNodesDlg::myLineEdit3
◆ mySelectButton1
QPushButton* SMESHGUI_DuplicateNodesDlg::mySelectButton1
◆ mySelectButton2
QPushButton* SMESHGUI_DuplicateNodesDlg::mySelectButton2
◆ mySelectButton3
QPushButton* SMESHGUI_DuplicateNodesDlg::mySelectButton3
◆ mySelectionMgr
LightApp_SelectionMgr* SMESHGUI_DuplicateNodesDlg::mySelectionMgr
◆ mySMESHGUI
SMESHGUI* SMESHGUI_DuplicateNodesDlg::mySMESHGUI
◆ myTextLabel1
QLabel* SMESHGUI_DuplicateNodesDlg::myTextLabel1
◆ myTextLabel2
QLabel* SMESHGUI_DuplicateNodesDlg::myTextLabel2
◆ myTextLabel3
QLabel* SMESHGUI_DuplicateNodesDlg::myTextLabel3
