SMESHGUI_FieldSelectorWdg Class Reference
Widget listing all fields available for export to MED file. More...
#include <SMESHGUI_FieldSelectorWdg.h>
Inheritance diagram for SMESHGUI_FieldSelectorWdg:
 SMESHGUI_FieldSelectorWdg (QWidget *=0)
 Constructor of SMESHGUI_FieldSelectorWdg. More...
bool GetAllFields (const QList< QPair< SMESH::SMESH_IDSource_var, QString > > &meshes, QList< QPair< GEOM::ListOfFields_var, QString > > &fields)
 Retrieves all fields defined on geometry of given meshes. More...
bool GetSelectedFields ()
 Filter off not selected fields from myFields. More...
Private Slots
void onItemCheck (QTreeWidgetItem *item, int column)
 SLOT called when a tree item is checked. More...
QList< QPair< GEOM::ListOfFields_var, QString > > * myFields
QTreeWidget * myTree
◆ SMESHGUI_FieldSelectorWdg()
SMESHGUI_FieldSelectorWdg::SMESHGUI_FieldSelectorWdg ( QWidget *  p = 0)
References myTree, and onItemCheck().
◆ GetAllFields()
bool SMESHGUI_FieldSelectorWdg::GetAllFields ( const QList< QPair< SMESH::SMESH_IDSource_var, QString > > &  meshes,
QList< QPair< GEOM::ListOfFields_var, QString > > &  fields
References SMESH::EDGE, SMESH::FACE, SMESH::GetGEOMGen(), myFields, myTree, SMESH::NODE, and SMESH::VOLUME.
◆ GetSelectedFields()
bool SMESHGUI_FieldSelectorWdg::GetSelectedFields ( )
References myFields, and myTree.
◆ onItemCheck
void SMESHGUI_FieldSelectorWdg::onItemCheck ( QTreeWidgetItem *  item,
int  column
privateslot
References myTree.
Referenced by SMESHGUI_FieldSelectorWdg().
◆ myFields
QList< QPair< GEOM::ListOfFields_var, QString > >* SMESHGUI_FieldSelectorWdg::myFields
Referenced by GetAllFields(), and GetSelectedFields().
◆ myTree
QTreeWidget* SMESHGUI_FieldSelectorWdg::myTree
