SMESHGUI_MinDistance Class Reference
Minimum distance measurement widget. More...
#include <SMESHGUI_Measurements.h>
Inheritance diagram for SMESHGUI_MinDistance:
 SMESHGUI_MinDistance (QWidget *=0)
 ~SMESHGUI_MinDistance ()
bool eventFilter (QObject *, QEvent *)
 Event filter. More...
void updateSelection ()
 Setup selection mode depending on the current widget state. More...
void deactivate ()
 Deactivate widget. More...
Private Types
enum  { NoTgt , FirstTgt , SecondTgt }
enum  { OriginTgt , NodeTgt , ElementTgt , ObjectTgt }
Private Slots
void selectionChanged ()
 Called when selection is changed. More...
void firstChanged ()
 Called when first target mode is changed by the user. More...
void secondChanged ()
 Called when second target mode is changed by the user. More...
void firstEdited ()
 Called when first target is edited by the user. More...
void secondEdited ()
 Called when second target is edited by the user. More...
void compute ()
 Compute the minimum distance between targets. More...
void clear ()
 Reset the widget to the initial state (nullify result fields) More...
void setTarget (int)
 Set current target for selection. More...
void erasePreview ()
 Erase preview actor. More...
void displayPreview ()
 Display preview actor. More...
void createPreview (double, double, double, double, double, double)
 Create preview actor. More...
QButtonGroup * myFirst
QButtonGroup * mySecond
QLineEdit * myFirstTgt
QLineEdit * mySecondTgt
QLineEdit * myDX
QLineEdit * myDY
QLineEdit * myDZ
QLineEdit * myDistance
int myCurrentTgt
SMESH::SMESH_IDSource_var myFirstSrc
SMESH::SMESH_IDSource_var mySecondSrc
SMESH_Actor * myFirstActor
SMESH_Actor * mySecondActor
SMESHGUI_IdValidator * myValidator
SUIT_SelectionFilter * myFilter
SALOME_Actor * myPreview
Widget to calculate minimum distance between two objects.
◆ anonymous enum
anonymous enum
NoTgt
FirstTgt
SecondTgt
◆ anonymous enum
anonymous enum
OriginTgt
NodeTgt
ElementTgt
ObjectTgt
◆ SMESHGUI_MinDistance()
◆ ~SMESHGUI_MinDistance()
SMESHGUI_MinDistance::~SMESHGUI_MinDistance ( )
References erasePreview(), and myPreview.
◆ clear
void SMESHGUI_MinDistance::clear ( )
privateslot
References erasePreview(), myDistance, myDX, myDY, and myDZ.
Referenced by compute(), firstChanged(), firstEdited(), secondChanged(), secondEdited(), selectionChanged(), and SMESHGUI_MinDistance().
◆ compute
◆ createPreview()
void SMESHGUI_MinDistance::createPreview ( double  x1,
double  y1,
double  z1,
double  x2,
double  y2,
double  z2
x1X coordinate of first point
y1X coordinate of first point
z1Y coordinate of first point
x2Y coordinate of second point
y2Z coordinate of second point
z2Z coordinate of second point
References myPreview.
Referenced by compute().
◆ deactivate()
void SMESHGUI_MinDistance::deactivate ( )
Deactivate widget.
References SMESHGUI::selectionMgr().
Referenced by SMESHGUI_MeasureDlg::deactivate().
◆ displayPreview()
void SMESHGUI_MinDistance::displayPreview ( )
References SMESH::GetViewWindow(), and myPreview.
◆ erasePreview()
void SMESHGUI_MinDistance::erasePreview ( )
Referenced by clear(), compute(), and ~SMESHGUI_MinDistance().
◆ eventFilter()
bool SMESHGUI_MinDistance::eventFilter ( QObject *  o,
QEvent *  e
Event filter.
oobject
oevent
true if event is filtered or false otherwise
References FirstTgt, myFirstTgt, mySecondTgt, SecondTgt, and setTarget().
◆ firstChanged
void SMESHGUI_MinDistance::firstChanged ( )
privateslot
References clear(), FirstTgt, myFirst, myFirstSrc, myFirstTgt, myValidator, ObjectTgt, setTarget(), and updateSelection().
Referenced by SMESHGUI_MinDistance().
◆ firstEdited
void SMESHGUI_MinDistance::firstEdited ( )
privateslot
References clear(), ElementTgt, FirstTgt, SMESH::GetViewWindow(), Handle(), myFirst, myFirstActor, myFirstTgt, NodeTgt, and setTarget().
Referenced by SMESHGUI_MinDistance(), and updateSelection().
◆ secondChanged
void SMESHGUI_MinDistance::secondChanged ( )
privateslot
References clear(), mySecond, mySecondSrc, mySecondTgt, myValidator, NoTgt, ObjectTgt, OriginTgt, SecondTgt, setTarget(), and updateSelection().
◆ secondEdited
void SMESHGUI_MinDistance::secondEdited ( )
privateslot
References clear(), ElementTgt, SMESH::GetViewWindow(), Handle(), mySecond, mySecondActor, mySecondTgt, NodeTgt, SecondTgt, selectionChanged(), and setTarget().
◆ selectionChanged
◆ setTarget()
void SMESHGUI_MinDistance::setTarget ( int  target)
targetnew target ID
References myCurrentTgt, and updateSelection().
Referenced by eventFilter(), firstChanged(), firstEdited(), secondChanged(), and secondEdited().
◆ updateSelection()
◆ myCurrentTgt
int SMESHGUI_MinDistance::myCurrentTgt
◆ myDistance
QLineEdit* SMESHGUI_MinDistance::myDistance
◆ myDX
QLineEdit* SMESHGUI_MinDistance::myDX
◆ myDY
QLineEdit* SMESHGUI_MinDistance::myDY
◆ myDZ
QLineEdit* SMESHGUI_MinDistance::myDZ
◆ myFilter
SUIT_SelectionFilter* SMESHGUI_MinDistance::myFilter
◆ myFirst
QButtonGroup* SMESHGUI_MinDistance::myFirst
◆ myFirstActor
SMESH_Actor* SMESHGUI_MinDistance::myFirstActor
Referenced by firstEdited(), and selectionChanged().
◆ myFirstSrc
SMESH::SMESH_IDSource_var SMESHGUI_MinDistance::myFirstSrc
◆ myFirstTgt
QLineEdit* SMESHGUI_MinDistance::myFirstTgt
◆ myPreview
SALOME_Actor* SMESHGUI_MinDistance::myPreview
◆ mySecond
QButtonGroup* SMESHGUI_MinDistance::mySecond
◆ mySecondActor
SMESH_Actor* SMESHGUI_MinDistance::mySecondActor
Referenced by secondEdited(), and selectionChanged().
◆ mySecondSrc
SMESH::SMESH_IDSource_var SMESHGUI_MinDistance::mySecondSrc
◆ mySecondTgt
QLineEdit* SMESHGUI_MinDistance::mySecondTgt
◆ myValidator
SMESHGUI_IdValidator* SMESHGUI_MinDistance::myValidator
