SMESHUtils::BoostTxtArchive Class Reference
Load an object from a string created by boost::archive::text_oarchive. More...
#include <SMESH_BoostTxtArchive.hxx>
 BoostTxtArchive (const std::string &s)
 BoostTxtArchive (std::istream &stream)
 ~BoostTxtArchive ()
template<class T >
BoostTxtArchive & operator>> (T &t)
void makeReader ()
bool fixString ()
 Change boost::archive library version in myString to be equal to the current library version. More...
template<class Archive >
void serialize (Archive &, const unsigned int)
boost::archive::text_iarchive * myArchiveReader
std::string myString
bool myStringFixed
std::istream * myStream
bool myOwnStream
Friends
class boost::serialization::access
Try to workaround the issue that loading fails if the archive string is created by a newer version of boost::archive library.
Usage: ObjType obj; SMESHUtils::BoostTxtArchive( arcString ) >> obj;
◆ BoostTxtArchive() [1/2]
BoostTxtArchive::BoostTxtArchive ( const std::string &  s)
References makeReader(), myStream, and myString.
◆ BoostTxtArchive() [2/2]
BoostTxtArchive::BoostTxtArchive ( std::istream &  stream)
References makeReader(), and myString.
◆ ~BoostTxtArchive()
BoostTxtArchive::~BoostTxtArchive ( )
◆ fixString()
bool BoostTxtArchive::fixString ( )
bool - return true if the version is changed
References myOwnStream, myStream, myString, and myStringFixed.
Referenced by makeReader().
◆ makeReader()
void BoostTxtArchive::makeReader ( )
References fixString(), myArchiveReader, and myStream.
Referenced by BoostTxtArchive().
◆ operator>>()
template<class T >
BoostTxtArchive & SMESHUtils::BoostTxtArchive::operator>> ( T &  t)
◆ serialize()
void SMESHUtils::BoostTxtArchive::serialize ( Archive &  ,
const unsigned int
◆ boost::serialization::access
friend class boost::serialization::access
friend
◆ myArchiveReader
boost::archive::text_iarchive* SMESHUtils::BoostTxtArchive::myArchiveReader
Referenced by makeReader(), and ~BoostTxtArchive().
◆ myOwnStream
bool SMESHUtils::BoostTxtArchive::myOwnStream
Referenced by fixString(), and ~BoostTxtArchive().
◆ myStream
std::istream* SMESHUtils::BoostTxtArchive::myStream
◆ myString
std::string SMESHUtils::BoostTxtArchive::myString
Referenced by BoostTxtArchive(), and fixString().
◆ myStringFixed
bool SMESHUtils::BoostTxtArchive::myStringFixed
Referenced by fixString().
