SMESH_NumberFilter Class Reference
Class : SMESH_NumberFilter Description : Filter for geom or smesh objects. More...
#include <SMESH_NumberFilter.hxx>
Inheritance diagram for SMESH_NumberFilter:
 SMESH_NumberFilter (const char *theKind, const TopAbs_ShapeEnum theSubShapeType, const int theNumber, const TopAbs_ShapeEnum theShapeType=TopAbs_SHAPE, GEOM::GEOM_Object_ptr theMainObj=GEOM::GEOM_Object::_nil(), const bool theIsClosedOnly=false)
 Class : SMESH_NumberFilter Description : Filter for geom objects. More...
 SMESH_NumberFilter (const char *theKind, const TopAbs_ShapeEnum theSubShapeType, const int theNumber, const TColStd_MapOfInteger &theShapeTypes, GEOM::GEOM_Object_ptr theMainObj=GEOM::GEOM_Object::_nil(), const bool theIsClosedOnly=false)
virtual ~SMESH_NumberFilter ()
virtual bool isOk (const SUIT_DataOwner *) const
void SetSubShapeType (const TopAbs_ShapeEnum)
void SetNumber (const int)
void SetClosedOnly (const bool)
void SetShapeType (const TopAbs_ShapeEnum)
void SetShapeTypes (const TColStd_MapOfInteger &)
void SetMainShape (GEOM::GEOM_Object_ptr)
GEOM::GEOM_Object_ptr getGeom (const SUIT_DataOwner *, const bool extractReference=true) const
std::string myKind
TopAbs_ShapeEnum mySubShapeType
int myNumber
bool myIsClosedOnly
TColStd_MapOfInteger myShapeTypes
GEOM::GEOM_Object_var myMainObj
Filter geom objects by number of subshapes of the given type Parameters of constructor:
  • theSubShapeType - Type of subshape
  • theNumber - Number of subshapes. Object is selected if it contains theNumber of theSubShapeType sub-shapes, or at least one theSubShapeType, provided that theNumber==0
  • theShapeType - This map specifies types of object to be selected
  • theMainObject - Sub-shapes of this object is selected only
  • theIsClosedOnly - Closed shapes is selected if this parameter is true
◆ SMESH_NumberFilter() [1/2]
SMESH_NumberFilter::SMESH_NumberFilter ( const char *  theKind,
const TopAbs_ShapeEnum  theShapeType = TopAbs_SHAPE,
GEOM::GEOM_Object_ptr  theMainObj = GEOM::GEOM_Object::_nil(),
const bool  theIsClosedOnly = false
References myIsClosedOnly, myKind, myMainObj, myNumber, myShapeTypes, and mySubShapeType.
◆ SMESH_NumberFilter() [2/2]
const TColStd_MapOfInteger &  theShapeTypes,
◆ ~SMESH_NumberFilter()
SMESH_NumberFilter::~SMESH_NumberFilter ( )
◆ getGeom()
GEOM::GEOM_Object_ptr SMESH_NumberFilter::getGeom ( const SUIT_DataOwner *  theDataOwner,
const bool  extractReference = true
References SMESH::_PTR(), and myKind.
Referenced by isOk().
◆ isOk()
bool SMESH_NumberFilter::isOk ( const SUIT_DataOwner *  theDataOwner) const
◆ SetClosedOnly()
void SMESH_NumberFilter::SetClosedOnly ( const bool  theIsClosedOnly)
References myIsClosedOnly.
◆ SetMainShape()
void SMESH_NumberFilter::SetMainShape ( GEOM::GEOM_Object_ptr  theMainObj)
References myMainObj.
◆ SetNumber()
void SMESH_NumberFilter::SetNumber ( const int  theNumber)
References myNumber.
◆ SetShapeType()
void SMESH_NumberFilter::SetShapeType ( const TopAbs_ShapeEnum  theShapeType)
References myShapeTypes.
◆ SetShapeTypes()
void SMESH_NumberFilter::SetShapeTypes ( const TColStd_MapOfInteger &  )
◆ SetSubShapeType()
void SMESH_NumberFilter::SetSubShapeType ( const TopAbs_ShapeEnum  theSubShapeType)
References mySubShapeType.
◆ myIsClosedOnly
bool SMESH_NumberFilter::myIsClosedOnly
◆ myKind
std::string SMESH_NumberFilter::myKind
Referenced by getGeom(), and SMESH_NumberFilter().
◆ myMainObj
GEOM::GEOM_Object_var SMESH_NumberFilter::myMainObj
◆ myNumber
int SMESH_NumberFilter::myNumber
Referenced by isOk(), SetNumber(), and SMESH_NumberFilter().
◆ myShapeTypes
TColStd_MapOfInteger SMESH_NumberFilter::myShapeTypes
◆ mySubShapeType
TopAbs_ShapeEnum SMESH_NumberFilter::mySubShapeType
