SMESH_OrientedIndexer Class Reference
Oriented converter of a pair of integers to a sole index. More...
#include <SMESH_Indexer.hxx>
Inheritance diagram for SMESH_OrientedIndexer:
enum  OriFlags {
  NO_TRSF = 0 , REV_X = 1 , REV_Y = 2 , SWAP_XY = 4 ,
  MAX_ORI = REV_X|REV_Y|SWAP_XY
 < transformation types More...
 SMESH_OrientedIndexer (const SMESH_Indexer &indexer, const int oriFlags=NO_TRSF)
 Return index by XY. More...
size_t operator() (size_t x, size_t y) const
 Return index for a corner. More...
size_t corner (bool xMax, bool yMax) const
size_t xSize () const
size_t ySize () const
void set (size_t xSize, size_t ySize)
 set size More...
size_t size () const
Data Fields
size_t _xSize
size_t _ySize
Private Types
typedef SMESH_Indexer TFather
typedef void(* TFun) (size_t &x, size_t &y)
static void lazy (size_t &, size_t &)
static void reverse (size_t &x, size_t &size)
static void swap (size_t &x, size_t &y)
TFun _xRevFun
TFun _yRevFun
TFun _swapFun
size_t _xSizeOriented
size_t _ySizeOriented
Allows virtual transformation of an 1D array viewed as 2D one. Possible transformations are inverse in one or two directions and exchange of the directions. Any combination of these transformations is allowed.
The following code picks up a transformation such that two known array items appear in desired positions:
for ( int ori = 0; ori < SMESH_OrientedIndexer::MAX_ORI+1; ++ori )
SMESH_OrientedIndexer oriIndex( index, ori );
if ( item1 == array[ oriIndex( i1, j1 ) ] &&
item2 == array[ oriIndex( i2, j2 ) ])
// needed transformation found
Definition: SMESH_Indexer.hxx:99
@ MAX_ORI
Definition: SMESH_Indexer.hxx:104
◆ TFather
◆ TFun
typedef void(* SMESH_OrientedIndexer::TFun) (size_t &x, size_t &y)
◆ OriFlags
NO_TRSF
REV_X
REV_Y
SWAP_XY
MAX_ORI
◆ SMESH_OrientedIndexer()
SMESH_OrientedIndexer::SMESH_OrientedIndexer ( const SMESH_Indexer &  indexer,
const int  oriFlags = NO_TRSF
Return index by XY.
References _xSizeOriented, and _ySizeOriented.
◆ corner()
size_t SMESH_OrientedIndexer::corner ( bool  xMax,
bool  yMax
◆ lazy()
static void SMESH_OrientedIndexer::lazy ( size_t &  ,
size_t &
staticprivate
◆ operator()()
size_t SMESH_OrientedIndexer::operator() ( size_t  x,
size_t  y
References SMESH_Indexer::_xSize, SMESH_Indexer::_ySize, and SMESH_Indexer::operator()().
◆ reverse()
static void SMESH_OrientedIndexer::reverse ( size_t &  x,
size_t &  size
staticprivate
References SMESH_Indexer::size().
◆ set()
void SMESH_Indexer::set ( size_t  xSize,
size_t  ySize
set size
References SMESH_Indexer::_xSize, and SMESH_Indexer::_ySize.
◆ size()
size_t SMESH_Indexer::size ( ) const
size of 1D array
Referenced by corner(), and reverse().
◆ swap()
static void SMESH_OrientedIndexer::swap ( size_t &  x,
size_t &  y
staticprivate
◆ xSize()
size_t SMESH_OrientedIndexer::xSize ( ) const
References _xSizeOriented.
◆ ySize()
size_t SMESH_OrientedIndexer::ySize ( ) const
References _ySizeOriented.
◆ _swapFun
TFun SMESH_OrientedIndexer::_swapFun
◆ _xRevFun
TFun SMESH_OrientedIndexer::_xRevFun
◆ _xSize
◆ _xSizeOriented
size_t SMESH_OrientedIndexer::_xSizeOriented
Referenced by SMESH_OrientedIndexer(), and xSize().
◆ _yRevFun
TFun SMESH_OrientedIndexer::_yRevFun
◆ _ySize
size_t SMESH_Indexer::_ySize
◆ _ySizeOriented
size_t SMESH_OrientedIndexer::_ySizeOriented
Referenced by SMESH_OrientedIndexer(), and ySize().
