SMESH_Swig Class Reference
SMESH GUI Python interface. More...
#include <libSMESH_Swig.h>
 SMESH_Swig ()
 ~SMESH_Swig ()
void Init ()
 Initialize SMESH GUI Python interface. More...
const char * publish (const char *, const char *=0)
 Publish object. More...
void rename (const char *, const char *)
 Set new study name of given object. More...
const char * AddNewMesh (const char *, const char *=0)
 Publish mesh in the active study. More...
const char * AddNewHypothesis (const char *, const char *=0)
 Publish hypothesis in the active study. More...
const char * AddNewAlgorithm (const char *, const char *=0)
 Publish algorithm in the active study. More...
const char * AddNewAlgorithms (const char *, const char *=0)
void SetShape (const char *, const char *)
 Add reference on a shape for mesh in a study. More...
void SetHypothesis (const char *, const char *)
 Assign hypothesis to mesh or sub-mesh. More...
void SetAlgorithms (const char *, const char *)
 Assign algorithm to mesh or sub-mesh. More...
void UnSetHypothesis (const char *)
 Anassign hypothesis or algorithm from mesh or sub-mesh. More...
const char * AddSubMesh (const char *, const char *, int, const char *=0)
 Publish sub-mesh in the active study. More...
const char * AddSubMeshOnShape (const char *, const char *, const char *, int, const char *=0)
void SetName (const char *, const char *)
void SetMeshIcon (const char *, const bool, const bool)
 Set mesh icon according to compute status. More...
void display (const char *, int=0, bool=true)
 Display mesh object. More...
void erase (const char *, int=0, bool=true)
 Erase mesh object. More...
void update (const char *)
 Update mesh object. More...
Properties properties (const char *, int=0)
 Get mesh object's visual properties. More...
void setProperties (const char *, const Properties &, int=0)
 Set mesh object's visual properties. More...
bool nodesNumbering (const char *, int=0)
 Check if nodes numbering is switched on. More...
void setNodesNumbering (const char *, bool, int=0)
 Switch nodes numbering on/off. More...
bool elementsNumbering (const char *, int=0)
 Check if elements numbering is switched on. More...
void setElementsNumbering (const char *, bool, int=0)
 Switch elements numbering on/off. More...
DisplayMode displayMode (const char *, int=0)
 Get mesh object's display mode. More...
void setDisplayMode (const char *, DisplayMode, int=0)
 Set mesh object's display mode. More...
bool shrinkMode (const char *, int=0)
 Check if shrink mode is switched on. More...
void setShrinkMode (const char *, bool, int=0)
 Switch shrink mode on/off. More...
double opacity (const char *, int=0)
 Get mesh object's opacity. More...
void setOpacity (const char *, double, int=0)
 Set mesh object's opacity. More...
bool isOrientationShown (const char *, int=0)
 Check if faces orientation vectors are shown. More...
void setOrientationShown (const char *, bool, int=0)
 Show/hide faces orientation vectors. More...
int entitiesShown (const char *, int=0)
 Get mesh object's visible entities. More...
void setEntitiesShown (const char *, int, int=0)
 Set mesh object's visible entities. More...
bool isEntityShown (const char *, EntityMode, int=0)
 Check if given mesh object's entity is shown. More...
void setEntityShown (const char *, EntityMode, bool, int=0)
 Show/hide entity for given mesh object. More...
void CreateAndDisplayActor (const char *)
 Display mesh in the currently active view window. More...
void EraseActor (const char *, const bool=false)
 Erase mesh in the view window(s). More...
void UpdateActor (const char *Mesh_Entry)
actorAspect GetActorAspect (const char *, int=0)
 Get mesh object's properties. More...
void SetActorAspect (const actorAspect &, const char *, int=0)
 Set mesh object's properties. More...
SelectionMode getSelectionMode (int=0)
 Get selection mode of view window. More...
void setSelectionMode (SelectionMode, int=0)
 Set selection mode to view window. More...
std::vector< int > getSelected (const char *)
 Get selected elements of the mesh, sub-mesh or group. More...
std::vector< std::pair< int, int > > getSelectedEdgeOfCell (const char *)
 Get selected pseudo-edges (specified by two nodes) of the mesh, sub-mesh or group. More...
void select (const char *, std::vector< int >, bool=false)
 Select elements of the mesh, sub-mesh or group. More...
void select (const char *, int, bool=false)
 Select element of the mesh, sub-mesh or group. More...
void select (const char *, std::vector< std::pair< int, int > >, bool=false)
 Select pseudo-edges (specified by two nodes) of the mesh, sub-mesh or group. More...
void init ()
 Initialize interface. More...
◆ SMESH_Swig()
SMESH_Swig::SMESH_Swig ( )
References init().
◆ ~SMESH_Swig()
SMESH_Swig::~SMESH_Swig ( )
◆ AddNewAlgorithm()
const char * SMESH_Swig::AddNewAlgorithm ( const char *  ior,
const char *  name = 0
Deprecated:
Publishing is done automatically.
iorIOR of the algorithm.
nameName of the algorithm (optional).
UID of the data object.
References publish().
◆ AddNewAlgorithms()
const char * SMESH_Swig::AddNewAlgorithms ( const char *  ior,
Deprecated:
Synonym of AddNewAlgorithm().
◆ AddNewHypothesis()
const char * SMESH_Swig::AddNewHypothesis ( const char *  ior,
Deprecated:
iorIOR of the hypothesis.
nameName of the hypothesis (optional).
◆ AddNewMesh()
const char * SMESH_Swig::AddNewMesh ( const char *  ior,
Deprecated:
iorIOR of the mesh.
nameName of the mesh (optional).
◆ AddSubMesh()
const char * SMESH_Swig::AddSubMesh ( const char *  ,
const char *  ior,
int  ,
Deprecated:
meshUidParent mesh's study UID (not used).
iorIOR of the sub-mesh.
shapeTypeGEOM shape's type (not used).
nameName of the sub-mesh (optional).
◆ AddSubMeshOnShape()
const char * SMESH_Swig::AddSubMeshOnShape ( const char *  ,
const char *  ,
const char *  ior,
int  ,
Deprecated:
shapeUidGEOM shape's study UID (not used).
◆ CreateAndDisplayActor()
void SMESH_Swig::CreateAndDisplayActor ( const char *  meshUid)
Deprecated:
Use display() method.
meshUidMesh's study UID.
References display().
◆ display()
void SMESH_Swig::display ( const char *  uid,
int  viewUid = 0,
bool  updateViewer = true
uidObject's study UID or IOR.
viewUidView window UID (0 means currently active view window; if there's no view, it is created). Default: 0.
updateViewer"Update view" flag. Default: true.
References SMESH::_PTR(), and init().
Referenced by CreateAndDisplayActor().
◆ displayMode()
DisplayMode SMESH_Swig::displayMode ( const char *  uid,
int  viewUid = 0
uidMesh object's study UID or IOR.
viewUidView window UID (0 means currently active view window); Default: 0.
Display mode (UndefinedMode if actor isn't found).
References SMESH::_PTR(), init(), and UndefinedMode.
◆ elementsNumbering()
bool SMESH_Swig::elementsNumbering ( const char *  uid,
int  viewUid = 0
true if elements numbering is switched on; false otherwise.
◆ entitiesShown()
int SMESH_Swig::entitiesShown ( const char *  uid,
int  viewUid = 0
Enumerator describing entities being visible.
References SMESH::_PTR(), EntityNone, and init().
◆ erase()
void SMESH_Swig::erase ( const char *  uid,
int  viewUid = 0,
Erase mesh object.
viewUidView window UID (0 means currently active view window); -1 means "all view windows". Default: 0.
Referenced by EraseActor().
◆ EraseActor()
void SMESH_Swig::EraseActor ( const char *  meshUid,
const bool  allViewers = false
Deprecated:
Use erase() method.
allViewersIf true, mesh is removed from all views. Default: false.
References erase().
◆ GetActorAspect()
actorAspect SMESH_Swig::GetActorAspect ( const char *  meshUid,
int  viewUid = 0
Deprecated:
Use properties() method.
viewUidView window UID (0 means currently active view window). Default: 0.
References properties().
◆ getSelected()
std::vector< int > SMESH_Swig::getSelected ( const char *  uid)
List of selected mesh elements.
◆ getSelectedEdgeOfCell()
std::vector< std::pair< int, int > > SMESH_Swig::getSelectedEdgeOfCell ( const char *  uid)
idsList of pairs containing two nodes IDs.
appendIf true, pseudo-edges are added to current selection; otherwise, previous selection is cleared.
◆ getSelectionMode()
SelectionMode SMESH_Swig::getSelectionMode ( int  viewUid = 0)
Current selection mode.
References init().
◆ Init()
void SMESH_Swig::Init ( )
Deprecated:
Interface is initialized automatically.
◆ init()
◆ isEntityShown()
bool SMESH_Swig::isEntityShown ( const char *  uid,
EntityMode  entity,
int  viewUid = 0
entityMesh entity.
true if entity is shown; false otherwise.
◆ isOrientationShown()
bool SMESH_Swig::isOrientationShown ( const char *  uid,
int  viewUid = 0
true if faces orientation vectors are shown; false otherwise.
◆ nodesNumbering()
bool SMESH_Swig::nodesNumbering ( const char *  uid,
int  viewUid = 0
true if nodes numbering is switched on; false otherwise.
◆ opacity()
double SMESH_Swig::opacity ( const char *  uid,
int  viewUid = 0
Opacity value.
References SMESH::_PTR(), init(), and opacity().
Referenced by opacity(), and setOpacity().
◆ properties()
Properties SMESH_Swig::properties ( const char *  uid,
int  viewUid = 0
Properties data structure.
Referenced by GetActorAspect().
◆ publish()
const char * SMESH_Swig::publish ( const char *  ior,
Publish object.
iorIOR of the mesh object to publish.
nameStudy name of the object; if not given, name is assigned automatically.
References SMESHGUI::GetSMESHGen(), and init().
Referenced by AddNewAlgorithm(), AddNewAlgorithms(), AddNewHypothesis(), AddNewMesh(), AddSubMesh(), and AddSubMeshOnShape().
◆ rename()
void SMESH_Swig::rename ( const char *  uid,
const char *  name
nameNew name of the object.
Referenced by SetName().
◆ select() [1/3]
void SMESH_Swig::select ( const char *  uid,
int  id,
bool  append = false
idMesh element.
appendIf true, element is added to current selection; otherwise, previous selection is cleared.
◆ select() [2/3]
std::vector< int >  ids,
bool  append = false
idsList of mesh elements.
appendIf true, elements are added to current selection; otherwise, previous selection is cleared.
◆ select() [3/3]
std::vector< std::pair< int, int > >  ids,
bool  append = false
◆ SetActorAspect()
void SMESH_Swig::SetActorAspect ( const actorAspect &  aspect,
int  viewUid = 0
Deprecated:
Use setProperties() method.
References setProperties().
◆ SetAlgorithms()
void SMESH_Swig::SetAlgorithms ( const char *  ,
const char *
Deprecated:
meshUidMesh's or sub-mesh's study UID (not used).
algoUIDAlgorithm's study UID (not used).
◆ setDisplayMode()
void SMESH_Swig::setDisplayMode ( const char *  uid,
DisplayMode  mode,
int  viewUid = 0
modeDisplay mode.
◆ setElementsNumbering()
void SMESH_Swig::setElementsNumbering ( const char *  uid,
bool  numbering,
int  viewUid = 0
numberingtrue to switch elements numbering on; false otherwise.
◆ setEntitiesShown()
void SMESH_Swig::setEntitiesShown ( const char *  uid,
int  entities,
int  viewUid = 0
entitiesEnumerator describing entities to be shown.
◆ setEntityShown()
void SMESH_Swig::setEntityShown ( const char *  uid,
EntityMode  entity,
bool  show,
int  viewUid = 0
entityMesh entity.
showVisibility status.
◆ SetHypothesis()
void SMESH_Swig::SetHypothesis ( const char *  ,
const char *
Deprecated:
hypoUIDHypothesis's study UID (not used).
◆ SetMeshIcon()
void SMESH_Swig::SetMeshIcon ( const char *  ,
const bool  ,
const bool
Deprecated:
meshUidMesh's study UID (not used).
isComputedFlag pointing that mesh is computed or no (not used).
isEmptyFlag pointing that mesh is empty or no (not used).
◆ SetName()
void SMESH_Swig::SetName ( const char *  uid,
const char *  name
Deprecated:
Use rename() method.
References rename().
◆ setNodesNumbering()
void SMESH_Swig::setNodesNumbering ( const char *  uid,
bool  numbering,
int  viewUid = 0
numberingtrue to switch nodes numbering on; false otherwise.
◆ setOpacity()
void SMESH_Swig::setOpacity ( const char *  uid,
double  opacity,
int  viewUid = 0
opacityOpacity value.
◆ setOrientationShown()
void SMESH_Swig::setOrientationShown ( const char *  uid,
bool  shown,
int  viewUid = 0
showntrue to show faces orientation vectors; false otherwise.
◆ setProperties()
void SMESH_Swig::setProperties ( const char *  uid,
const Properties &  props,
int  viewUid = 0
propsProperties data structure.
Referenced by SetActorAspect().
◆ setSelectionMode()
void SMESH_Swig::setSelectionMode ( SelectionMode  mode,
int  viewUid = 0
modeSelection mode.
References init().
◆ SetShape()
void SMESH_Swig::SetShape ( const char *  ,
const char *
Deprecated:
◆ setShrinkMode()
void SMESH_Swig::setShrinkMode ( const char *  uid,
bool  shrink,
int  viewUid = 0
shrinktrue to switch shrink mode on; false otherwise.
◆ shrinkMode()
bool SMESH_Swig::shrinkMode ( const char *  uid,
int  viewUid = 0
true if shrink mode is switched on; false otherwise.
References SMESH::_PTR(), init(), and shrinkMode().
Referenced by shrinkMode().
◆ UnSetHypothesis()
void SMESH_Swig::UnSetHypothesis ( const char *  )
Deprecated:
Unpublishing is done automatically.
uidHypothesis's or algorithm's study UID (not used).
◆ update()
void SMESH_Swig::update ( const char *  uid)
Update mesh object.
References SMESH::_PTR(), Handle(), init(), and SMESH::Update().
Referenced by UpdateActor().
◆ UpdateActor()
void SMESH_Swig::UpdateActor ( const char *  meshUid)
Update mesh object.
Deprecated:
Use update() method.
References update().
