import"MESHJOB.idl";
| boolean | configure (in string configId, in MESHJOB::ConfigParameter configParameter) raises (SALOME::SALOME_Exception) |
| Add a resource configuration, identified by the string configId and characterized by the parameters in configParameter. More... | |
| long | initialize (in MESHJOB::MeshJobFileList meshJobFileList, in MESHJOB::MeshJobParameterList MeshJobParameterList, in string configId) raises (SALOME::SALOME_Exception) |
| Initialize a smesh computation job and return the job identifier. More... | |
| boolean | start (in long jobId) raises (SALOME::SALOME_Exception) |
| Submit the job execution and return true if submission is OK. More... | |
| string | getState (in long jobId) raises (SALOME::SALOME_Exception) |
| Request the launch manager for the state of the specified job. More... | |
| MeshJobResults | finalize (in long jobid) raises (SALOME::SALOME_Exception) |
| Request the launch manager for downloading the results. More... | |
| boolean | clean (in long jobId) raises (SALOME::SALOME_Exception) |
| Clean all data associated to this job and remove the job from the launch manager. More... | |
| MeshJobPaths | getPaths (in long jobId) raises (SALOME::SALOME_Exception) |
| Returns the set of temporary folders used by the job instance. More... | |
| string | getLastErrorMessage () |
| Returns the last error message (for user display) More... | |
| boolean MESHJOB::MeshJobManager::clean | ( | in long | jobId | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
| boolean MESHJOB::MeshJobManager::configure | ( | in string | configId, |
| in MESHJOB::ConfigParameter | configParameter | ||
| MeshJobResults MESHJOB::MeshJobManager::finalize | ( | in long | jobid | ) | |
| string MESHJOB::MeshJobManager::getLastErrorMessage | ( | ) |
| MeshJobPaths MESHJOB::MeshJobManager::getPaths | ( | in long | jobId | ) | |
| string MESHJOB::MeshJobManager::getState | ( | in long | jobId | ) | |
| long MESHJOB::MeshJobManager::initialize | ( | in MESHJOB::MeshJobFileList | meshJobFileList, |
| in MESHJOB::MeshJobParameterList | MeshJobParameterList, | ||
| in string | configId | ||
| boolean MESHJOB::MeshJobManager::start | ( | in long | jobId | ) | |
