MED::TGaussDef Struct Reference
Description of family of integration points. More...
#include <MED_GaussDef.hxx>
 TGaussDef (const int geomType, const int nbPoints, const int variant=1)
 Creates definition of gauss points family. More...
int dim () const
int nbPoints () const
Data Fields
int myType
 element geometry (EGeometrieElement or med_geometrie_element) More...
TDoubleVector myRefCoords
 description of reference points More...
TDoubleVector myCoords
 coordinates of Gauss points More...
TDoubleVector myWeights
 weights, len(weights)==<nb of gauss points> More...
void add (const double x, const double weight)
void add (const double x, const double y, const double weight)
void add (const double x, const double y, const double z, const double weight)
void setRefCoords (const TShapeFun &aShapeFun)
◆ TGaussDef()
MED::TGaussDef::TGaussDef ( const int  geomType,
const int  nbPoints,
const int  variant = 1
Fill definition of gauss points family.
geomType- element geometry (EGeometrieElement or med_geometrie_element)
nbPoints- nb gauss point
variant- [1-3] to choose the variant of definition
Throws in case of invalid parameters variant == 1 refers to "Fonctions de forme et points d'integration des elements finis" v7.4 by J. PELLET, X. DESROCHES, 15/09/05 variant == 2 refers to the same doc v6.4 by J.P. LEFEBVRE, X. DESROCHES, 03/07/03 variant == 3 refers to the same doc v6.4, second variant for 2D elements
References add(), MESHCUT::d, dim(), MED::eHEXA20, MED::eHEXA8, MED::ePENTA15, MED::ePENTA6, MED::ePYRA13, MED::ePYRA5, MED::eQUAD4, MED::eQUAD8, MED::eSEG2, MED::eSEG3, MED::eTETRA10, MED::eTETRA4, MED::eTRIA3, MED::eTRIA6, EXCEPTION, myCoords, myType, myWeights, and setRefCoords().
◆ add() [1/3]
void MED::TGaussDef::add ( const double  x,
const double  weight
References dim(), EXCEPTION, myCoords, and myWeights.
Referenced by TGaussDef().
◆ add() [2/3]
const double  y,
const double  weight
◆ add() [3/3]
const double  y,
const double  z,
const double  weight
◆ dim()
int MED::TGaussDef::dim ( ) const
References myType.
Referenced by add(), and TGaussDef().
◆ nbPoints()
int MED::TGaussDef::nbPoints ( ) const
References myWeights.
◆ setRefCoords()
void MED::TGaussDef::setRefCoords ( const TShapeFun &  aShapeFun)
References MED::TShapeFun::myRefCoord, and myRefCoords.
◆ myCoords
TDoubleVector MED::TGaussDef::myCoords
◆ myRefCoords
TDoubleVector MED::TGaussDef::myRefCoords
Referenced by setRefCoords().
◆ myType
int MED::TGaussDef::myType
Referenced by dim(), and TGaussDef().
◆ myWeights
TDoubleVector MED::TGaussDef::myWeights
Referenced by add(), nbPoints(), and TGaussDef().
