MED::TTNodeInfo Struct Referenceabstract
#include <MED_TStructures.hxx>
Inheritance diagram for MED::TTNodeInfo:
typedef TTElemInfo TElemInfoBase
 TTNodeInfo (const PMeshInfo &theMeshInfo, const PNodeInfo &theInfo)
 TTNodeInfo (const PMeshInfo &theMeshInfo, TInt theNbElem, EModeSwitch theMode, ERepere theSystem, EBooleen theIsElemNum, EBooleen theIsElemNames)
 TTNodeInfo (const PMeshInfo &theMeshInfo, const TFloatVector &theNodeCoords, EModeSwitch theMode, ERepere theSystem, const TStringVector &theCoordNames, const TStringVector &theCoordUnits, const TIntVector &theFamilyNums, const TIntVector &theElemNums, const TStringVector &theElemNames)
virtual std::string GetCoordName (TInt theId) const
 Get name of the coordinate dimension by its order number. More...
virtual void SetCoordName (TInt theId, const std::string &theValue)
 Set name of the coordinate dimension by its order number. More...
virtual std::string GetCoordUnit (TInt theId) const
 Get name of unit for the coordinate dimension by its order number. More...
virtual void SetCoordUnit (TInt theId, const std::string &theValue)
 Set name of unit for the coordinate dimension by its order number. More...
TCCoordSlice GetCoordSlice (TInt theId) const
 Gives coordinates for mesh node by its number (const version) More...
TCoordSlice GetCoordSlice (TInt theId)
 Gives coordinates for mesh node by its number. More...
ERepere GetSystem () const
 Get which coordinate system is used for the node describing. More...
void SetSystem (ERepere theSystem)
 Set coordinate system to be used for the node describing. More...
const PMeshInfo & GetMeshInfo () const
 Get a reference to corresponding MED Mesh. More...
TInt GetNbElem () const
TInt GetFamNum (TInt theId) const
 Get number of a MED FAMILY by order number of the mesh element. More...
void SetFamNum (TInt theId, TInt theVal)
 Set number of a MED FAMILY for the mesh element with the order number. More...
EBooleen IsElemNum () const
 Let know if the mesh elements are indexed. More...
EBooleen IsFamNum () const
 Let know if the mesh elements family are indexed. More...
TInt GetElemNum (TInt theId) const
 Get a reference number of the mesh element by its order number. More...
void SetElemNum (TInt theId, TInt theVal)
 Set a reference number for the mesh element by its order number. More...
EBooleen IsElemNames () const
 Let know if the mesh elements have names. More...
virtual std::string GetElemName (TInt theId) const =0
 Get name of the mesh element by its order number. More...
virtual void SetElemName (TInt theId, const std::string &theValue)=0
 Set name of the mesh element by its order number. More...
EModeSwitch GetModeSwitch () const
Data Fields
PNodeCoord myCoord
 Contains all nodal coordinates. More...
ERepere mySystem
 Defines, which coordinate system is used. More...
TString myCoordNames
 Contains names for the coordinate dimensions. More...
TString myCoordUnits
 Contains units for the coordinate dimensions. More...
PMeshInfo myMeshInfo
 A reference to corresponding MED Mesh. More...
TInt myNbElem
PElemNum myFamNum
 Get number of mesh elements. More...
EBooleen myIsElemNum
 Defines if the mesh elements are indexed. More...
EBooleen myIsFamNum
 Defines if the mesh elements family are indexed. More...
PElemNum myElemNum
 Contains sequence of the indexes for the mesh elements. More...
EBooleen myIsElemNames
 Defines if the mesh elements are named. More...
PString myElemNames
 Contains sequence of the names for the mesh elements. More...
EModeSwitch myModeSwitch
 Keeps the interlace mode. More...
◆ TElemInfoBase
◆ TTNodeInfo() [1/3]
◆ TTNodeInfo() [2/3]
MED::TTNodeInfo::TTNodeInfo ( const PMeshInfo &  theMeshInfo,
TInt  theNbElem,
ERepere  theSystem,
◆ TTNodeInfo() [3/3]
const TFloatVector &  theNodeCoords,
ERepere  theSystem,
const TStringVector &  theCoordNames,
const TStringVector &  theCoordUnits,
const TIntVector &  theFamilyNums,
const TIntVector &  theElemNums,
const TStringVector &  theElemNames
◆ GetCoordName()
virtual std::string MED::TTNodeInfo::GetCoordName ( TInt  theId) const
Implements MED::TNodeInfo.
References MED::GetPNOMLength(), MED::GetString(), and MED::TNodeInfo::myCoordNames.
◆ GetCoordSlice() [1/2]
TCoordSlice MED::TNodeInfo::GetCoordSlice ( TInt  theId)
References MED::eFULL_INTERLACE, MED::TModeSwitchInfo::GetModeSwitch(), MED::TNodeInfo::myCoord, and MED::TElemInfo::myMeshInfo.
◆ GetCoordSlice() [2/2]
TCCoordSlice MED::TNodeInfo::GetCoordSlice ( TInt  theId) const
Referenced by MED::TShapeFun::Eval(), and MED::GetBaryCenter().
◆ GetCoordUnit()
virtual std::string MED::TTNodeInfo::GetCoordUnit ( TInt  theId) const
References MED::GetPNOMLength(), MED::GetString(), and MED::TNodeInfo::myCoordUnits.
◆ GetElemName() [1/2]
virtual std::string MED::TTElemInfo::GetElemName ( TInt  theId) const
Implements MED::TElemInfo.
References MED::GetPNOMLength(), MED::GetString(), and MED::TElemInfo::myElemNames.
◆ GetElemName() [2/2]
virtual std::string MED::TElemInfo::GetElemName ( TInt  theId) const
pure virtualinherited
Implemented in MED::TTElemInfo.
◆ GetElemNum()
TInt MED::TElemInfo::GetElemNum ( TInt  theId) const
References MED::TElemInfo::myElemNum.
◆ GetFamNum()
TInt MED::TElemInfo::GetFamNum ( TInt  theId) const
References MED::TElemInfo::myFamNum.
◆ GetMeshInfo()
const PMeshInfo & MED::TElemInfo::GetMeshInfo ( ) const
◆ GetModeSwitch()
◆ GetNbElem()
TInt MED::TElemInfo::GetNbElem ( ) const
◆ GetSystem()
ERepere MED::TNodeInfo::GetSystem ( ) const
◆ IsElemNames()
EBooleen MED::TElemInfo::IsElemNames ( ) const
◆ IsElemNum()
EBooleen MED::TElemInfo::IsElemNum ( ) const
Referenced by MED::TElemInfo::SetElemNum().
◆ IsFamNum()
EBooleen MED::TElemInfo::IsFamNum ( ) const
◆ SetCoordName()
virtual void MED::TTNodeInfo::SetCoordName ( TInt  theId,
const std::string &  theValue
References MED::GetPNOMLength(), MED::TNodeInfo::myCoordNames, and MED::SetString().
Referenced by TTNodeInfo().
◆ SetCoordUnit()
virtual void MED::TTNodeInfo::SetCoordUnit ( TInt  theId,
References MED::GetPNOMLength(), MED::TNodeInfo::myCoordUnits, and MED::SetString().
◆ SetElemName() [1/2]
virtual void MED::TTElemInfo::SetElemName ( TInt  theId,
References MED::GetPNOMLength(), MED::TElemInfo::myElemNames, and MED::SetString().
Referenced by MED::TTElemInfo::TTElemInfo().
◆ SetElemName() [2/2]
virtual void MED::TElemInfo::SetElemName ( TInt  theId,
◆ SetElemNum()
void MED::TElemInfo::SetElemNum ( TInt  theId,
TInt  theVal
References MED::TElemInfo::IsElemNum().
◆ SetFamNum()
void MED::TElemInfo::SetFamNum ( TInt  theId,
TInt  theVal
References MED::eVRAI, and MED::TElemInfo::myIsFamNum.
◆ SetSystem()
void MED::TNodeInfo::SetSystem ( ERepere  theSystem)
◆ myCoord
PNodeCoord MED::TNodeInfo::myCoord
◆ myCoordNames
TString MED::TNodeInfo::myCoordNames
Referenced by GetCoordName(), MED::TWrapper::GetNodeInfo(), SetCoordName(), MED::TWrapper::SetNodeInfo(), and TTNodeInfo().
◆ myCoordUnits
TString MED::TNodeInfo::myCoordUnits
Referenced by GetCoordUnit(), MED::TWrapper::GetNodeInfo(), SetCoordUnit(), MED::TWrapper::SetNodeInfo(), and TTNodeInfo().
◆ myElemNames
◆ myElemNum
◆ myFamNum
◆ myIsElemNames
◆ myIsElemNum
◆ myIsFamNum
EBooleen MED::TElemInfo::myIsFamNum
Referenced by MED::TWrapper::GetCellInfo(), MED::TWrapper::SetCellInfo(), MED::TElemInfo::SetFamNum(), and MED::TTElemInfo::TTElemInfo().
◆ myMeshInfo
◆ myModeSwitch
◆ myNbElem
◆ mySystem
ERepere MED::TNodeInfo::mySystem
Referenced by MED::TWrapper::GetNodeInfo(), MED::TWrapper::SetNodeInfo(), and TTNodeInfo().
