testhelper.hxx File Reference
#include <stdlib.h>
#include <unistd.h>
Include dependency graph for testhelper.hxx:
static std::string SMESH_ROOT_DIR ()
 This function returns the module SMESH installation root directory as a string. More...
static std::string PADDEREXE_RPATH ("/share/salome/resources/smesh/padderexe")
 Relative path of the directory containing data and exe for tests. More...
static std::string PADDEREXE_APATH (SMESH_ROOT_DIR()+PADDEREXE_RPATH)
 Absolute path of the directory containing data and exe for tests. More...
static std::string PADDEREXE_SCRIPT_FILENAME (PADDEREXE_APATH+"/padder.sh")
 Absolute path of the exe shell script for tests. More...
static int testssh_using_system ()
◆ PADDEREXE_APATH()
static std::string PADDEREXE_APATH ( SMESH_ROOT_DIR()+  PADDEREXE_RPATH)
◆ PADDEREXE_RPATH()
static std::string PADDEREXE_RPATH ( "/share/salome/resources/smesh/padderexe"  )
◆ PADDEREXE_SCRIPT_FILENAME()
static std::string PADDEREXE_SCRIPT_FILENAME ( PADDEREXE_APATH+"/padder.sh"  )
◆ SMESH_ROOT_DIR()
static std::string SMESH_ROOT_DIR ( )
References SMESH_ROOT_DIR().
Referenced by SMESH_ROOT_DIR().
◆ testssh_using_system()
static int testssh_using_system ( )
