BasicMainTest.hxx
1// Copyright (C) 2007-2026 CEA, EDF
20#ifndef _BASICMAINTEST_HXX_
21#define _BASICMAINTEST_HXX_
23#include <cppunit/CompilerOutputter.h>
24#include <cppunit/TestResult.h>
25#include <cppunit/TestResultCollector.h>
26#include <cppunit/TextTestProgressListener.h>
27#include <cppunit/BriefTestProgressListener.h>
28#include <cppunit/extensions/TestFactoryRegistry.h>
29#include <cppunit/TestRunner.h>
30#include <stdexcept>
31
32#include <iostream>
33#include <fstream>
34
35#if !defined WIN32 && !defined __APPLE__
36#include <fpu_control.h>
37#endif
38
39// ============================================================================
44// ============================================================================
45
46int main(int argc, char* argv[])
47{
48#if !defined WIN32 && !defined __APPLE__
49 fpu_control_t cw = _FPU_DEFAULT & ~(_FPU_MASK_IM | _FPU_MASK_ZM | _FPU_MASK_OM);
50 _FPU_SETCW(cw);
51#endif
52 // --- Create the event manager and test controller
53 CPPUNIT_NS::TestResult controller;
54
55 // --- Add a listener that collects test result
56 CPPUNIT_NS::TestResultCollector result;
57 controller.addListener( &result );
58
59 // --- Add a listener that print dots as test run.
60#if defined WIN32 || defined __APPLE__
61 CPPUNIT_NS::TextTestProgressListener progress;
62#else
63 CPPUNIT_NS::BriefTestProgressListener progress;
64#endif
65 controller.addListener( &progress );
66
67 // --- Get the top level suite from the registry
68
69 CPPUNIT_NS::Test *suite =
70 CPPUNIT_NS::TestFactoryRegistry::getRegistry().makeTest();
71
72 // --- Adds the test to the list of test to run
73
74 CPPUNIT_NS::TestRunner runner;
75 runner.addTest( suite );
76 runner.run( controller);
77
78 // --- Print test in a compiler compatible format.
79
80 std::ofstream testFile;
81 testFile.open("UnitTestsResult", std::ios::out | std::ios::trunc);
82 //CPPUNIT_NS::CompilerOutputter outputter( &result, std::cerr );
83 CPPUNIT_NS::CompilerOutputter outputter( &result, testFile );
84 outputter.write();
85
86 // --- Run the tests.
87
88 bool wasSucessful = result.wasSuccessful();
89 testFile.close();
90
91 // --- Return error code 1 if the one of test failed.
92
93 return wasSucessful ? 0 : 1;
94}
95
96#endif
int main(int argc, char *argv[])
