ConnectionManager.hxx
1// Copyright (C) 2007-2026 CEA, EDF
20#ifndef _CONNECTION_MANAGER_HXX_
21#define _CONNECTION_MANAGER_HXX_
24#include "DSC_Basic.hxx"
26#include <map>
27#include <mutex>
28
29#include <string>
30
31#include <SALOMEconfig.h>
32#include CORBA_SERVER_HEADER(DSC_Engines)
33
39{
40 public :
43
44 typedef short connectionId;
45
49 ConnectionManager::connectionId connect(Engines::DSC_ptr uses_component,
50 const char* uses_port_name,
51 Engines::DSC_ptr provides_component,
52 const char* provides_port_name);
53
57 void disconnect(ConnectionManager::connectionId id,
58 Engines::DSC::Message message);
59
63 void ShutdownWithExit();
64
65 private :
66
68 Engines::DSC_var uses_component;
69 std::string uses_port_name;
70 Engines::DSC_var provides_component;
71 std::string provides_port_name;
72 Ports::Port_var provides_port;
73 };
74
75 typedef std::map<Engines::ConnectionManager::connectionId,
77 typedef std::map<Engines::ConnectionManager::connectionId,
79
82 std::mutex _mutex;
83};
84
85#endif
#define YACSRUNTIMESALOME_EXPORT
This class implements the interface Engines::ConnectionManager. It is used to make connections betwee...
std::map< Engines::ConnectionManager::connectionId, connection_infos * > ids_type
std::map< Engines::ConnectionManager::connectionId, connection_infos * >::iterator ids_it_type
