FormSchemaView.cxx
20#include "FormSchemaView.hxx"
21#include "GraphicsView.hxx"
23//#define _DEVDEBUG_
24#include "YacsTrace.hxx"
26using namespace std;
27using namespace YACS::HMI;
28
30{
31 setupUi(this);
32
33 vboxLayout->removeWidget(gv_schema);
34 delete gv_schema;
35 gv_schema = new GraphicsView(this);
36 gv_schema->setObjectName(QString::fromUtf8("gv_schema"));
37 vboxLayout->insertWidget(0, gv_schema);
38
40 dial->setWrapping(true);
41 dial->setRange(0, 359);
42 dial->setValue(0);
43
44 _prevHsPos=500;
45 hs_position->setRange(0, 999);
46 hs_position->setValue(500);
47
48 _prevVsPos=500;
49 vs_position->setRange(0, 999);
50 vs_position->setValue(500);
51
52 _prevZoom=0;
53 vs_zoom->setRange(-100, 100);
54 vs_zoom->setValue(0);
55
56}
57
59{
60}
61
63{
64 DEBTRACE("FormSchemaView::on_dial_valueChanged " << val);
65 int delta = val - _prevRotate;
66 _prevRotate = val;
67 gv_schema->rotate(delta);
68}
69
71{
72 DEBTRACE("FormSchemaView::on_hs_poistion_valueChanged " << val);
73 int delta = val - _prevHsPos;
74 _prevHsPos = val;
75 gv_schema->translate(val,0);
76}
77
79{
80 DEBTRACE("FormSchemaView::on_vs_poistion_valueChanged " << val);
81 int delta = val - _prevVsPos;
82 _prevVsPos = val;
83 gv_schema->translate(0, val);
84}
85
87{
88 DEBTRACE("FormSchemaView::on_vs_zoom_valueChanged " << val);
89 int delta = val - _prevZoom;
90 double s=1;
91 if (delta>=0) s=delta/25.0;
92 else s=25/delta;
93 _prevZoom = val;
94 gv_schema->scale(s, s);
95}
void on_vs_zoom_valueChanged(int val)
void on_dial_valueChanged(int val)
void on_hs_position_valueChanged(int val)
void on_vs_position_valueChanged(int val)
FormSchemaView(QWidget *parent=0)
virtual ~FormSchemaView()
