Tree.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20# -*- coding: iso-8859-15 -*-
21#
22"""Ce module permet de créer des vues sous forme d'arbre
23 Ces vues sont construites à partir des informations
24 fournies par un modèle
25"""
26
27import sys
28from qt import *
29from . import Icons
30from . import CONNECTOR
31
32class Tree(QListView):
33 """Tree(parent=None)
34 Classe pour faire une vue d'un arbre
35 """
36 def __init__(self,parent=None,onSelect=None,onDblSelect=None):
37 QListView.__init__(self,parent)
38 self.setCaption("Tree")
39 self.setRootIsDecorated(1)
40 self.setSorting(-1)
41 self.addColumn("Name")
42 self.children=[]
43 self.last=None
44 self.onSelect=onSelect
45 self.onDblSelect=onDblSelect
46 self.connect(self,SIGNAL('selectionChanged(QListViewItem *)'),
47 self.handleSelected)
48 self.connect(self,SIGNAL('doubleClicked(QListViewItem *, const QPoint &, int)'),
50
51 def handleSelected(self,node):
52 node.item.selected()
53 if self.onSelect:
54 self.onSelect(node.item)
55
56 def handleDblSelected(self,node,point,col):
57 node.item.dblselected()
58 if self.onDblSelect:
59 self.onDblSelect(node.item)
60
61 def additem(self,item):
62 node=Node(self,item.label,item,self.last)
63 self.last=node
64 self.children.append(node)
65 CONNECTOR.Connect(item,"selected",self.selectItem,())
66 CONNECTOR.Connect(item,"add",node.addNode,())
67 return node
68
69 def selectNodeItem(self,item,node):
70 #print "selectNodeItem",node,item
71 self.setSelected(node,True)
72
73 def selectItem(self,item):
74 #print "selectItem",item
75 node=self.selectedItem()
76 if node.item is item:
77 #print "item has been selected at item level"
78 return
79
80 #print "item has not been selected at item level"
81 #try another way
82 #find its father ???
83 it = QListViewItemIterator(self)
84 node = it.current()
85 while node:
86 if node.item is item:
87 break
88 it += 1
89 node = it.current()
90
91 if node:
92 self.setSelected(node,True)
93
95 """Node(parent,text,item,after)
96 Classe pour faire une vue d'un noeud d'un arbre
97 """
98 def __init__(self,parent,text,item,after=None):
99 if after is None:
100 QListViewItem.__init__(self,parent,text)
101 else:
102 QListViewItem.__init__(self,parent,after,text)
103 self.item=item
104 self.setPixmap(0,Icons.get_image(item.getIconName()))
105 self.setExpandable(self.item.isExpandable())
106 self.children = []
107
108 def selectNode(self,item):
109 self.listView().setSelected(self,True)
110
111 def addNode(self,item):
112 #print "Tree.addNode",item
113 self.additem(item)
114
115 def delNode(self,node):
116 #print "Tree.delNode",node,node.item
117 CONNECTOR.Disconnect(node.item,"selected",node.selectNode,())
118 CONNECTOR.Disconnect(node.item,"add",node.addNode,())
119 CONNECTOR.Disconnect(node.item,"remove",self.delNode,(node,))
120 self.takeItem(node)
121 self.children.remove(node)
122
123 def additem(self,item):
124 if self.children:
125 node=Node(self,item.label,item,self.children[-1])
126 else:
127 node=Node(self,item.label,item)
128 self.children.append(node)
129 #CONNECTOR.Connect(item,"selected",self.listView().selectNodeItem,(node,))
130 CONNECTOR.Connect(item,"selected",node.selectNode,())
131 CONNECTOR.Connect(item,"add",node.addNode,())
132 CONNECTOR.Connect(item,"remove",self.delNode,(node,))
133 return node
134
135 def setOpen(self,o):
136 if o and not self.childCount():
137 for child in self.item.getChildren():
138 self.additem(child)
139 QListViewItem.setOpen(self,o)
140
141 def setOpen_old(self,o):
142 if o:
143 #open
144 for child in self.item.getChildren():
145 self.additem(child)
146 else:
147 #close
148 for node in self.children:
149 #CONNECTOR.Disconnect(node.item,"selected",self.listView().selectNodeItem,(node,))
150 CONNECTOR.Disconnect(node.item,"selected",node.selectNode,())
151 CONNECTOR.Disconnect(node.item,"add",node.addNode,())
152 self.takeItem(node)
153 del node
154 self.children=[]
155 QListViewItem.setOpen(self,o)
156
157
158if __name__ == "__main__":
159 from .Item import Item
160 app = QApplication(sys.argv)
162 t.additem(Item("item1"))
163 #n=t.additem(Item("item2"))
164 #n.additem(Item("item3"))
165 app.setMainWidget(t)
166 t.show()
167 app.exec_loop()
168
def setOpen(self, o)
Definition: Tree.py:135
def additem(self, item)
Definition: Tree.py:123
def delNode(self, node)
Definition: Tree.py:115
def setOpen_old(self, o)
Definition: Tree.py:141
def selectNode(self, item)
Definition: Tree.py:108
def addNode(self, item)
Definition: Tree.py:111
def __init__(self, parent, text, item, after=None)
Definition: Tree.py:98
def handleSelected(self, node)
Definition: Tree.py:51
def __init__(self, parent=None, onSelect=None, onDblSelect=None)
Definition: Tree.py:36
def selectItem(self, item)
Definition: Tree.py:73
Definition: Tree.py:61
def handleDblSelected(self, node, point, col)
Definition: Tree.py:56
def selectNodeItem(self, item, node)
Definition: Tree.py:69
