YACS::BASES::AlternateThreadPT Class Referenceabstract
This class provides a mechanism to run two threads alternately. More...
#include <AlternateThreadPT.hxx>
Collaboration diagram for YACS::BASES::AlternateThreadPT:
enum  ThreadStatus { UNEXISTING , NORMAL_CYCLE , TERMINATION_REQUESTED , READY_TO_JOIN }
 AlternateThreadPT ()
virtual ~AlternateThreadPT ()
void start ()
 Create and launch the slave thread. More...
virtual void signalSlaveAndWait ()
 Block the master thread and release the slave thread. More...
void terminateSlaveThread ()
 Terminate the slave thread. More...
virtual void signalMasterAndWait ()
 Block the slave thread and release the master thread. More...
bool isTerminationRequested () const
 Return true if the master requested the slave thread termination. More...
ThreadStatus getThreadStatus () const
 Return the thread status. More...
virtual void run ()=0
 This method must be implemented in subclasses and will be run in the slave thread. More...
void signalAndWait ()
static void * runThread (void *instance)
static void threadCleanupFct (void *instance)
pthread_t _threadId
ThreadStatus _threadStatus
pthread_cond_t _pingPongCond
pthread_mutex_t _pingPongMutex
Alternate threads can be necessary when two pieces of code must run alternately and communicate but are difficult or impossible to synchronize explicitly (e.g. asynchronous algorithms in optimizer loop). This class guarantees that the two threads NEVER run concurrently, so no lock mechanism is necessary when sharing data between them.
The two threads are called "master thread" and "slave thread". The master thread is the one that calls the method start() and that will continue to run after the destruction of this object. The slave thread is created when the method start() is called. It will run the code in the method run() and will be destroyed when the master thread calls terminateSlaveThread() or at the destruction of this object.
When the master thread calls start(), it will block and the slave thread will begin to execute the code in the method run(). The two threads can then alternate by calling the method signalMasterAndWait() (in the slave thread) and signalSlaveAndWait() (in the master thread). Finally, the master thread must call terminateSlaveThread() to terminate the slave thread. There is no explicit mechanism for the slave thread to request its own termination, but this can be done with an external flag (see the pool object in OptimizerLoop for instance).
This class is purely virtual. Subclasses must implement the run() method that will be executed in the slave thread.
Definition at line 55 of file AlternateThreadPT.hxx.
◆ ThreadStatus
◆ AlternateThreadPT()
AlternateThreadPT::AlternateThreadPT ( )
Definition at line 31 of file AlternateThreadPT.cxx.
33{
34 YASSERT(pthread_cond_init(&_pingPongCond, NULL) == 0)
35 YASSERT(pthread_mutex_init(&_pingPongMutex, NULL) == 0)
36}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
References _pingPongCond, _pingPongMutex, and YASSERT.
◆ ~AlternateThreadPT()
AlternateThreadPT::~AlternateThreadPT ( )
Definition at line 38 of file AlternateThreadPT.cxx.
39{
40 try {
42 YASSERT(pthread_mutex_destroy(&_pingPongMutex) == 0)
43 YASSERT(pthread_cond_destroy(&_pingPongCond) == 0)
44 } catch (const exception & e) {
45 cerr << "Exception happened in AlternateThreadPT destructor: " << e.what() << endl;
46 } catch (...) {
47 cerr << "Unknown exception happened in AlternateThreadPT destructor." << endl;
48 }
49}
void terminateSlaveThread()
References _pingPongCond, _pingPongMutex, terminateSlaveThread(), and YASSERT.
◆ getThreadStatus()
AlternateThreadPT::ThreadStatus AlternateThreadPT::getThreadStatus ( ) const
Definition at line 134 of file AlternateThreadPT.cxx.
135{
136 return _threadStatus;
137}
References _threadStatus.
◆ isTerminationRequested()
bool AlternateThreadPT::isTerminationRequested ( ) const
Definition at line 129 of file AlternateThreadPT.cxx.
130{
132}
References _threadStatus, and TERMINATION_REQUESTED.
◆ run()
virtual void YACS::BASES::AlternateThreadPT::run ( )
protectedpure virtual
The slave thread must call signalMasterAndWait() when necessary to give the control back to the master thread. When returning from this method, the slave thread MUST check for an eventual termination request (with the method isTerminationRequested()). If the termination is requested, the slave thread must perform any necessary cleanup and finish as soon as possible.
Referenced by runThread().
◆ runThread()
void * AlternateThreadPT::runThread ( void *  instance)
staticprivate
Definition at line 139 of file AlternateThreadPT.cxx.
140{
141 try {
142 AlternateThreadPT * instanceCst = (AlternateThreadPT *)instance;
143 YASSERT(pthread_mutex_lock(&instanceCst->_pingPongMutex) == 0)
144 DEBTRACE("Slave thread is now running")
145 instanceCst->_threadStatus = NORMAL_CYCLE;
146 pthread_cleanup_push(threadCleanupFct, instance);
147 instanceCst->run();
148 pthread_cleanup_pop(1);
149 } catch (const exception & e) {
150 cerr << "Unrecoverable error: an exception was caught in AlternateThread "
151 "(exceptions should normally be caught before getting here). "
152 "Exception type is: " << typeid(e).name() << ", message is: " <<
153 e.what() << endl;
154 threadCleanupFct(instance);
155 }
156 // We can't catch (...) here because it causes problems with thread cancellation, at least
157 // with gcc 4.1.2 and older. With newer versions it should be possible to do something like
158 // catch (abi::__forced_unwind e) { throw; }. See
159 // http://gcc.gnu.org/bugzilla/show_bug.cgi?id=28145 for details.
160 // The problem is that no exception should get out of the thread scope without being caught
161 // (otherwise the program aborts). So for now the user has to take care of catching all
162 // exceptions, but he cannot use catch (...).
163 return NULL;
164}
virtual void run()=0
static void threadCleanupFct(void *instance)
References _pingPongMutex, _threadStatus, DEBTRACE, NORMAL_CYCLE, run(), threadCleanupFct(), and YASSERT.
Referenced by start().
◆ signalAndWait()
void AlternateThreadPT::signalAndWait ( )
Definition at line 122 of file AlternateThreadPT.cxx.
123{
125 YASSERT(pthread_cond_signal(&_pingPongCond) == 0)
126 YASSERT(pthread_cond_wait(&_pingPongCond, &_pingPongMutex) == 0)
127}
References _pingPongCond, _pingPongMutex, _threadStatus, NORMAL_CYCLE, TERMINATION_REQUESTED, and YASSERT.
Referenced by signalMasterAndWait(), and signalSlaveAndWait().
◆ signalMasterAndWait()
void AlternateThreadPT::signalMasterAndWait ( )
Definition at line 114 of file AlternateThreadPT.cxx.
115{
116 YASSERT(pthread_equal(pthread_self(), _threadId))
117 DEBTRACE("Slave signaling master and waiting");
119 DEBTRACE("Slave running again");
120}
References _threadId, DEBTRACE, signalAndWait(), and YASSERT.
◆ signalSlaveAndWait()
void AlternateThreadPT::signalSlaveAndWait ( )
Definition at line 106 of file AlternateThreadPT.cxx.
107{
108 YASSERT(!pthread_equal(pthread_self(), _threadId))
109 DEBTRACE("Master signaling slave and waiting");
111 DEBTRACE("Master running again");
112}
Referenced by terminateSlaveThread().
◆ start()
void AlternateThreadPT::start ( )
This method must not be called by the slave thread or if a slave thread is already running.
Definition at line 51 of file AlternateThreadPT.cxx.
52{
53 // This method must not be called if a slave thread is running
55
56 YASSERT(pthread_mutex_lock(&_pingPongMutex) == 0)
57 DEBTRACE("Starting thread")
58 YASSERT(pthread_create(&_threadId, 0, runThread, this) == 0)
59 DEBTRACE("Master waiting for slave")
60 YASSERT(pthread_cond_wait(&_pingPongCond, &_pingPongMutex) == 0)
61 DEBTRACE("Master running again")
62}
static void * runThread(void *instance)
References _pingPongCond, _pingPongMutex, _threadId, _threadStatus, DEBTRACE, runThread(), UNEXISTING, and YASSERT.
◆ terminateSlaveThread()
void AlternateThreadPT::terminateSlaveThread ( )
Definition at line 64 of file AlternateThreadPT.cxx.
65{
66 // This method must not be called by the slave thread
67 YASSERT(_threadStatus == UNEXISTING || !pthread_equal(pthread_self(), _threadId))
68
69 switch (_threadStatus) {
70 case UNEXISTING:
71 return;
72 case READY_TO_JOIN:
73 break;
74 case NORMAL_CYCLE:
75 {
76 // First try to signal the slave thread to end properly
77 DEBTRACE("Master is trying to terminate slave by signaling error")
80
82 // Try to cancel the thread
83 cerr << "Warning: Slave thread in AlternateThread did not end properly. "
84 "Thread will be canceled." << endl;
85 YASSERT(pthread_cancel(_threadId) == 0)
86 YASSERT(pthread_cond_wait(&_pingPongCond, &_pingPongMutex) == 0)
87
89 // If cancel failed, we can do nothing more, throw an exception
90 YASSERT(false);
91 }
92 }
93 break;
94 }
95 default:
96 YASSERT(false)
97 }
98
99 // Finally join the thread
100 YASSERT(pthread_mutex_unlock(&_pingPongMutex) == 0)
101 YASSERT(pthread_join(_threadId, NULL) == 0)
103 DEBTRACE("AlternateThread terminated")
104}
virtual void signalSlaveAndWait()
References _pingPongCond, _pingPongMutex, _threadId, _threadStatus, DEBTRACE, NORMAL_CYCLE, READY_TO_JOIN, signalSlaveAndWait(), TERMINATION_REQUESTED, UNEXISTING, and YASSERT.
Referenced by ~AlternateThreadPT().
◆ threadCleanupFct()
void AlternateThreadPT::threadCleanupFct ( void *  instance)
staticprivate
Definition at line 166 of file AlternateThreadPT.cxx.
167{
168 // Beware of not throwing exceptions in this method
169 DEBTRACE("Cleaning up slave thread")
170 AlternateThreadPT * instanceCst = (AlternateThreadPT *)instance;
171 instanceCst->_threadStatus = READY_TO_JOIN;
172 pthread_cond_signal(&instanceCst->_pingPongCond);
173 pthread_mutex_unlock(&instanceCst->_pingPongMutex);
174}
References _pingPongCond, _pingPongMutex, _threadStatus, DEBTRACE, and READY_TO_JOIN.
◆ _pingPongCond
pthread_cond_t YACS::BASES::AlternateThreadPT::_pingPongCond
◆ _pingPongMutex
pthread_mutex_t YACS::BASES::AlternateThreadPT::_pingPongMutex
◆ _threadId
pthread_t YACS::BASES::AlternateThreadPT::_threadId
◆ _threadStatus
ThreadStatus YACS::BASES::AlternateThreadPT::_threadStatus
