YACS::BASES::DynLibLoaderGNU Class Reference
#include <DynLibLoaderGNU.hxx>
Collaboration diagram for YACS::BASES::DynLibLoaderGNU:
 DynLibLoaderGNU (const std::string &libNameWithoutExtension)
 ~DynLibLoaderGNU ()
bool isLibFileFindable () const
std::string getLibNameWithoutExt () const
int appendDirInSearchPath (const std::string &dirName)
int removeDirInSearchPath (const std::string &dirName)
void * getHandleOnSymbolWithName (const std::string &symbName, bool stopOnError=true)
bool load ()
bool reload ()
bool unload ()
static const char * getExtensionForDynLib ()
void loadLib ()
void * resolveSymb (const std::string &symbName, bool stopOnError)
 load lib without regarding that _libName is reachable More...
 DynLibLoaderGNU (const DynLibLoaderGNU &orig)
DynLibLoaderGNU & operator= (const DynLibLoaderGNU &orig)
void * _handleOnLoadedLib
std::string _libName
Static Private Attributes
static const char _extForDynLib [] =".so"
Definition at line 29 of file DynLibLoaderGNU.hxx.
◆ DynLibLoaderGNU() [1/2]
DynLibLoaderGNU::DynLibLoaderGNU ( const std::string &  libNameWithoutExtension)
Definition at line 33 of file DynLibLoaderGNU.cxx.
33 :_libName(libNameWithoutExtension),
35{
36}
◆ ~DynLibLoaderGNU()
DynLibLoaderGNU::~DynLibLoaderGNU ( )
Definition at line 38 of file DynLibLoaderGNU.cxx.
39{
41 dlclose(_handleOnLoadedLib);
42}
References _handleOnLoadedLib.
◆ DynLibLoaderGNU() [2/2]
YACS::BASES::DynLibLoaderGNU::DynLibLoaderGNU ( const DynLibLoaderGNU &  orig)
inlineprivate
Definition at line 54 of file DynLibLoaderGNU.hxx.
54{}
◆ appendDirInSearchPath()
int DynLibLoaderGNU::appendDirInSearchPath ( const std::string &  dirName)
Append a directory with name dirName to the searching paths.
If append succeeds 0 is returned. If the directory does not exists 1 is returned. If the addition of directory causes some troubles due to seach paths name 2 is returned.
Definition at line 60 of file DynLibLoaderGNU.cxx.
61{
62 return 0;
63}
◆ getExtensionForDynLib()
const char * DynLibLoaderGNU::getExtensionForDynLib ( )
Definition at line 137 of file DynLibLoaderGNU.cxx.
138{
139 return _extForDynLib+1;
140}
static const char _extForDynLib[]
References _extForDynLib.
◆ getHandleOnSymbolWithName()
void * DynLibLoaderGNU::getHandleOnSymbolWithName ( const std::string &  symbName,
bool  stopOnError = true
Definition at line 76 of file DynLibLoaderGNU.cxx.
77{
80 {
81 std::cerr << "Dynamic library with name " << symbName << _extForDynLib;
82 std::cerr << " not existing in paths specified" << std::endl;
83 return 0;
84 }
85 else
86 loadLib();
87 return resolveSymb(symbName, stopOnError);
88}
void * resolveSymb(const std::string &symbName, bool stopOnError)
References _extForDynLib, _handleOnLoadedLib, isLibFileFindable(), loadLib(), and resolveSymb().
◆ getLibNameWithoutExt()
std::string DynLibLoaderGNU::getLibNameWithoutExt ( ) const
Definition at line 49 of file DynLibLoaderGNU.cxx.
50{
51 return _libName;
52}
References _libName.
◆ isLibFileFindable()
bool DynLibLoaderGNU::isLibFileFindable ( ) const
Definition at line 44 of file DynLibLoaderGNU.cxx.
45{
46 return true;
47}
Referenced by getHandleOnSymbolWithName().
◆ load()
bool DynLibLoaderGNU::load ( )
Definition at line 90 of file DynLibLoaderGNU.cxx.
91{
92 std::string fullLibName(_libName);
93 fullLibName+=_extForDynLib;
94 dlerror();
95 _handleOnLoadedLib=dlopen(fullLibName.c_str(),RTLD_LAZY | RTLD_GLOBAL);
96 char *message=dlerror();
97 if (message != NULL)
98 {
99 std::string error = "Error while trying to load library with name " + fullLibName +
100 " with the following internal message: " + message;
101 throw YACS::Exception(error);
102 }
103 return _handleOnLoadedLib != NULL;
104}
References _extForDynLib, _handleOnLoadedLib, and _libName.
Referenced by loadLib(), and reload().
◆ loadLib()
void YACS::BASES::DynLibLoaderGNU::loadLib ( )
inlineprivate
Definition at line 49 of file DynLibLoaderGNU.hxx.
References load().
◆ operator=()
DynLibLoaderGNU & YACS::BASES::DynLibLoaderGNU::operator= ( const DynLibLoaderGNU &  orig)
inlineprivate
Definition at line 55 of file DynLibLoaderGNU.hxx.
55{ return *this; }
◆ reload()
bool DynLibLoaderGNU::reload ( )
Definition at line 116 of file DynLibLoaderGNU.cxx.
117{
118 unload();
119 return load();
120}
References load(), and unload().
◆ removeDirInSearchPath()
int DynLibLoaderGNU::removeDirInSearchPath ( const std::string &  dirName)
Removes a directory with name dirName from the searching paths.
If removal succeeds 0 is returned. If the directory does not exists 1 is returned. If the path were not already in existing paths 2 is returned.
Definition at line 71 of file DynLibLoaderGNU.cxx.
72{
73 return 0;
74}
◆ resolveSymb()
void * DynLibLoaderGNU::resolveSymb ( const std::string &  symbName,
bool  stopOnError
Definition at line 122 of file DynLibLoaderGNU.cxx.
123{
124 dlerror();
125 void *ret=dlsym(_handleOnLoadedLib,symbName.c_str());
126 char *message=dlerror();
127 if(stopOnError && (NULL != message))
128 {
129 std::string error="Error detected on symbol ";
130 error=error+symbName +" search in library with name "+_libName+_extForDynLib+" with the following internal message "+message;
131 throw YACS::Exception(error);
132 }
133 else
134 return ret;
135}
◆ unload()
bool DynLibLoaderGNU::unload ( )
Definition at line 106 of file DynLibLoaderGNU.cxx.
107{
109 {
110 dlclose(_handleOnLoadedLib);
111 _handleOnLoadedLib = NULL;
112 }
113 return false;
114}
Referenced by reload().
◆ _extForDynLib
const char DynLibLoaderGNU::_extForDynLib =".so"
staticprivate
◆ _handleOnLoadedLib
void* YACS::BASES::DynLibLoaderGNU::_handleOnLoadedLib
◆ _libName
std::string YACS::BASES::DynLibLoaderGNU::_libName
Definition at line 33 of file DynLibLoaderGNU.hxx.
Referenced by getLibNameWithoutExt(), load(), and resolveSymb().
