YACS::BASES::DynLibLoaderWin Class Reference
#include <DynLibLoaderWin.hxx>
Collaboration diagram for YACS::BASES::DynLibLoaderWin:
 DynLibLoaderWin (const std::string &libNameWithoutExtension)
 ~DynLibLoaderWin ()
bool isLibFileFindable () const
std::string getLibNameWithoutExt () const
int appendDirInSearchPath (const std::string &dirName)
int removeDirInSearchPath (const std::string &dirName)
void * getHandleOnSymbolWithName (const std::string &symbName, bool stopOnError=true)
bool load ()
bool reload ()
bool unload ()
static const char * getExtensionForDynLib ()
void loadLib ()
void * resolveSymb (const std::string &symbName, bool stopOnError)
 load lib without regarding that _libName is reachable More...
HMODULE _handleOnLoadedLib
std::string _libName
Static Private Attributes
static const char _extForDynLib [] =".dll"
Definition at line 32 of file DynLibLoaderWin.hxx.
◆ DynLibLoaderWin()
DynLibLoaderWin::DynLibLoaderWin ( const std::string &  libNameWithoutExtension)
Definition at line 28 of file DynLibLoaderWin.cxx.
28 :_libName(libNameWithoutExtension),
30{
31}
◆ ~DynLibLoaderWin()
DynLibLoaderWin::~DynLibLoaderWin ( )
Definition at line 33 of file DynLibLoaderWin.cxx.
34{
36 FreeLibrary(_handleOnLoadedLib);
37}
References _handleOnLoadedLib.
◆ appendDirInSearchPath()
int DynLibLoaderWin::appendDirInSearchPath ( const std::string &  dirName)
Append a directory with name dirName to the searching paths.
If append succeeds 0 is returned. If the directory does not exists 1 is returned. If the addition of directory causes some troubles due to seach paths name 2 is returned.
Definition at line 55 of file DynLibLoaderWin.cxx.
56{
57 return 0;
58}
◆ getExtensionForDynLib()
const char * DynLibLoaderWin::getExtensionForDynLib ( )
Definition at line 133 of file DynLibLoaderWin.cxx.
134{
135 return _extForDynLib+1;
136}
static const char _extForDynLib[]
References _extForDynLib.
◆ getHandleOnSymbolWithName()
void * DynLibLoaderWin::getHandleOnSymbolWithName ( const std::string &  symbName,
bool  stopOnError = true
Definition at line 71 of file DynLibLoaderWin.cxx.
72{
75 {
76 std::cerr << "Dynamic library with name " << symbName << _extForDynLib;
77 std::cerr << " not existing in paths specified" << std::endl;
78 return 0;
79 }
80 else
81 loadLib();
82 return resolveSymb(symbName, stopOnError);
83}
void * resolveSymb(const std::string &symbName, bool stopOnError)
References _extForDynLib, _handleOnLoadedLib, isLibFileFindable(), loadLib(), and resolveSymb().
◆ getLibNameWithoutExt()
std::string DynLibLoaderWin::getLibNameWithoutExt ( ) const
Definition at line 44 of file DynLibLoaderWin.cxx.
45{
46 return _libName;
47}
References _libName.
◆ isLibFileFindable()
bool DynLibLoaderWin::isLibFileFindable ( ) const
Definition at line 39 of file DynLibLoaderWin.cxx.
40{
41 return true;
42}
Referenced by getHandleOnSymbolWithName().
◆ load()
bool DynLibLoaderWin::load ( )
Definition at line 85 of file DynLibLoaderWin.cxx.
86{
87 std::string fullLibName(_libName);
88 fullLibName+=_extForDynLib;
89#if defined(UNICODE) && defined(WIN32)
90 size_t length = strlen(fullLibName.c_str()) + sizeof(char);
91 wchar_t* aPath = new wchar_t[length + 1];
92 memset(aPath, '\0', length);
93 mbstowcs(aPath, fullLibName.c_str(), length);
94#else
95 const char* aPath = fullLibName.c_str();
96#endif
97
98 _handleOnLoadedLib=LoadLibrary(aPath);
99 return _handleOnLoadedLib != NULL;
100}
References _extForDynLib, _handleOnLoadedLib, and _libName.
Referenced by reload().
◆ loadLib()
void YACS::BASES::DynLibLoaderWin::loadLib ( )
inlineprivate
Definition at line 52 of file DynLibLoaderWin.hxx.
◆ reload()
bool DynLibLoaderWin::reload ( )
Definition at line 112 of file DynLibLoaderWin.cxx.
113{
114 unload();
115 return load();
116}
References load(), and unload().
◆ removeDirInSearchPath()
int DynLibLoaderWin::removeDirInSearchPath ( const std::string &  dirName)
Removes a directory with name dirName from the searching paths.
If removal succeeds 0 is returned. If the directory does not exists 1 is returned. If the path were not already in existing paths 2 is returned.
Definition at line 66 of file DynLibLoaderWin.cxx.
67{
68 return 0;
69}
◆ resolveSymb()
void * DynLibLoaderWin::resolveSymb ( const std::string &  symbName,
bool  stopOnError
Definition at line 118 of file DynLibLoaderWin.cxx.
119{
120 void *ret=(void*)GetProcAddress(_handleOnLoadedLib,symbName.c_str());
121 char *message="Not available here !";
122 if(stopOnError && (NULL != message))
123 {
124 std::cerr << "Error detected on symbol " << symbName << " search in library with name " << _libName << _extForDynLib;
125 std::cerr << " with the following internal message"<< std::endl;
126 std::cerr << message << std::endl;
127 return 0;
128 }
129 else
130 return ret;
131}
◆ unload()
bool DynLibLoaderWin::unload ( )
Definition at line 102 of file DynLibLoaderWin.cxx.
103{
105 {
106 FreeLibrary(_handleOnLoadedLib);
107 _handleOnLoadedLib = NULL;
108 }
109 return 0;
110}
◆ _extForDynLib
const char DynLibLoaderWin::_extForDynLib =".dll"
staticprivate
◆ _handleOnLoadedLib
HMODULE YACS::BASES::DynLibLoaderWin::_handleOnLoadedLib
◆ _libName
std::string YACS::BASES::DynLibLoaderWin::_libName
Definition at line 36 of file DynLibLoaderWin.hxx.
Referenced by getLibNameWithoutExt(), load(), and resolveSymb().
