YACS::ENGINE::LinkedBlocPoint Member List
This is the complete list of members for YACS::ENGINE::LinkedBlocPoint, including all inherited members.
_fatherYACS::ENGINE::AbstractPointprotected
_nodesYACS::ENGINE::BlocPointprotected
AbstractPoint()=defaultYACS::ENGINE::AbstractPoint
AbstractPoint(AbstractPoint *father)YACS::ENGINE::AbstractPointinline
accept(PointVisitor *pv) overrideYACS::ENGINE::LinkedBlocPointvirtual
amIGod()YACS::ENGINE::AbstractPointinline
anyOf(const std::set< Node * > &nodes) const overrideYACS::ENGINE::BlocPointvirtual
BlocPoint()=defaultYACS::ENGINE::BlocPoint
BlocPoint(const std::list< AbstractPoint * > &nodes, AbstractPoint *father)YACS::ENGINE::BlocPoint
contains(Node *node) const overrideYACS::ENGINE::BlocPointvirtual
deepCopy(AbstractPoint *father) const overrideYACS::ENGINE::LinkedBlocPointvirtual
deepCopyFrom(const BlocPoint &other)YACS::ENGINE::BlocPoint
Display(std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)YACS::ENGINE::AbstractPointstatic
expandNonSimpleCaseOn(NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) overrideYACS::ENGINE::LinkedBlocPointvirtual
FeedData(AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)YACS::ENGINE::AbstractPointstatic
FeedData(const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)YACS::ENGINE::AbstractPointstatic
findPointWithNode(Node *node)YACS::ENGINE::BlocPointvirtual
GetDirectSonOf(AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)YACS::ENGINE::AbstractPointstatic
getFather() constYACS::ENGINE::AbstractPointinline
getFirstNode() overrideYACS::ENGINE::LinkedBlocPointvirtual
getGodFather()YACS::ENGINE::AbstractPoint
getLastNode() overrideYACS::ENGINE::LinkedBlocPointvirtual
getListOfPoints() constYACS::ENGINE::BlocPointinline
getMaxLevelOfParallelism() constYACS::ENGINE::LinkedBlocPointvirtual
GetNodeAfter(Node *node)YACS::ENGINE::AbstractPointstatic
getNodeAfter(Node *node)YACS::ENGINE::BlocPoint
GetNodeB4(Node *node)YACS::ENGINE::AbstractPointstatic
getNodeB4(Node *node)YACS::ENGINE::BlocPoint
getNumberOfNodes() constYACS::ENGINE::BlocPointvirtual
getOutPoint(AbstractPoint *node)YACS::ENGINE::BlocPointprotected
getRepr() constYACS::ENGINE::LinkedBlocPointvirtual
getUnique()YACS::ENGINE::BlocPoint
getUnique() constYACS::ENGINE::BlocPoint
getUniqueAndReleaseIt()YACS::ENGINE::BlocPoint
getWeightRegardingDPL(ComplexWeight *weight)YACS::ENGINE::LinkedBlocPointvirtual
internalContinueForSimplify() constYACS::ENGINE::BlocPoint
isBegin()YACS::ENGINE::AbstractPoint
IsCommonDirectSonOf(AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)YACS::ENGINE::AbstractPointstatic
IsCommonDirectSonOf(AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)YACS::ENGINE::AbstractPointstatic
IsGatherB4Ext(Node *node)YACS::ENGINE::AbstractPointstatic
isLast()YACS::ENGINE::AbstractPoint
IsNoLinksAfter(Node *node)YACS::ENGINE::AbstractPointstatic
IsNoLinksBefore(Node *node)YACS::ENGINE::AbstractPointstatic
isNullBeforeNullAfter(BlocPoint *sop)YACS::ENGINE::AbstractPoint
IsScatterAfterExt(Node *node)YACS::ENGINE::AbstractPointstatic
isSimplyLinkedAfter(BlocPoint *sop, Node *node)YACS::ENGINE::AbstractPoint
IsSimplyLinkedAfterExt(Node *node)YACS::ENGINE::AbstractPointstatic
isSimplyLinkedAfterNullBefore(BlocPoint *sop)YACS::ENGINE::AbstractPoint
isSimplyLinkedBefore(BlocPoint *sop, Node *node)YACS::ENGINE::AbstractPoint
isSimplyLinkedBeforeAfter(BlocPoint *sop)YACS::ENGINE::AbstractPoint
IsSimplyLinkedBeforeExt(Node *node)YACS::ENGINE::AbstractPointstatic
isSimplyLinkedBeforeNullAfter(BlocPoint *sop)YACS::ENGINE::AbstractPoint
LinkedBlocPoint()=defaultYACS::ENGINE::LinkedBlocPoint
LinkedBlocPoint(const std::list< AbstractPoint * > &nodes, AbstractPoint *father)YACS::ENGINE::LinkedBlocPoint
partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) constYACS::ENGINE::LinkedBlocPointvirtual
presenceOfNonSimpleCase() constYACS::ENGINE::BlocPoint
Rewire(const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)YACS::ENGINE::AbstractPointstatic
setFather(AbstractPoint *father)YACS::ENGINE::AbstractPointinline
tryAsFork(BlocPoint *sop)YACS::ENGINE::AbstractPoint
tryAsForkBis(BlocPoint *sop)YACS::ENGINE::AbstractPoint
tryAsForkQuatro(BlocPoint *sop)YACS::ENGINE::AbstractPoint
tryAsForkTer(BlocPoint *sop)YACS::ENGINE::AbstractPoint
tryAsLink(BlocPoint *sop)YACS::ENGINE::AbstractPoint
TryAsNotSimpleCase(AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)YACS::ENGINE::AbstractPointstatic
UnRewire(std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)YACS::ENGINE::AbstractPointstatic
~AbstractPoint()YACS::ENGINE::AbstractPointvirtual
~BlocPoint()YACS::ENGINE::BlocPointvirtual
~LinkedBlocPoint()YACS::ENGINE::LinkedBlocPointvirtual
