YACS::ENGINE::LinkedBlocPoint Class Reference
#include <LinkedBlocPoint.hxx>
Inheritance diagram for YACS::ENGINE::LinkedBlocPoint:
Collaboration diagram for YACS::ENGINE::LinkedBlocPoint:
 LinkedBlocPoint ()=default
 LinkedBlocPoint (const std::list< AbstractPoint * > &nodes, AbstractPoint *father)
AbstractPoint * deepCopy (AbstractPoint *father) const override
Node * getFirstNode () override
Node * getLastNode () override
void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
std::string getRepr () const
void accept (PointVisitor *pv) override
AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes) override
virtual ~LinkedBlocPoint ()
- Public Member Functions inherited from YACS::ENGINE::BlocPoint
void deepCopyFrom (const BlocPoint &other)
AbstractPoint * findPointWithNode (Node *node)
AbstractPoint * getNodeAfter (Node *node)
AbstractPoint * getNodeB4 (Node *node)
bool contains (Node *node) const override
bool anyOf (const std::set< Node * > &nodes) const override
int getNumberOfNodes () const
const std::list< AbstractPoint * > & getListOfPoints () const
virtual ~BlocPoint ()
bool internalContinueForSimplify () const
bool presenceOfNonSimpleCase () const
AbstractPoint * getUnique ()
const AbstractPoint * getUnique () const
AbstractPoint * getUniqueAndReleaseIt ()
- Public Member Functions inherited from YACS::ENGINE::AbstractPoint
 AbstractPoint ()=default
 AbstractPoint (AbstractPoint *father)
AbstractPoint * getFather () const
AbstractPoint * getGodFather ()
bool amIGod ()
void setFather (AbstractPoint *father)
bool isBegin ()
bool isLast ()
bool isSimplyLinkedBeforeAfter (BlocPoint *sop)
bool isSimplyLinkedAfterNullBefore (BlocPoint *sop)
bool isSimplyLinkedBeforeNullAfter (BlocPoint *sop)
bool isNullBeforeNullAfter (BlocPoint *sop)
LinkedBlocPoint * tryAsLink (BlocPoint *sop)
ForkBlocPoint * tryAsFork (BlocPoint *sop)
ForkBlocPoint * tryAsForkBis (BlocPoint *sop)
ForkBlocPoint * tryAsForkTer (BlocPoint *sop)
ForkBlocPoint * tryAsForkQuatro (BlocPoint *sop)
virtual AbstractPoint * deepCopy (AbstractPoint *father) const =0
virtual Node * getFirstNode ()=0
virtual Node * getLastNode ()=0
virtual AbstractPoint * findPointWithNode (Node *node)=0
virtual bool contains (Node *node) const =0
virtual bool anyOf (const std::set< Node * > &nodes) const =0
virtual int getNumberOfNodes () const =0
virtual void partitionRegardingDPL (const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const =0
virtual std::string getRepr () const =0
virtual void accept (PointVisitor *pv)=0
virtual AbstractPoint * expandNonSimpleCaseOn (NotSimpleCasePoint *pathologicalPt, const std::set< Node * > &uncatchedNodes)=0
virtual ~AbstractPoint ()
bool isSimplyLinkedAfter (BlocPoint *sop, Node *node)
bool isSimplyLinkedBefore (BlocPoint *sop, Node *node)
- Static Public Member Functions inherited from YACS::ENGINE::AbstractPoint
static void TryAsNotSimpleCase (AbstractPoint *father, const std::vector< AbstractPoint * > &ptsToKill, std::list< AbstractPoint * > &nodes, bool &somethingDone)
static bool IsGatherB4Ext (Node *node)
static bool IsSimplyLinkedAfterExt (Node *node)
static bool IsScatterAfterExt (Node *node)
static bool IsSimplyLinkedBeforeExt (Node *node)
static bool IsNoLinksBefore (Node *node)
static bool IsNoLinksAfter (Node *node)
static Node * GetNodeB4 (Node *node)
static Node * GetNodeAfter (Node *node)
static AbstractPoint * GetDirectSonOf (AbstractPoint *refFather, AbstractPoint *sonOrLittleSon)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< OutGate * > &outgs, AbstractPoint *&ret)
static bool IsCommonDirectSonOf (AbstractPoint *refFather, const std::list< InGate * > &ings, AbstractPoint *&ret)
static void FeedData (AbstractPoint *ptToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void FeedData (const std::list< AbstractPoint * > &ptsToBeRewired, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void Rewire (const std::vector< AbstractPoint * > &ptsToKill, std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
static void UnRewire (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > &m)
static void Display (std::map< std::string, std::tuple< ElementaryPoint *, Node *, std::shared_ptr< Bloc > > > *m)
- Protected Member Functions inherited from YACS::ENGINE::BlocPoint
void getOutPoint (AbstractPoint *node)
- Protected Attributes inherited from YACS::ENGINE::BlocPoint
std::list< AbstractPoint * > _nodes
- Protected Attributes inherited from YACS::ENGINE::AbstractPoint
AbstractPoint * _father = nullptr
Definition at line 32 of file LinkedBlocPoint.hxx.
◆ LinkedBlocPoint() [1/2]
YACS::ENGINE::LinkedBlocPoint::LinkedBlocPoint ( )
default
◆ LinkedBlocPoint() [2/2]
LinkedBlocPoint::LinkedBlocPoint ( const std::list< AbstractPoint * > &  nodes,
AbstractPoint *  father
Definition at line 34 of file LinkedBlocPoint.cxx.
34 :BlocPoint(nodes,father)
35{
36}
◆ ~LinkedBlocPoint()
LinkedBlocPoint::~LinkedBlocPoint ( )
Definition at line 136 of file LinkedBlocPoint.cxx.
137{
138}
◆ accept()
void LinkedBlocPoint::accept ( PointVisitor *  pv)
overridevirtual
Implements YACS::ENGINE::AbstractPoint.
Definition at line 128 of file LinkedBlocPoint.cxx.
129{
130 pv->beginLinkedBlocPoint(this);
131 for(auto it:_nodes)
132 it->accept(pv);
133 pv->endLinkedBlocPoint(this);
134}
Definition: BlocPoint.hxx:35
virtual void beginLinkedBlocPoint(LinkedBlocPoint *pt)=0
virtual void endLinkedBlocPoint(LinkedBlocPoint *pt)=0
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::PointVisitor::beginLinkedBlocPoint(), and YACS::ENGINE::PointVisitor::endLinkedBlocPoint().
◆ deepCopy()
AbstractPoint * LinkedBlocPoint::deepCopy ( AbstractPoint *  father) const
overridevirtual
Definition at line 38 of file LinkedBlocPoint.cxx.
39{
41 ret->deepCopyFrom(*this);
42 ret->setFather(father);
43 return ret;
44}
References YACS::ENGINE::BlocPoint::deepCopyFrom(), and YACS::ENGINE::AbstractPoint::setFather().
Referenced by expandNonSimpleCaseOn().
◆ expandNonSimpleCaseOn()
AbstractPoint * LinkedBlocPoint::expandNonSimpleCaseOn ( NotSimpleCasePoint *  pathologicalPt,
const std::set< Node * > &  uncatchedNodes
overridevirtual
Definition at line 99 of file LinkedBlocPoint.cxx.
100{
101 if(anyOf(uncatchedNodes))
102 {
103 for(auto& it : _nodes)
104 {
105 AbstractPoint *ret(it->expandNonSimpleCaseOn(pathologicalPt,uncatchedNodes));
106 if(ret!=it)
107 {
108 ret->setFather(this);
109 auto oldIt(it);
110 it = ret;
111 delete oldIt;
112 }
113 }
114 return this;
115 }
116 else
117 {
118 std::list<AbstractPoint *> l;
119 AbstractPoint *p0(this->deepCopy(getFather())),*p1(pathologicalPt->getUnique()->deepCopy(getFather()));
120 l.push_back(p0);
121 l.push_back(p1);
123 p0->setFather(ret); p1->setFather(ret);
124 return ret;
125 }
126}
virtual AbstractPoint * deepCopy(AbstractPoint *father) const =0
AbstractPoint * getFather() const
AbstractPoint * getUnique()
Definition: BlocPoint.cxx:111
bool anyOf(const std::set< Node * > &nodes) const override
Definition: BlocPoint.cxx:101
AbstractPoint * deepCopy(AbstractPoint *father) const override
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::BlocPoint::anyOf(), YACS::ENGINE::AbstractPoint::deepCopy(), deepCopy(), YACS::ENGINE::AbstractPoint::getFather(), YACS::ENGINE::BlocPoint::getUnique(), testCppPluginInvokation::l, and YACS::ENGINE::AbstractPoint::setFather().
◆ getFirstNode()
Node * LinkedBlocPoint::getFirstNode ( )
overridevirtual
Definition at line 46 of file LinkedBlocPoint.cxx.
47{
48 if(_nodes.empty())
49 throw Exception("LinkedBlocPoint::getFirstNode : error no branches !");
50 return _nodes.front()->getFirstNode();
51}
References YACS::ENGINE::BlocPoint::_nodes.
◆ getLastNode()
Node * LinkedBlocPoint::getLastNode ( )
overridevirtual
Definition at line 53 of file LinkedBlocPoint.cxx.
54{
55 if(_nodes.empty())
56 throw Exception("LinkedBlocPoint::getFirstNode : error no branches !");
57 return _nodes.back()->getLastNode();
58}
◆ getMaxLevelOfParallelism()
int LinkedBlocPoint::getMaxLevelOfParallelism ( ) const
Definition at line 60 of file LinkedBlocPoint.cxx.
61{
62 int ret(0);
63 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
64 ret=std::max(ret,(*it)->getMaxLevelOfParallelism());
65 return ret;
66}
◆ getRepr()
std::string LinkedBlocPoint::getRepr ( ) const
Definition at line 85 of file LinkedBlocPoint.cxx.
86{
87 std::size_t sz(_nodes.size()),ii(0);
88 std::string ret("(");
89 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++,ii++)
90 {
91 ret+=(*it)->getRepr();
92 if(ii!=sz-1)
93 ret+="+";
94 }
95 ret+=")";
96 return ret;
97}
◆ getWeightRegardingDPL()
void LinkedBlocPoint::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 68 of file LinkedBlocPoint.cxx.
69{
70 ComplexWeight localWeight;
71 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
72 {
73 (*it)->getWeightRegardingDPL(&localWeight);
74 weight->addWeight(&localWeight);
75 localWeight.setToZero();
76 }
77}
void addWeight(const ComplexWeight *other)
References YACS::ENGINE::BlocPoint::_nodes, YACS::ENGINE::ComplexWeight::addWeight(), and YACS::ENGINE::ComplexWeight::setToZero().
◆ partitionRegardingDPL()
void LinkedBlocPoint::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 79 of file LinkedBlocPoint.cxx.
80{
81 for(std::list<AbstractPoint *>::const_iterator it=_nodes.begin();it!=_nodes.end();it++)
82 (*it)->partitionRegardingDPL(pd,zeMap);
83}
