ComplexWeight.cxx
20
21#include "ComplexWeight.hxx"
23#include "Exception.hxx"
24
25using namespace YACS::ENGINE;
26
27#ifdef WIN32
28#include <algorithm>
29#endif
30
31ComplexWeight::ComplexWeight()
32{
33 setToZero();
34}
35
36ComplexWeight::ComplexWeight(double elementaryWeight, double loopWeight, int nbCoresByIteration): _elementaryWeight(elementaryWeight), _bootWeight(false)
37{
38 _loopWeight.push_back(std::pair<double,int>(loopWeight,nbCoresByIteration));
39}
40
42{
43 if(_loopWeight.size()!=1)
44 throw Exception("ComplexWeight::getSimpleLoopWeight : can not get loop weight. Node contain multiple loop weights!");
45 return (*(_loopWeight.begin())).first;
46}
47
48double ComplexWeight::calculateTotalLength(int nbOfCoresAllocated) const
49{
50 if (isDefaultValue())
51 throw Exception("ComplexWeight::calculateTotalLength : can not calculate total weight with default value!");
52 double totalWeight(0);
54 totalWeight+=_elementaryWeight;
55 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
56 {
57 if ((*it).second>0)
58 totalWeight+=(*it).first*((double)(*it).second)/((double)nbOfCoresAllocated);
59 }
60 return totalWeight;
61}
62
63void ComplexWeight::setLoopWeight(double loopWeight, int nbCoresByIteration)
64{
65 bool found(false);
66 int i(0), rankFound(0);
67 _bootWeight=false;
68 for(std::vector<std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++,i++)
69 {
70 if ((*it).second==nbCoresByIteration)
71 {
72 found=true;
73 rankFound=i;
74 }
75
76 }
77 if (found)
78 _loopWeight.erase(_loopWeight.begin()+rankFound);
79 _loopWeight.push_back(std::pair<double,int>(loopWeight,nbCoresByIteration));
80 if ((_loopWeight.size()>1) && ((*(_loopWeight.begin())).second==-1))
81 _loopWeight.erase(_loopWeight.begin());
82}
83
85{
86 int nbCoresPerShotLoopMax(0);
87 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
88 if ((*it).second>nbCoresPerShotLoopMax)nbCoresPerShotLoopMax=(*it).second;
89 return nbCoresPerShotLoopMax;
90}
91
93{
95
96 double allLoopWeight1(0);
97 double allLoopWeight2(0);
98 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
99 {
100 if (((*it).first>0) && ((*it).second>0))
101 allLoopWeight1+=(*it).first * (*it).second;
102 }
103 for(std::vector< std::pair<double,int> >::const_iterator it=other._loopWeight.begin();it!=other._loopWeight.end();it++)
104 {
105 if (((*it).first>0) && ((*it).second>0))
106 allLoopWeight2+=(*it).first * (*it).second;
107 }
108 if (allLoopWeight2>allLoopWeight1)
110}
111
113{
114 bool found;
115 if ((!_bootWeight) && ((other->isUnsetLoopWeight() && this->isDefaultValueLoop()) || (this->isUnsetLoopWeight() && other->isDefaultValueLoop())))
116 this->unsetLoop();
117 else
118 {
119 for(std::vector< std::pair<double,int> >::const_iterator it=other->_loopWeight.begin();it!=other->_loopWeight.end();it++)
120 {
121 found=false;
122 for(std::vector< std::pair<double,int> >::iterator it2=_loopWeight.begin();it2!=_loopWeight.end();it2++)
123 {
124 if ((*it).second == (*it2).second)
125 {
126 if (((*it2).first>=0) && ((*it).first>=0))
127 this->setLoopWeight((*it2).first+(*it).first, (*it2).second);
128 else if ((*it).first>=0)
129 this->setLoopWeight((*it).first, (*it2).second);
130 found=true;
131 continue;
132 }
133 }
134 if ((!found) && ((*it).second!=-1))
135 this->setLoopWeight((*it).first, (*it).second);
136 }
137 if ((_loopWeight.size()>1) && ((*(_loopWeight.begin())).second==-1))
138 _loopWeight.erase(_loopWeight.begin());
139 }
140
141 if ((!_bootWeight) && ((other->isUnsetElementaryWeight() && this->isDefaultValueElementary()) || (this->isUnsetElementaryWeight() && other->isDefaultValueElementary())))
142 this->unsetElementary();
143 else
144 {
145 if (other->hasValidElementaryWeight())
146 {
149 else
151 }
152 }
153 if (!other->_bootWeight)
154 _bootWeight=false;
155}
156
157
158
159
bool isDefaultValueElementary() const
std::vector< std::pair< double, int > > _loopWeight
void addWeight(const ComplexWeight *other)
void setLoopWeight(double loopWeight, int nbCoresByIteration)
bool isUnsetElementaryWeight() const
double calculateTotalLength(int nbOfCoresAllocated) const
void max(ComplexWeight &other)
bool hasValidElementaryWeight() const
double getSimpleLoopWeight() const
