YACS::ENGINE::ComplexWeight Class Reference
#include <ComplexWeight.hxx>
Collaboration diagram for YACS::ENGINE::ComplexWeight:
 ComplexWeight ()
 ComplexWeight (double elementaryWeight, double loopWeight, int nbCoresByIteration)
 ComplexWeight (const ComplexWeight &other)
 ~ComplexWeight ()
std::vector< std::pair< double, int > > getLoopWeight () const
double getSimpleLoopWeight () const
double getElementaryWeight () const
double calculateTotalLength (int nbOfCoresAllocated) const
void setDefaultElementary ()
void setDefaultLoop ()
bool isDefaultValue () const
bool isUnsetLoopWeight () const
bool isUnsetElementaryWeight () const
bool hasValidLoopWeight () const
bool hasValidElementaryWeight () const
void setLoopWeight (double loopWeight, int nbCoresByIteration)
void setElementaryWeight (double elementaryWeight)
void setToZero ()
int getNbCoresConsoLoopMax () const
void max (ComplexWeight &other)
void addWeight (const ComplexWeight *other)
bool _bootWeight
std::vector< std::pair< double, int > > _loopWeight
double _elementaryWeight
void unsetLoop ()
void unsetElementary ()
bool isDefaultValueLoop () const
bool isDefaultValueElementary () const
Definition at line 38 of file ComplexWeight.hxx.
◆ ComplexWeight() [1/3]
ComplexWeight::ComplexWeight ( )
Definition at line 31 of file ComplexWeight.cxx.
32{
33 setToZero();
34}
References setToZero().
◆ ComplexWeight() [2/3]
ComplexWeight::ComplexWeight ( double  elementaryWeight,
double  loopWeight,
Definition at line 36 of file ComplexWeight.cxx.
36 : _elementaryWeight(elementaryWeight), _bootWeight(false)
37{
38 _loopWeight.push_back(std::pair<double,int>(loopWeight,nbCoresByIteration));
39}
References _loopWeight.
◆ ComplexWeight() [3/3]
YACS::ENGINE::ComplexWeight::ComplexWeight ( const ComplexWeight &  other)
Definition at line 43 of file ComplexWeight.hxx.
43{_bootWeight=other._bootWeight; _loopWeight=other._loopWeight; _elementaryWeight=other._elementaryWeight;}
References _bootWeight, _elementaryWeight, and _loopWeight.
◆ ~ComplexWeight()
YACS::ENGINE::ComplexWeight::~ComplexWeight ( )
Definition at line 44 of file ComplexWeight.hxx.
44{};
◆ addWeight()
void ComplexWeight::addWeight ( const ComplexWeight *  other)
Definition at line 112 of file ComplexWeight.cxx.
113{
114 bool found;
115 if ((!_bootWeight) && ((other->isUnsetLoopWeight() && this->isDefaultValueLoop()) || (this->isUnsetLoopWeight() && other->isDefaultValueLoop())))
116 this->unsetLoop();
117 else
118 {
119 for(std::vector< std::pair<double,int> >::const_iterator it=other->_loopWeight.begin();it!=other->_loopWeight.end();it++)
120 {
121 found=false;
122 for(std::vector< std::pair<double,int> >::iterator it2=_loopWeight.begin();it2!=_loopWeight.end();it2++)
123 {
124 if ((*it).second == (*it2).second)
125 {
126 if (((*it2).first>=0) && ((*it).first>=0))
127 this->setLoopWeight((*it2).first+(*it).first, (*it2).second);
128 else if ((*it).first>=0)
129 this->setLoopWeight((*it).first, (*it2).second);
130 found=true;
131 continue;
132 }
133 }
134 if ((!found) && ((*it).second!=-1))
135 this->setLoopWeight((*it).first, (*it).second);
136 }
137 if ((_loopWeight.size()>1) && ((*(_loopWeight.begin())).second==-1))
138 _loopWeight.erase(_loopWeight.begin());
139 }
140
141 if ((!_bootWeight) && ((other->isUnsetElementaryWeight() && this->isDefaultValueElementary()) || (this->isUnsetElementaryWeight() && other->isDefaultValueElementary())))
142 this->unsetElementary();
143 else
144 {
145 if (other->hasValidElementaryWeight())
146 {
149 else
151 }
152 }
153 if (!other->_bootWeight)
154 _bootWeight=false;
155}
bool isDefaultValueElementary() const
void setLoopWeight(double loopWeight, int nbCoresByIteration)
bool isUnsetElementaryWeight() const
bool hasValidElementaryWeight() const
References _bootWeight, _elementaryWeight, _loopWeight, hasValidElementaryWeight(), isDefaultValueElementary(), isDefaultValueLoop(), isUnsetElementaryWeight(), isUnsetLoopWeight(), setLoopWeight(), unsetElementary(), and unsetLoop().
Referenced by YACS::ENGINE::DynParaLoop::getWeightRegardingDPL(), YACS::ENGINE::ElementaryNode::getWeightRegardingDPL(), YACS::ENGINE::ForkBlocPoint::getWeightRegardingDPL(), YACS::ENGINE::LinkedBlocPoint::getWeightRegardingDPL(), and YACS::ENGINE::NotSimpleCasePoint::getWeightRegardingDPL().
◆ calculateTotalLength()
double ComplexWeight::calculateTotalLength ( int  nbOfCoresAllocated) const
Definition at line 48 of file ComplexWeight.cxx.
49{
50 if (isDefaultValue())
51 throw Exception("ComplexWeight::calculateTotalLength : can not calculate total weight with default value!");
52 double totalWeight(0);
54 totalWeight+=_elementaryWeight;
55 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
56 {
57 if ((*it).second>0)
58 totalWeight+=(*it).first*((double)(*it).second)/((double)nbOfCoresAllocated);
59 }
60 return totalWeight;
61}
References _elementaryWeight, _loopWeight, hasValidElementaryWeight(), and isDefaultValue().
◆ getElementaryWeight()
double YACS::ENGINE::ComplexWeight::getElementaryWeight ( ) const
◆ getLoopWeight()
std::vector< std::pair< double, int > > YACS::ENGINE::ComplexWeight::getLoopWeight ( ) const
Definition at line 45 of file ComplexWeight.hxx.
45{return _loopWeight;}
◆ getNbCoresConsoLoopMax()
int ComplexWeight::getNbCoresConsoLoopMax ( ) const
Definition at line 84 of file ComplexWeight.cxx.
85{
86 int nbCoresPerShotLoopMax(0);
87 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
88 if ((*it).second>nbCoresPerShotLoopMax)nbCoresPerShotLoopMax=(*it).second;
89 return nbCoresPerShotLoopMax;
90}
◆ getSimpleLoopWeight()
double ComplexWeight::getSimpleLoopWeight ( ) const
Definition at line 41 of file ComplexWeight.cxx.
42{
43 if(_loopWeight.size()!=1)
44 throw Exception("ComplexWeight::getSimpleLoopWeight : can not get loop weight. Node contain multiple loop weights!");
45 return (*(_loopWeight.begin())).first;
46}
Referenced by YACS::ENGINE::VisitorSaveSchema::visitForEachLoop(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoopDyn(), and YACS::ENGINE::VisitorSaveSchema::visitOptimizerLoop().
◆ hasValidElementaryWeight()
bool YACS::ENGINE::ComplexWeight::hasValidElementaryWeight ( ) const
Definition at line 55 of file ComplexWeight.hxx.
55{ return (_elementaryWeight>=0);}
Referenced by addWeight(), and calculateTotalLength().
◆ hasValidLoopWeight()
bool YACS::ENGINE::ComplexWeight::hasValidLoopWeight ( ) const
Definition at line 54 of file ComplexWeight.hxx.
54{ return (((*(_loopWeight.begin())).first>0) && ((*(_loopWeight.begin())).second!=-1));}
◆ isDefaultValue()
bool YACS::ENGINE::ComplexWeight::isDefaultValue ( ) const
Definition at line 51 of file ComplexWeight.hxx.
51{ return ((isDefaultValueElementary()) && (isDefaultValueLoop()));}
Referenced by calculateTotalLength().
◆ isDefaultValueElementary()
bool YACS::ENGINE::ComplexWeight::isDefaultValueElementary ( ) const
inlineprivate
Definition at line 71 of file ComplexWeight.hxx.
71{return (_elementaryWeight<0);}
Referenced by addWeight().
◆ isDefaultValueLoop()
bool YACS::ENGINE::ComplexWeight::isDefaultValueLoop ( ) const
inlineprivate
Definition at line 70 of file ComplexWeight.hxx.
70{return ((*(_loopWeight.begin())).second==-1);}
◆ isUnsetElementaryWeight()
bool YACS::ENGINE::ComplexWeight::isUnsetElementaryWeight ( ) const
Definition at line 53 of file ComplexWeight.hxx.
53{return (_elementaryWeight==0);}
◆ isUnsetLoopWeight()
bool YACS::ENGINE::ComplexWeight::isUnsetLoopWeight ( ) const
Definition at line 52 of file ComplexWeight.hxx.
52{return ((*(_loopWeight.begin())).second==0);}
◆ max()
void ComplexWeight::max ( ComplexWeight &  other)
Definition at line 92 of file ComplexWeight.cxx.
93{
95
96 double allLoopWeight1(0);
97 double allLoopWeight2(0);
98 for(std::vector< std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++)
99 {
100 if (((*it).first>0) && ((*it).second>0))
101 allLoopWeight1+=(*it).first * (*it).second;
102 }
103 for(std::vector< std::pair<double,int> >::const_iterator it=other._loopWeight.begin();it!=other._loopWeight.end();it++)
104 {
105 if (((*it).first>0) && ((*it).second>0))
106 allLoopWeight2+=(*it).first * (*it).second;
107 }
108 if (allLoopWeight2>allLoopWeight1)
110}
References _elementaryWeight, and _loopWeight.
Referenced by YACS::ENGINE::Switch::getWeightRegardingDPL().
◆ setDefaultElementary()
void YACS::ENGINE::ComplexWeight::setDefaultElementary ( )
Definition at line 49 of file ComplexWeight.hxx.
49{setToZero(); setLoopWeight(0.,0);}
Referenced by YACS::ENGINE::ElementaryNode::ElementaryNode().
◆ setDefaultLoop()
void YACS::ENGINE::ComplexWeight::setDefaultLoop ( )
Definition at line 50 of file ComplexWeight.hxx.
void setElementaryWeight(double elementaryWeight)
Referenced by YACS::ENGINE::DynParaLoop::DynParaLoop().
◆ setElementaryWeight()
void YACS::ENGINE::ComplexWeight::setElementaryWeight ( double  elementaryWeight)
Definition at line 57 of file ComplexWeight.hxx.
57{_bootWeight=false; _elementaryWeight=elementaryWeight;}
Referenced by YACS::ENGINE::ElementaryNode::setWeight().
◆ setLoopWeight()
void ComplexWeight::setLoopWeight ( double  loopWeight,
Definition at line 63 of file ComplexWeight.cxx.
64{
65 bool found(false);
66 int i(0), rankFound(0);
67 _bootWeight=false;
68 for(std::vector<std::pair<double,int> >::const_iterator it=_loopWeight.begin();it!=_loopWeight.end();it++,i++)
69 {
70 if ((*it).second==nbCoresByIteration)
71 {
72 found=true;
73 rankFound=i;
74 }
75
76 }
77 if (found)
78 _loopWeight.erase(_loopWeight.begin()+rankFound);
79 _loopWeight.push_back(std::pair<double,int>(loopWeight,nbCoresByIteration));
80 if ((_loopWeight.size()>1) && ((*(_loopWeight.begin())).second==-1))
81 _loopWeight.erase(_loopWeight.begin());
82}
References _bootWeight, _loopWeight, and yacsorb.CORBAEngineTest::i.
Referenced by addWeight(), and YACS::ENGINE::DynParaLoop::getWeight().
◆ setToZero()
◆ unsetElementary()
void YACS::ENGINE::ComplexWeight::unsetElementary ( )
inlineprivate
Definition at line 69 of file ComplexWeight.hxx.
◆ unsetLoop()
void YACS::ENGINE::ComplexWeight::unsetLoop ( )
inlineprivate
Definition at line 68 of file ComplexWeight.hxx.
68{_loopWeight.clear(); _loopWeight.push_back(std::pair<double,int>(-1.,-1));}
◆ _bootWeight
bool YACS::ENGINE::ComplexWeight::_bootWeight
Definition at line 63 of file ComplexWeight.hxx.
Referenced by addWeight(), ComplexWeight(), and setLoopWeight().
◆ _elementaryWeight
double YACS::ENGINE::ComplexWeight::_elementaryWeight
Definition at line 66 of file ComplexWeight.hxx.
Referenced by addWeight(), calculateTotalLength(), ComplexWeight(), and max().
◆ _loopWeight
std::vector<std::pair<double,int> > YACS::ENGINE::ComplexWeight::_loopWeight
