DynParaLoop.hxx
20#ifndef __DYNPARALOOP_HXX__
21#define __DYNPARALOOP_HXX__
24#include "ComposedNode.hxx"
25#include "AnyInputPort.hxx"
26#include "AnyOutputPort.hxx"
27#include "OutputPort.hxx"
28#include "NbBranches.hxx"
30#include <memory>
31
32namespace YACS
33{
34 namespace ENGINE
35 {
41 {
42 protected:
43 typedef enum
44 {
45 INIT_NODE = 5,
46 WORK_NODE = 6,
47 FINALIZE_NODE = 7
48 } TypeOfNode;
49 protected:
54 std::vector<int> _execIds;
55 //NbBranches _nbOfBranches2;
56 std::unique_ptr<NbBranchesAbstract> _nbOfBranches;
58 std::vector<Node *> _execNodes;
59 std::vector<Node *> _execInitNodes;
60 std::vector<Node *> _execFinalizeNodes;
66 protected:
67 static const char NAME_OF_SPLITTED_SEQ_OUT[];
68 static const char OLD_NAME_OF_SPLITTED_SEQ_OUT[];
69 protected:
70 DynParaLoop(const std::string& name, TypeCode *typeOfDataSplitted, std::unique_ptr<NbBranchesAbstract>&& branchManager);
71 virtual ~DynParaLoop();
72 DynParaLoop(const DynParaLoop& other, ComposedNode *father, bool editionOnly);
73 public:
74 Node *edRemoveNode();
75 Node *edRemoveInitNode();
76 Node *edRemoveFinalizeNode();
77 //Node* DISOWNnode is a SWIG notation to indicate that the ownership of the node is transfered to C++
78 Node *edSetNode(Node *DISOWNnode);
79 Node *edSetInitNode(Node *DISOWNnode);
80 Node *edSetFinalizeNode(Node *DISOWNnode);
81 virtual bool edAddDFLink(OutPort *start, InPort *end) ;
82 void init(bool start=true);
83 InputPort *edGetNbOfBranchesPort() { return _nbOfBranches->getPort(); }
84 int getNumberOfInputPorts() const;
85 int getNumberOfOutputPorts() const;
86 unsigned getNumberOfEltsConsumed() const { return _nbOfEltConsumed; }
87 int getBranchIDOfNode(Node *node) const;
88 std::list<OutputPort *> getSetOfOutputPort() const;
89 std::list<OutputPort *> getLocalOutputPorts() const;
90 OutputPort *edGetSamplePort() { return &_splittedPort; }
91 OutPort *getOutPort(const std::string& name) const ;
92 InputPort *getInputPort(const std::string& name) const ;
93 OutputPort *getOutputPort(const std::string& name) const ;
95 bool isPlacementPredictableB4Run() const;
96 void edRemoveChild(Node *node) ;
97 bool isLoop() const override { return true; }
98 virtual bool edAddChild(Node *DISOWNnode) ;
99 std::list<Node *> edGetDirectDescendants() const;
100 std::list<InputPort *> getSetOfInputPort() const;
101 std::list<InputPort *> getLocalInputPorts() const;
102 unsigned getNumberOfBranchesCreatedDyn() const ;
103 Node *getChildByShortName(const std::string& name) const ;
104 Node *getChildByNameExec(const std::string& name, unsigned id) const ;
105 std::vector<Node *> getNodes() const { return _execNodes; } // need to use in GUI part for adding observers for clone nodes
106 ComplexWeight * getWeight();
107 void setWeight(double loopWeight);
108 void getWeightRegardingDPL(ComplexWeight *weight) {weight->addWeight(getWeight());}
109 bool isMultiplicitySpecified(unsigned& value) const;
110 void forceMultiplicity(unsigned value);
111 virtual void checkBasicConsistency() const ;
112 virtual std::string getErrorReport();
113 void accept(Visitor *visitor);
114 Node * getInitNode();
115 Node * getExecNode();
116 Node * getFinalizeNode();
117 int getMaxLevelOfParallelism() const;
118 void partitionRegardingDPL(const PartDefinition *pd, std::map<ComposedNode *, YACS::BASES::AutoRefCnt<PartDefinition> >& zeMap);
119 virtual void cleanDynGraph();
120 protected:
121 void buildDelegateOf(InPort * & port, OutPort *initialStart, const std::list<ComposedNode *>& pointsOfView);
122 void buildDelegateOf(std::pair<OutPort *, OutPort *>& port, InPort *finalTarget, const std::list<ComposedNode *>& pointsOfView);
123 void checkCFLinks(const std::list<OutPort *>& starts, InputPort *end, unsigned char& alreadyFed, bool direction, LinkInfo& info) const;
124 void checkControlDependancy(OutPort *start, InPort *end, bool cross,
125 std::map < ComposedNode *, std::list < OutPort * >, SortHierarc >& fw,
126 std::vector<OutPort *>& fwCross,
127 std::map< ComposedNode *, std::list < OutPort *>, SortHierarc >& bw,
128 LinkInfo& info) const;
129 virtual void checkLinkPossibility(OutPort *start, const std::list<ComposedNode *>& pointsOfViewStart,
130 InPort *end, const std::list<ComposedNode *>& pointsOfViewEnd) ;
131 protected:
132 void prepareInputsFromOutOfScope(int branchNb);
133 void putValueOnBranch(Any *val, unsigned branchId, bool first);
134 TypeOfNode getIdentityOfNotifyerNode(const Node *node, unsigned& id);
135 InputPort *getDynInputPortByAbsName(int branchNb, const std::string& name, bool initNodeAdmitted);
136 virtual void forwardExecStateToOriginalBody(Node *execNode);
137 virtual YACS::Event updateStateOnFailedEventFrom(Node *node, const Executor *execInst);
138 std::vector<Node *> cloneAndPlaceNodesCoherently(const std::vector<Node *> & origNodes);
139 Node * checkConsistencyAndSetNode(Node* &nodeToReplace, Node* DISOWNnode);
140 Node * removeNode(Node* &nodeToRemove);
141 virtual void shutdown(int level);
142 };
143 }
144}
145
146#endif
#define YACSLIBENGINE_EXPORT
Definition: Any.hxx:79
void addWeight(const ComplexWeight *other)
Base class for dynamically (fully or semifully) built graphs.
Definition: DynParaLoop.hxx:41
Definition: DynParaLoop.hxx:97
std::unique_ptr< NbBranchesAbstract > _nbOfBranches
Definition: DynParaLoop.hxx:56
InputPort * edGetNbOfBranchesPort()
Definition: DynParaLoop.hxx:83
std::vector< Node * > _execNodes
Definition: DynParaLoop.hxx:58
std::vector< int > _execIds
Definition: DynParaLoop.hxx:54
OutputPort * edGetSamplePort()
Definition: DynParaLoop.hxx:90
std::vector< Node * > getNodes() const
std::vector< Node * > _execFinalizeNodes
Definition: DynParaLoop.hxx:60
Definition: DynParaLoop.hxx:86
AnyOutputPort _splittedPort
Definition: DynParaLoop.hxx:57
std::vector< Node * > _execInitNodes
Definition: DynParaLoop.hxx:59
Threaded Executor.
Definition: Executor.hxx:63
Base class for Input Ports.
Definition: InputPort.hxx:44
Class that deal with list of semantics links for high level analysis.
Definition: LinkInfo.hxx:83
Base class for all nodes.
Definition: Node.hxx:70
Definition: TypeCode.hxx:68
Event
Definition: define.hxx:56
