YACS::ENGINE::TypeCode Class Reference
Base class for all type objects. More...
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCode:
Collaboration diagram for YACS::ENGINE::TypeCode:
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual const TypeCode * contentType () const
virtual int isA (const char *repositoryId) const
virtual int isA (const TypeCode *tc) const
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
virtual unsigned getSizeInByteOfAnyReprInSeq () const
virtual std::string getPrintStr () const
void incrRef () const
bool decrRef () const
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
const DynType _kind
unsigned int _cnt
Static Protected Attributes
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
All type objects should be a subclass of TypeCode. Some type objects, TypeCodeObjref for example, represent one individual type. Other type objects, such as TypeCodeSeq, are composite types (sequence, here)
See also
TypeCodeObjref
TypeCodeSeq
TypeCodeStruct
TypeCodeArray
Definition at line 67 of file TypeCode.hxx.
◆ TypeCode() [1/2]
TypeCode::TypeCode ( DynType  kind)
Definition at line 35 of file TypeCode.cxx.
35 :_kind(kind)
36{
37}
DynType kind() const
Definition: TypeCode.cxx:47
const DynType _kind
Definition: TypeCode.hxx:104
Referenced by clone().
◆ TypeCode() [2/2]
TypeCode::TypeCode ( const TypeCode &  tc)
Definition at line 39 of file TypeCode.cxx.
39 :_kind(tc._kind)
40{
41}
◆ ~TypeCode()
TypeCode::~TypeCode ( )
Definition at line 43 of file TypeCode.cxx.
44{
45}
◆ clone()
TypeCode * TypeCode::clone ( ) const
Reimplemented in YACS::ENGINE::TypeCodeObjref, YACS::ENGINE::TypeCodeSeq, YACS::ENGINE::TypeCodeArray, and YACS::ENGINE::TypeCodeStruct.
Definition at line 52 of file TypeCode.cxx.
53{
54 return new TypeCode(*this);
55}
TypeCode(DynType kind)
Definition: TypeCode.cxx:35
References TypeCode().
Referenced by YACS::HMI::SubjectProc::addSubjectDataType().
◆ contentType()
◆ destroyZippedAny()
◆ getKindRepr() [1/2]
const char * TypeCode::getKindRepr ( ) const
Definition at line 223 of file TypeCode.cxx.
224{
225 return KIND_STR_REPR[(int)_kind];
226}
static const char * KIND_STR_REPR[]
Definition: TypeCode.hxx:105
References _kind, and KIND_STR_REPR.
Referenced by YACS::ENGINE::InvalidExtractionException::InvalidExtractionException().
◆ getKindRepr() [2/2]
const char * TypeCode::getKindRepr ( DynType  kind)
Definition at line 201 of file TypeCode.cxx.
202{
203 return KIND_STR_REPR[(int)kind];
204}
References kind(), and KIND_STR_REPR.
◆ getOrBuildAnyFromZippedData()
AnyPtr TypeCode::getOrBuildAnyFromZippedData ( char *  data) const
◆ getPrintStr()
std::string TypeCode::getPrintStr ( ) const
Reimplemented in YACS::ENGINE::TypeCodeSeq.
Definition at line 140 of file TypeCode.cxx.
141{
142 return id();
143}
virtual const char * id() const
Definition: TypeCode.cxx:82
References id().
Referenced by YACS::ENGINE::TypeCodeSeq::getPrintStr().
◆ getSizeInByteOfAnyReprInSeq()
◆ id()
const char * TypeCode::id ( ) const
Definition at line 82 of file TypeCode.cxx.
83{
84 switch(_kind)
85 {
86 case Double:
87 return "double";
88 case Int:
89 return "int";
90 case String:
91 return "string";
92 case Bool:
93 return "bool";
94 default:
95 return "";
96 }
97}
References _kind, YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::Int, and YACS::ENGINE::String.
Referenced by YACS::ENGINE::RuntimeSALOME::adaptCorbaToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToPython(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToXml(), YACS::ENGINE::RuntimeSALOME::adaptCppToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCppToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCppToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCppToPython(), YACS::ENGINE::RuntimeSALOME::adaptCppToXml(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCorba(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCpp(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToPython(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToXml(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCorba(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCpp(), YACS::ENGINE::RuntimeSALOME::adaptPythonToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptPythonToPython(), YACS::ENGINE::RuntimeSALOME::adaptPythonToXml(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCorba(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCpp(), YACS::ENGINE::RuntimeSALOME::adaptXmlToPython(), YACS::ENGINE::RuntimeSALOME::adaptXmlToXml(), YACS::ENGINE::isAdaptableObjref< IMPLIN, IMPLOUT >::apply(), YACS::ENGINE::OutputDataStreamPort::edAddInputDataStreamPort(), getPrintStr(), YACS::ENGINE::TypeCodeObjref::isA(), YACS::ENGINE::TypeCodeStruct::isA(), YACS::ENGINE::TypeCodeObjref::isAdaptable(), YACS::ENGINE::TypeCodeStruct::isAdaptable(), YACS::ENGINE::TypeCodeObjref::isEquivalent(), name(), and shortName().
◆ interfaceTc() [1/2]
TypeCode * TypeCode::interfaceTc ( const char *  id,
const char *  name
Definition at line 229 of file TypeCode.cxx.
231{
233 return new TypeCodeObjref(id, name);
234};
static void checkValidName(const char *name)
Definition: TypeCode.cxx:190
Class for reference objects.
Definition: TypeCode.hxx:126
Definition: TypeCode.cxx:72
References checkValidName(), and name().
Referenced by YACS::ENGINE::Proc::createInterfaceTc(), YACS::ENGINE::Runtime::createInterfaceTc(), and YACS::ENGINE::RuntimeSALOME::createInterfaceTc().
◆ interfaceTc() [2/2]
const char *  name,
const std::list< TypeCodeObjref * > &  ltc
ltc: the list of base types
The name must be a valid one (throw Exception is not)
Definition at line 244 of file TypeCode.cxx.
247{
249 return new TypeCodeObjref(id, name,ltc);
250}
◆ isA() [1/2]
◆ isA() [2/2]
int TypeCode::isA ( const TypeCode *  tc) const
Definition at line 104 of file TypeCode.cxx.
105{
106 if(_kind == tc->kind()) return 1;
107 return 0;
108}
References _kind, and kind().
◆ isAdaptable()
int TypeCode::isAdaptable ( const TypeCode *  tc) const
this TypeCode is adaptable to tc if tc type can be converted to this type
tc: the TypeCode that must be convertible to this
Definition at line 116 of file TypeCode.cxx.
117{
118 switch(_kind)
119 {
120 case Double:
121 if (tc->kind() == Double) return 1;
122 if (tc->kind() == Int) return 1;
123 return 0;
124 case Int:
125 if (tc->kind() == Int) return 1;
126 return 0;
127 case String:
128 if (tc->kind() == String) return 1;
129 return 0;
130 case Bool:
131 if (tc->kind() == Bool) return 1;
132 if (tc->kind() == Int) return 1;
133 return 0;
134 default:
135 //objref, sequence, ...
136 return 0;
137 }
138}
References _kind, YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::Int, kind(), and YACS::ENGINE::String.
Referenced by YACS::ENGINE::RuntimeSALOME::adaptCorbaToXml(), YACS::ENGINE::RuntimeSALOME::adaptCppToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCppToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCorba(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToPython(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToXml(), YACS::ENGINE::RuntimeSALOME::adaptPythonToXml(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCpp(), YACS::ENGINE::RuntimeSALOME::adaptXmlToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptXmlToPython(), YACS::ENGINE::RuntimeSALOME::adaptXmlToXml(), YACS::ENGINE::OutputDataStreamPort::edAddInputDataStreamPort(), YACS::ENGINE::TypeCodeSeq::isAdaptable(), and YACS::ENGINE::TypeCodeArray::isAdaptable().
◆ isEquivalent()
int TypeCode::isEquivalent ( const TypeCode *  tc) const
this TypeCode is equivalent to tc if they have the same kind
tc: the TypeCode to compare
Definition at line 151 of file TypeCode.cxx.
152{
153 if(_kind == tc->kind()) return 1;
154 return 0;
155}
Referenced by YACS::ENGINE::TypeCodeSeq::isEquivalent(), and YACS::ENGINE::TypeCodeArray::isEquivalent().
◆ kind()
DynType TypeCode::kind ( ) const
Definition at line 47 of file TypeCode.cxx.
48{
49 return _kind;
50}
References _kind.
Referenced by YACS::ENGINE::RuntimeSALOME::adaptCorbaToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToPython(), YACS::ENGINE::RuntimeSALOME::adaptCppToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCppToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToPython(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCorba(), YACS::ENGINE::RuntimeSALOME::adaptPythonToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCpp(), YACS::ENGINE::isAdaptableObjref< IMPLIN, IMPLOUT >::apply(), YACS::ENGINE::AtomAny::AtomAny(), YACS::ENGINE::convertToYacsDouble< CPPImpl, void *, const TypeCode *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsInt< CPPImpl, void *, const TypeCode *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsDouble< NEUTRALImpl, YACS::ENGINE::Any *, void *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsInt< NEUTRALImpl, YACS::ENGINE::Any *, void *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsString< NEUTRALImpl, YACS::ENGINE::Any *, void *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsBool< NEUTRALImpl, YACS::ENGINE::Any *, void *, IMPLOUT, TOUT >::convert(), YACS::ENGINE::convertToYacsObjref< NEUTRALImpl, YACS::ENGINE::Any *, void *, IMPLOUT, TOUT >::convert(), YACS::HMI::ValueDelegate::createEditor(), YACS::ENGINE::RuntimeSALOME::createInputDataStreamPort(), YACS::ENGINE::RuntimeSALOME::createOutputDataStreamPort(), YACS::ENGINE::AtomAny::destroyReprAtPlace(), YACS::ENGINE::AnyInputPort::dump(), YACS::ENGINE::VisitorSaveSchema::dumpTypeCode(), YACS::ENGINE::OutputCorbaPort::getAnyOut(), YACS::ENGINE::ComposedAny::getBoolValue(), YACS::ENGINE::AtomAny::getBytesValue(), YACS::ENGINE::ComposedAny::getDoubleValue(), YACS::ENGINE::ComposedAny::getIntValue(), getKindRepr(), YACS::ENGINE::AtomAny::getStringValue(), YACS::ENGINE::ComposedAny::getStringValue(), isA(), YACS::ENGINE::TypeCodeSeq::isA(), YACS::ENGINE::TypeCodeArray::isA(), YACS::ENGINE::TypeCodeStruct::isA(), isAdaptable(), YACS::ENGINE::TypeCodeObjref::isAdaptable(), YACS::ENGINE::TypeCodeSeq::isAdaptable(), YACS::ENGINE::TypeCodeArray::isAdaptable(), YACS::ENGINE::TypeCodeStruct::isAdaptable(), isEquivalent(), YACS::ENGINE::TypeCodeObjref::isEquivalent(), YACS::ENGINE::TypeCodeSeq::isEquivalent(), YACS::ENGINE::TypeCodeArray::isEquivalent(), YACS::ENGINE::TypeCodeStruct::isEquivalent(), YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetOutPortValue::localExecute(), YACS::HMI::CommandSetInPortValue::localReverse(), YACS::HMI::CommandSetOutPortValue::localReverse(), YACS::HMI::TreeView::onCommitData(), YACS::ENGINE::AtomAny::operator==(), YACS::ENGINE::AtomAny::operator[](), YACS::structtypeParser::post(), YACS::ENGINE::SequenceAny::pushBack(), YACS::ENGINE::XmlCorba::put(), YACS::ENGINE::OutputStudyPort::putIOR(), YACS::ENGINE::AtomAny::putMyReprAtPlace(), YACS::ENGINE::AtomAny::putReprAtPlace(), YACS::ENGINE::Proc::setInPortValue(), YACS::ENGINE::AtomAny::takeInChargeStorageOf(), YACS::ENGINE::SequenceAny::takeInChargeStorageOf(), YACS::ENGINE::ArrayAny::takeInChargeStorageOf(), and YACS::ENGINE::AtomAny::~AtomAny().
◆ operator=()
TypeCode & YACS::ENGINE::TypeCode::operator= ( const TypeCode &  tc)
◆ putReprAtPlace()
void TypeCode::putReprAtPlace ( char *  pt,
const char *  val,
bool  deepCpy
◆ sequenceTc()
TypeCode * TypeCode::sequenceTc ( const char *  id,
const char *  name,
TypeCode *  content
Definition at line 254 of file TypeCode.cxx.
257{
258 std::string typname;
259 if(std::string(name)=="")
260 {
261 typname="seq"+std::string(content->name());
262 name=typname.c_str();
263 }
264 if(std::string(id)=="")
265 id=name;
266 return new TypeCodeSeq(id, name,content);
267};
Class for sequence objects.
Definition: TypeCode.hxx:160
References name().
Referenced by YACS::ENGINE::ForEachLoopGen::buildDelegateOf(), YACS::ENGINE::Proc::createSequenceTc(), YACS::ENGINE::Runtime::createSequenceTc(), and YACS::ENGINE::RuntimeSALOME::createSequenceTc().
◆ shortName()
const char * TypeCode::shortName ( ) const
◆ structTc()
TypeCode * TypeCode::structTc ( const char *  id,
const char *  name
Definition at line 269 of file TypeCode.cxx.
271{
272 return new TypeCodeStruct(id, name);
273};
Class for struct type.
Definition: TypeCode.hxx:228
References name().
Referenced by YACS::ENGINE::Proc::createStructTc(), YACS::ENGINE::Runtime::createStructTc(), and YACS::ENGINE::RuntimeSALOME::createStructTc().
◆ subContentType()
const TypeCode * TypeCode::subContentType ( int  lev) const
Definition at line 206 of file TypeCode.cxx.
207{
208 if(lev<0)
209 throw YACS::Exception("subContentType: Invalid input val !");
210 if(lev==0)
211 return this;
212 const TypeCode *ret(this);
213 for(int i=0;i<lev;i++)
214 {
215 const TypeCode *cand(ret->contentType());
216 if(!cand)
217 throw YACS::Exception("subContentType : Invalid input val 2 !");
218 ret=cand;
219 }
220 return ret;
221}
Definition: TypeCode.hxx:68
References contentType(), and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::ForEachLoopGen::buildDelegateOf().
◆ _kind
◆ KIND_STR_REPR
const char * TypeCode::KIND_STR_REPR ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
staticprotected
Definition at line 105 of file TypeCode.hxx.
Referenced by getKindRepr().
