YACS::ENGINE::TypeCodeArray Class Reference
Class for array objects. More...
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCodeArray:
Collaboration diagram for YACS::ENGINE::TypeCodeArray:
 TypeCodeArray (const char *repositoryId, const char *name, const TypeCode *content, unsigned staticLgth)
 Create an Array type with a given name, a given id and a given contained type. More...
TypeCode * clone () const
void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
void destroyZippedAny (char *data) const
AnyPtr getOrBuildAnyFromZippedData (char *data) const
const char * id () const
const char * name () const
const char * shortName () const
unsigned getStaticLgth () const
virtual const TypeCode * contentType () const
virtual int isA (const TypeCode *tc) const
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
unsigned getSizeInByteOfAnyReprInSeq () const
- Public Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual int isA (const char *repositoryId) const
virtual unsigned getSizeInByteOfAnyReprInSeq () const
virtual std::string getPrintStr () const
void incrRef () const
bool decrRef () const
virtual ~TypeCodeArray ()
 TypeCodeArray (const TypeCodeArray &tc)
- Protected Member Functions inherited from YACS::ENGINE::TypeCodeComposed
 TypeCodeComposed (const TypeCodeComposed &other)
 TypeCodeComposed (DynType kind, const char *repositoryId, const char *name)
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
const TypeCode * _content
const unsigned _staticLgth
- Static Public Member Functions inherited from YACS::ENGINE::TypeCode
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
- Protected Attributes inherited from YACS::ENGINE::TypeCodeComposed
const std::string _name
const std::string _repoId
std::string _shortName
const DynType _kind
unsigned int _cnt
- Static Protected Attributes inherited from YACS::ENGINE::TypeCode
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
Definition at line 192 of file TypeCode.hxx.
◆ TypeCodeArray() [1/2]
TypeCodeArray::TypeCodeArray ( const char *  repositoryId,
const char *  name,
const TypeCode *  content,
unsigned  staticLgth
repositoryId: the given id
name: the given name
content: the given contained TypeCode
staticLgth: the length
Definition at line 529 of file TypeCode.cxx.
532 : TypeCodeComposed(Array,repositoryId,name), _content(content),_staticLgth(staticLgth)
533{
534 _content->incrRef();
535}
const char * name() const
Definition: TypeCode.cxx:567
Definition: TypeCode.hxx:216
Definition: TypeCode.hxx:217
TypeCodeComposed(const TypeCodeComposed &other)
Definition: TypeCode.cxx:275
References _content, and YACS::ENGINE::RefCounter::incrRef().
Referenced by clone().
◆ ~TypeCodeArray()
TypeCodeArray::~TypeCodeArray ( )
Definition at line 537 of file TypeCode.cxx.
538{
539 ((TypeCode *)_content)->decrRef();
540}
Definition: TypeCode.hxx:68
References _content.
◆ TypeCodeArray() [2/2]
TypeCodeArray::TypeCodeArray ( const TypeCodeArray &  tc)
Definition at line 624 of file TypeCode.cxx.
624 :TypeCodeComposed(tc),
625 _content(tc._content),
627{
628 _content->incrRef();
629}
◆ clone()
TypeCode * TypeCodeArray::clone ( ) const
Reimplemented from YACS::ENGINE::TypeCode.
Definition at line 542 of file TypeCode.cxx.
543{
544 return new TypeCodeArray(*this);
545}
TypeCodeArray(const char *repositoryId, const char *name, const TypeCode *content, unsigned staticLgth)
Definition: TypeCode.cxx:529
References TypeCodeArray().
◆ contentType()
const TypeCode * TypeCodeArray::contentType ( ) const
Definition at line 581 of file TypeCode.cxx.
582{
583 return _content;
584}
Referenced by YACS::ENGINE::ArrayAny::destroyReprAtPlace(), isAdaptable(), and YACS::ENGINE::ArrayAny::putReprAtPlace().
◆ destroyZippedAny()
void TypeCodeArray::destroyZippedAny ( char *  data) const
Definition at line 552 of file TypeCode.cxx.
553{
555}
static void destroyReprAtPlace(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1034
References YACS::ENGINE::ArrayAny::destroyReprAtPlace().
◆ getOrBuildAnyFromZippedData()
AnyPtr TypeCodeArray::getOrBuildAnyFromZippedData ( char *  data) const
Definition at line 557 of file TypeCode.cxx.
558{
559 return ArrayAny::getOrBuildFromData(data,this);
560}
static AnyPtr getOrBuildFromData(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1042
References YACS::ENGINE::ArrayAny::getOrBuildFromData().
◆ getSizeInByteOfAnyReprInSeq()
unsigned TypeCodeArray::getSizeInByteOfAnyReprInSeq ( ) const
Definition at line 631 of file TypeCode.cxx.
632{
634}
virtual unsigned getSizeInByteOfAnyReprInSeq() const
Definition: TypeCode.cxx:157
References _content, _staticLgth, and YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq().
◆ getStaticLgth()
unsigned TypeCodeArray::getStaticLgth ( ) const
◆ id()
const char * TypeCodeArray::id ( ) const
Definition at line 562 of file TypeCode.cxx.
563{
564 return _repoId.c_str();
565}
Definition: TypeCode.hxx:115
References YACS::ENGINE::TypeCodeComposed::_repoId.
◆ isA()
int TypeCodeArray::isA ( const TypeCode *  tc) const
Definition at line 586 of file TypeCode.cxx.
587{
588 if(_kind == tc->kind())
589 if(_content->isA(tc->contentType()))
590 {
591 const TypeCodeArray *tcC=dynamic_cast<const TypeCodeArray *>(tc);
592 if(tcC)
593 return tcC->getStaticLgth()==_staticLgth;
594 return 0;
595 }
596 return 0;
597}
Definition: TypeCode.hxx:193
unsigned getStaticLgth() const
Definition: TypeCode.cxx:576
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:174
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:99
DynType kind() const
Definition: TypeCode.cxx:47
const DynType _kind
Definition: TypeCode.hxx:104
References _content, YACS::ENGINE::TypeCode::_kind, _staticLgth, YACS::ENGINE::TypeCode::contentType(), getStaticLgth(), YACS::ENGINE::TypeCode::isA(), and YACS::ENGINE::TypeCode::kind().
◆ isAdaptable()
int TypeCodeArray::isAdaptable ( const TypeCode *  tc) const
tc: the given TypeCode
1 if true, 0 if false
Definition at line 604 of file TypeCode.cxx.
605{
606 if(_kind == tc->kind())
607 return contentType()->isAdaptable(tc->contentType());
608 return 0;
609}
Definition: TypeCode.cxx:581
virtual int isAdaptable(const TypeCode *tc) const
Definition: TypeCode.cxx:116
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::contentType(), contentType(), YACS::ENGINE::TypeCode::isAdaptable(), and YACS::ENGINE::TypeCode::kind().
◆ isEquivalent()
int TypeCodeArray::isEquivalent ( const TypeCode *  tc) const
this TypeCode is equivalent to tc if they have the same kind
tc: the TypeCode to compare
Definition at line 617 of file TypeCode.cxx.
618{
619 if(_kind == tc->kind())
620 return _content->isEquivalent(tc->contentType());
621 return 0;
622}
virtual int isEquivalent(const TypeCode *tc) const
Definition: TypeCode.cxx:151
References _content, YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::isEquivalent(), and YACS::ENGINE::TypeCode::kind().
const char * TypeCodeArray::name ( ) const
Definition at line 567 of file TypeCode.cxx.
568{
569 return _name.c_str();
570}
References YACS::ENGINE::TypeCodeComposed::_name.
◆ putReprAtPlace()
void TypeCodeArray::putReprAtPlace ( char *  pt,
const char *  val,
bool  deepCpy
Definition at line 547 of file TypeCode.cxx.
548{
549 ArrayAny::putReprAtPlace(pt,val,this,deepCpy);
550}
static void putReprAtPlace(char *data, const char *src, const TypeCodeArray *type, bool deepCpy)
Definition: Any.cxx:1026
References YACS::ENGINE::ArrayAny::putReprAtPlace().
◆ shortName()
const char * TypeCodeArray::shortName ( ) const
Definition at line 571 of file TypeCode.cxx.
572{
573 return _shortName.c_str();
574}
References YACS::ENGINE::TypeCodeComposed::_shortName.
◆ _content
const TypeCode* YACS::ENGINE::TypeCodeArray::_content
◆ _staticLgth
const unsigned YACS::ENGINE::TypeCodeArray::_staticLgth
Definition at line 217 of file TypeCode.hxx.
Referenced by getSizeInByteOfAnyReprInSeq(), getStaticLgth(), and isA().
