YACS::ENGINE::TypeCodeObjref Class Reference
Class for reference objects. More...
#include <TypeCode.hxx>
Inheritance diagram for YACS::ENGINE::TypeCodeObjref:
Collaboration diagram for YACS::ENGINE::TypeCodeObjref:
 TypeCodeObjref (const char *repositoryId, const char *name)
 TypeCodeObjref (const char *repositoryId, const char *name, const std::list< TypeCodeObjref * > &ltc)
TypeCode * clone () const
void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
void destroyZippedAny (char *data) const
AnyPtr getOrBuildAnyFromZippedData (char *data) const
const char * id () const
const char * name () const
const char * shortName () const
int isA (const char *repositoryId) const
 Check if this TypeCode is derived from a TypeCode with a given id. More...
virtual int isA (const TypeCode *tc) const
 Check if this TypeCode is derived from a given TypeCode. More...
virtual int isAdaptable (const TypeCode *tc) const
 Check if this TypeCode is adaptable to a given TypeCode (tc) More...
virtual int isEquivalent (const TypeCode *tc) const
 Check if this TypeCode can be used in place of tc. More...
- Public Member Functions inherited from YACS::ENGINE::TypeCode
 TypeCode (DynType kind)
DynType kind () const
const char * getKindRepr () const
const TypeCode * subContentType (int lev) const
virtual TypeCode * clone () const
virtual void putReprAtPlace (char *pt, const char *val, bool deepCpy) const
virtual void destroyZippedAny (char *data) const
virtual AnyPtr getOrBuildAnyFromZippedData (char *data) const
virtual const char * name () const
virtual const char * shortName () const
virtual const char * id () const
virtual const TypeCode * contentType () const
virtual int isA (const char *repositoryId) const
virtual unsigned getSizeInByteOfAnyReprInSeq () const
virtual std::string getPrintStr () const
void incrRef () const
bool decrRef () const
virtual ~TypeCodeObjref ()
 TypeCodeObjref (const TypeCodeObjref &other)
- Protected Member Functions inherited from YACS::ENGINE::TypeCodeComposed
 TypeCodeComposed (const TypeCodeComposed &other)
 TypeCodeComposed (DynType kind, const char *repositoryId, const char *name)
 TypeCode (const TypeCode &tc)
TypeCode & operator= (const TypeCode &tc)
virtual ~TypeCode ()
 RefCounter ()
virtual ~RefCounter ()
std::list< TypeCodeObjref * > _listOfBases
Friends
class Visitor
- Static Public Member Functions inherited from YACS::ENGINE::TypeCode
static const char * getKindRepr (DynType kind)
static TypeCode * interfaceTc (const char *id, const char *name)
 static factory of object reference type given an id and a name More...
static TypeCode * interfaceTc (const char *id, const char *name, const std::list< TypeCodeObjref * > &ltc)
 static factory of object reference type given an id, a name and a list of base types More...
static TypeCode * sequenceTc (const char *id, const char *name, TypeCode *content)
 static factory of sequence type given an id, a name and a content type More...
static TypeCode * structTc (const char *id, const char *name)
 static factory of struct type given an id and a name More...
- Protected Attributes inherited from YACS::ENGINE::TypeCodeComposed
const std::string _name
const std::string _repoId
std::string _shortName
const DynType _kind
unsigned int _cnt
- Static Protected Attributes inherited from YACS::ENGINE::TypeCode
static const char * KIND_STR_REPR [] ={ "None", "double", "int", "string", "bool", "Objref", "Sequence", "Array","Struct" }
Definition at line 125 of file TypeCode.hxx.
◆ TypeCodeObjref() [1/3]
TypeCodeObjref::TypeCodeObjref ( const char *  repositoryId,
const char *  name
Definition at line 294 of file TypeCode.cxx.
295 : TypeCodeComposed(Objref,repositoryId,name)
296{
297}
TypeCodeComposed(const TypeCodeComposed &other)
Definition: TypeCode.cxx:275
const char * name() const
Definition: TypeCode.cxx:332
Referenced by clone().
◆ TypeCodeObjref() [2/3]
const char *  name,
const std::list< TypeCodeObjref * > &  ltc
Definition at line 342 of file TypeCode.cxx.
344 : TypeCodeComposed(Objref,repositoryId,name)
345{
346 _listOfBases=ltc;
347 list<TypeCodeObjref *>::const_iterator iter;
348 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
349 (*iter)->incrRef();
350}
Definition: TypeCode.hxx:150
References _listOfBases.
◆ ~TypeCodeObjref()
TypeCodeObjref::~TypeCodeObjref ( )
Definition at line 300 of file TypeCode.cxx.
301{
302 list<TypeCodeObjref *>::iterator iter;
303 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
304 (*iter)->decrRef();
305}
◆ TypeCodeObjref() [3/3]
TypeCodeObjref::TypeCodeObjref ( const TypeCodeObjref &  other)
Definition at line 402 of file TypeCode.cxx.
402 :TypeCodeComposed(other),
404{
405 list<TypeCodeObjref *>::const_iterator iter;
406 for(iter=other._listOfBases.begin();iter!=other._listOfBases.end();iter++)
407 (*iter)->incrRef();
408}
References _listOfBases, and YACS::ENGINE::RefCounter::incrRef().
◆ clone()
TypeCode * TypeCodeObjref::clone ( ) const
Reimplemented from YACS::ENGINE::TypeCode.
Definition at line 307 of file TypeCode.cxx.
308{
309 return new TypeCodeObjref(*this);
310}
TypeCodeObjref(const char *repositoryId, const char *name)
Definition: TypeCode.cxx:294
References TypeCodeObjref().
◆ destroyZippedAny()
void TypeCodeObjref::destroyZippedAny ( char *  data) const
Definition at line 317 of file TypeCode.cxx.
318{
320}
static void destroyReprAtPlace(char *data, const TypeCode *type)
Definition: Any.cxx:468
References YACS::ENGINE::AtomAny::destroyReprAtPlace().
◆ getOrBuildAnyFromZippedData()
AnyPtr TypeCodeObjref::getOrBuildAnyFromZippedData ( char *  data) const
Definition at line 322 of file TypeCode.cxx.
323{
324 return AtomAny::getOrBuildFromData(data,this);
325}
static AnyPtr getOrBuildFromData(char *data, const TypeCode *type)
Definition: Any.cxx:481
References YACS::ENGINE::AtomAny::getOrBuildFromData().
◆ id()
const char * TypeCodeObjref::id ( ) const
Definition at line 327 of file TypeCode.cxx.
328{
329 return _repoId.c_str();
330};
Definition: TypeCode.hxx:115
References YACS::ENGINE::TypeCodeComposed::_repoId.
Referenced by YACS::ENGINE::VisitorSaveSchema::dumpTypeCode().
◆ isA() [1/2]
int TypeCodeObjref::isA ( const char *  id) const
id: a given id
1 if true, 0 if false
Definition at line 357 of file TypeCode.cxx.
358{
359 if(_repoId == id)return 1;
360 list<TypeCodeObjref *>::const_iterator iter;
361 for(iter=_listOfBases.begin();iter != _listOfBases.end(); iter++)
362 {
363 if ((*iter)->isA(id)) return 1;
364 }
365 return 0;
366}
References _listOfBases, and YACS::ENGINE::TypeCodeComposed::_repoId.
Referenced by isA(), and isAdaptable().
◆ isA() [2/2]
int TypeCodeObjref::isA ( const TypeCode *  tc) const
tc: the given TypeCode
Definition at line 373 of file TypeCode.cxx.
374{
375 return isA(tc->id());
376}
int isA(const char *repositoryId) const
Definition: TypeCode.cxx:357
virtual const char * id() const
Definition: TypeCode.cxx:82
References YACS::ENGINE::TypeCode::id(), and isA().
◆ isAdaptable()
int TypeCodeObjref::isAdaptable ( const TypeCode *  tc) const
Definition at line 383 of file TypeCode.cxx.
384{
385 if(_kind == tc->kind()) return isA(tc->id());
386 return 0;
387}
DynType kind() const
Definition: TypeCode.cxx:47
const DynType _kind
Definition: TypeCode.hxx:104
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCode::id(), isA(), and YACS::ENGINE::TypeCode::kind().
◆ isEquivalent()
int TypeCodeObjref::isEquivalent ( const TypeCode *  tc) const
this TypeCode is equivalent to tc if they have the same kind
tc: the TypeCode to compare
Definition at line 395 of file TypeCode.cxx.
396{
397 if(_kind != tc->kind())return 0;
398 if(_repoId == tc->id())return 1;
399 return 0;
400}
References YACS::ENGINE::TypeCode::_kind, YACS::ENGINE::TypeCodeComposed::_repoId, YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::TypeCode::kind().
const char * TypeCodeObjref::name ( ) const
Definition at line 332 of file TypeCode.cxx.
333{
334 return _name.c_str();
335}
References YACS::ENGINE::TypeCodeComposed::_name.
◆ putReprAtPlace()
void TypeCodeObjref::putReprAtPlace ( char *  pt,
const char *  val,
bool  deepCpy
Definition at line 312 of file TypeCode.cxx.
313{
314 AtomAny::putReprAtPlace(pt,val,this,deepCpy);
315}
static void putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
Definition: Any.cxx:448
References YACS::ENGINE::AtomAny::putReprAtPlace().
◆ shortName()
const char * TypeCodeObjref::shortName ( ) const
Definition at line 337 of file TypeCode.cxx.
338{
339 return _shortName.c_str();
340}
References YACS::ENGINE::TypeCodeComposed::_shortName.
◆ Visitor
friend class Visitor
friend
Definition at line 127 of file TypeCode.hxx.
◆ _listOfBases
std::list<TypeCodeObjref *> YACS::ENGINE::TypeCodeObjref::_listOfBases
