YACS::ENGINE::AtomAny Class Reference
#include <Any.hxx>
Inheritance diagram for YACS::ENGINE::AtomAny:
Collaboration diagram for YACS::ENGINE::AtomAny:
union  ValueContainer
Any * clone () const
AnyPtr operator[] (int i) const
AnyPtr operator[] (const char *key) const
bool operator== (const Any &other) const
int getIntValue () const
bool getBoolValue () const
double getDoubleValue () const
std::string getStringValue () const
const char * getBytesValue (std::size_t &len) const
- Public Member Functions inherited from YACS::ENGINE::Any
const TypeCode * getType () const
virtual Any * clone () const =0
virtual AnyPtr operator[] (int i) const =0
virtual AnyPtr operator[] (const char *key) const =0
virtual bool operator== (const Any &other) const =0
virtual int getIntValue () const =0
virtual bool getBoolValue () const =0
virtual double getDoubleValue () const =0
virtual std::string getStringValue () const =0
void incrRef () const
bool decrRef () const
template<class T >
static AtomAny * New (T val)
static AtomAny * New (char *val, Deallocator dealloc)
static AtomAny * New (const std::string &val, TypeCode *type)
void putMyReprAtPlace (char *data) const
- Protected Member Functions inherited from YACS::ENGINE::Any
virtual ~Any ()
 Any (TypeCode *type)
 Any (const Any &other)
virtual void putMyReprAtPlace (char *data) const =0
 RefCounter ()
virtual ~RefCounter ()
static void putReprAtPlace (char *data, const char *src, const TypeCode *type, bool deepCpy)
static void destroyReprAtPlace (char *data, const TypeCode *type)
static AnyPtr getOrBuildFromData (char *data, const TypeCode *type)
static bool takeInChargeStorageOf (TypeCode *type)
- Static Protected Member Functions inherited from YACS::ENGINE::Any
static bool IsNull (char *data)
ValueContainer _value
- Protected Attributes inherited from YACS::ENGINE::Any
TypeCode * _type
unsigned int _cnt
 ~AtomAny ()
 AtomAny (int val)
 AtomAny (bool val)
 AtomAny (double val)
 AtomAny (const char *val)
 AtomAny (const std::string &val)
 AtomAny (const std::string &val, TypeCode *type)
 AtomAny (const AtomAny &other)
 AtomAny (char *data, TypeCode *type)
 AtomAny (char *val, Deallocator deAlloc)
Friends
class TypeCode
class TypeCodeObjref
Definition at line 111 of file Any.hxx.
◆ ~AtomAny()
AtomAny::~AtomAny ( )
◆ AtomAny() [1/9]
AtomAny::AtomAny ( int  val)
Definition at line 258 of file Any.cxx.
259{
260 _value._i=val;
261}
Any(TypeCode *type)
Definition: Any.cxx:233
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
References YACS::ENGINE::AtomAny::ValueContainer::_i, and _value.
Referenced by clone(), getOrBuildFromData(), and New().
◆ AtomAny() [2/9]
AtomAny::AtomAny ( bool  val)
Definition at line 263 of file Any.cxx.
264{
265 _value._b=val;
266}
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
References YACS::ENGINE::AtomAny::ValueContainer::_b, and _value.
◆ AtomAny() [3/9]
AtomAny::AtomAny ( double  val)
Definition at line 268 of file Any.cxx.
269{
270 _value._d=val;
271}
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
References YACS::ENGINE::AtomAny::ValueContainer::_d, and _value.
◆ AtomAny() [4/9]
AtomAny::AtomAny ( const char *  val)
Definition at line 273 of file Any.cxx.
274{
275 _value._s=new StringOnHeap(val);
276}
static YACS::ENGINE::TypeCode * _tc_string
Definition: Runtime.hxx:139
References YACS::ENGINE::AtomAny::ValueContainer::_s, and _value.
◆ AtomAny() [5/9]
AtomAny::AtomAny ( const std::string &  val)
Definition at line 278 of file Any.cxx.
279{
280 _value._s=new StringOnHeap(val);
281}
◆ AtomAny() [6/9]
AtomAny::AtomAny ( const std::string &  val,
TypeCode *  type
Definition at line 283 of file Any.cxx.
283 :Any(type)
284{
285 _value._s=new StringOnHeap(val);
286}
◆ AtomAny() [7/9]
◆ AtomAny() [8/9]
◆ AtomAny() [9/9]
AtomAny::AtomAny ( char *  val,
Deallocator  deAlloc
Definition at line 303 of file Any.cxx.
304{
305 _value._s=new StringOnHeap(val,deAlloc);
306}
◆ clone()
Any * AtomAny::clone ( ) const
Implements YACS::ENGINE::Any.
Definition at line 324 of file Any.cxx.
325{
326 return new AtomAny(*this);
327}
AtomAny(int val)
Definition: Any.cxx:258
References AtomAny().
◆ destroyReprAtPlace()
void AtomAny::destroyReprAtPlace ( char *  data,
const TypeCode *  type
staticprotected
: Opposite method of putMyReprAtPlace. But static because due to data compression instance is lost.
Definition at line 468 of file Any.cxx.
469{
470 DynType typ=type->kind();
471 if(typ==String || typ==Objref)
472 {
473 if(!Any::IsNull(data))
474 {
475 void **tmp=(void **)data;
476 delete ((StringOnHeap *)(*tmp));
477 }
478 }
479}
static bool IsNull(char *data)
Definition: Any.cxx:248
References YACS::ENGINE::Any::IsNull(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, and YACS::ENGINE::String.
Referenced by YACS::ENGINE::TypeCode::destroyZippedAny(), and YACS::ENGINE::TypeCodeObjref::destroyZippedAny().
◆ getBoolValue()
bool AtomAny::getBoolValue ( ) const
Definition at line 374 of file Any.cxx.
375{
377 return _value._b;
378 else
379 throw Exception("Value is not a bool");
380}
References YACS::ENGINE::AtomAny::ValueContainer::_b, YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Any::_type, _value, and YACS::ENGINE::TypeCode::isA().
◆ getBytesValue()
const char * AtomAny::getBytesValue ( std::size_t &  len) const
◆ getDoubleValue()
double AtomAny::getDoubleValue ( ) const
Definition at line 382 of file Any.cxx.
383{
385 return _value._d;
386 else
387 throw Exception("Value is not a double");
388}
References YACS::ENGINE::AtomAny::ValueContainer::_d, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Any::_type, _value, and YACS::ENGINE::TypeCode::isA().
◆ getIntValue()
int AtomAny::getIntValue ( ) const
Definition at line 366 of file Any.cxx.
367{
369 return _value._i;
370 else
371 throw Exception("Value is not an int");
372}
References YACS::ENGINE::AtomAny::ValueContainer::_i, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Any::_type, _value, and YACS::ENGINE::TypeCode::isA().
◆ getOrBuildFromData()
AnyPtr AtomAny::getOrBuildFromData ( char *  data,
staticprotected
Definition at line 481 of file Any.cxx.
482{
483 Any *ret;
484 ret=new AtomAny(data,(TypeCode *)type);
485 return AnyPtr(ret);
486}
Definition: Any.hxx:79
Definition: TypeCode.hxx:68
SharedPtr< Any > AnyPtr
Definition: Any.hxx:72
Referenced by YACS::ENGINE::TypeCode::getOrBuildAnyFromZippedData(), and YACS::ENGINE::TypeCodeObjref::getOrBuildAnyFromZippedData().
◆ getStringValue()
std::string AtomAny::getStringValue ( ) const
Definition at line 390 of file Any.cxx.
391{
393 {
394 std::size_t sz(_value._s->size());
395 if(sz==0)
396 return string(_value._s->cStr());
397 else
398 return string(_value._s->cStr(),sz);
399 }
400 else
401 throw Exception("Value is not a string");
402}
References YACS::ENGINE::AtomAny::ValueContainer::_s, YACS::ENGINE::Runtime::_tc_string, YACS::ENGINE::Any::_type, _value, YACS::ENGINE::StringOnHeap::cStr(), YACS::ENGINE::TypeCode::isA(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, and YACS::ENGINE::StringOnHeap::size().
◆ New() [1/3]
AtomAny * AtomAny::New ( char *  val,
Deallocator  dealloc
Definition at line 329 of file Any.cxx.
330{
331 return new AtomAny(val,dealloc);
332}
◆ New() [2/3]
AtomAny * AtomAny::New ( const std::string &  val,
TypeCode *  type
Definition at line 334 of file Any.cxx.
335{
336 return new AtomAny(val,type);
337}
◆ New() [3/3]
◆ operator==()
bool AtomAny::operator== ( const Any &  other) const
◆ operator[]() [1/2]
AnyPtr AtomAny::operator[] ( const char *  key) const
Definition at line 344 of file Any.cxx.
345{
346 throw Exception("AtomAny::operator[] : try to get a part of a partitionned data whereas atomical.");
347}
◆ operator[]() [2/2]
AnyPtr AtomAny::operator[] ( int  i) const
◆ putMyReprAtPlace()
void AtomAny::putMyReprAtPlace ( char *  data) const
: This method put in data its zipped recursive content in data. The ownership of the recursive content is tranfered to data. So this owns nothing and its counter fall by 1. For memory space minimal use, not all of '*this' is pushed at data location.
data: already allocated memory zone where to put compressed content of 'this'
Definition at line 422 of file Any.cxx.
423{
425 {
427 memcpy(data,&tmp,_type->getSizeInByteOfAnyReprInSeq());
428 }
429 else if(_type->isA(Runtime::_tc_double))
431 else if(_type->isA(Runtime::_tc_int))
433 else if(_type->isA(Runtime::_tc_bool))
435}
StringOnHeap * deepCopy() const
Definition: Any.cxx:217
References YACS::ENGINE::AtomAny::ValueContainer::_b, YACS::ENGINE::AtomAny::ValueContainer::_d, YACS::ENGINE::AtomAny::ValueContainer::_i, YACS::ENGINE::AtomAny::ValueContainer::_s, YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Runtime::_tc_string, YACS::ENGINE::Any::_type, _value, YACS::ENGINE::StringOnHeap::deepCopy(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), YACS::ENGINE::TypeCode::isA(), YACS::ENGINE::TypeCode::kind(), and YACS::ENGINE::Objref.
◆ putReprAtPlace()
void AtomAny::putReprAtPlace ( char *  data,
const char *  src,
const TypeCode *  type,
bool  deepCpy
staticprotected
: This method put in data its zipped recursive content in data. The ownership of the recursive content is tranfered to data. So this owns nothing and its counter fall by 1. For memory space minimal use, not all of '*this' is pushed at data location. 'deepCpy' param is not used here because by definition of AtomAny deep copy is performed.
src:
type:
deepCpy:
Definition at line 448 of file Any.cxx.
449{
450 if(type->isA(Runtime::_tc_string) || type->kind()==YACS::ENGINE::Objref)
451 {
452 void **tmp1=(void **)src;
453 StringOnHeap *tmp=((const StringOnHeap *)(*tmp1))->deepCopy();
454 memcpy(data,&tmp,type->getSizeInByteOfAnyReprInSeq());
455 }
456 else if(type->isA(Runtime::_tc_double))
457 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
458 else if(type->isA(Runtime::_tc_int))
459 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
460 else if(type->isA(Runtime::_tc_bool))
461 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
462}
References YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Runtime::_tc_string, YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), YACS::ENGINE::TypeCode::isA(), YACS::ENGINE::TypeCode::kind(), and YACS::ENGINE::Objref.
Referenced by YACS::ENGINE::TypeCode::putReprAtPlace(), and YACS::ENGINE::TypeCodeObjref::putReprAtPlace().
◆ takeInChargeStorageOf()
bool AtomAny::takeInChargeStorageOf ( TypeCode *  type)
staticprotected
Definition at line 488 of file Any.cxx.
489{
490 DynType typ=type->kind();
491 return (typ==Double || typ==Int || typ==Bool || typ==String);
492}
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), and YACS::ENGINE::String.
◆ TypeCode
friend class TypeCode
friend
Definition at line 113 of file Any.hxx.
◆ TypeCodeObjref
friend class TypeCodeObjref
friend
Definition at line 114 of file Any.hxx.
◆ _value
ValueContainer YACS::ENGINE::AtomAny::_value
