Any.cxx
20#include "Any.hxx"
21#include "Runtime.hxx"
22#include "TypeCode.hxx"
24
25#include <boost/archive/iterators/base64_from_binary.hpp>
26#include <boost/archive/iterators/binary_from_base64.hpp>
27#include <boost/archive/iterators/transform_width.hpp>
28#include <boost/archive/iterators/insert_linebreaks.hpp>
29#include <boost/archive/iterators/remove_whitespace.hpp>
30
31#include <algorithm>
32#include <cstring>
33#include <cstdlib>
34
35using namespace YACS::ENGINE;
36using namespace std;
37
38// forbidden value int=-269488145 double=-1.54947e+231 bool=239
39const char SeqAlloc::DFT_CHAR_VAR=-17;//0xEF
40
41constexpr unsigned NB_BITS = 6;
42
43constexpr unsigned char TAB[64]={46, 61, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122};
44
45unsigned char BitAtPosSimple(char val, std::size_t bitPos)
46{
47 return (val >> bitPos) & 0x1;
48}
49
50unsigned char BitAtPos(char pt0, char pt1, std::size_t bitPos)
51{
52 if(bitPos<8)
53 return BitAtPosSimple(pt0,bitPos);
54 else
55 return BitAtPosSimple(pt1,bitPos-8);
56}
57
58unsigned char ChunkInternal(char pt0, char pt1, std::size_t startBitIdInByte)
59{
60 unsigned char ret(0);
61 for(unsigned i = 0; i<NB_BITS; ++i)
62 {
63 ret |= BitAtPos(pt0,pt1,startBitIdInByte+i);
64 ret <<= 1;
65 }
66 ret >>= 1;
67 return ret;
68}
69
70unsigned char ChunkAtPos(const char *pt, std::size_t len, std::size_t posChunk)
71{
72 std::size_t startByte((posChunk*NB_BITS)/8);
73 std::size_t startBitIdInByte((posChunk*NB_BITS)%8);
74 char pt1(startByte!=len-1?pt[startByte+1]:pt[startByte]);
75 return ChunkInternal(pt[startByte],pt1,startBitIdInByte);
76}
77
78std::size_t OnOff(std::size_t i)
79{
80 if(i!=0)
81 return 1;
82 return 0;
83}
84
85std::string YACS::ENGINE::ToBase64(const std::string& bytes)
86{//64 == 2**6
87 const char *bytesPt(bytes.c_str());
88 std::size_t input_len(bytes.size());
89 std::size_t input_len_bit(input_len*8);
90 std::size_t nb_chunks( input_len_bit/NB_BITS + OnOff((NB_BITS - input_len_bit%NB_BITS)%NB_BITS) );
91 std::string ret(nb_chunks,'\0');
92 for(std::size_t i=0;i<nb_chunks;++i)
93 {
94 unsigned char cp(ChunkAtPos(bytesPt,input_len, i));
95 ret[i] = TAB[cp];
96 }
97 return ret;
98}
99
100constexpr unsigned MAX_VAL_TAB2=123;
101
102constexpr unsigned NOT_OK_VAL = 128;
103
105
106unsigned char BitAtPosSimple2(char val, std::size_t bitPos)
107{
108 return ( val >> (5-bitPos) ) & 0x1;
109}
110
111char BitAtPosOnChunk(char pt0, char pt1, std::size_t bitPos)
112{
113 if(bitPos<6)
114 return BitAtPosSimple2(pt0,bitPos);
115 else
116 return BitAtPosSimple2(pt1,bitPos-6);
117}
118
119unsigned char CheckEntry(char c)
120{
121 if( ((unsigned) c) < MAX_VAL_TAB2 )
122 {
123 unsigned char ret(TAB2[(unsigned char)c]);
124 if(ret != NOT_OK_VAL)
125 return ret;
126 throw YACS::Exception("Invalid character found !");
127 }
128 throw YACS::Exception("Invalid character found !");
129}
130
131char ByteInternal(char c0, char c1, std::size_t startBitIdInByte)
132{
133 unsigned char ret(0);
134 char ct0(CheckEntry(c0)),ct1(CheckEntry(c1));
135 for(int i = 7; i>=0; --i)
136 {
137 ret |= BitAtPosOnChunk(ct0,ct1,startBitIdInByte+i);
138 if(i!=0)
139 ret <<= 1;
140 }
141 return ret;
142}
143
144char ByteAtPos(const char *chunckPt, std::size_t bytePos)
145{
146 std::size_t startChunk((bytePos*8)/NB_BITS);
147 std::size_t startBitId((bytePos*8)%NB_BITS);
148 return ByteInternal(chunckPt[startChunk],chunckPt[startChunk+1],startBitId);
149}
150
151std::string YACS::ENGINE::FromBase64(const std::string& bytes)
152{
153 std::size_t nb_chunks(bytes.size());
154 const char *chunckPt(bytes.c_str());
155 std::size_t nb_bytes_output((nb_chunks*NB_BITS)/8);
156 std::string ret(nb_bytes_output,'\0');
157 for(std::size_t i = 0; i<nb_bytes_output; ++i)
158 {
159 ret[i] = ByteAtPos(chunckPt,i);
160 }
161 return ret;
162}
163
167std::string YACS::ENGINE::FromBase64Safe(const std::string& bytes)
168{
169 try
170 {
171 return FromBase64(bytes);
172 }
173 catch(const YACS::Exception& e)
174 {
175 return bytes;
176 }
177}
178
179StringOnHeap::StringOnHeap(const char *val):_str(strdup(val)),_len(strlen(val)),_dealloc(0)
180{
181}
182
183StringOnHeap::StringOnHeap(const char *val, std::size_t len):_dealloc(0),_len(len)
184{
185 _str=(char *)malloc(len+1);
186 std::copy(val,val+len,_str);
187 _str[len]='\0';
188}
189
190StringOnHeap::StringOnHeap(const std::string& val):_dealloc(0),_len(val.size()),_str(nullptr)
191{
192 _str=(char *)malloc(val.size()+1);
193 std::copy(val.cbegin(),val.cend(),_str);
194 _str[val.size()]='\0';
195}
196
204StringOnHeap::StringOnHeap(char *val, Deallocator deAlloc):_len(0),_dealloc(deAlloc)
205{
206 if(deAlloc)
207 _str=val;
208 else
209 _str=strdup(val);
210}
211
213{
214 return strcmp(_str, other._str)==0;
215}
216
218{
219 if(_len==0)
220 return new StringOnHeap(_str);
221 else
222 return new StringOnHeap(_str,_len);
223}
224
226{
227 if(_dealloc)
228 _dealloc(_str);
229 else
230 free(_str);
231}
232
233Any::Any(TypeCode* type):_type(type)
234{
235 _type->incrRef();
236}
237
238Any::Any(const Any& other):_type(other._type)
239{
240 _type->incrRef();
241}
242
244{
245 _type->decrRef();
246}
247
248bool Any::IsNull(char *data)
249{
250 if(!data)
251 return true;
252 bool isNull(true);
253 for(std::size_t i=0;i<sizeof(void *) && isNull;i++)
254 isNull=(data[i]==SeqAlloc::DFT_CHAR_VAR);
255 return isNull;
256}
257
258AtomAny::AtomAny(int val):Any(Runtime::_tc_int)
259{
260 _value._i=val;
261}
262
263AtomAny::AtomAny(bool val):Any(Runtime::_tc_bool)
264{
265 _value._b=val;
266}
267
268AtomAny::AtomAny(double val):Any(Runtime::_tc_double)
269{
270 _value._d=val;
271}
272
273AtomAny::AtomAny(const char *val):Any(Runtime::_tc_string)
274{
275 _value._s=new StringOnHeap(val);
276}
277
278AtomAny::AtomAny(const std::string& val):Any(Runtime::_tc_string)
279{
280 _value._s=new StringOnHeap(val);
281}
282
283AtomAny::AtomAny(const std::string& val, TypeCode* type):Any(type)
284{
285 _value._s=new StringOnHeap(val);
286}
287
288AtomAny::AtomAny(const AtomAny& other):Any(other)
289{
291 {
292 StringOnHeap *cpy=(other._value._s)->deepCopy();
294 }
295 else if(_type->isA(Runtime::_tc_double))
297 else if(_type->isA(Runtime::_tc_int))
299 else if(_type->isA(Runtime::_tc_bool))
301}
302
303AtomAny::AtomAny(char *val, Deallocator deAlloc):Any(Runtime::_tc_string)
304{
305 _value._s=new StringOnHeap(val,deAlloc);
306}
307
308AtomAny::AtomAny(char *data, TypeCode* type):Any(type)
309{
311 {
312 void **tmp=(void **)data;
313 StringOnHeap *cpy=((StringOnHeap *)(*tmp))->deepCopy();
314 memcpy(&_value._s,&cpy,type->getSizeInByteOfAnyReprInSeq());
315 }
316 else if(type->isA(Runtime::_tc_double))
317 memcpy(&_value._d,data,type->getSizeInByteOfAnyReprInSeq());
318 else if(type->isA(Runtime::_tc_int))
319 memcpy(&_value._i,data,type->getSizeInByteOfAnyReprInSeq());
320 else if(type->isA(Runtime::_tc_bool))
321 memcpy(&_value._b,data,type->getSizeInByteOfAnyReprInSeq());
322}
323
325{
326 return new AtomAny(*this);
327}
328
330{
331 return new AtomAny(val,dealloc);
332}
333
334AtomAny *AtomAny::New(const std::string& val, TypeCode *type)
335{
336 return new AtomAny(val,type);
337}
338
340{
342}
343
344AnyPtr AtomAny::operator[](const char *key) const
345{
346 throw Exception("AtomAny::operator[] : try to get a part of a partitionned data whereas atomical.");
347}
348
349bool AtomAny::operator ==(const Any& other) const
350{
351 if(!_type->isA(other.getType()))
352 return false;
353 const AtomAny& otherC=(const AtomAny&) other;//cast granted due to previous lines
355 return _value._d==otherC._value._d;
356 else if(_type->isA(Runtime::_tc_int))
357 return _value._i==otherC._value._i;
358 else if(_type->isA(Runtime::_tc_bool))
359 return _value._b==otherC._value._b;
360 else if(_type->isA(Runtime::_tc_string) || _type->kind()==Objref)
361 return (*_value._s)==*(otherC._value._s);
362 else
363 return false;
364}
365
367{
369 return _value._i;
370 else
371 throw Exception("Value is not an int");
372}
373
375{
377 return _value._b;
378 else
379 throw Exception("Value is not a bool");
380}
381
383{
385 return _value._d;
386 else
387 throw Exception("Value is not a double");
388}
389
390std::string AtomAny::getStringValue() const
391{
393 {
394 std::size_t sz(_value._s->size());
395 if(sz==0)
396 return string(_value._s->cStr());
397 else
398 return string(_value._s->cStr(),sz);
399 }
400 else
401 throw Exception("Value is not a string");
402}
403
404const char *AtomAny::getBytesValue(std::size_t& len) const
405{
407 {
408 len=_value._s->size();
409 return _value._s->cStr();
410 }
411 else
412 throw Exception("Value is not a string");
413}
414
422void AtomAny::putMyReprAtPlace(char *data) const
423{
425 {
427 memcpy(data,&tmp,_type->getSizeInByteOfAnyReprInSeq());
428 }
429 else if(_type->isA(Runtime::_tc_double))
431 else if(_type->isA(Runtime::_tc_int))
433 else if(_type->isA(Runtime::_tc_bool))
435}
436
448void AtomAny::putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
449{
450 if(type->isA(Runtime::_tc_string) || type->kind()==YACS::ENGINE::Objref)
451 {
452 void **tmp1=(void **)src;
453 StringOnHeap *tmp=((const StringOnHeap *)(*tmp1))->deepCopy();
454 memcpy(data,&tmp,type->getSizeInByteOfAnyReprInSeq());
455 }
456 else if(type->isA(Runtime::_tc_double))
457 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
458 else if(type->isA(Runtime::_tc_int))
459 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
460 else if(type->isA(Runtime::_tc_bool))
461 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
462}
463
468void AtomAny::destroyReprAtPlace(char *data, const TypeCode *type)
469{
470 DynType typ=type->kind();
471 if(typ==String || typ==Objref)
472 {
473 if(!Any::IsNull(data))
474 {
475 void **tmp=(void **)data;
476 delete ((StringOnHeap *)(*tmp));
477 }
478 }
479}
480
482{
483 Any *ret;
484 ret=new AtomAny(data,(TypeCode *)type);
485 return AnyPtr(ret);
486}
487
489{
490 DynType typ=type->kind();
491 return (typ==Double || typ==Int || typ==Bool || typ==String);
492}
493
495{
496 if(_type->kind() == String || _type->kind()==Objref)
497 delete _value._s;
498}
499
501{
502}
503
504ComposedAny::ComposedAny(TypeCode* type, bool isNew):Any(type)
505{
506 if(isNew)
507 _type->decrRef();
508}
509
510AnyPtr ComposedAny::operator[](const char *key) const
511{
512 throw Exception("AtomAny::operator[] : try to get a part of a partitionned data not localizable by a string.");
513}
514
515void ComposedAny::checkTypeOf(const Any *elem) const
516{
517 if(!elem->getType()->isA(_type->contentType()))
518 throw Exception("ComposedAny::checkTypeOf : invalid type.");
519}
520
522{
524}
525
527{
529}
530
532{
534}
535
537{
539}
540
541SeqAlloc::SeqAlloc(const SeqAlloc& other):_sizeOf1Elm(other._sizeOf1Elm),_notStdDeAlloc(0),
542 _start(0),_finish(0),_endOfStorage(0)
543{
544 _start=allocate(other._finish-other._start);
545 _finish=_start+(other._finish-other._start);
547}
548
549SeqAlloc::SeqAlloc(unsigned int sizeOf1Elm):_sizeOf1Elm(sizeOf1Elm),_notStdDeAlloc(0),
550 _start(0),_finish(0),_endOfStorage(0)
551{
552}
553
555{
557}
558
560{
562 _start=0;
563 _finish=0;
565}
566
571void SeqAlloc::initCoarseMemory(char *mem, unsigned int size, Deallocator dealloc)
572{
573 unsigned sizeInByte=size*_sizeOf1Elm;
574 if(dealloc)
575 {
576 _notStdDeAlloc=dealloc;
577 _start=mem;
578 }
579 else
580 {
581 _start=allocate(sizeInByte);
582 if(mem)
583 memcpy(_start,mem,sizeInByte);
584 else
585 {
586 for(unsigned int i=0;i<sizeInByte;i++) _start[i]=DFT_CHAR_VAR;// see getSetItems
587 }
588 }
589 _finish=_start+sizeInByte;
591}
592
593void SeqAlloc::construct(char *pt, const Any *val)
594{
595 val->putMyReprAtPlace(pt);
596}
597
605void SeqAlloc::construct(char *pt, const char *val, const TypeCode *tc, bool deepCpy)
606{
607 tc->putReprAtPlace(pt,val,deepCpy);
608}
609
610char *SeqAlloc::allocate(unsigned int nbOfByte)
611{
612 if(nbOfByte>0)
613 return (char *)::operator new(nbOfByte);
614 else
615 return 0;
616}
617
618// pt is not permitted to be a null pointer.
620{
621 if(pt)
622 {
623 if(!_notStdDeAlloc)
624 ::operator delete(pt);
625 else
626 {
627 _notStdDeAlloc(pt);
629 }
630 }
631}
632
633void SeqAlloc::destroy(char *pt, const TypeCode *tc)
634{
635 tc->destroyZippedAny(pt);
636}
637
638unsigned int SeqAlloc::size() const
639{
640 return (_finish-_start)/_sizeOf1Elm;
641}
642
643std::vector<unsigned int> SeqAlloc::getSetItems() const
644{
645 std::vector<unsigned int> ret;
646 unsigned int sz(size());
647 for(unsigned int i=0;i<sz;i++)
648 {
649 const char *pt(_start+i*_sizeOf1Elm);
650 for(unsigned j=0;j<_sizeOf1Elm && *pt==DFT_CHAR_VAR;j++,pt++); //see initCoarseMemory
651 if(pt!=_start+(i+1)*_sizeOf1Elm)
652 ret.push_back(i);
653 }
654 return ret;
655}
656
658{
659 for (char *cur=_alloc._start;cur!=_alloc._finish;cur+=_alloc._sizeOf1Elm)
661 _alloc.clear();
662}
663
665{
668}
669
670void SequenceAny::pushBack(const Any* elem)
671{
672 if(!elem->_type->isA(_type->contentType()))
675 {
678 }
679 else
680 realloc(_alloc._finish, elem);
681}
682
683bool SequenceAny::operator ==(const Any& other) const
684{
685 if(!_type->isA(other.getType()))
686 return false;
687 const SequenceAny& otherC=(const SequenceAny&) other;//cast granted due to previous lines
688 if(size()!=otherC.size())
689 return false;
690 for(unsigned i=0;i<size();i++)
691 if(!((*(*this)[i])==(*otherC[i])))
692 return false;
693 return true;
694}
695
696void SequenceAny::setEltAtRank(int i, const Any *elem)
697{
698 checkTypeOf(elem);
701}
702
704{
706}
707
712void SequenceAny::putMyReprAtPlace(char *data) const
713{
714 const void *tmp=(const void *)this;
715 memcpy(data,&tmp,_type->getSizeInByteOfAnyReprInSeq());
716 const void **tmp2=(const void **) data;
717 ((SequenceAny *)(*tmp2))->incrRef();
718 //::new((SequenceAny *)data) SequenceAny((SequenceAny&) (*this));
719}
720
721void SequenceAny::putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
722{
723 void **tmp2=(void **) src;
724 if(!deepCpy)
725 {
726 ((SequenceAny *)(*tmp2))->incrRef();
727 memcpy(data,src,type->getSizeInByteOfAnyReprInSeq());
728 }
729 else
730 {
731 SequenceAny *cpy=new SequenceAny(*((SequenceAny *)(*tmp2)));
732 memcpy(data,&cpy,type->getSizeInByteOfAnyReprInSeq());
733 }
734 //::new((SequenceAny *)data) SequenceAny((SequenceAny&) (*this));
735}
736
737void SequenceAny::destroyReprAtPlace(char *data, const TypeCode *type)
738{
739 void **tmp=(void **) data;
740 if(!Any::IsNull(data))
741 ((SequenceAny *)(*tmp))->decrRef();
742 //((SequenceAny *)data)->~SequenceAny();
743}
744
746{
747 void **tmp=(void **) data;
748 ((SequenceAny *) (*tmp))->incrRef();
749 return AnyPtr((SequenceAny *)(*tmp));
750}
751
753{
754 return new SequenceAny(*this);
755}
756
758{
759 std::vector<unsigned int> its(getSetItems());
760 std::size_t sz(its.size());
761 SequenceAny *ret(SequenceAny::New(getType()->contentType(),sz));
762 for(std::size_t i=0;i<sz;i++)
763 {
764 AnyPtr obj((*this)[its[i]]);
765 ret->setEltAtRank(i,obj);
766 }
767 return ret;
768}
769
771{
772 return new SequenceAny(typeOfContent);
773}
774
775SequenceAny *SequenceAny::New(const TypeCode *typeOfContent, unsigned lgth)
776{
777 return new SequenceAny(typeOfContent,lgth);
778}
779
781{
782 DynType typ=type->kind();
783 return (typ==Sequence);
784}
785
786SequenceAny::SequenceAny(const SequenceAny& other):ComposedAny(other),_alloc(other._alloc)
787{
788 const char *srcCur=other._alloc._start;
789 for(char *cur=_alloc._start;srcCur != other._alloc._finish; srcCur+=_alloc._sizeOf1Elm, cur+=_alloc._sizeOf1Elm)
790 _alloc.construct(cur, srcCur, _type->contentType(),true);
791}
792
794{
795 for (char *cur=_alloc._start;cur!=_alloc._finish;cur+=_alloc._sizeOf1Elm)
797}
798
802SequenceAny::SequenceAny(const TypeCode *typeOfContent):ComposedAny(new TypeCodeSeq("","",typeOfContent)),
803 _alloc(typeOfContent->getSizeInByteOfAnyReprInSeq())
804{
805}
806
807SequenceAny::SequenceAny(const TypeCode *typeOfContent, unsigned lgth):ComposedAny(new TypeCodeSeq("","",typeOfContent)),
808 _alloc(typeOfContent->getSizeInByteOfAnyReprInSeq())
809{
810 _alloc.initCoarseMemory(0,lgth,0);
811}
812
813SequenceAny::SequenceAny(int *val, unsigned int lgth, Deallocator deAlloc):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_int)),
814 _alloc(Runtime::_tc_int->getSizeInByteOfAnyReprInSeq())
815{
816 _alloc.initCoarseMemory((char *)val,lgth,deAlloc);
817}
818
819SequenceAny::SequenceAny(bool *val, unsigned int lgth, Deallocator deAlloc):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_bool)),
820 _alloc(Runtime::_tc_bool->getSizeInByteOfAnyReprInSeq())
821{
822 _alloc.initCoarseMemory((char *)val,lgth,deAlloc);
823}
824
825SequenceAny::SequenceAny(double *val, unsigned int lgth, Deallocator deAlloc):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_double)),
826 _alloc(Runtime::_tc_double->getSizeInByteOfAnyReprInSeq())
827{
828 _alloc.initCoarseMemory((char *)val,lgth,deAlloc);
829}
830
831SequenceAny::SequenceAny(const std::vector<int>& val):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_int)),
832 _alloc(Runtime::_tc_int->getSizeInByteOfAnyReprInSeq())
833{
834 _alloc.initCoarseMemory((char *)&val[0],val.size(),0);
835}
836
837SequenceAny::SequenceAny(const std::vector<bool>& val):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_bool)),
838 _alloc(Runtime::_tc_bool->getSizeInByteOfAnyReprInSeq())
839{
840 for(vector<bool>::const_iterator iter=val.begin();iter!=val.end();iter++)
841 {
842 AtomAnyPtr tmp=AtomAny::New(*iter);
843 pushBack(tmp);
844 }
845}
846
847SequenceAny::SequenceAny(const std::vector<double>& val):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_double)),
848 _alloc(Runtime::_tc_double->getSizeInByteOfAnyReprInSeq())
849{
850 _alloc.initCoarseMemory((char *)&val[0],val.size(),0);
851}
852
853SequenceAny::SequenceAny(const std::vector<std::string>& val):ComposedAny(new TypeCodeSeq("","",Runtime::_tc_string)),
854 _alloc(Runtime::_tc_string->getSizeInByteOfAnyReprInSeq())
855{
856 for(vector<string>::const_iterator iter=val.begin();iter!=val.end();iter++)
857 {
858 AtomAnyPtr tmp=AtomAny::New(*iter);
859 pushBack(tmp);
860 }
861}
862
863void SequenceAny::realloc(char *endOfCurrentAllocated, const Any *elem)
864{
865 unsigned int oldSize=_alloc._finish-_alloc._start;
866 unsigned int newSize = oldSize != 0 ? 2 * oldSize : _alloc._sizeOf1Elm;
867 char *newStart=_alloc.allocate(newSize);
868 //
869 char *newFinish=performCpy(_alloc._start, endOfCurrentAllocated,newStart);
870 _alloc.construct(newFinish, elem);
871 newFinish+=_alloc._sizeOf1Elm;
872 newFinish=performCpy(endOfCurrentAllocated, _alloc._finish, newFinish);
873 //
874 for (char *cur=_alloc._start;cur!=_alloc._finish;cur+=_alloc._sizeOf1Elm)
877 _alloc._start = newStart;
878 _alloc._finish = newFinish;
879 _alloc._endOfStorage=newStart+newSize;
880}
881
882char *SequenceAny::performCpy(char *srcStart, char *srcFinish, char *destStart)
883{
884 char *cur=destStart;
885 for (;srcStart != srcFinish; srcStart+=_alloc._sizeOf1Elm, cur+=_alloc._sizeOf1Elm)
886 _alloc.construct(cur, srcStart, _type->contentType(),false);
887 return cur;
888}
889
891{
892 const TypeCode *subType=_type->contentType();
893 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
894 unsigned int size=((TypeCodeArray *)_type)->getStaticLgth();
895 char *tmp=_data;
896 for(unsigned i=0;i<size;i++,tmp+=sizePerContent)
897 subType->destroyZippedAny(tmp);
898 delete [] _data;
899}
900
901ArrayAny::ArrayAny(const TypeCode *typeOfContent, unsigned int lgth):ComposedAny(new TypeCodeArray("","",typeOfContent,lgth))
902{
904 for(unsigned int i=0;i<_type->getSizeInByteOfAnyReprInSeq();i++)
906}
907
908ArrayAny::ArrayAny(char *data, TypeCodeArray * type):ComposedAny(type,false),_data(0)
909{
911 const TypeCode *subType=_type->contentType();
912 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
913 for(unsigned i=0;i<type->getStaticLgth();i++)
914 subType->putReprAtPlace(_data+i*sizePerContent,data+i*sizePerContent,false);
915}
916
918{
920 const TypeCode *subType=_type->contentType();
921 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
922 for(unsigned i=0;i<((TypeCodeArray *)_type)->getStaticLgth();i++)
923 subType->putReprAtPlace(_data+i*sizePerContent,other._data+i*sizePerContent,true);
924}
925
926ArrayAny::ArrayAny(const int *val, unsigned int lgth):ComposedAny(new TypeCodeArray("","",Runtime::_tc_int,lgth)),
927 _data(0)
928{
931}
932
933ArrayAny::ArrayAny(const bool *val, unsigned int lgth):ComposedAny(new TypeCodeArray("","",Runtime::_tc_bool,lgth)),
934 _data(0)
935{
938}
939
940ArrayAny::ArrayAny(const double *val, unsigned int lgth):ComposedAny(new TypeCodeArray("","",Runtime::_tc_double,lgth)),
941 _data(0)
942{
945}
946
947ArrayAny::ArrayAny(const std::vector<int>& val):ComposedAny(new TypeCodeArray("","",Runtime::_tc_int,val.size())),
948 _data(0)
949{
951 memcpy(_data,&val[0],_type->getSizeInByteOfAnyReprInSeq());
952}
953
954ArrayAny::ArrayAny(const std::vector<double>& val):ComposedAny(new TypeCodeArray("","",Runtime::_tc_double,val.size())),
955 _data(0)
956{
958 memcpy(_data,&val[0],_type->getSizeInByteOfAnyReprInSeq());
959}
960
961ArrayAny::ArrayAny(const std::vector<std::string>& val):ComposedAny(new TypeCodeArray("","",Runtime::_tc_string,val.size())),
962 _data(0)
963{
965 unsigned i=0;
966 const TypeCode *subType=_type->contentType();
967 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
968 for(vector<std::string>::const_iterator iter=val.begin();iter!=val.end();iter++,i++)
969 {
970 StringOnHeap *st=new StringOnHeap(*iter);
971 memcpy(_data+i*sizePerContent,&st,sizePerContent);
972 }
973}
974
975void ArrayAny::setEltAtRank(int i, const Any *elem)
976{
977 checkTypeOf(elem);
978 const TypeCode *subType=_type->contentType();
981}
982
983bool ArrayAny::operator ==(const Any& other) const
984{
985 if(!_type->isA(other.getType()))
986 return false;
987 const ArrayAny& otherC=(const ArrayAny&) other;//cast granted due to previous lines
988 for(unsigned i=0;i<((const TypeCodeArray *)_type)->getStaticLgth();i++)
989 if(!((*(*this)[i])==(*otherC[i])))
990 return false;
991 return true;
992}
993
995{
996 const TypeCode *subType=_type->contentType();
997 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
998 if(i<0 || i>=((TypeCodeArray *)_type)->getStaticLgth())
999 throw Exception("Trying to access to an invalid index in an Any Tuple");
1000 return _type->contentType()->getOrBuildAnyFromZippedData(_data+i*sizePerContent);
1001}
1002
1003unsigned int ArrayAny::size() const
1004{
1005 return ((TypeCodeArray *)_type)->getStaticLgth();
1006}
1007
1009{
1010 return new ArrayAny(*this);
1011}
1012
1013ArrayAny *ArrayAny::New(const TypeCode *typeOfContent, unsigned int lgth)
1014{
1015 return new ArrayAny(typeOfContent,lgth);
1016}
1017
1018void ArrayAny::putMyReprAtPlace(char *data) const
1019{
1020 const TypeCode *subType=_type->contentType();
1021 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1022 for(unsigned i=0;i<((const TypeCodeArray *)_type)->getStaticLgth();i++)
1023 subType->putReprAtPlace(data+i*sizePerContent,_data+i*sizePerContent,false);
1024}
1025
1026void ArrayAny::putReprAtPlace(char *data, const char *src, const TypeCodeArray *type, bool deepCpy)
1027{
1028 const TypeCode *subType=type->contentType();
1029 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1030 for(unsigned i=0;i<type->getStaticLgth();i++)
1031 subType->putReprAtPlace(data+i*sizePerContent,src+i*sizePerContent,deepCpy);
1032}
1033
1034void ArrayAny::destroyReprAtPlace(char *data, const TypeCodeArray *type)
1035{
1036 const TypeCode *subType=type->contentType();
1037 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1038 for(unsigned i=0;i<type->getStaticLgth();i++)
1039 subType->destroyZippedAny(data+i*sizePerContent);
1040}
1041
1043{
1044 Any *ret;
1045 ret=new ArrayAny(data,(TypeCodeArray *)type);
1046 return AnyPtr(ret);
1047}
1048
1050{
1051 DynType typ=type->kind();
1052 return (typ==Array);
1053}
1054
1056{
1057 return new StructAny(*this);
1058}
1059
1060bool StructAny::operator ==(const Any& other) const
1061{
1062 if(!_type->isA(other.getType()))
1063 return false;
1064 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1065 vector< pair<string,TypeCode*> >::const_iterator iter;
1066 for(iter=typeC->_members.begin();iter!=typeC->_members.end();iter++)
1067 if(!((*(*this)[(*iter).first.c_str()]==(*other[(*iter).first.c_str()]))))
1068 return false;
1069 return true;
1070}
1071
1073{
1074 const char what[]="StructAny::operator[](int i) : Struct key are strings not integers.";
1075 throw Exception(what);
1076}
1077
1078AnyPtr StructAny::operator[](const char *key) const
1079{
1080 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1081 char *whereToGet=_data;
1082 vector< pair<string,TypeCode*> >::const_iterator iter;
1083 for(iter=typeC->_members.begin();iter!=typeC->_members.end();iter++)
1084 if((*iter).first!=key)
1085 whereToGet+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1086 else
1087 break;
1088 if(iter==typeC->_members.end())
1089 {
1090 string what("Unexisting key \""); what+=key; what+="\" for struct extraction.";
1091 throw Exception(what);
1092 }
1093 return (*iter).second->getOrBuildAnyFromZippedData(whereToGet);
1094}
1095
1096void StructAny::setEltAtRank(int i, const Any *elem)
1097{
1098 const char what[]="Struct key are strings not integers.";
1099 throw Exception(what);
1100}
1101
1102void StructAny::setEltAtRank(const char *key, const Any *elem)
1103{
1104 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1105 unsigned offset;
1106 const TypeCode *tcOnKey=typeC->getMember(key,offset);
1107 if(!tcOnKey)
1108 throw Exception("StructAny::setEltAtRank : invalid key given.");
1109 if(!elem->getType()->isA(tcOnKey))
1110 throw Exception("StructAny::setEltAtRank : invalid data type on the specified given key.");
1111 tcOnKey->destroyZippedAny(_data+offset);
1112 elem->putMyReprAtPlace(_data+offset);
1113}
1114
1115void StructAny::putMyReprAtPlace(char *data) const
1116{
1117 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1118 unsigned offset=0;
1119 vector< pair<string,TypeCode*> >::const_iterator iter;
1120 for(iter=typeC->_members.begin();iter!=typeC->_members.end();iter++)
1121 {
1122 (*iter).second->putReprAtPlace(data+offset,_data+offset,false);
1123 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1124 }
1125}
1126
1127void StructAny::putReprAtPlace(char *data, const char *src, const TypeCodeStruct *type, bool deepCpy)
1128{
1129 unsigned offset=0;
1130 vector< pair<string,TypeCode*> >::const_iterator iter;
1131 for(iter=type->_members.begin();iter!=type->_members.end();iter++)
1132 {
1133 (*iter).second->putReprAtPlace(data+offset,src+offset,deepCpy);
1134 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1135 }
1136}
1137
1139{
1140 char *whereToGet=data;
1141 vector< pair<string,TypeCode*> >::const_iterator iter;
1142 for(iter=type->_members.begin();iter!=type->_members.end();iter++)
1143 {
1144 (*iter).second->destroyZippedAny(whereToGet);
1145 whereToGet+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1146 }
1147}
1148
1150{
1151 Any *ret;
1152 ret=new StructAny(data,(TypeCodeStruct *)type);
1153 return AnyPtr(ret);
1154}
1155
1157{
1158 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1159 vector< pair<string,TypeCode*> >::const_iterator iter;
1160 char *whereToGet=_data;
1161 for(iter=typeC->_members.begin();iter!=typeC->_members.end();iter++)
1162 {
1163 (*iter).second->destroyZippedAny(whereToGet);
1164 whereToGet+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1165 }
1166 delete [] _data;
1167}
1168
1170{
1172 for(unsigned int i=0;i<_type->getSizeInByteOfAnyReprInSeq();i++)
1174}
1175
1177{
1179 const TypeCodeStruct *typeC=(const TypeCodeStruct *)_type;
1180 vector< pair<string,TypeCode*> >::const_iterator iter;
1181 unsigned offset=0;
1182 for(iter=typeC->_members.begin();iter!=typeC->_members.end();iter++)
1183 {
1184 (*iter).second->putReprAtPlace(_data+offset,other._data+offset,true);
1185 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1186 }
1187}
1188
1189StructAny::StructAny(char *data, TypeCodeStruct * type):ComposedAny(type,false),_data(0)
1190{
1192 vector< pair<string,TypeCode*> >::const_iterator iter;
1193 unsigned offset=0;
1194 for(iter=type->_members.begin();iter!=type->_members.end();iter++)
1195 {
1196 (*iter).second->putReprAtPlace(_data+offset,data+offset,false);
1197 offset+=(*iter).second->getSizeInByteOfAnyReprInSeq();
1198 }
1199}
1200
1202{
1203 return new StructAny(type);
1204}
Definition: Any.cxx:144
Definition: Any.cxx:106
Definition: Any.cxx:119
Definition: Any.cxx:58
Definition: Any.cxx:45
Definition: Any.cxx:111
Definition: Any.cxx:70
Definition: Any.cxx:131
constexpr unsigned char TAB2[MAX_VAL_TAB2]
Definition: Any.cxx:104
Definition: Any.cxx:43
Definition: Any.cxx:41
Definition: Any.cxx:50
Definition: Any.cxx:78
Definition: Any.cxx:100
Definition: Any.cxx:102
: Allow to manage memory of instances of T. The only constraint on T is to have method incrRef and De...
Definition: SharedPtr.hxx:30
Definition: Any.hxx:79
Any(TypeCode *type)
Definition: Any.cxx:233
friend class SequenceAny
Definition: Any.hxx:83
TypeCode * _type
Definition: Any.hxx:106
friend class StructAny
Definition: Any.hxx:82
virtual void putMyReprAtPlace(char *data) const =0
static bool IsNull(char *data)
Definition: Any.cxx:248
const TypeCode * getType() const
Definition: Any.hxx:85
virtual ~Any()
Definition: Any.cxx:243
friend class ArrayAny
Definition: Any.hxx:81
static AnyPtr getOrBuildFromData(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1042
bool operator==(const Any &other) const
Definition: Any.cxx:983
static void destroyReprAtPlace(char *data, const TypeCodeArray *type)
Definition: Any.cxx:1034
Definition: Any.cxx:1018
AnyPtr operator[](int i) const
Definition: Any.cxx:994
void setEltAtRank(int i, const Any *elem)
Definition: Any.cxx:975
static void putReprAtPlace(char *data, const char *src, const TypeCodeArray *type, bool deepCpy)
Definition: Any.cxx:1026
static ArrayAny * New(const std::vector< T > &vec)
Definition: Any.hxx:324
static bool takeInChargeStorageOf(TypeCode *type)
Definition: Any.cxx:1049
Any * clone() const
Definition: Any.cxx:1008
unsigned int size() const
Definition: Any.cxx:1003
int getIntValue() const
Definition: Any.cxx:366
Definition: Any.cxx:339
Definition: Any.cxx:488
Any * clone() const
Definition: Any.cxx:324
static void putReprAtPlace(char *data, const char *src, const TypeCode *type, bool deepCpy)
Definition: Any.cxx:448
static AtomAny * New(T val)
Definition: Any.hxx:126
static AnyPtr getOrBuildFromData(char *data, const TypeCode *type)
Definition: Any.cxx:481
Definition: Any.cxx:349
ValueContainer _value
Definition: Any.hxx:155
std::string getStringValue() const
Definition: Any.cxx:390
AtomAny(int val)
Definition: Any.cxx:258
double getDoubleValue() const
Definition: Any.cxx:382
const char * getBytesValue(std::size_t &len) const
Definition: Any.cxx:404
Definition: Any.cxx:422
static void destroyReprAtPlace(char *data, const TypeCode *type)
Definition: Any.cxx:468
bool getBoolValue() const
Definition: Any.cxx:374
Definition: Any.cxx:521
void checkTypeOf(const Any *elem) const
Definition: Any.cxx:515
AnyPtr operator[](const char *key) const
Definition: Any.cxx:510
Definition: Any.cxx:526
Definition: Any.cxx:531
ComposedAny(const ComposedAny &other)
Definition: Any.cxx:500
Definition: Any.cxx:536
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
static YACS::ENGINE::TypeCode * _tc_string
Definition: Runtime.hxx:139
SeqAlloc(const SeqAlloc &other)
Definition: Any.cxx:541
void destroy(char *pt, const TypeCode *tc)
Definition: Any.cxx:633
void construct(char *pt, const Any *val)
Definition: Any.cxx:593
char * _endOfStorage
Definition: Any.hxx:164
const unsigned int _sizeOf1Elm
Definition: Any.hxx:166
void initCoarseMemory(char *mem, unsigned int size, Deallocator dealloc)
Definition: Any.cxx:571
static const char DFT_CHAR_VAR
Definition: Any.hxx:181
char * allocate(unsigned int nbOfByte)
Definition: Any.cxx:610
Definition: Any.cxx:638
Deallocator _notStdDeAlloc
Definition: Any.hxx:165
void deallocate(char *pt)
Definition: Any.cxx:619
std::vector< unsigned int > getSetItems() const
Definition: Any.cxx:643
Definition: Any.hxx:221
Definition: Any.cxx:696
Definition: Any.hxx:209
Definition: Any.cxx:703
Definition: Any.cxx:721
SequenceAny * removeUnsetItemsFromThis() const
Definition: Any.cxx:757
Definition: Any.cxx:683
Definition: Any.cxx:712
Definition: Any.cxx:737
Definition: Any.cxx:780
void realloc(char *endOfCurrentAllocated, const Any *elem)
Definition: Any.cxx:863
Any * clone() const
Definition: Any.cxx:752
void pushBack(const Any *elem)
Definition: Any.cxx:670
char * performCpy(char *srcStart, char *srcFinish, char *destStart)
Definition: Any.cxx:882
static SequenceAny * New(const std::vector< T > &vec)
Definition: Any.hxx:318
Definition: Any.cxx:745
std::size_t _len
Definition: Any.hxx:68
Definition: Any.cxx:179
const char * cStr() const
Definition: Any.hxx:63
StringOnHeap * deepCopy() const
Definition: Any.cxx:217
bool operator==(const StringOnHeap &other) const
Definition: Any.cxx:212
std::size_t size() const
Definition: Any.hxx:64
Deallocator _dealloc
Definition: Any.hxx:69
static AnyPtr getOrBuildFromData(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1149
static StructAny * New(TypeCodeStruct *type)
Definition: Any.cxx:1201
Definition: Any.cxx:1072
Definition: Any.cxx:1115
Definition: Any.cxx:1060
Any * clone() const
Definition: Any.cxx:1055
static void putReprAtPlace(char *data, const char *src, const TypeCodeStruct *type, bool deepCpy)
Definition: Any.cxx:1127
static void destroyReprAtPlace(char *data, const TypeCodeStruct *type)
Definition: Any.cxx:1138
Definition: Any.cxx:1096
Class for array objects.
Definition: TypeCode.hxx:193
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:581
unsigned getStaticLgth() const
Definition: TypeCode.cxx:576
Class for sequence objects.
Definition: TypeCode.hxx:160
Class for struct type.
Definition: TypeCode.hxx:228
const TypeCode * getMember(const std::string &name, unsigned &offset) const
Get typecode of struct member given its name.
Definition: TypeCode.cxx:801
std::vector< std::pair< std::string, TypeCode * > > _members
Definition: TypeCode.hxx:257
Definition: TypeCode.hxx:68
virtual void destroyZippedAny(char *data) const
Definition: TypeCode.cxx:62
Definition: TypeCode.cxx:174
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:99
DynType kind() const
Definition: TypeCode.cxx:47
virtual unsigned getSizeInByteOfAnyReprInSeq() const
Definition: TypeCode.cxx:157
virtual void putReprAtPlace(char *pt, const char *val, bool deepCpy) const
virtual AnyPtr getOrBuildAnyFromZippedData(char *data) const
Definition: TypeCode.cxx:67
YACSLIBENGINE_EXPORT std::string FromBase64Safe(const std::string &bytes)
Definition: Any.cxx:167
SharedPtr< Any > AnyPtr
Definition: Any.hxx:72
void(* Deallocator)(void *)
Definition: Any.hxx:43
YACSLIBENGINE_EXPORT std::string ToBase64(const std::string &bytes)
Definition: Any.cxx:85
YACSLIBENGINE_EXPORT std::string FromBase64(const std::string &bytes)
Definition: Any.cxx:151
