YACS::ENGINE::ArrayAny Class Reference
#include <Any.hxx>
Inheritance diagram for YACS::ENGINE::ArrayAny:
Collaboration diagram for YACS::ENGINE::ArrayAny:
void setEltAtRank (int i, const Any *elem)
bool operator== (const Any &other) const
AnyPtr operator[] (int i) const
unsigned int size () const
Any * clone () const
- Public Member Functions inherited from YACS::ENGINE::ComposedAny
virtual void setEltAtRank (int i, const Any *elem)=0
AnyPtr operator[] (const char *key) const
- Public Member Functions inherited from YACS::ENGINE::Any
const TypeCode * getType () const
virtual Any * clone () const =0
virtual AnyPtr operator[] (int i) const =0
virtual AnyPtr operator[] (const char *key) const =0
virtual bool operator== (const Any &other) const =0
virtual int getIntValue () const =0
virtual bool getBoolValue () const =0
virtual double getDoubleValue () const =0
virtual std::string getStringValue () const =0
void incrRef () const
bool decrRef () const
template<class T >
static ArrayAny * New (const std::vector< T > &vec)
template<class T >
static ArrayAny * New (const T *val, unsigned int lgth)
static ArrayAny * New (const TypeCode *typeOfContent, unsigned int lgth)
void putMyReprAtPlace (char *data) const
- Protected Member Functions inherited from YACS::ENGINE::ComposedAny
 ComposedAny (const ComposedAny &other)
 ComposedAny (TypeCode *type, bool isNew=true)
void checkTypeOf (const Any *elem) const
- Protected Member Functions inherited from YACS::ENGINE::Any
virtual ~Any ()
 Any (TypeCode *type)
 Any (const Any &other)
virtual void putMyReprAtPlace (char *data) const =0
 RefCounter ()
virtual ~RefCounter ()
static void putReprAtPlace (char *data, const char *src, const TypeCodeArray *type, bool deepCpy)
static void destroyReprAtPlace (char *data, const TypeCodeArray *type)
static AnyPtr getOrBuildFromData (char *data, const TypeCodeArray *type)
static bool takeInChargeStorageOf (TypeCode *type)
- Static Protected Member Functions inherited from YACS::ENGINE::Any
static bool IsNull (char *data)
char * _data
- Protected Attributes inherited from YACS::ENGINE::Any
TypeCode * _type
unsigned int _cnt
 ~ArrayAny ()
 ArrayAny (const TypeCode *typeOfContent, unsigned int lgth)
 ArrayAny (char *data, TypeCodeArray *type)
 ArrayAny (const ArrayAny &other)
 ArrayAny (const int *val, unsigned int lgth)
 ArrayAny (const bool *val, unsigned int lgth)
 ArrayAny (const double *val, unsigned int lgth)
 ArrayAny (const std::vector< int > &val)
 ArrayAny (const std::vector< double > &val)
 ArrayAny (const std::vector< std::string > &val)
Friends
class TypeCodeArray
Definition at line 249 of file Any.hxx.
◆ ~ArrayAny()
ArrayAny::~ArrayAny ( )
Definition at line 890 of file Any.cxx.
891{
892 const TypeCode *subType=_type->contentType();
893 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
894 unsigned int size=((TypeCodeArray *)_type)->getStaticLgth();
895 char *tmp=_data;
896 for(unsigned i=0;i<size;i++,tmp+=sizePerContent)
897 subType->destroyZippedAny(tmp);
898 delete [] _data;
899}
TypeCode * _type
Definition: Any.hxx:106
unsigned int size() const
Definition: Any.cxx:1003
Class for array objects.
Definition: TypeCode.hxx:193
Definition: TypeCode.hxx:68
virtual void destroyZippedAny(char *data) const
Definition: TypeCode.cxx:62
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:174
virtual unsigned getSizeInByteOfAnyReprInSeq() const
Definition: TypeCode.cxx:157
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::destroyZippedAny(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), yacsorb.CORBAEngineTest::i, and size().
◆ ArrayAny() [1/9]
ArrayAny::ArrayAny ( const TypeCode *  typeOfContent,
unsigned int  lgth
Definition at line 901 of file Any.cxx.
901 :ComposedAny(new TypeCodeArray("","",typeOfContent,lgth))
902{
904 for(unsigned int i=0;i<_type->getSizeInByteOfAnyReprInSeq();i++)
906}
friend class TypeCodeArray
Definition: Any.hxx:251
ComposedAny(const ComposedAny &other)
Definition: Any.cxx:500
static const char DFT_CHAR_VAR
Definition: Any.hxx:181
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::SeqAlloc::DFT_CHAR_VAR, YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), and yacsorb.CORBAEngineTest::i.
◆ ArrayAny() [2/9]
ArrayAny::ArrayAny ( char *  data,
TypeCodeArray *  type
Definition at line 908 of file Any.cxx.
908 :ComposedAny(type,false),_data(0)
909{
911 const TypeCode *subType=_type->contentType();
912 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
913 for(unsigned i=0;i<type->getStaticLgth();i++)
914 subType->putReprAtPlace(_data+i*sizePerContent,data+i*sizePerContent,false);
915}
unsigned getStaticLgth() const
Definition: TypeCode.cxx:576
virtual void putReprAtPlace(char *pt, const char *val, bool deepCpy) const
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), YACS::ENGINE::TypeCodeArray::getStaticLgth(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::TypeCode::putReprAtPlace().
◆ ArrayAny() [3/9]
ArrayAny::ArrayAny ( const ArrayAny &  other)
Definition at line 917 of file Any.cxx.
917 :ComposedAny(other)
918{
920 const TypeCode *subType=_type->contentType();
921 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
922 for(unsigned i=0;i<((TypeCodeArray *)_type)->getStaticLgth();i++)
923 subType->putReprAtPlace(_data+i*sizePerContent,other._data+i*sizePerContent,true);
924}
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::TypeCode::putReprAtPlace().
◆ ArrayAny() [4/9]
ArrayAny::ArrayAny ( const int *  val,
unsigned int  lgth
Definition at line 926 of file Any.cxx.
927 _data(0)
928{
931}
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
References _data, YACS::ENGINE::Any::_type, and YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq().
◆ ArrayAny() [5/9]
ArrayAny::ArrayAny ( const bool *  val,
unsigned int  lgth
Definition at line 933 of file Any.cxx.
934 _data(0)
935{
938}
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
◆ ArrayAny() [6/9]
ArrayAny::ArrayAny ( const double *  val,
unsigned int  lgth
Definition at line 940 of file Any.cxx.
941 _data(0)
942{
945}
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
◆ ArrayAny() [7/9]
ArrayAny::ArrayAny ( const std::vector< int > &  val)
Definition at line 947 of file Any.cxx.
947 :ComposedAny(new TypeCodeArray("","",Runtime::_tc_int,val.size())),
948 _data(0)
949{
951 memcpy(_data,&val[0],_type->getSizeInByteOfAnyReprInSeq());
952}
◆ ArrayAny() [8/9]
ArrayAny::ArrayAny ( const std::vector< double > &  val)
Definition at line 954 of file Any.cxx.
954 :ComposedAny(new TypeCodeArray("","",Runtime::_tc_double,val.size())),
955 _data(0)
956{
958 memcpy(_data,&val[0],_type->getSizeInByteOfAnyReprInSeq());
959}
◆ ArrayAny() [9/9]
ArrayAny::ArrayAny ( const std::vector< std::string > &  val)
Definition at line 961 of file Any.cxx.
961 :ComposedAny(new TypeCodeArray("","",Runtime::_tc_string,val.size())),
962 _data(0)
963{
965 unsigned i=0;
966 const TypeCode *subType=_type->contentType();
967 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
968 for(vector<std::string>::const_iterator iter=val.begin();iter!=val.end();iter++,i++)
969 {
970 StringOnHeap *st=new StringOnHeap(*iter);
971 memcpy(_data+i*sizePerContent,&st,sizePerContent);
972 }
973}
static YACS::ENGINE::TypeCode * _tc_string
Definition: Runtime.hxx:139
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), and yacsorb.CORBAEngineTest::i.
◆ clone()
Any * ArrayAny::clone ( ) const
Implements YACS::ENGINE::Any.
Definition at line 1008 of file Any.cxx.
1009{
1010 return new ArrayAny(*this);
1011}
friend class ArrayAny
Definition: Any.hxx:81
References YACS::ENGINE::Any::ArrayAny.
◆ destroyReprAtPlace()
void ArrayAny::destroyReprAtPlace ( char *  data,
const TypeCodeArray *  type
staticprotected
Definition at line 1034 of file Any.cxx.
1035{
1036 const TypeCode *subType=type->contentType();
1037 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1038 for(unsigned i=0;i<type->getStaticLgth();i++)
1039 subType->destroyZippedAny(data+i*sizePerContent);
1040}
Definition: TypeCode.cxx:581
References YACS::ENGINE::TypeCodeArray::contentType(), YACS::ENGINE::TypeCode::destroyZippedAny(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), YACS::ENGINE::TypeCodeArray::getStaticLgth(), and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::TypeCodeArray::destroyZippedAny().
◆ getOrBuildFromData()
AnyPtr ArrayAny::getOrBuildFromData ( char *  data,
staticprotected
Definition at line 1042 of file Any.cxx.
1043{
1044 Any *ret;
1045 ret=new ArrayAny(data,(TypeCodeArray *)type);
1046 return AnyPtr(ret);
1047}
Definition: Any.hxx:79
SharedPtr< Any > AnyPtr
Definition: Any.hxx:72
Referenced by YACS::ENGINE::TypeCodeArray::getOrBuildAnyFromZippedData().
◆ New() [1/3]
template<class T >
ArrayAny * YACS::ENGINE::ArrayAny::New ( const std::vector< T > &  vec)
Definition at line 324 of file Any.hxx.
325 {
326 return new ArrayAny(vec);
327 }
◆ New() [2/3]
template<class T >
ArrayAny * YACS::ENGINE::ArrayAny::New ( const T *  val,
unsigned int  lgth
Definition at line 330 of file Any.hxx.
331 {
332 return new ArrayAny(val,lgth);
333 }
◆ New() [3/3]
ArrayAny * ArrayAny::New ( const TypeCode *  typeOfContent,
unsigned int  lgth
Definition at line 1013 of file Any.cxx.
1014{
1015 return new ArrayAny(typeOfContent,lgth);
1016}
◆ operator==()
bool ArrayAny::operator== ( const Any &  other) const
Definition at line 983 of file Any.cxx.
984{
985 if(!_type->isA(other.getType()))
986 return false;
987 const ArrayAny& otherC=(const ArrayAny&) other;//cast granted due to previous lines
988 for(unsigned i=0;i<((const TypeCodeArray *)_type)->getStaticLgth();i++)
989 if(!((*(*this)[i])==(*otherC[i])))
990 return false;
991 return true;
992}
const TypeCode * getType() const
Definition: Any.hxx:85
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:99
References YACS::ENGINE::Any::_type, YACS::ENGINE::Any::getType(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::TypeCode::isA().
◆ operator[]()
AnyPtr ArrayAny::operator[] ( int  i) const
Definition at line 994 of file Any.cxx.
995{
996 const TypeCode *subType=_type->contentType();
997 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
998 if(i<0 || i>=((TypeCodeArray *)_type)->getStaticLgth())
999 throw Exception("Trying to access to an invalid index in an Any Tuple");
1000 return _type->contentType()->getOrBuildAnyFromZippedData(_data+i*sizePerContent);
1001}
virtual AnyPtr getOrBuildAnyFromZippedData(char *data) const
Definition: TypeCode.cxx:67
References _data, YACS::ENGINE::Any::_type, YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::TypeCode::getOrBuildAnyFromZippedData(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), and yacsorb.CORBAEngineTest::i.
◆ putMyReprAtPlace()
void ArrayAny::putMyReprAtPlace ( char *  data) const
Definition at line 1018 of file Any.cxx.
1019{
1020 const TypeCode *subType=_type->contentType();
1021 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1022 for(unsigned i=0;i<((const TypeCodeArray *)_type)->getStaticLgth();i++)
1023 subType->putReprAtPlace(data+i*sizePerContent,_data+i*sizePerContent,false);
1024}
◆ putReprAtPlace()
void ArrayAny::putReprAtPlace ( char *  data,
const char *  src,
const TypeCodeArray *  type,
bool  deepCpy
staticprotected
Definition at line 1026 of file Any.cxx.
1027{
1028 const TypeCode *subType=type->contentType();
1029 unsigned sizePerContent=subType->getSizeInByteOfAnyReprInSeq();
1030 for(unsigned i=0;i<type->getStaticLgth();i++)
1031 subType->putReprAtPlace(data+i*sizePerContent,src+i*sizePerContent,deepCpy);
1032}
References YACS::ENGINE::TypeCodeArray::contentType(), YACS::ENGINE::TypeCode::getSizeInByteOfAnyReprInSeq(), YACS::ENGINE::TypeCodeArray::getStaticLgth(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::TypeCode::putReprAtPlace().
Referenced by YACS::ENGINE::TypeCodeArray::putReprAtPlace().
◆ setEltAtRank()
void ArrayAny::setEltAtRank ( int  i,
const Any *  elem
◆ size()
unsigned int ArrayAny::size ( ) const
Definition at line 1003 of file Any.cxx.
1004{
1005 return ((TypeCodeArray *)_type)->getStaticLgth();
1006}
References YACS::ENGINE::Any::_type.
Referenced by ~ArrayAny().
◆ takeInChargeStorageOf()
bool ArrayAny::takeInChargeStorageOf ( TypeCode *  type)
staticprotected
Definition at line 1049 of file Any.cxx.
1050{
1051 DynType typ=type->kind();
1052 return (typ==Array);
1053}
DynType kind() const
Definition: TypeCode.cxx:47
References YACS::ENGINE::Array, and YACS::ENGINE::TypeCode::kind().
◆ TypeCodeArray
friend
Definition at line 251 of file Any.hxx.
◆ _data
char* YACS::ENGINE::ArrayAny::_data
Definition at line 281 of file Any.hxx.
Referenced by ArrayAny(), operator[](), putMyReprAtPlace(), setEltAtRank(), and ~ArrayAny().
