YACS::ENGINE::Runtime Class Referenceabstract
#include <Runtime.hxx>
Inheritance diagram for YACS::ENGINE::Runtime:
Collaboration diagram for YACS::ENGINE::Runtime:
virtual void init ()
virtual void fini ()
virtual std::vector< std::pair< std::string, int > > getCatalogOfComputeNodes () const =0
virtual Catalog * loadCatalog (const std::string &sourceKind, const std::string &path)
 Load a catalog of calculation to use as factory. More...
virtual InlineFuncNode * createFuncNode (const std::string &kind, const std::string &name)
virtual InlineNode * createScriptNode (const std::string &kind, const std::string &name)
virtual ServiceNode * createRefNode (const std::string &kind, const std::string &name)
virtual ServiceNode * createCompoNode (const std::string &kind, const std::string &name)
virtual ServiceInlineNode * createSInlineNode (const std::string &kind, const std::string &name)
virtual DataNode * createInDataNode (const std::string &kind, const std::string &name)
virtual DataNode * createOutDataNode (const std::string &kind, const std::string &name)
virtual ComponentInstance * createComponentInstance (const std::string &name, const std::string &kind="")
virtual Container * createContainer (const std::string &kind="")
virtual Proc * createProc (const std::string &name)
virtual Bloc * createBloc (const std::string &name)
virtual WhileLoop * createWhileLoop (const std::string &name)
virtual ForLoop * createForLoop (const std::string &name)
virtual ForEachLoop * createForEachLoop (const std::string &name, TypeCode *type)
virtual ForEachLoopDyn * createForEachLoopDyn (const std::string &name, TypeCode *type)
virtual OptimizerLoop * createOptimizerLoop (const std::string &name, const std::string &algLib, const std::string &factoryName, bool algInitOnFile, const std::string &kind="", Proc *procForTypes=NULL)
virtual Switch * createSwitch (const std::string &name)
virtual TypeCode * createInterfaceTc (const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
virtual TypeCode * createSequenceTc (const std::string &id, const std::string &name, TypeCode *content)
virtual TypeCodeStruct * createStructTc (const std::string &id, const std::string &name)
virtual InputPort * createInputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
virtual OutputPort * createOutputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
virtual InputDataStreamPort * createInputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual OutputDataStreamPort * createOutputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual InputPort * adapt (InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
virtual InputPort * adapt (InPropertyPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
virtual void * convertNeutral (TypeCode *type, Any *data)
 Convert a YACS::ENGINE::Any object to an external object with type type. More...
virtual std::string convertNeutralAsString (TypeCode *type, Any *data)
 Convert a YACS::ENGINE::Any object to a string to be used in GUI for example. More...
virtual void removeRuntime ()
virtual ~Runtime ()
virtual void setCatalogLoaderFactory (const std::string &name, CatalogLoader *factory)
 Add a catalog loader factory to the map _catalogLoaderFactoryMap under the name name. More...
Catalog * getBuiltinCatalog ()
 Get the catalog of base nodes (elementary and composed) More...
virtual void addCatalog (Catalog *catalog)
 Add a catalog of types and nodes to the runtime. More...
virtual TypeCode * getTypeCode (const std::string &name)
 Get a typecode by its name from runtime catalogs. More...
Public Attributes
std::map< std::string, CatalogLoader * > _catalogLoaderFactoryMap
Static Public Attributes
static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME [] ="Neutral"
static YACS::ENGINE::TypeCode * _tc_double = 0
static YACS::ENGINE::TypeCode * _tc_int = 0
static YACS::ENGINE::TypeCode * _tc_bool = 0
static YACS::ENGINE::TypeCode * _tc_string = 0
static YACS::ENGINE::TypeCode * _tc_file = 0
static YACS::ENGINE::TypeCode * _tc_stringpair = 0
static YACS::ENGINE::TypeCode * _tc_propvec = 0
 Runtime ()
std::set< std::string > _setOfImplementation
Catalog * _builtinCatalog
std::vector< Catalog * > _catalogs
Static Protected Attributes
static Runtime * _singleton = 0
Friends
Runtime * getRuntime ()
Definition at line 68 of file Runtime.hxx.
◆ ~Runtime()
Runtime::~Runtime ( )
Definition at line 143 of file Runtime.cxx.
144{
145 delete _builtinCatalog;
146 DEBTRACE( "_tc_double refcnt: " << Runtime::_tc_double->getRefCnt() );
147 DEBTRACE( "_tc_int refcnt: " << Runtime::_tc_int->getRefCnt() );
148 DEBTRACE( "_tc_bool refcnt: " << Runtime::_tc_bool->getRefCnt() );
149 DEBTRACE( "_tc_string refcnt: " << Runtime::_tc_string->getRefCnt() );
150 DEBTRACE( "_tc_file refcnt: " << Runtime::_tc_file->getRefCnt() );
156 for(std::vector<Catalog *>::iterator it=_catalogs.begin();it !=_catalogs.end();it++)
157 (*it)->decrRef();
159 DEBTRACE( "Total YACS::ENGINE::Refcount: " << RefCounter::_totalCnt );
160}
static unsigned int _totalCnt
Definition: RefCounter.hxx:35
Definition: Runtime.hxx:136
Definition: Runtime.hxx:138
Definition: Runtime.hxx:153
Definition: Runtime.hxx:140
Definition: Runtime.hxx:154
Definition: Runtime.hxx:150
Definition: Runtime.hxx:137
Definition: Runtime.hxx:139
References _builtinCatalog, _catalogs, _singleton, _tc_bool, _tc_double, _tc_file, _tc_int, _tc_string, YACS::ENGINE::RefCounter::_totalCnt, DEBTRACE, and YACS::ENGINE::RefCounter::decrRef().
◆ Runtime()
Runtime::Runtime ( )
Definition at line 68 of file Runtime.cxx.
69{
70 DEBTRACE("Runtime::Runtime");
75 Runtime::_tc_file = new TypeCodeObjref("file", "file");
76 TypeCodeStruct * stringpair = new TypeCodeStruct("stringpair", "stringpair");
77 stringpair->addMember("name", Runtime::_tc_string);
78 stringpair->addMember("value", Runtime::_tc_string);
79 Runtime::_tc_stringpair = stringpair;
80 Runtime::_tc_propvec = new TypeCodeSeq("propvec", "propvec", Runtime::_tc_stringpair);
81 DEBTRACE( "_tc_double refcnt: " << Runtime::_tc_double->getRefCnt() );
82 DEBTRACE( "_tc_int refcnt: " << Runtime::_tc_int->getRefCnt() );
83 DEBTRACE( "_tc_bool refcnt: " << Runtime::_tc_bool->getRefCnt() );
84 DEBTRACE( "_tc_string refcnt: " << Runtime::_tc_string->getRefCnt() );
85 DEBTRACE( "_tc_file refcnt: " << Runtime::_tc_file->getRefCnt() );
86 DEBTRACE( "_tc_stringpair refcnt: " << Runtime::_tc_stringpair->getRefCnt() );
87 DEBTRACE( "_tc_propvec refcnt: " << Runtime::_tc_propvec->getRefCnt() );
88 _builtinCatalog = new Catalog("builtins");
89 std::map<std::string,TypeCode*>& typeMap=_builtinCatalog->_typeMap;
90 /* All composed node creations are moved to RuntimeSALOME::initBuiltins.
91 It is not safe to have all those calls to virtual functions (create*)
92 in the constructor. */
94 typeMap["double"]=Runtime::_tc_double;
96 typeMap["int"]=Runtime::_tc_int;
98 typeMap["bool"]=Runtime::_tc_bool;
100 typeMap["string"]=Runtime::_tc_string;
102 typeMap["file"]=Runtime::_tc_file;
104 typeMap["stringpair"]=Runtime::_tc_stringpair;
106 typeMap["propvec"]=Runtime::_tc_propvec;
107
108 // Get dynamic trace level
110 char* valenv=getenv("YACS_TRACELEVEL");
111 if(valenv)
112 {
113 std::istringstream iss(valenv);
114 int temp;
115 if (iss >> temp)
116 YACS::traceLevel=temp;
117 }
118
119 // Get max threads number
120 char *maxThreadStr = getenv("YACS_MAX_THREADS");
121 if (maxThreadStr != NULL)
122 {
123 int maxThreads = atoi(maxThreadStr);
124 DEBTRACE("maxThreads = " << maxThreads);
125 if (maxThreads > 0) Executor::_maxThreads = maxThreads;
126 }
127
128 // Get thread stack size
129 char *threadStackSizeStr = getenv("YACS_THREADS_STACK_SIZE");
130 if (threadStackSizeStr != NULL)
131 {
132 size_t threadStackSize = strtoul(threadStackSizeStr, NULL, 0);
133 DEBTRACE("threadStackSize = " << threadStackSize);
134 if (threadStackSize > 0) Executor::_threadStackSize = threadStackSize;
135 }
136}
class for YACS catalogs.
Definition: Catalog.hxx:42
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
static size_t _threadStackSize
Definition: Executor.hxx:132
static int _maxThreads
Definition: Executor.hxx:131
Definition: Runtime.hxx:142
Definition: Runtime.hxx:141
Class for reference objects.
Definition: TypeCode.hxx:126
Class for sequence objects.
Definition: TypeCode.hxx:160
Class for struct type.
Definition: TypeCode.hxx:228
virtual void addMember(const std::string &name, TypeCode *tc)
The only non const method.
Definition: TypeCode.cxx:781
Definition: TypeCode.hxx:68
int traceLevel
Definition: YacsTrace.cxx:37
References _builtinCatalog, YACS::ENGINE::Executor::_maxThreads, _tc_bool, _tc_double, _tc_file, _tc_int, _tc_propvec, _tc_string, _tc_stringpair, YACS::ENGINE::Executor::_threadStackSize, YACS::ENGINE::Catalog::_typeMap, YACS::ENGINE::TypeCodeStruct::addMember(), YACS::ENGINE::Bool, DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::RefCounter::incrRef(), YACS::ENGINE::Int, YACS::ENGINE::String, and YACS::traceLevel.
◆ adapt() [1/2]
virtual InputPort * YACS::ENGINE::Runtime::adapt ( InPropertyPort *  source,
const std::string &  impl,
TypeCode *  type,
bool  init = false
pure virtual
Implemented in YACS::ENGINE::RuntimeSALOME.
◆ adapt() [2/2]
virtual InputPort * YACS::ENGINE::Runtime::adapt ( InputPort *  source,
TypeCode *  type,
bool  init = false
pure virtual
◆ addCatalog()
void Runtime::addCatalog ( Catalog *  catalog)
These catalogs are searched when calling getTypeCode method
Definition at line 323 of file Runtime.cxx.
324{
325 _catalogs.push_back(catalog);
326 catalog->incrRef();
327}
References _catalogs, and YACS::ENGINE::RefCounter::incrRef().
Referenced by YACS::HMI::GenericGui::GenericGui(), and main().
◆ convertNeutral()
void * Runtime::convertNeutral ( TypeCode *  type,
Any *  data
This method is used to convert Neutral objects to script languages. For example Python language. The runtime has one external script language. The object is returned as a void * because engine knows nothing about external script language.
typethe type of the converted object if the conversion is possible
datathe object to convert
Reimplemented in YACS::ENGINE::RuntimeSALOME.
Definition at line 355 of file Runtime.cxx.
356{
357 throw Exception("convertNeutral is not implemented by your runtime");
358}
◆ convertNeutralAsString()
std::string Runtime::convertNeutralAsString ( TypeCode *  type,
Any *  data
engine package does not provide a conversion to string. It has to be implemented in the runtime package.
typethe type of the object to convert
the string representation of the object
Definition at line 369 of file Runtime.cxx.
370{
371 throw Exception("convertNeutralAsString is not implemented by your runtime");
372}
Referenced by YACS::ENGINE::AnyInputPort::getAsString(), and YACS::ENGINE::AnyOutputPort::getAsString().
◆ createBloc()
Bloc * Runtime::createBloc ( const std::string &  name)
Definition at line 231 of file Runtime.cxx.
232{
233 return new Bloc(name);
234}
Definition: Bloc.hxx:36
Referenced by YACS::bloctypeParser< T >::name().
◆ createComponentInstance()
ComponentInstance * Runtime::createComponentInstance ( const std::string &  name,
const std::string &  kind = ""
Definition at line 215 of file Runtime.cxx.
217{
218 throw Exception("ComponentInstance factory not implemented");
219}
Referenced by YACS::ENGINE::Proc::createComponentInstance(), YACS::inlinetypeParser< T >::function(), and YACS::ENGINE::ServiceNode::setRef().
◆ createCompoNode()
ServiceNode * Runtime::createCompoNode ( const std::string &  kind,
Definition at line 205 of file Runtime.cxx.
206{
207 throw Exception("CompoNode factory not implemented");
208}
Referenced by YACS::servicetypeParser< T >::component(), YACS::servicetypeParser< T >::componentinstance(), and YACS::ENGINE::SessionCataLoader::importComponent().
◆ createContainer()
Container * Runtime::createContainer ( const std::string &  kind = "")
Definition at line 221 of file Runtime.cxx.
222{
223 throw Exception("Container factory not implemented");
224}
Referenced by YACS::ENGINE::CppComponent::CppComponent(), and YACS::ENGINE::CppComponent::load().
◆ createForEachLoop()
ForEachLoop * Runtime::createForEachLoop ( const std::string &  name,
TypeCode *  type
Definition at line 251 of file Runtime.cxx.
252{
253 ForEachLoop* ret = new ForEachLoop(name,type);
254 ret->edGetNbOfBranchesPort()->edInit(1);
255 return ret;
256}
InputPort * edGetNbOfBranchesPort()
Definition: DynParaLoop.hxx:83
Loop node for parametric calculation.
void edInit(T value)
Definition: InputPort.hxx:129
References YACS::ENGINE::DynParaLoop::edGetNbOfBranchesPort(), and YACS::ENGINE::InputPort::edInit().
Referenced by YACS::buildFrom< ENGINE::ForEachLoop * >(), and YACS::ENGINE::RuntimeSALOME::initBuiltins().
◆ createForEachLoopDyn()
ForEachLoopDyn * Runtime::createForEachLoopDyn ( const std::string &  name,
TypeCode *  type
Definition at line 258 of file Runtime.cxx.
259{
260 return new ForEachLoopDyn(name,type);
261}
Referenced by YACS::buildFrom< ENGINE::ForEachLoopDyn * >().
◆ createForLoop()
ForLoop * Runtime::createForLoop ( const std::string &  name)
Definition at line 246 of file Runtime.cxx.
247{
248 return new ForLoop(name);
249}
Class for for loop node.
Definition: ForLoop.hxx:33
Referenced by YACS::forlooptypeParser< T >::name().
◆ createFuncNode()
InlineFuncNode * Runtime::createFuncNode ( const std::string &  kind,
Definition at line 190 of file Runtime.cxx.
191{
192 throw Exception("FuncNode factory not implemented");
193}
Referenced by YACS::inlinetypeParser< T >::function(), YACS::remotetypeParser< T >::function(), and YACS::servertypeParser< T >::loadcontainer().
◆ createInDataNode()
DataNode * Runtime::createInDataNode ( const std::string &  kind,
Definition at line 180 of file Runtime.cxx.
181{
182 throw Exception("InDataNode factory not implemented");
183}
Referenced by YACS::presettypeParser< T >::create().
◆ createInputDataStreamPort()
InputDataStreamPort * Runtime::createInputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 269 of file Runtime.cxx.
270{
271 return new InputDataStreamPort(name,node,type);
272}
Referenced by YACS::ENGINE::ElementaryNode::createInputDataStreamPort().
◆ createInputPort()
virtual InputPort * YACS::ENGINE::Runtime::createInputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
pure virtual
◆ createInterfaceTc()
TypeCode * Runtime::createInterfaceTc ( const std::string &  id,
Definition at line 162 of file Runtime.cxx.
164{
165 return TypeCode::interfaceTc(id.c_str(),name.c_str(),ltc);
166}
static TypeCode * interfaceTc(const char *id, const char *name)
static factory of object reference type given an id and a name
Definition: TypeCode.cxx:229
References YACS::ENGINE::TypeCode::interfaceTc().
◆ createOptimizerLoop()
OptimizerLoop * Runtime::createOptimizerLoop ( const std::string &  name,
const std::string &  algLib,
const std::string &  factoryName,
bool  algInitOnFile,
const std::string &  kind = "",
Proc *  procForTypes = NULL
Definition at line 263 of file Runtime.cxx.
265{
266 return new OptimizerLoop(name,algLib,factoryName,algInitOnFile, true, procForTypes);
267}
Referenced by YACS::optimizerlooptypeParser< T >::postAttr().
◆ createOutDataNode()
DataNode * Runtime::createOutDataNode ( const std::string &  kind,
Definition at line 185 of file Runtime.cxx.
186{
187 throw Exception("OutDataNode factory not implemented");
188}
Referenced by YACS::outnodetypeParser< T >::create().
◆ createOutputDataStreamPort()
OutputDataStreamPort * Runtime::createOutputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 274 of file Runtime.cxx.
275{
276 return new OutputDataStreamPort(name,node,type);
277}
Referenced by YACS::ENGINE::ElementaryNode::createOutputDataStreamPort().
◆ createOutputPort()
virtual OutputPort * YACS::ENGINE::Runtime::createOutputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
pure virtual
◆ createProc()
Proc * Runtime::createProc ( const std::string &  name)
Definition at line 226 of file Runtime.cxx.
227{
228 return new Proc(name);
229}
Definition: Proc.hxx:44
Referenced by YACS::proctypeParser< T >::pre().
◆ createRefNode()
ServiceNode * Runtime::createRefNode ( const std::string &  kind,
Definition at line 200 of file Runtime.cxx.
201{
202 throw Exception("RefNode factory not implemented");
203}
Referenced by YACS::servicetypeParser< T >::ref().
◆ createScriptNode()
InlineNode * Runtime::createScriptNode ( const std::string &  kind,
Definition at line 195 of file Runtime.cxx.
196{
197 throw Exception("ScriptNode factory not implemented");
198}
Referenced by YACS::inlinetypeParser< T >::script(), and YACS::remotetypeParser< T >::script().
◆ createSequenceTc()
TypeCode * Runtime::createSequenceTc ( const std::string &  id,
TypeCode *  content
Definition at line 168 of file Runtime.cxx.
171{
172 return TypeCode::sequenceTc(id.c_str(),name.c_str(),content);
173};
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
Definition: TypeCode.cxx:254
References YACS::ENGINE::TypeCode::sequenceTc().
◆ createSInlineNode()
ServiceInlineNode * Runtime::createSInlineNode ( const std::string &  kind,
Definition at line 210 of file Runtime.cxx.
211{
212 throw Exception("SInlineNode factory not implemented");
213}
Referenced by YACS::inlinetypeParser< T >::function().
◆ createStructTc()
TypeCodeStruct * Runtime::createStructTc ( const std::string &  id,
Definition at line 175 of file Runtime.cxx.
176{
177 return (TypeCodeStruct *)TypeCode::structTc(id.c_str(),name.c_str());
178}
static TypeCode * structTc(const char *id, const char *name)
static factory of struct type given an id and a name
Definition: TypeCode.cxx:269
References YACS::ENGINE::TypeCode::structTc().
◆ createSwitch()
Switch * Runtime::createSwitch ( const std::string &  name)
Definition at line 236 of file Runtime.cxx.
237{
238 return new Switch(name);
239}
Definition: Switch.hxx:85
Referenced by YACS::ENGINE::RuntimeSALOME::initBuiltins(), and YACS::switchtypeParser::name().
◆ createWhileLoop()
WhileLoop * Runtime::createWhileLoop ( const std::string &  name)
Definition at line 241 of file Runtime.cxx.
242{
243 return new WhileLoop(name);
244}
Class for a while loop.
Definition: WhileLoop.hxx:39
Referenced by YACS::whilelooptypeParser< T >::name().
◆ fini()
virtual void YACS::ENGINE::Runtime::fini ( )
Definition at line 73 of file Runtime.hxx.
73{ }
Referenced by main().
◆ getBuiltinCatalog()
Catalog * Runtime::getBuiltinCatalog ( )
◆ getCatalogOfComputeNodes()
virtual std::vector< std::pair< std::string, int > > YACS::ENGINE::Runtime::getCatalogOfComputeNodes ( ) const
pure virtual
◆ getTypeCode()
TypeCode * Runtime::getTypeCode ( const std::string &  name)
the typecode if it exists or NULL
Definition at line 333 of file Runtime.cxx.
334{
335 if (_builtinCatalog->_typeMap.count(name) != 0)
336 return _builtinCatalog->_typeMap[name];
337 for(std::vector<Catalog *>::const_iterator it=_catalogs.begin();it !=_catalogs.end();it++)
338 {
339 if ((*it)->_typeMap.count(name) != 0)
340 return (*it)->_typeMap[name];
341 }
342 return 0;
343}
References _builtinCatalog, _catalogs, and YACS::ENGINE::Catalog::_typeMap.
Referenced by YACS::objtypeParser::base(), YACS::seqtypeParser::content(), YACS::ENGINE::Proc::getTypeCode(), YACS::inlinetypeParser< T >::inport(), YACS::servertypeParser< T >::instream(), YACS::servicetypeParser< T >::instream(), YACS::structtypeParser::member(), YACS::inlinetypeParser< T >::outport(), YACS::servertypeParser< T >::outstream(), YACS::servicetypeParser< T >::outstream(), YACS::outnodetypeParser< T >::parameter(), YACS::presettypeParser< T >::parameter(), and YACS::foreachlooptypeParser< T >::postAttr().
◆ init()
◆ loadCatalog()
Catalog * Runtime::loadCatalog ( const std::string &  sourceKind,
const std::string &  path
sourceKindthe kind of catalog source. It depends on runtime. It could be a file, a server, a directory
paththe path to the catalog.
the loaded Catalog
Definition at line 285 of file Runtime.cxx.
286{
287 if (_catalogLoaderFactoryMap.find(sourceKind) == _catalogLoaderFactoryMap.end())
288 {
289 throw Exception("This type of catalog loader does not exist: " + sourceKind);
290 }
291 else
292 {
293 Catalog* cata=new Catalog(path);
294 CatalogLoader* proto=_catalogLoaderFactoryMap[sourceKind];
295 proto->load(cata,path);
296 return cata;
297 }
298}
class for YACS catalog loader.
Definition: Catalog.hxx:63
virtual void load(Catalog *cata, const std::string &path)
Definition: Catalog.cxx:74
Definition: Runtime.hxx:144
References _catalogLoaderFactoryMap, and YACS::ENGINE::CatalogLoader::load().
Referenced by YACS::HMI::CatalogWidget::addCatalogFromFile(), YACS::HMI::GenericGui::GenericGui(), and main().
◆ removeRuntime()
void Runtime::removeRuntime ( )
Definition at line 138 of file Runtime.cxx.
139{
140 delete this;
141}
◆ setCatalogLoaderFactory()
void Runtime::setCatalogLoaderFactory ( const std::string &  name,
CatalogLoader *  factory
namename under which the factory is registered
factorythe factory
Definition at line 305 of file Runtime.cxx.
306{
307 _catalogLoaderFactoryMap[name]=factory;
308}
References _catalogLoaderFactoryMap.
Referenced by YACS::YACSLoader::registerProcCataLoader().
◆ getRuntime
Runtime * getRuntime ( )
friend
◆ _builtinCatalog
Catalog* YACS::ENGINE::Runtime::_builtinCatalog
◆ _catalogLoaderFactoryMap
std::map<std::string,CatalogLoader*> YACS::ENGINE::Runtime::_catalogLoaderFactoryMap
◆ _catalogs
std::vector<Catalog*> YACS::ENGINE::Runtime::_catalogs
Definition at line 154 of file Runtime.hxx.
Referenced by addCatalog(), getTypeCode(), and ~Runtime().
◆ _setOfImplementation
std::set<std::string> YACS::ENGINE::Runtime::_setOfImplementation
Definition at line 152 of file Runtime.hxx.
Referenced by YACS::ENGINE::RuntimeSALOME::RuntimeSALOME().
◆ _singleton
Runtime * Runtime::_singleton = 0
staticprotected
◆ _tc_bool
◆ _tc_double
◆ _tc_file
◆ _tc_int
◆ _tc_propvec
TypeCode * Runtime::_tc_propvec = 0
Definition at line 142 of file Runtime.hxx.
Referenced by YACS::ENGINE::Node::Node(), and Runtime().
◆ _tc_string
◆ _tc_stringpair
TypeCode * Runtime::_tc_stringpair = 0
Definition at line 141 of file Runtime.hxx.
Referenced by Runtime().
◆ RUNTIME_ENGINE_INTERACTION_IMPL_NAME
const char Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME ="Neutral"
