YACS::ENGINE::InlineNode Class Reference
Class for calculation node (script) inlined (and executed) in the schema. More...
#include <InlineNode.hxx>
Inheritance diagram for YACS::ENGINE::InlineNode:
Collaboration diagram for YACS::ENGINE::InlineNode:
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
bool isDeployable () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
static int _total = 0
This node is like a script. It has no state if it is executed several times. Each execution the string _script is executed within a clean context.
See also
ServiceNode
ElementaryNode
Definition at line 43 of file InlineNode.hxx.
◆ InlineNode() [1/2]
YACS::ENGINE::InlineNode::InlineNode ( const InlineNode &  other,
ComposedNode *  father
inlineprotected
Definition at line 46 of file InlineNode.hxx.
47 :ElementaryNode(other,father),_script(other._script),_mode(other._mode),_container(0) { }
friend class ElementaryNode
Definition: Node.hxx:80
◆ InlineNode() [2/2]
YACS::ENGINE::InlineNode::InlineNode ( const std::string &  name)
inlineprotected
Definition at line 48 of file InlineNode.hxx.
static const char LOCAL_STR[]
Definition: InlineNode.hxx:72
◆ ~InlineNode()
InlineNode::~InlineNode ( )
Definition at line 35 of file InlineNode.cxx.
36{
37 if(_container)
39}
References _container, and YACS::ENGINE::RefCounter::decrRef().
◆ accept()
void InlineNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ElementaryNode.
Reimplemented in YACS::ENGINE::InlineFuncNode, and YACS::ENGINE::ServerNode.
Definition at line 41 of file InlineNode.cxx.
42{
43 visitor->visitInlineNode(this);
44}
virtual void visitInlineNode(InlineNode *node)=0
References YACS::ENGINE::Visitor::visitInlineNode().
◆ cloneNode()
virtual InlineNode * YACS::ENGINE::InlineNode::cloneNode ( const std::string &  name)
namename of the new node
the new node built by cloning.
Reimplemented in YACS::ENGINE::PythonNode, and YACS::ENGINE::PyFuncNode.
Definition at line 58 of file InlineNode.hxx.
59 { throw Exception("Not implemented");};
◆ getContainer()
◆ getExecutionMode()
std::string InlineNode::getExecutionMode ( )
◆ getMaxLevelOfParallelism()
int InlineNode::getMaxLevelOfParallelism ( ) const
Definition at line 142 of file InlineNode.cxx.
143{
144 if(!isDeployable())
145 return 1;
146 if(!_container)
147 return 1;
148 std::map<std::string,std::string> props(_container->getProperties());
149 std::map<std::string,std::string>::iterator it(props.find(std::string("nb_proc_per_node")));
150 if(it==props.end())
151 return 1;
152 if((*it).second.empty())
153 return 1;
154 std::istringstream iss((*it).second);
155 int ret(1); iss >> ret;
156 return ret;
157}
virtual std::map< std::string, std::string > getProperties() const =0
References _container, YACS::ENGINE::Container::getProperties(), and isDeployable().
◆ getScript()
◆ isDeployable()
bool InlineNode::isDeployable ( ) const
Reimplemented in YACS::ENGINE::ServerNode.
Definition at line 134 of file InlineNode.cxx.
135{
136 if(_mode==REMOTE_STR)
137 return true;
138 else
139 return false;
140}
static const char REMOTE_STR[]
Definition: InlineNode.hxx:73
References _mode, and REMOTE_STR.
Referenced by getMaxLevelOfParallelism().
◆ performDuplicationOfPlacement()
void InlineNode::performDuplicationOfPlacement ( const Node &  other)
performs a duplication of placement using clone method of containers and components. clone behaviour is driven by attachOnCloning attribute.
Definition at line 115 of file InlineNode.cxx.
116{
117 const InlineNode &otherC=*(dynamic_cast<const InlineNode *>(&other));
118 //if other has no container don't clone: this will not have one
119 if(otherC._container)
120 _container=otherC._container->clone();
121}
virtual Container * clone() const =0
WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method
Definition: InlineNode.hxx:44
References _container, and YACS::ENGINE::Container::clone().
◆ performShallowDuplicationOfPlacement()
void InlineNode::performShallowDuplicationOfPlacement ( const Node &  other)
performs a also duplication of placement but here containers and components are not copied at all whatever the value of attachedOnCloning.
Definition at line 123 of file InlineNode.cxx.
124{
125 const InlineNode &otherC=*(dynamic_cast<const InlineNode *>(&other));
126 //if other has no container don't clone: this will not have one
127 if(otherC._container)
128 {
129 _container=otherC._container;
131 }
132}
References _container, and YACS::ENGINE::RefCounter::incrRef().
◆ setContainer()
◆ setExecutionMode()
void InlineNode::setExecutionMode ( const std::string &  mode)
Definition at line 85 of file InlineNode.cxx.
86{
87 if(mode == _mode)return;
88 if(mode == LOCAL_STR || mode == REMOTE_STR)
89 {
90 _mode=mode;
91 modified();
92 }
93}
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References _mode, LOCAL_STR, YACS::ENGINE::Node::modified(), and REMOTE_STR.
Referenced by YACS::remotetypeParser< T >::function(), and YACS::remotetypeParser< T >::script().
◆ setScript()
void InlineNode::setScript ( const std::string &  script)
scriptscript to execute
Definition at line 50 of file InlineNode.cxx.
51{
52 _script=script;
53 modified();
54}
References _script, and YACS::ENGINE::Node::modified().
Referenced by YACS::inlinetypeParser< T >::function(), YACS::remotetypeParser< T >::function(), YACS::inlinetypeParser< T >::script(), YACS::remotetypeParser< T >::script(), and YACS::servertypeParser< T >::script().
◆ typeName()
virtual std::string YACS::ENGINE::InlineNode::typeName ( )
Reimplemented in YACS::ENGINE::InlineFuncNode, YACS::ENGINE::ServerNode, YACS::ENGINE::DistributedPythonNode, YACS::ENGINE::PythonNode, and YACS::ENGINE::PyFuncNode.
Definition at line 62 of file InlineNode.hxx.
62{return "YACS__ENGINE__InlineNode";}
◆ _container
◆ _mode
◆ _script
◆ LOCAL_STR
const char InlineNode::LOCAL_STR ="local"
◆ REMOTE_STR
const char InlineNode::REMOTE_STR ="remote"
Definition at line 73 of file InlineNode.hxx.
Referenced by isDeployable(), and setExecutionMode().
