YACS::ENGINE::Container Class Referenceabstract
#include <Container.hxx>
Inheritance diagram for YACS::ENGINE::Container:
Collaboration diagram for YACS::ENGINE::Container:
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
This is an abstract class, that represents an abstract process in which ComponentInstances can be launched and run. An instance of this will be mapped to one and only one physical container (except in the foreach context)
Definition at line 41 of file Container.hxx.
◆ Container()
Container::Container ( )
Definition at line 37 of file Container.cxx.
38{
39}
◆ ~Container()
Container::~Container ( )
Definition at line 41 of file Container.cxx.
42{
43}
◆ addComponentName()
virtual void YACS::ENGINE::Container::addComponentName ( const std::string &  name)
pure virtual
◆ attachOnCloning()
void Container::attachOnCloning ( ) const
By calling this method the current container 'this' is not destined to be deeply copied on clone call.
Reimplemented in YACS::ENGINE::HomogeneousPoolContainer.
Definition at line 76 of file Container.cxx.
77{
79}
References _isAttachedOnCloning.
◆ canAcceptImposedResource()
bool Container::canAcceptImposedResource ( )
◆ checkCapabilityToDealWith()
virtual void YACS::ENGINE::Container::checkCapabilityToDealWith ( const ComponentInstance *  inst) const
pure virtual
◆ clearProperties()
virtual void YACS::ENGINE::Container::clearProperties ( )
pure virtual
◆ clone()
◆ cloneAlways()
virtual Container * YACS::ENGINE::Container::cloneAlways ( ) const
pure virtual
◆ dettachOnCloning()
void Container::dettachOnCloning ( ) const
By calling this method the current container 'this' will be deeply copied on clone call.
Definition at line 84 of file Container.cxx.
85{
87}
◆ getDiscreminantStrOfThis()
std::string Container::getDiscreminantStrOfThis ( const Task *  askingNode) const
Reimplemented in YACS::ENGINE::SalomeContainerTmpForHP, and YACS::ENGINE::SalomeHPContainer.
Definition at line 45 of file Container.cxx.
46{
47 const void *ptr(this);
48 std::ostringstream oss; oss << ptr;
49 return oss.str();
50}
Referenced by YACS::ENGINE::SalomeContainerTools::getNotNullContainerName().
◆ getFullPlacementId()
virtual std::string YACS::ENGINE::Container::getFullPlacementId ( const Task *  askingNode) const
pure virtual
◆ getKind()
virtual std::string YACS::ENGINE::Container::getKind ( ) const
pure virtual
◆ getName()
◆ getPlacementId()
virtual std::string YACS::ENGINE::Container::getPlacementId ( const Task *  askingNode) const
pure virtual
◆ getProc()
Proc * YACS::ENGINE::Container::getProc ( )
Definition at line 85 of file Container.hxx.
85{ return _proc; }
References driver_internal::_proc.
Referenced by YACS::ENGINE::SalomeContainerToolsBase::CreateComponentInstance().
◆ getProperties()
◆ getProperty()
◆ getResourceProperties()
virtual std::map< std::string, std::string > YACS::ENGINE::Container::getResourceProperties ( const std::string &  name) const
pure virtual
◆ isAlreadyStarted()
◆ isAttachedOnCloning()
◆ isSupportingRTODefNbOfComp()
bool Container::isSupportingRTODefNbOfComp ( ) const
This method informs about the capability of the container to deal with CT an unpredictably number of components. By default : True
Definition at line 98 of file Container.cxx.
99{
100 return true;
101}
◆ isUsingPythonCache()
bool Container::isUsingPythonCache ( )
Definition at line 109 of file Container.cxx.
110{
111 bool found = false;
112 std::string str_value;
114 const char* yes_values[] = {"YES", "Yes", "yes", "TRUE", "True", "true", "1",
115 "ON", "on", "On"};
116 for(const char* v : yes_values)
117 if(str_value == v)
118 {
119 found = true;
120 break;
121 }
122 return found;
123}
virtual std::string getProperty(const std::string &name) const =0
static const char USE_PYCACHE_PROPERTY[]
Definition: Container.hxx:89
References getProperty(), and USE_PYCACHE_PROPERTY.
Referenced by FormAdvParamContainer::FillPanel(), YACS::ENGINE::PythonNode::isUsingPythonCache(), and FormAdvParamContainer::onModifyUsePyCache().
◆ lock()
virtual void YACS::ENGINE::Container::lock ( )
pure virtual
◆ setAttachOnCloningStatus()
void Container::setAttachOnCloningStatus ( bool  val) const
If val is equal to true the current container 'this' is not destined to be deeply copied on clone call. If val is equal to false the current container 'this' is destined to be deeply copied on clone call.
Definition at line 68 of file Container.cxx.
69{
71}
Referenced by FormContainer::onModifyAOC(), and YACS::ENGINE::SalomeContainer::setProperty().
◆ setName()
void YACS::ENGINE::Container::setName ( std::string  name)
Definition at line 83 of file Container.hxx.
83{ _name = name; }
Referenced by YACS::ENGINE::Proc::createContainer(), YACS::servertypeParser< T >::loadcontainer(), YACS::HMI::CommandRenameContainer::localExecute(), YACS::HMI::CommandAddContainerBase::localExecute(), and YACS::HMI::CommandRenameContainer::localReverse().
◆ setProc()
void YACS::ENGINE::Container::setProc ( Proc *  proc)
◆ setProperties()
void Container::setProperties ( const std::map< std::string, std::string > &  properties)
Definition at line 103 of file Container.cxx.
104{
105 for (std::map<std::string,std::string>::const_iterator it=properties.begin();it!=properties.end();++it)
106 setProperty((*it).first,(*it).second);
107}
virtual void setProperty(const std::string &name, const std::string &value)=0
References setProperty().
Referenced by YACS::HMI::CommandAddContainerBase::localExecute().
◆ setProperty()
virtual void YACS::ENGINE::Container::setProperty ( const std::string &  name,
const std::string &  value
pure virtual
◆ shutdown()
◆ start() [1/2]
◆ start() [2/2]
void Container::start ( const Task *  askingNode,
const std::string &  resource_name,
const std::string &  container_name
Reimplemented in YACS::ENGINE::SalomeContainer.
Definition at line 52 of file Container.cxx.
55{
56 return start(askingNode);
57}
virtual void start(const Task *askingNode)=0
References start().
◆ unLock()
virtual void YACS::ENGINE::Container::unLock ( )
pure virtual
◆ usePythonCache()
void Container::usePythonCache ( bool  v)
Definition at line 125 of file Container.cxx.
126{
127 if(v)
129 else
131}
References setProperty(), and USE_PYCACHE_PROPERTY.
Referenced by FormAdvParamContainer::onModifyUsePyCache().
◆ _isAttachedOnCloning
◆ _name
std::string YACS::ENGINE::Container::_name
Definition at line 91 of file Container.hxx.
Referenced by YACS::ENGINE::SalomeContainer::shutdown().
◆ _proc
Proc* YACS::ENGINE::Container::_proc
Definition at line 93 of file Container.hxx.
◆ AOC_ENTRY
◆ KIND_ENTRY
const char Container::KIND_ENTRY ="container_kind"
◆ USE_PYCACHE_PROPERTY
const char Container::USE_PYCACHE_PROPERTY ="use_py_cache"
Definition at line 89 of file Container.hxx.
Referenced by isUsingPythonCache(), and usePythonCache().
