Container.cxx
20#include "Container.hxx"
21#include "ComponentInstance.hxx"
23//#define _DEVDEBUG_
24#include "YacsTrace.hxx"
26#include <sstream>
27
28using namespace std;
29using namespace YACS::ENGINE;
30
31const char Container::KIND_ENTRY[]="container_kind";
32
33const char Container::AOC_ENTRY[]="attached_on_cloning";
34
35const char Container::USE_PYCACHE_PROPERTY[]="use_py_cache";
36
37Container::Container():_isAttachedOnCloning(false),_proc(0)
38{
39}
40
42{
43}
44
45std::string Container::getDiscreminantStrOfThis(const Task *askingNode) const
46{
47 const void *ptr(this);
48 std::ostringstream oss; oss << ptr;
49 return oss.str();
50}
51
52void Container::start(const Task *askingNode,
53 const std::string& resource_name,
54 const std::string& container_name)
55{
56 return start(askingNode);
57}
58
60{
61 return false;
62}
63
69{
71}
72
77{
79}
80
85{
87}
88
90{
92}
93
99{
100 return true;
101}
102
103void Container::setProperties(const std::map<std::string,std::string>& properties)
104{
105 for (std::map<std::string,std::string>::const_iterator it=properties.begin();it!=properties.end();++it)
106 setProperty((*it).first,(*it).second);
107}
108
110{
111 bool found = false;
112 std::string str_value;
114 const char* yes_values[] = {"YES", "Yes", "yes", "TRUE", "True", "true", "1",
115 "ON", "on", "On"};
116 for(const char* v : yes_values)
117 if(str_value == v)
118 {
119 found = true;
120 break;
121 }
122 return found;
123}
124
126{
127 if(v)
129 else
131}
132
virtual void start(const Task *askingNode)=0
virtual bool isSupportingRTODefNbOfComp() const
Definition: Container.cxx:98
virtual std::string getDiscreminantStrOfThis(const Task *askingNode) const
Definition: Container.cxx:45
virtual void setProperty(const std::string &name, const std::string &value)=0
virtual void attachOnCloning() const
Definition: Container.cxx:76
virtual void dettachOnCloning() const
Definition: Container.cxx:84
virtual std::string getProperty(const std::string &name) const =0
virtual void usePythonCache(bool v)
Definition: Container.cxx:125
static const char USE_PYCACHE_PROPERTY[]
Definition: Container.hxx:89
virtual bool isUsingPythonCache()
Definition: Container.cxx:109
virtual bool isAttachedOnCloning() const
Definition: Container.cxx:89
virtual bool canAcceptImposedResource()
Definition: Container.cxx:59
virtual void setAttachOnCloningStatus(bool val) const
Definition: Container.cxx:68
virtual void setProperties(const std::map< std::string, std::string > &properties)
Definition: Container.cxx:103
