Container.hxx
20#ifndef __CONTAINER_HXX__
21#define __CONTAINER_HXX__
24#include "Exception.hxx"
25#include "RefCounter.hxx"
26
27#include <list>
28#include <map>
30namespace YACS
31{
32 namespace ENGINE
33 {
34 class ComponentInstance;
35 class Proc;
36 class Task;
42 {
43 protected:
44 Container();
45#ifndef SWIG
46 virtual ~Container();
47#endif
48 public:
49 virtual std::string getKind() const = 0;
50 //Execution only methods
51 virtual std::string getDiscreminantStrOfThis(const Task *askingNode) const;
52 virtual bool isAlreadyStarted(const Task *askingNode) const = 0;
53 virtual void start(const Task *askingNode) = 0;
54 virtual void start(const Task *askingNode,
55 const std::string& resource_name,
56 const std::string& container_name);
57 virtual bool canAcceptImposedResource();
58 virtual bool isUsingPythonCache();
59 virtual void usePythonCache(bool v);
60 virtual std::string getPlacementId(const Task *askingNode) const = 0;
61 virtual std::string getFullPlacementId(const Task *askingNode) const = 0;
62 //Edition only methods
63 virtual void setAttachOnCloningStatus(bool val) const;
64 virtual void attachOnCloning() const;
65 virtual void dettachOnCloning() const;
66 virtual bool isAttachedOnCloning() const;
67 virtual void lock() = 0;
68 virtual void unLock() = 0;
70 virtual Container *clone() const = 0;
71 virtual Container *cloneAlways() const = 0;
72 virtual bool isSupportingRTODefNbOfComp() const;
73 virtual void checkCapabilityToDealWith(const ComponentInstance *inst) const = 0;
74 virtual void setProperty(const std::string& name,const std::string& value) = 0;
75 virtual std::string getProperty(const std::string& name) const = 0;
76 virtual void clearProperties() = 0;
77 virtual void addComponentName(const std::string& name) = 0;
78 virtual std::map<std::string,std::string> getProperties() const = 0;
79 virtual std::map<std::string,std::string> getResourceProperties(const std::string& name) const = 0;
80 virtual void setProperties(const std::map<std::string,std::string>& properties);
81 virtual std::string getName() const { return _name; }
83 void setName(std::string name) { _name = name; }
84 void setProc(Proc* proc) { _proc = proc; }
85 Proc* getProc() { return _proc; }
86 virtual void shutdown(int level) = 0;
87 static const char KIND_ENTRY[];
88 static const char AOC_ENTRY[];
89 static const char USE_PYCACHE_PROPERTY[];
90 protected:
91 std::string _name;
94 };
95 }
96}
97
98#endif
#define YACSLIBENGINE_EXPORT
WARNING ! name is used in edition to identify different containers, it is not the runtime name of the...
Definition: Container.hxx:83
virtual void start(const Task *askingNode)=0
virtual void shutdown(int level)=0
virtual Container * clone() const =0
WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method
virtual std::string getKind() const =0
void setProc(Proc *proc)
Definition: Container.hxx:84
virtual bool isAlreadyStarted(const Task *askingNode) const =0
virtual void unLock()=0
virtual std::map< std::string, std::string > getProperties() const =0
virtual void setProperty(const std::string &name, const std::string &value)=0
virtual std::string getFullPlacementId(const Task *askingNode) const =0
virtual void clearProperties()=0
virtual void addComponentName(const std::string &name)=0
virtual std::string getProperty(const std::string &name) const =0
virtual std::string getPlacementId(const Task *askingNode) const =0
virtual std::map< std::string, std::string > getResourceProperties(const std::string &name) const =0
virtual void checkCapabilityToDealWith(const ComponentInstance *inst) const =0
Definition: Container.hxx:81
virtual void lock()=0
virtual Container * cloneAlways() const =0
Definition: Proc.hxx:44
