YACS::ENGINE::Proc Class Reference
Base class for all schema objects. More...
#include <Proc.hxx>
Inheritance diagram for YACS::ENGINE::Proc:
Collaboration diagram for YACS::ENGINE::Proc:
typedef std::map< std::string, Logger * > LoggerMap
 Proc (const std::string &name)
virtual ~Proc ()
virtual TypeCode * createType (const std::string &name, const std::string &kind)
virtual TypeCode * createInterfaceTc (const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
 Create an object reference TypeCode. More...
virtual TypeCode * createSequenceTc (const std::string &id, const std::string &name, TypeCode *content)
 Create a sequence TypeCode. More...
virtual TypeCode * createStructTc (const std::string &id, const std::string &name)
virtual TypeCode * getTypeCode (const std::string &name)
virtual void setTypeCode (const std::string &name, TypeCode *t)
virtual Container * createContainer (const std::string &name, const std::string &kind="")
 Create a new Container and store it in containerMap. More...
virtual ComponentInstance * createComponentInstance (const std::string &componame, const std::string &name="", const std::string &kind="")
 Create a new ComponentInstance and add it into componentInstanceMap. More...
virtual void addComponentInstance (ComponentInstance *inst, const std::string &name="", bool resetCtr=false)
 Add a ComponentInstance into componentInstanceMap. More...
virtual void removeComponentInstance (ComponentInstance *inst)
 Remove a componentInstance from the componentInstanceMap. More...
virtual void removeContainer (Container *cont)
 Remove a container from the containerMap. More...
virtual Proc * getProc ()
 Return the proc (this) More...
virtual void updateContainersAndComponents ()
YACS::StatesForNode getNodeState (int numId)
std::string getNodeProgress (int numId)
int getGlobalProgressPercent ()
std::string getInPortValue (int nodeNumId, std::string portName)
std::string setInPortValue (std::string nodeName, std::string portName, std::string value)
std::string getOutPortValue (int nodeNumId, std::string portName)
std::string getNodeErrorDetails (int nodeNumId)
std::string getNodeErrorReport (int nodeNumId)
std::string getNodeContainerLog (int nodeNumId)
std::string getXMLState (int numId)
std::list< int > getNumIds ()
std::list< std::string > getIds ()
virtual Logger * getLogger (const std::string &name)
virtual bool getEdition ()
virtual void setEdition (bool edition)
virtual void modified ()
 Sets Proc in modified state and update state if in edition mode. More...
virtual void saveSchema (const std::string &xmlSchemaFile)
 Save Proc in XML schema file. More...
virtual void saveState (const std::string &xmlStateFile)
 Save Proc state in XML state file. More...
- Public Member Functions inherited from YACS::ENGINE::Bloc
 Bloc (const Bloc &other, ComposedNode *father, bool editionOnly)
 Bloc (const std::string &name)
 Create a Bloc node with a given name. More...
virtual ~Bloc ()
bool isFinished ()
 Indicate if the bloc execution is finished. More...
int getNumberOfCFLinks () const
void init (bool start=true)
 Initialize the bloc. More...
 Collect all nodes that are ready to execute. More...
void exUpdateState ()
 Update the bloc state. More...
bool edAddChild (Node *DISOWNnode)
 Add a child node to the bloc. More...
void edRemoveChild (Node *node)
std::list< Node * > getChildren () const
std::list< Node * > edGetDirectDescendants () const
std::vector< std::list< Node * > > splitIntoIndependantGraph () const
Node * getChildByShortName (const std::string &name) const
template<bool direction>
void findAllPathsStartingFrom (Node *start, std::list< std::vector< Node * > > &vec, std::map< Node *, std::set< Node * > > &accelStr) const
void findAllNodesStartingFrom (Node *start, std::set< Node * > &result, std::map< Node *, std::set< Node * > > &accelStr, LinkInfo &info) const
void removeRecursivelyRedundantCL ()
void fitToPlayGround (const PlayGround *pg)
void propagePlayGround (const PlayGround *pg)
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual bool edAddChild (Node *DISOWNnode)
virtual void edRemoveChild (Node *node)
 Remove a child node. More...
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
int getNumId ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Public Attributes
std::map< std::string, Node * > nodeMap
std::map< std::string, ServiceNode * > serviceMap
std::map< std::string, InlineNode * > inlineMap
std::map< std::string, TypeCode * > typeMap
std::map< std::string, Container * > containerMap
std::map< std::string, ComponentInstance * > componentInstanceMap
std::vector< std::string > names
LoggerMap _loggers
YACS::Colour _colour
void removeContainers ()
- Protected Member Functions inherited from YACS::ENGINE::Bloc
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
bool areAllSubNodesFinished () const
bool areAllSubNodesDone () const
void checkNoCyclePassingThrough (Node *node)
std::vector< std::pair< OutGate *, InGate * > > getSetOfInternalCFLinks () const
YACS::Event updateStateOnFinishedEventFrom (Node *node)
YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Notify this bloc that a node has failed. More...
void initComputation () const
void performCFComputationsOnlyOneLevel (LinkInfo &info) const
void performCFComputations (LinkInfo &info) const
void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
bool areLinked (Node *start, Node *end, bool fw) const
 Check if two nodes are linked. More...
bool arePossiblyRunnableAtSameTime (Node *start, Node *end) const
 Check if two nodes can run in parallel. More...
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 Check control flow links. More...
void seekOkAndUseless1 (std::vector< Node * > &okAndUseless1, std::set< Node * > &allNodes) const
void seekUseless2 (std::vector< Node * > &useless2, std::set< Node * > &allNodes) const
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
bool _edition
int _compoinstctr
- Protected Attributes inherited from YACS::ENGINE::Bloc
std::list< Node * > _setOfNode
std::map< Node *, std::set< Node * > > * _fwLinks
 For internal calculations. More...
std::map< Node *, std::set< Node * > > * _bwLinks
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Friends
std::ostream & operator<< (std::ostream &os, const Proc &p)
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Member Functions inherited from YACS::ENGINE::Bloc
static void verdictForOkAndUseless1 (const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::vector< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
static void verdictForCollapses (const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::set< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
This is an abstract class that must be specialized in runtime.
Definition at line 43 of file Proc.hxx.
◆ LoggerMap
typedef std::map<std::string, Logger*> YACS::ENGINE::Proc::LoggerMap
Definition at line 95 of file Proc.hxx.
◆ Proc()
Proc::Proc ( const std::string &  name)
Definition at line 48 of file Proc.cxx.
48 :Bloc(name),_edition(false),_compoinstctr(0)
49{
51 DEBTRACE("theRuntime->_tc_double->ref: " << theRuntime->_tc_double->getRefCnt());
52 DEBTRACE("theRuntime->_tc_int->ref: " << theRuntime->_tc_int->getRefCnt());
53 DEBTRACE("theRuntime->_tc_string->ref: " << theRuntime->_tc_string->getRefCnt());
54 DEBTRACE("theRuntime->_tc_bool->ref: " << theRuntime->_tc_bool->getRefCnt());
55 DEBTRACE("theRuntime->_tc_file->ref: " << theRuntime->_tc_file->getRefCnt());
61 typeMap["double"]=theRuntime->_tc_double;
62 typeMap["string"]=theRuntime->_tc_string;
66}
Definition: parsers.cxx:40
Definition: Proc.hxx:90
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
static YACS::ENGINE::TypeCode * _tc_file
Definition: Runtime.hxx:140
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
static YACS::ENGINE::TypeCode * _tc_string
Definition: Runtime.hxx:139
Definition: Runtime.cxx:61
References YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Runtime::_tc_file, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Runtime::_tc_string, DEBTRACE, YACS::ENGINE::RefCounter::getRefCnt(), YACS::ENGINE::getRuntime(), YACS::ENGINE::RefCounter::incrRef(), theRuntime, and typeMap.
◆ ~Proc()
Proc::~Proc ( )
Definition at line 68 of file Proc.cxx.
69{
70 DEBTRACE("Proc::~Proc");
71 //for the moment all nodes are owned, so no need to manage their destruction
72 //nodeMap, inlineMap, serviceMap will be cleared automatically
73 //but we need to destroy TypeCodes
74 std::map<std::string, TypeCode *>::iterator pt;
75 for(pt=typeMap.begin();pt!=typeMap.end();pt++)
76 ((*pt).second)->decrRef();
77
79
80 //get rid of loggers in logger map
81 std::map<std::string, Logger*>::const_iterator lt;
82 for(lt=_loggers.begin();lt!=_loggers.end();lt++)
83 delete (*lt).second;
84}
void removeContainers()
Definition: Proc.cxx:491
LoggerMap _loggers
Definition: Proc.hxx:96
References _loggers, DEBTRACE, removeContainers(), and typeMap.
◆ accept()
void Proc::accept ( Visitor *  visitor)
◆ addComponentInstance()
void Proc::addComponentInstance ( ComponentInstance *  inst,
const std::string &  name = "",
bool  resetCtr = false
If the name == "", the component instance is automatically named with a unique (in the Proc) name
instthe component instance
namethe component instance name
resetCtrtry to reuse instance number previously released, false by default
Definition at line 526 of file Proc.cxx.
527{
528 if(name != "")
529 {
530 inst->setName(name);
531 inst->setAnonymous(false);
532 if(componentInstanceMap.count(name)!=0)
533 componentInstanceMap[name]->decrRef();
534 componentInstanceMap[name]=inst;
535 inst->incrRef();
536 }
537 else
538 {
539 //automatic naming : componame_<_compoinstctr>
540 std::string instname;
541 std::string componame=inst->getCompoName();
542 if (resetCtr)
543 _compoinstctr = 0;
544 while(1)
545 {
546 std::ostringstream buffer;
547 buffer << ++_compoinstctr;
548 instname=componame+"_"+buffer.str();
549 if(componentInstanceMap.count(instname)==0)
550 {
551 inst->setName(instname);
552 componentInstanceMap[instname]=inst;
553 inst->incrRef();
554 break;
555 }
556 }
557 }
558}
virtual void setAnonymous(bool anon)
Definition: Proc.hxx:92
References _compoinstctr, componentInstanceMap, YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::RefCounter::incrRef(), YACS::ENGINE::ComponentInstance::setAnonymous(), and YACS::ENGINE::ComponentInstance::setName().
Referenced by createComponentInstance(), YACS::HMI::CommandAddComponentInstance::localExecute(), YACS::HMI::CommandAddComponentFromCatalog::localExecute(), and YACS::HMI::CommandAssociateServiceToComponent::localReverse().
◆ createComponentInstance()
ComponentInstance * Proc::createComponentInstance ( const std::string &  componame,
const std::string &  kind = ""
componamethe component name
kindthe component instance kind (depends on runtime)
the created ComponentInstance
Definition at line 599 of file Proc.cxx.
600{
601 ComponentInstance* inst= getRuntime()->createComponentInstance(componame,kind);
602 addComponentInstance(inst,name);
603 return inst;
604}
virtual void addComponentInstance(ComponentInstance *inst, const std::string &name="", bool resetCtr=false)
Definition: Proc.cxx:526
virtual ComponentInstance * createComponentInstance(const std::string &name, const std::string &kind="")
Definition: Runtime.cxx:215
References addComponentInstance(), YACS::ENGINE::Runtime::createComponentInstance(), and YACS::ENGINE::getRuntime().
Referenced by YACS::servicetypeParser< T >::component(), and YACS::proctypeParser< T >::componentinstance().
◆ createContainer()
Container * Proc::createContainer ( const std::string &  name,
namethe container name and key in containerMap
kindthe container kind (depends on runtime)
the created Container
Definition at line 506 of file Proc.cxx.
507{
509 co->setName(name);
510 if(containerMap.count(name)!=0)
511 containerMap[name]->decrRef();
512 containerMap[name]=co;
513 co->incrRef();
514 co->setProc(this);
515 return co;
516}
virtual Container * createContainer(const std::string &name, const std::string &kind="")
Definition: Proc.cxx:506
Definition: Proc.hxx:91
References containerMap, createContainer(), YACS::ENGINE::getRuntime(), YACS::ENGINE::RefCounter::incrRef(), YACS::ENGINE::Container::setName(), and YACS::ENGINE::Container::setProc().
Referenced by YACS::proctypeParser< T >::container(), createContainer(), YACS::servertypeParser< T >::loadcontainer(), and YACS::ENGINE::SalomeProc::SalomeProc().
◆ createInterfaceTc()
TypeCode * Proc::createInterfaceTc ( const std::string &  id,
idthe TypeCode repository id
namethe TypeCode name
ltca liste of object reference TypeCode to use as base types for this type
the created TypeCode
Reimplemented in YACS::ENGINE::SalomeProc.
Definition at line 132 of file Proc.cxx.
134{
135 TypeCode* t = TypeCode::interfaceTc(id.c_str(),name.c_str(),ltc);
136 if(typeMap.count(name)!=0)
137 typeMap[name]->decrRef();
138 typeMap[name]=t;
139 t->incrRef();
140 return t;
141}
Definition: TypeCode.hxx:68
static TypeCode * interfaceTc(const char *id, const char *name)
static factory of object reference type given an id and a name
Definition: TypeCode.cxx:229
References YACS::ENGINE::TypeCode::interfaceTc(), gui.Appli::t, and typeMap.
Referenced by YACS::ENGINE::SalomeProc::createInterfaceTc(), and YACS::objtypeParser::post().
◆ createSequenceTc()
TypeCode * Proc::createSequenceTc ( const std::string &  id,
TypeCode *  content
idthe TypeCode repository id ("" for normal use)
contentthe element TypeCode
Definition at line 150 of file Proc.cxx.
152{
153 TypeCode* t = TypeCode::sequenceTc(id.c_str(),name.c_str(),content);
154 if(typeMap.count(name)!=0)
155 typeMap[name]->decrRef();
156 typeMap[name]=t;
157 t->incrRef();
158 return t;
159}
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
Definition: TypeCode.cxx:254
References YACS::ENGINE::TypeCode::sequenceTc(), gui.Appli::t, and typeMap.
Referenced by YACS::seqtypeParser::post().
◆ createStructTc()
TypeCode * Proc::createStructTc ( const std::string &  id,
Definition at line 161 of file Proc.cxx.
162{
163 TypeCode* t = TypeCode::structTc(id.c_str(),name.c_str());
164 if(typeMap.count(name)!=0)
165 typeMap[name]->decrRef();
166 typeMap[name]=t;
167 t->incrRef();
168 return t;
169}
static TypeCode * structTc(const char *id, const char *name)
static factory of struct type given an id and a name
Definition: TypeCode.cxx:269
References YACS::ENGINE::TypeCode::structTc(), gui.Appli::t, and typeMap.
Referenced by YACS::ENGINE::SalomeProc::createStructTc(), and YACS::structtypeParser::post().
◆ createType()
TypeCode * Proc::createType ( const std::string &  name,
Definition at line 103 of file Proc.cxx.
104{
105 TypeCode* t;
106 if(kind=="double")
108 else if(kind=="string")
110 else if(kind=="int")
112 else if(kind=="bool")
114 else
115 throw Exception("Unknown kind");
116
117 if(typeMap.count(name)!=0)
118 typeMap[name]->decrRef();
119 t->incrRef();
120 typeMap[name]=t;
121 t->incrRef();
122 return t;
123}
References YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Runtime::_tc_string, YACS::ENGINE::getRuntime(), gui.Appli::t, and typeMap.
Referenced by YACS::proctypeParser< T >::type().
◆ getEdition()
virtual bool YACS::ENGINE::Proc::getEdition ( )
Definition at line 97 of file Proc.hxx.
97{return _edition;}
◆ getGlobalProgressPercent()
int Proc::getGlobalProgressPercent ( )
Definition at line 234 of file Proc.cxx.
235{
236 list<ProgressWeight> weightList = getProgressWeight();
237 int weightDone = 0;
238 int weightTotal = 0;
239 int progressPercent = 0;
240 for(list<ProgressWeight>::const_iterator iter=weightList.begin();iter!=weightList.end();iter++)
241 {
242 weightDone += (*iter).weightDone;
243 weightTotal += (*iter).weightTotal;
244 }
245 if (weightTotal > 0)
246 progressPercent = int(float(weightDone) / float(weightTotal) * 100);
247 return progressPercent;
248}
std::list< ProgressWeight > getProgressWeight() const
Get the progress weight for all elementary nodes.
References YACS::ENGINE::ComposedNode::getProgressWeight().
◆ getIds()
std::list< std::string > Proc::getIds ( )
Definition at line 417 of file Proc.cxx.
418{
419 list<YACS::ENGINE::Node *> nodes = getAllRecursiveConstituents();
420 int len = nodes.size();
421 list<string> ids;
422 for( list<YACS::ENGINE::Node *>::const_iterator iter = nodes.begin();
423 iter != nodes.end(); iter++)
424 {
425 ids.push_back(getChildName(*iter));
426 }
427 ids.push_back("_root_");
428 return ids;
429}
virtual std::list< Node * > getAllRecursiveConstituents()
References YACS::ENGINE::ComposedNode::getAllRecursiveConstituents(), and YACS::ENGINE::ComposedNode::getChildName().
◆ getInPortValue()
std::string Proc::getInPortValue ( int  nodeNumId,
Definition at line 265 of file Proc.cxx.
266{
267 DEBTRACE("Proc::getInPortValue " << nodeNumId << " " << portName);
268 stringstream msg;
269 if(YACS::ENGINE::Node::idMap.count(nodeNumId) == 0)
270 {
271 msg << "<value><error>unknown node id: " << nodeNumId << "</error></value>";
272 return msg.str();
273 }
274 try
275 {
277 InputPort * inputPort = node->getInputPort(portName);
278 return inputPort->getAsString();
279 }
280 catch(YACS::Exception& ex)
281 {
282 DEBTRACE("Proc::getInPortValue " << ex.what());
283 msg << "<value><error>" << ex.what() << "</error></value>";
284 return msg.str();
285 }
286}
Definition: DataPort.cxx:84
Base class for Input Ports.
Definition: InputPort.hxx:44
Base class for all nodes.
Definition: Node.hxx:70
static std::map< int, Node * > idMap
Definition: Node.hxx:188
virtual InputPort * getInputPort(const std::string &name) const
Definition: Node.cxx:260
References DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::Node::getInputPort(), and YACS::ENGINE::Node::idMap.
Referenced by YACS::HMI::GuiExecutor::updateSchema().
◆ getLogger()
Logger * Proc::getLogger ( const std::string &  name)
Definition at line 431 of file Proc.cxx.
432{
433 Logger* logger;
434 LoggerMap::const_iterator it = _loggers.find(name);
435
436 if (it != _loggers.end())
437 {
438 logger = it->second;
439 }
440 else
441 {
442 logger = new Logger(name);
443 _loggers[name]=logger;
444 }
445 return logger;
446}
Class for logging error messages.
Definition: Logger.hxx:38
References _loggers.
Referenced by YACS::YACSLoader::load(), YACS::ENGINE::ProcCataLoader::loadCata(), YACS::HMI::GenericGui::loadSchema(), YACS::parser::logError(), main(), YACS::HMI::GenericGui::onImportSchema(), YACS::HMI::GenericGui::onImportSupervSchema(), YACS::HMI::GenericGui::onLoadAndRunSchema(), YACS::HMI::EditionProc::synchronize(), and YACS::HMI::BatchJobsListDialog::userOK().
◆ getNodeContainerLog()
std::string Proc::getNodeContainerLog ( int  nodeNumId)
Definition at line 390 of file Proc.cxx.
391{
392 DEBTRACE("Proc::getNodeContainerLog " << nodeNumId);
393 stringstream msg;
394 if(YACS::ENGINE::Node::idMap.count(nodeNumId) == 0)
395 {
396 msg << "Unknown node id " << nodeNumId;
397 return msg.str();
398 }
400 return node->getContainerLog();
401}
virtual std::string getContainerLog()
returns a string that contains the name of the container log file if it exists
Definition: Node.cxx:796
References DEBTRACE, YACS::ENGINE::Node::getContainerLog(), and YACS::ENGINE::Node::idMap.
◆ getNodeErrorDetails()
std::string Proc::getNodeErrorDetails ( int  nodeNumId)
Definition at line 364 of file Proc.cxx.
365{
366 DEBTRACE("Proc::getNodeErrorDetails " << nodeNumId);
367 stringstream msg;
368 if(YACS::ENGINE::Node::idMap.count(nodeNumId) == 0)
369 {
370 msg << "Unknown node id " << nodeNumId;
371 return msg.str();
372 }
374 return node->getErrorDetails();
375}
virtual std::string getErrorDetails() const
Definition: Node.hxx:190
References DEBTRACE, YACS::ENGINE::Node::getErrorDetails(), and YACS::ENGINE::Node::idMap.
◆ getNodeErrorReport()
std::string Proc::getNodeErrorReport ( int  nodeNumId)
Definition at line 377 of file Proc.cxx.
378{
379 DEBTRACE("Proc::getNodeErrorReport " << nodeNumId);
380 stringstream msg;
381 if(YACS::ENGINE::Node::idMap.count(nodeNumId) == 0)
382 {
383 msg << "Unknown node id " << nodeNumId;
384 return msg.str();
385 }
387 return node->getErrorReport();
388}
virtual std::string getErrorReport()
returns a string that contains an error report if the node is in error
Definition: Node.cxx:755
References DEBTRACE, YACS::ENGINE::Node::getErrorReport(), and YACS::ENGINE::Node::idMap.
◆ getNodeProgress()
std::string Proc::getNodeProgress ( int  numId)
Definition at line 222 of file Proc.cxx.
223{
224 std::string progress = "0";
225 if(YACS::ENGINE::Node::idMap.count(numId) == 0)
226 {
227 cerr << "Unknown node id " << numId << endl;
228 }
230 progress = node->getProgress();
231 return progress;
232}
References YACS::ENGINE::Node::idMap.
◆ getNodeState()
YACS::StatesForNode Proc::getNodeState ( int  numId)
Definition at line 210 of file Proc.cxx.
211{
212 if(YACS::ENGINE::Node::idMap.count(numId) == 0)
213 {
214 cerr << "Unknown node id " << numId << endl;
215 return YACS::UNDEFINED;
216 }
219 return state;
220}
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
StatesForNode
Definition: define.hxx:34
@ UNDEFINED
Definition: define.hxx:35
References YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::Node::idMap, yacsorb.CORBAEngineTest::state, and YACS::UNDEFINED.
◆ getNumIds()
std::list< int > Proc::getNumIds ( )
Definition at line 403 of file Proc.cxx.
404{
405 list<YACS::ENGINE::Node *> nodes = getAllRecursiveConstituents();
406 int len = nodes.size();
407 list<int> numids;
408 for( list<YACS::ENGINE::Node *>::const_iterator iter = nodes.begin();
409 iter != nodes.end(); iter++)
410 {
411 numids.push_back((*iter)->getNumId());
412 }
413 numids.push_back(this->getNumId());
414 return numids;
415}
int getNumId()
return node instance identifiant, unique for each node instance
Definition: Node.cxx:643
References YACS::ENGINE::ComposedNode::getAllRecursiveConstituents(), YACS::ENGINE::Node::getNumId(), and yacsorb.CORBAEngineTest::numids.
◆ getOutPortValue()
std::string Proc::getOutPortValue ( int  nodeNumId,
Definition at line 341 of file Proc.cxx.
342{
343 DEBTRACE("Proc::getOutPortValue " << nodeNumId << " " << portName);
344 stringstream msg;
345 if(YACS::ENGINE::Node::idMap.count(nodeNumId) == 0)
346 {
347 msg << "<value><error>unknown node id: " << nodeNumId << "</error></value>";
348 return msg.str();
349 }
350 try
351 {
353 OutputPort * outputPort = node->getOutputPort(portName);
354 return outputPort->getAsString();
355 }
356 catch(YACS::Exception& ex)
357 {
358 DEBTRACE("Proc::getOutPortValue " << ex.what());
359 msg << "<value><error>" << ex.what() << "</error></value>";
360 return msg.str();
361 }
362}
virtual OutputPort * getOutputPort(const std::string &name) const =0
References DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::DataPort::getAsString(), YACS::ENGINE::Node::getOutputPort(), and YACS::ENGINE::Node::idMap.
◆ getProc() [1/2]
Proc * Proc::getProc ( )
Reimplemented from YACS::ENGINE::Node.
Definition at line 607 of file Proc.cxx.
608{
609 return this;
610}
◆ getProc() [2/2]
const Proc * Proc::getProc ( ) const
Definition at line 613 of file Proc.cxx.
614{
615 return this;
616}
◆ getTypeCode()
TypeCode * Proc::getTypeCode ( const std::string &  name)
Definition at line 171 of file Proc.cxx.
172{
173 TypeCode* aTC=0;
174 if(typeMap.count(name)==0)
175 aTC=getRuntime()->getTypeCode(name);
176 else
177 aTC=typeMap[name];
178
179 if(!aTC)
180 {
181 std::stringstream msg;
182 msg << "Type " << name << " does not exist" ;
183 msg << " (" <<__FILE__ << ":" << __LINE__ << ")";
184 throw Exception(msg.str());
185 }
186
187 return aTC;
188}
Definition: Runtime.cxx:333
References YACS::ENGINE::getRuntime(), YACS::ENGINE::Runtime::getTypeCode(), and typeMap.
◆ getXMLState()
std::string Proc::getXMLState ( int  numId)
Definition at line 250 of file Proc.cxx.
251{
252 if(YACS::ENGINE::Node::idMap.count(numId) == 0)
253 {
254 cerr << "Unknown node id " << numId << endl;
255 return "<state>unknown</state>";
256 }
258 stringstream msg;
259 msg << "<state>" << node->getEffectiveState() << "</state>";
260 msg << "<name>" << node->getQualifiedName() << "</name>";
261 msg << "<id>" << numId << "</id>";
262 return msg.str();
263}
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
References YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::Node::getQualifiedName(), and YACS::ENGINE::Node::idMap.
◆ modified()
void Proc::modified ( )
Definition at line 459 of file Proc.cxx.
460{
461 DEBTRACE("Proc::modified() " << _edition);
462 _modified=1;
463 if(_edition)
465}
virtual void edUpdateState()
update the status of the node
References _edition, YACS::ENGINE::Node::_modified, DEBTRACE, and YACS::ENGINE::ComposedNode::edUpdateState().
◆ removeComponentInstance()
void Proc::removeComponentInstance ( ComponentInstance *  inst)
To be used for a componentInstance with no service nodes referenced.
Definition at line 566 of file Proc.cxx.
567{
568 if (componentInstanceMap.count(inst->getInstanceName()))
569 {
571 inst->decrRef();
572 }
573}
const std::string & getInstanceName() const
References componentInstanceMap, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::ComponentInstance::getInstanceName().
Referenced by YACS::HMI::CommandAddComponentInstance::localReverse(), and YACS::HMI::CommandAddComponentFromCatalog::localReverse().
◆ removeContainer()
void Proc::removeContainer ( Container *  cont)
To be used for a container with no componentInstance referenced.
contthe container
Definition at line 581 of file Proc.cxx.
582{
583 if (containerMap.count(cont->getName()))
584 {
585 containerMap.erase(cont->getName());
586 cont->decrRef();
587 }
588}
virtual std::string getName() const
Definition: Container.hxx:81
References containerMap, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::Container::getName().
Referenced by YACS::HMI::SubjectContainerBase::~SubjectContainerBase().
◆ removeContainers()
void Proc::removeContainers ( )
Definition at line 491 of file Proc.cxx.
492{
493 //get rid of containers in container map
494 std::map<std::string, Container*>::const_iterator it;
495 for(it=containerMap.begin();it!=containerMap.end();it++)
496 ((*it).second)->decrRef();
497 containerMap.clear();
498}
References containerMap.
Referenced by updateContainersAndComponents(), and ~Proc().
◆ saveSchema()
void Proc::saveSchema ( const std::string &  xmlSchemaFile)
xmlSchemaFilethe file name
Definition at line 471 of file Proc.cxx.
472{
473 VisitorSaveSchema vss(this);
474 vss.openFileSchema(xmlSchemaFile);
475 accept(&vss);
476 vss.closeFileSchema();
477}
virtual void accept(Visitor *visitor)
Definition: Proc.cxx:199
Base class for all visitors that save a schema.
References accept(), YACS::ENGINE::VisitorSaveSchema::closeFileSchema(), and YACS::ENGINE::VisitorSaveSchema::openFileSchema().
◆ saveState()
void Proc::saveState ( const std::string &  xmlStateFile)
deprecated. See VisitorSalomeSaveState and schemaSaveState in order to deal with the execution state of ForEachLoop.
xmlStateFilethe file name
Definition at line 483 of file Proc.cxx.
484{
485 VisitorSaveState vst(this);
486 vst.openFileDump(xmlStateFile);
487 accept(&vst);
488 vst.closeFileDump();
489}
References accept(), YACS::ENGINE::VisitorSaveState::closeFileDump(), and YACS::ENGINE::VisitorSaveState::openFileDump().
◆ setEdition()
void Proc::setEdition ( bool  edition)
Definition at line 448 of file Proc.cxx.
449{
450 DEBTRACE("Proc::setEdition: " << edition);
451 _edition=edition;
452 if(_edition)
454}
References _edition, DEBTRACE, and YACS::ENGINE::ComposedNode::edUpdateState().
Referenced by YACS::HMI::GenericGui::createContext(), and YACS::HMI::QtGuiContext::~QtGuiContext().
◆ setInPortValue()
std::string Proc::setInPortValue ( std::string  nodeName,
std::string  value
Definition at line 288 of file Proc.cxx.
289{
290 DEBTRACE("Proc::setInPortValue " << nodeName << " " << portName << " " << value);
291
292 try
293 {
295 YACS::ENGINE::InputPort* inputPort = node->getInputPort(portName);
296
297 switch (inputPort->edGetType()->kind())
298 {
299 case Double:
300 {
301 double val = atof(value.c_str());
302 inputPort->edInit(val);
303 }
304 break;
305 case Int:
306 {
307 int val = atoi(value.c_str());
308 inputPort->edInit(val);
309 }
310 break;
311 case String:
312 inputPort->edInit(value.c_str());
313 break;
314 case Bool:
315 {
316 if((!value.compare("False")) || (!value.compare("false")))
317 inputPort->edInit(false);
318 else if ((!value.compare("True")) || (!value.compare("true")))
319 inputPort->edInit(true);
320 else
321 {
322 int val = atoi(value.c_str());
323 inputPort->edInit(val);
324 }
325 }
326 break;
327 default:
328 DEBTRACE("Proc::setInPortValue: filtered type: " << inputPort->edGetType()->kind());
329 }
330 return value;
331 }
332 catch(YACS::Exception& ex)
333 {
334 DEBTRACE("Proc::setInPortValue " << ex.what());
335 stringstream msg;
336 msg << "<value><error>" << ex.what() << "</error></value>";
337 return msg.str();
338 }
339}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
void edInit(T value)
Definition: InputPort.hxx:129
Definition: Proc.hxx:87
DynType kind() const
Definition: TypeCode.cxx:47
References YACS::ENGINE::Bool, DEBTRACE, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::InputPort::edInit(), testCppPluginInvokation::ex, YACS::ENGINE::Node::getInputPort(), YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), nodeMap, and YACS::ENGINE::String.
Referenced by main().
◆ setName()
void Proc::setName ( const std::string &  name)
Definition at line 204 of file Proc.cxx.
205{
207 _name = name;
208}
std::string _name
Definition: Node.hxx:89
static void checkValidityOfNodeName(const std::string &name)
Definition: Node.cxx:455
References YACS::ENGINE::Node::_name, and YACS::ENGINE::Node::checkValidityOfNodeName().
Referenced by YACS::proctypeParser< T >::name().
◆ setTypeCode()
void Proc::setTypeCode ( const std::string &  name,
TypeCode *  t
Definition at line 190 of file Proc.cxx.
191{
192 if(typeMap.count(name)!=0)
193 typeMap[name]->decrRef();
194 typeMap[name]=t;
195 t->incrRef();
196}
References gui.Appli::t, and typeMap.
◆ typeName()
virtual std::string YACS::ENGINE::Proc::typeName ( )
Reimplemented from YACS::ENGINE::Bloc.
Definition at line 84 of file Proc.hxx.
84{return "YACS__ENGINE__Proc";}
Referenced by YACS::ENGINE::DistributedPythonNode::execute().
◆ updateContainersAndComponents()
void Proc::updateContainersAndComponents ( )
This method is useful if this has been modified recursively and an update is needed between all the containers and components refered by children and little children and maps.
Definition at line 622 of file Proc.cxx.
623{
624 std::map<std::string, Container*> myContainerMap;
625 std::map<std::string, ComponentInstance*> myComponentInstanceMap;
627 vector<Container *> conts(treeToDup.getAllContainers());
628 for(vector<Container *>::const_iterator iterCt=conts.begin();iterCt!=conts.end();iterCt++)
629 {
630 Container *tmp(*iterCt);
631 if(tmp)
632 {
633 if(myContainerMap.find(tmp->getName())!=myContainerMap.end())
634 {
635 std::ostringstream oss; oss << "Proc::updateContainersAndComponents : more than one container instance with name \"" << tmp->getName() << "\" !";
636 throw YACS::Exception(oss.str());
637 }
638 myContainerMap[tmp->getName()]=tmp;
639 tmp->incrRef();
640 }
641 vector<ComponentInstance *> comps=treeToDup.getComponentsLinkedToContainer(*iterCt);
642 for(vector<ComponentInstance *>::iterator iterCp=comps.begin();iterCp!=comps.end();iterCp++)
643 {
644 ComponentInstance *tmp2(*iterCp);
645 if(tmp2)
646 {
647 if(myComponentInstanceMap.find(tmp2->getCompoName())!=myComponentInstanceMap.end())
648 {
649 std::ostringstream oss; oss << "Proc::updateContainersAndComponents : more than one component instance with name \"" << tmp2->getCompoName() << "\" !";
650 throw YACS::Exception(oss.str());
651 }
652 }
653 myComponentInstanceMap[tmp2->getCompoName()]=tmp2;
654 tmp2->incrRef();
655 }
656 }
658 containerMap=myContainerMap;
659 componentInstanceMap=myComponentInstanceMap;
660}
DeploymentTree getDeploymentTree() const
Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is cons...
References componentInstanceMap, containerMap, YACS::ENGINE::DeploymentTree::getAllContainers(), YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::DeploymentTree::getComponentsLinkedToContainer(), YACS::ENGINE::ComposedNode::getDeploymentTree(), YACS::ENGINE::Container::getName(), YACS::ENGINE::RefCounter::incrRef(), and removeContainers().
◆ writeDot()
void Proc::writeDot ( std::ostream &  os) const
Dump to the input stream a dot representation of the node.
os: the input stream
Definition at line 86 of file Proc.cxx.
87{
88 os << "digraph " << getQualifiedName() << " {\n" ;
89 os << "node [ style=\"filled\" ];\n" ;
90 os << "compound=true;";
91 os << "states [label=< <TABLE> <TR> <TD BGCOLOR=\"pink\" > Ready</TD> <TD BGCOLOR=\"magenta\" > Toload</TD> </TR> <TR> <TD BGCOLOR=\"magenta\" > Loaded</TD> <TD BGCOLOR=\"purple\" > Toactivate</TD> </TR> <TR> <TD BGCOLOR=\"blue\" > Activated</TD> <TD BGCOLOR=\"green\" > Done</TD> </TR> <TR> <TD BGCOLOR=\"red\" > Error</TD> <TD BGCOLOR=\"orange\" > Failed</TD> </TR> <TR> <TD BGCOLOR=\"grey\" > Disabled</TD> <TD BGCOLOR=\"white\" > Pause</TD> </TR> </TABLE>> \n shape = plaintext \n style = invis \n ];\n";
92
94 os << "}\n" ;
95}
virtual void writeDot(std::ostream &os) const
Definition: Bloc.cxx:423
References YACS::ENGINE::Node::getQualifiedName(), and YACS::ENGINE::Bloc::writeDot().
Referenced by driverTest(), and main().
◆ operator<<
std::ostream & operator<< ( std::ostream &  os,
const Proc &  p
friend
Definition at line 97 of file Proc.cxx.
98{
99 os << "Proc" ;
100 return os;
101}
◆ _compoinstctr
int YACS::ENGINE::Proc::_compoinstctr
Definition at line 108 of file Proc.hxx.
Referenced by addComponentInstance().
◆ _edition
bool YACS::ENGINE::Proc::_edition
Definition at line 107 of file Proc.hxx.
Referenced by modified(), and setEdition().
◆ _loggers
LoggerMap YACS::ENGINE::Proc::_loggers
Definition at line 96 of file Proc.hxx.
Referenced by getLogger(), and ~Proc().
◆ componentInstanceMap
◆ containerMap
std::map<std::string, Container*> YACS::ENGINE::Proc::containerMap
Definition at line 91 of file Proc.hxx.
Referenced by YACS::HMI::EditionComponent::changeContainer(), YACS::HMI::EditionSalomeNode::changeContainer(), YACS::HMI::EditionScript::changeContainer(), YACS::proctypeParser< T >::componentinstance(), YACS::proctypeParser< T >::container(), createContainer(), YACS::HMI::EditionComponent::fillContainerPanel(), YACS::HMI::EditionSalomeNode::fillContainerPanel(), YACS::HMI::EditionScript::fillContainerPanel(), YACS::ENGINE::Visitor::getContainerMap(), YACS::servertypeParser< T >::loadcontainer(), YACS::HMI::SubjectProc::loadContainers(), YACS::HMI::CommandRenameContainer::localExecute(), YACS::HMI::CommandAddContainerBase::localExecute(), YACS::HMI::CommandSetContainerProperties::localExecute(), YACS::HMI::CommandAddComponentInstance::localExecute(), YACS::HMI::CommandSetContainer::localExecute(), YACS::HMI::CommandAssociateComponentToContainer::localExecute(), YACS::HMI::CommandDestroy::localExecute(), YACS::HMI::CommandRenameContainer::localReverse(), YACS::HMI::CommandAddContainerBase::localReverse(), YACS::HMI::CommandSetContainerProperties::localReverse(), YACS::HMI::CommandSetContainer::localReverse(), YACS::HMI::CommandAssociateComponentToContainer::localReverse(), YACS::HMI::CommandAssociateServiceToComponent::localReverse(), YACS::remotetypeParser< T >::post(), YACS::servertypeParser< T >::post(), YACS::servicetypeParser< T >::post(), YACS::sinlinetypeParser< T >::post(), removeContainer(), removeContainers(), YACS::HMI::SubjectServiceNode::setComponent(), and updateContainersAndComponents().
◆ inlineMap
◆ names
std::vector<std::string> YACS::ENGINE::Proc::names
Definition at line 93 of file Proc.hxx.
Referenced by YACS::looptypeParser< T >::bloc(), YACS::casetypeParser::bloc(), YACS::bloctypeParser< T >::bloc(), YACS::bloctypeParser< T >::control(), YACS::bloctypeParser< T >::datalink(), YACS::looptypeParser< T >::datalink(), YACS::looptypeParser< T >::foreach(), YACS::casetypeParser::foreach(), YACS::bloctypeParser< T >::foreach(), YACS::looptypeParser< T >::forloop(), YACS::casetypeParser::forloop(), YACS::bloctypeParser< T >::forloop(), YACS::casetypeParser::id(), YACS::looptypeParser< T >::inline_(), YACS::casetypeParser::inline_(), YACS::bloctypeParser< T >::inline_(), YACS::bloctypeParser< T >::name(), YACS::whilelooptypeParser< T >::name(), YACS::forlooptypeParser< T >::name(), YACS::foreachlooptypeParser< T >::name(), YACS::optimizerlooptypeParser< T >::name(), YACS::switchtypeParser::name(), YACS::servertypeParser< T >::node(), YACS::servicetypeParser< T >::node(), YACS::looptypeParser< T >::node(), YACS::casetypeParser::node(), YACS::bloctypeParser< T >::node(), YACS::looptypeParser< T >::optimizer(), YACS::casetypeParser::optimizer(), YACS::bloctypeParser< T >::optimizer(), YACS::bloctypeParser< T >::outnode(), YACS::bloctypeParser< T >::parameter(), YACS::bloctypeParser< T >::post(), YACS::whilelooptypeParser< T >::post(), YACS::forlooptypeParser< T >::post(), YACS::foreachlooptypeParser< T >::post(), YACS::optimizerlooptypeParser< T >::post(), YACS::nodetypeParser< T >::post(), YACS::casetypeParser::post(), YACS::switchtypeParser::post(), YACS::foreachlooptypeParser< T >::postAttr(), YACS::optimizerlooptypeParser< T >::postAttr(), YACS::proctypeParser< T >::pre(), YACS::defaultcasetypeParser::pre(), YACS::bloctypeParser< T >::preset(), YACS::looptypeParser< T >::remote(), YACS::casetypeParser::remote(), YACS::bloctypeParser< T >::remote(), YACS::looptypeParser< T >::server(), YACS::casetypeParser::server(), YACS::bloctypeParser< T >::server(), YACS::looptypeParser< T >::service(), YACS::casetypeParser::service(), YACS::bloctypeParser< T >::service(), YACS::looptypeParser< T >::sinline(), YACS::casetypeParser::sinline(), YACS::bloctypeParser< T >::sinline(), YACS::bloctypeParser< T >::stream(), YACS::looptypeParser< T >::switch_(), YACS::casetypeParser::switch_(), YACS::bloctypeParser< T >::switch_(), YACS::looptypeParser< T >::while_(), YACS::casetypeParser::while_(), and YACS::bloctypeParser< T >::while_().
◆ nodeMap
std::map<std::string, Node*> YACS::ENGINE::Proc::nodeMap
Definition at line 87 of file Proc.hxx.
Referenced by YACS::looptypeParser< T >::bloc(), YACS::casetypeParser::bloc(), YACS::bloctypeParser< T >::bloc(), YACS::bloctypeParser< T >::control(), YACS::bloctypeParser< T >::datalink(), YACS::looptypeParser< T >::datalink(), YACS::looptypeParser< T >::foreach(), YACS::casetypeParser::foreach(), YACS::bloctypeParser< T >::foreach(), YACS::looptypeParser< T >::forloop(), YACS::casetypeParser::forloop(), YACS::bloctypeParser< T >::forloop(), YACS::looptypeParser< T >::inline_(), YACS::casetypeParser::inline_(), YACS::bloctypeParser< T >::inline_(), YACS::whilelooptypeParser< T >::name(), YACS::forlooptypeParser< T >::name(), YACS::looptypeParser< T >::node(), YACS::casetypeParser::node(), YACS::bloctypeParser< T >::node(), YACS::looptypeParser< T >::optimizer(), YACS::casetypeParser::optimizer(), YACS::bloctypeParser< T >::optimizer(), YACS::bloctypeParser< T >::outnode(), YACS::bloctypeParser< T >::parameter(), YACS::bloctypeParser< T >::preset(), YACS::looptypeParser< T >::remote(), YACS::casetypeParser::remote(), YACS::bloctypeParser< T >::remote(), YACS::looptypeParser< T >::server(), YACS::casetypeParser::server(), YACS::bloctypeParser< T >::server(), YACS::looptypeParser< T >::service(), YACS::casetypeParser::service(), YACS::bloctypeParser< T >::service(), setInPortValue(), YACS::looptypeParser< T >::sinline(), YACS::casetypeParser::sinline(), YACS::bloctypeParser< T >::sinline(), YACS::bloctypeParser< T >::stream(), YACS::looptypeParser< T >::switch_(), YACS::casetypeParser::switch_(), YACS::bloctypeParser< T >::switch_(), YACSPMMLBasicsTest1::testYACSdriver_LRANN(), YACSPMMLBasicsTest1::testYACSdriver_PmmlDoesNotExist(), YACSPMMLBasicsTest1::testYACSdriverLinearRegression(), YACSPMMLBasicsTest1::testYACSdriverNeuralNetwork(), YACS::looptypeParser< T >::while_(), YACS::casetypeParser::while_(), and YACS::bloctypeParser< T >::while_().
◆ serviceMap
◆ typeMap
