YACS::ENGINE::InputPort Class Referenceabstract
Base class for Input Ports. More...
#include <InputPort.hxx>
Inheritance diagram for YACS::ENGINE::InputPort:
Collaboration diagram for YACS::ENGINE::InputPort:
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Static Public Attributes
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
Friends
class Runtime
class OutPort
static int _total = 0
Definition at line 43 of file InputPort.hxx.
◆ ~InputPort()
InputPort::~InputPort ( )
Definition at line 89 of file InputPort.cxx.
90{
91 if(_initValue)
93}
References _initValue, and YACS::ENGINE::RefCounter::decrRef().
◆ InputPort() [1/2]
InputPort::InputPort ( const InputPort &  other,
Node *  newHelder
Definition at line 36 of file InputPort.cxx.
37 : DataFlowPort(other, newHelder),
38 InPort(other, newHelder),
39 DataPort(other, newHelder),
40 Port(other, newHelder),
41 _initValue(0),
43{
44 if(other._initValue)
46}
virtual Any * clone() const =0
DataFlowPort(const DataFlowPort &other, Node *newHelder)
Definition: DataPort.cxx:41
InPort(const InPort &other, Node *newHelder)
Definition: InPort.cxx:30
Port(Node *node)
Definition: Port.cxx:34
References _initValue, and YACS::ENGINE::Any::clone().
◆ InputPort() [2/2]
InputPort::InputPort ( const std::string &  name,
Node *  node,
TypeCode *  type,
bool  canBeNull = false
Definition at line 48 of file InputPort.cxx.
49 : DataFlowPort(name, node, type),
50 InPort(name, node, type),
51 DataPort(name, node, type),
52 Port(node),
53 _initValue(0),
55{
56}
bool canBeNull() const
Definition: InputPort.cxx:174
◆ canBeNull()
bool InputPort::canBeNull ( ) const
Definition at line 174 of file InputPort.cxx.
175{
176 return _canBeNull;
177}
References _canBeNull.
◆ checkBasicConsistency()
void InputPort::checkBasicConsistency ( ) const
Check basically that this port has one chance to be specified on time. It's a necessary condition not sufficient at all.
Definition at line 148 of file InputPort.cxx.
149{
150 if(!_canBeNull && !edIsManuallyInitialized() && _backLinks.size()==0 )
151 {
152 ostringstream stream;
153 stream << "InputPort::checkBasicConsistency : Port " << _name << " of node with name " << _node->getName() << " neither initialized nor linked back";
154 throw Exception(stream.str());
155 }
156}
std::set< std::pair< OutPort *, bool > > _backLinks
Definition: InPort.hxx:78
virtual bool edIsManuallyInitialized() const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition: InputPort.cxx:76
Definition: Node.hxx:125
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::InPort::_backLinks, _canBeNull, YACS::ENGINE::DataPort::_name, YACS::ENGINE::Port::_node, edIsManuallyInitialized(), and YACS::ENGINE::Node::getName().
Referenced by YACS::ENGINE::OutNode::checkBasicConsistency(), YACS::ENGINE::StudyOutNode::checkBasicConsistency(), and exInit().
◆ clone()
◆ dump()
std::string InputPort::dump ( )
Reimplemented in YACS::ENGINE::AnyInputPort, YACS::ENGINE::ConditionInputPort, YACS::ENGINE::SeqAnyInputPort, YACS::ENGINE::InputCorbaPort, YACS::ENGINE::InputCppPort, YACS::ENGINE::InputPresetPort, YACS::ENGINE::InputPyPort, YACS::ENGINE::InputStudyPort, and YACS::ENGINE::InputXmlPort.
Definition at line 158 of file InputPort.cxx.
159{
160 string xmldump = "<value><error> NO_SERIALISATION_AVAILABLE </error></value>";
161 return xmldump;
162}
Referenced by getHumanRepr().
◆ edInit() [1/3]
void InputPort::edInit ( Any *  value)
Definition at line 95 of file InputPort.cxx.
96{
97 InputPort *manuallySet=getRuntime()->adapt(this,
99 try
100 {
101 manuallySet->put((const void *) value);
102 if(manuallySet!=this)
103 delete manuallySet;
104 }
105 catch(ConversionException&)
106 {
107 if(manuallySet!=this)
108 delete manuallySet;
109 throw;
110 }
111 exSaveInit();
112 modified();
113}
Definition: InputPort.hxx:44
virtual void exSaveInit()=0
void modified()
Definition: Port.cxx:53
static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME[]
Definition: Runtime.hxx:135
virtual InputPort * adapt(InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
Definition: Runtime.cxx:61
References YACS::ENGINE::DataPort::_type, YACS::ENGINE::Runtime::adapt(), exSaveInit(), YACS::ENGINE::getRuntime(), YACS::ENGINE::Port::modified(), put(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ edInit() [2/3]
void InputPort::edInit ( const std::string &  impl,
const void *  value
Initialize the port with an object (value) coming from a world with implementation impl.
You should be careful when using this method : the caller must set the context according to implementation For instance, if implementation is Python, the caller must hold the Global Interpreter Lock (also known as GIL).
Definition at line 120 of file InputPort.cxx.
121{
122 InputPort *manuallySet=getRuntime()->adapt(this,impl,_type,true);
123 try
124 {
125 manuallySet->put(value);
126 if(manuallySet!=this)
127 delete manuallySet;
128 }
129 catch(ConversionException&)
130 {
131 if(manuallySet!=this)
132 delete manuallySet;
133 throw;
134 }
135 exSaveInit();
136 modified();
137}
References YACS::ENGINE::DataPort::_type, YACS::ENGINE::Runtime::adapt(), exSaveInit(), YACS::ENGINE::getRuntime(), YACS::ENGINE::Port::modified(), and put().
◆ edInit() [3/3]
template<class T >
void YACS::ENGINE::InputPort::edInit ( T  value)
◆ edIsInitialized()
bool InputPort::edIsInitialized ( ) const
soon deprecated
Perform a quick and not complete check. Use ComposedNode::CheckConsistency instead.
Definition at line 84 of file InputPort.cxx.
85{
86 return (edIsManuallyInitialized() || _backLinks.size()!=0 );
87}
References YACS::ENGINE::InPort::_backLinks, and edIsManuallyInitialized().
◆ edIsManuallyInitialized()
◆ edRemoveManInit()
◆ exInit()
void InputPort::exInit ( bool  start)
Definition at line 63 of file InputPort.cxx.
64{
66 if(start)
68}
virtual void exRestoreInit()=0
Check basically that this port has one chance to be specified on time. It's a necessary condition not...
Definition: InputPort.cxx:148
References checkBasicConsistency(), and exRestoreInit().
Referenced by YACS::ENGINE::NbBranches::exInit(), YACS::ENGINE::SplitterNode::init(), YACS::ENGINE::ForLoop::init(), YACS::ENGINE::OptimizerLoop::init(), and YACS::ENGINE::WhileLoop::init().
◆ exRestoreInit()
◆ exSaveInit()
◆ get()
◆ getHumanRepr()
std::string InputPort::getHumanRepr ( )
Reimplemented in YACS::ENGINE::InputPyPort.
Definition at line 164 of file InputPort.cxx.
165{
166 return dump();
167}
virtual std::string dump()
Definition: InputPort.cxx:158
References dump().
string InputPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 58 of file InputPort.cxx.
59{
60 return NAME;
61}
static const char NAME[]
Definition: InputPort.hxx:48
References NAME.
◆ getPublicRepresentant()
virtual InputPort * YACS::ENGINE::InputPort::getPublicRepresentant ( )
◆ isEmpty()
◆ isIntermediate()
virtual bool YACS::ENGINE::InputPort::isIntermediate ( ) const
Reimplemented in YACS::ENGINE::ProxyPort.
Definition at line 59 of file InputPort.hxx.
59{ return false; }
◆ put()
virtual void YACS::ENGINE::InputPort::put ( const void *  data)
pure virtual
Implemented in YACS::ENGINE::AnyInputPort, YACS::ENGINE::ConditionInputPort, YACS::ENGINE::InPropertyPort, YACS::ENGINE::ProxyPort, YACS::ENGINE::InputPort4DF2DS, YACS::ENGINE::CorbaCorba, YACS::ENGINE::CorbaCpp, YACS::ENGINE::CorbaNeutral, YACS::ENGINE::InputCorbaPort, YACS::ENGINE::CorbaPyDouble, YACS::ENGINE::CorbaPyInt, YACS::ENGINE::CorbaPyString, YACS::ENGINE::CorbaPyBool, YACS::ENGINE::CorbaPyObjref, YACS::ENGINE::CorbaPySequence, YACS::ENGINE::CorbaPyStruct, YACS::ENGINE::CorbaXml, YACS::ENGINE::CppCorba, YACS::ENGINE::CppCpp, YACS::ENGINE::CppNeutral, YACS::ENGINE::InputCppPort, YACS::ENGINE::CppPy, YACS::ENGINE::CppXml, YACS::ENGINE::NeutralCorbaInt, YACS::ENGINE::NeutralCorbaDouble, YACS::ENGINE::NeutralCorbaBool, YACS::ENGINE::NeutralCorbaSequence, YACS::ENGINE::NeutralCorbaString, YACS::ENGINE::NeutralCorbaObjref, YACS::ENGINE::NeutralCorbaStruct, YACS::ENGINE::NeutralCpp, YACS::ENGINE::NeutralInit, YACS::ENGINE::NeutralPyDouble, YACS::ENGINE::NeutralPyInt, YACS::ENGINE::NeutralPyString, YACS::ENGINE::NeutralPyBool, YACS::ENGINE::NeutralPyObjref, YACS::ENGINE::NeutralPySequence, YACS::ENGINE::NeutralPyStruct, YACS::ENGINE::NeutralXml, YACS::ENGINE::PyCorbaInt, YACS::ENGINE::PyCorbaDouble, YACS::ENGINE::PyCorbaString, YACS::ENGINE::PyCorbaBool, YACS::ENGINE::PyCorbaObjref, YACS::ENGINE::PyCorbaSequence, YACS::ENGINE::PyCorbaStruct, YACS::ENGINE::PyCpp, YACS::ENGINE::PyInit, YACS::ENGINE::PyNeutral, YACS::ENGINE::InputPyPort, YACS::ENGINE::PyXml, YACS::ENGINE::XmlCorba, YACS::ENGINE::XmlCpp, YACS::ENGINE::XmlNeutral, YACS::ENGINE::InputXmlPort, and YACS::ENGINE::XmlPython.
Referenced by edInit(), YACS::ENGINE::DynParaLoop::prepareInputsFromOutOfScope(), YACS::ENGINE::CppPy::put(), YACS::ENGINE::CppCorba::put(), YACS::ENGINE::CppCpp::put(), YACS::ENGINE::CppNeutral::put(), YACS::ENGINE::XmlCorba::put(), YACS::ENGINE::XmlCpp::put(), YACS::ENGINE::XmlNeutral::put(), YACS::ENGINE::XmlPython::put(), YACS::ENGINE::ProxyPort::put(), YACS::ENGINE::CorbaCorba::put(), YACS::ENGINE::CorbaCpp::put(), YACS::ENGINE::CorbaNeutral::put(), YACS::ENGINE::CorbaPyDouble::put(), YACS::ENGINE::CorbaPyInt::put(), YACS::ENGINE::CorbaPyString::put(), YACS::ENGINE::CorbaPyBool::put(), YACS::ENGINE::CorbaPyObjref::put(), YACS::ENGINE::CorbaPySequence::put(), YACS::ENGINE::CorbaPyStruct::put(), YACS::ENGINE::PyCorbaInt::put(), YACS::ENGINE::PyCorbaDouble::put(), YACS::ENGINE::PyCorbaString::put(), YACS::ENGINE::PyCorbaBool::put(), YACS::ENGINE::PyCorbaObjref::put(), YACS::ENGINE::PyCorbaSequence::put(), YACS::ENGINE::PyCorbaStruct::put(), YACS::ENGINE::PyCpp::put(), YACS::ENGINE::PyInit::put(), YACS::ENGINE::PyNeutral::put(), YACS::ENGINE::NeutralCorbaInt::put(), YACS::ENGINE::NeutralCorbaDouble::put(), YACS::ENGINE::NeutralCorbaBool::put(), YACS::ENGINE::NeutralCorbaSequence::put(), YACS::ENGINE::NeutralCorbaString::put(), YACS::ENGINE::NeutralCorbaObjref::put(), YACS::ENGINE::NeutralCorbaStruct::put(), YACS::ENGINE::NeutralCpp::put(), YACS::ENGINE::NeutralInit::put(), YACS::ENGINE::NeutralPyDouble::put(), YACS::ENGINE::NeutralPyInt::put(), YACS::ENGINE::NeutralPyString::put(), YACS::ENGINE::NeutralPyBool::put(), YACS::ENGINE::NeutralPyObjref::put(), YACS::ENGINE::NeutralPySequence::put(), YACS::ENGINE::NeutralPyStruct::put(), and YACS::ENGINE::DynParaLoop::putValueOnBranch().
◆ releaseData()
◆ releaseDataUnsafe()
void YACS::ENGINE::InputPort::releaseDataUnsafe ( )
◆ setStringRef()
void InputPort::setStringRef ( std::string  strRef)
Definition at line 169 of file InputPort.cxx.
170{
171 _stringRef = strRef;
172}
Definition: InputPort.hxx:90
References _stringRef.
Referenced by YACS::ENGINE::XmlCorba::put(), and YACS::ENGINE::XmlPython::put().
◆ typeName()
virtual std::string YACS::ENGINE::InputPort::typeName ( )
◆ OutPort
friend class OutPort
friend
Definition at line 46 of file InputPort.hxx.
◆ Runtime
friend class Runtime
friend
Definition at line 45 of file InputPort.hxx.
◆ _canBeNull
bool YACS::ENGINE::InputPort::_canBeNull
Definition at line 91 of file InputPort.hxx.
Referenced by canBeNull(), and checkBasicConsistency().
◆ _initValue
◆ _stringRef
std::string YACS::ENGINE::InputPort::_stringRef
◆ NAME
