YACS::ENGINE::AnyInputPort Class Reference
#include <AnyInputPort.hxx>
Inheritance diagram for YACS::ENGINE::AnyInputPort:
Collaboration diagram for YACS::ENGINE::AnyInputPort:
 AnyInputPort (const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
 AnyInputPort (const AnyInputPort &other, Node *newHelder)
virtual ~AnyInputPort ()
void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
void exRestoreInit ()
 Restore the saved data value to current data value. More...
Any * getValue () const
int getIntValue () const
void releaseData () override
void put (Any *data)
void * get () const
virtual bool isEmpty ()
void put (const void *data)
std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
Any * _value
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
YACS::BASES::Mutex _mutex
static int _total = 0
Definition at line 33 of file AnyInputPort.hxx.
◆ AnyInputPort() [1/2]
AnyInputPort::AnyInputPort ( const std::string &  name,
Node *  node,
TypeCode *  type,
bool  canBeNull = false
Definition at line 35 of file AnyInputPort.cxx.
36 : InputPort(name, node, type, canBeNull),
37 DataPort(name, node, type),
38 Port(node),
39 _value(0)
40{
41}
Definition: DataPort.cxx:41
bool canBeNull() const
Definition: InputPort.cxx:174
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ AnyInputPort() [2/2]
AnyInputPort::AnyInputPort ( const AnyInputPort &  other,
Node *  newHelder
Definition at line 43 of file AnyInputPort.cxx.
44 : InputPort(other, newHelder),
45 DataPort(other, newHelder),
46 Port(other, newHelder),
47 _value(0)
48{
49 if(other._value)
50 _value=other._value->clone();
51}
virtual Any * clone() const =0
References _value, and YACS::ENGINE::Any::clone().
◆ ~AnyInputPort()
AnyInputPort::~AnyInputPort ( )
Definition at line 53 of file AnyInputPort.cxx.
54{
55 if(_value)
56 {
57 DEBTRACE("_value ref count: " << _value->getRefCnt());
58 _value->decrRef();
59 }
60}
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
References _value, DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::getRefCnt().
◆ clone()
InputPort * AnyInputPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Reimplemented in YACS::ENGINE::InterceptorInputPort, and YACS::ENGINE::SeqAnyInputPort.
Definition at line 133 of file AnyInputPort.cxx.
134{
135 return new AnyInputPort(*this,newHelder);
136}
AnyInputPort(const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
References AnyInputPort().
Referenced by YACS::ENGINE::OptimizerLoop::initInterceptors().
◆ dump()
std::string AnyInputPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Reimplemented in YACS::ENGINE::SeqAnyInputPort.
Definition at line 138 of file AnyInputPort.cxx.
139{
140 if(!_value)
141 {
142 std::string what="AnyInputPort::get : no value currently in input port with name \""; what+=_name; what+="\"";
143 throw Exception(what);
144 }
145 stringstream xmldump;
146 switch (_value->getType()->kind())
147 {
148 case Double:
149 xmldump << "<value><double>" << setprecision(16) << _value->getDoubleValue() << "</double></value>" << endl;
150 break;
151 case Int:
152 xmldump << "<value><int>" << _value->getIntValue() << "</int></value>" << endl;
153 break;
154 case Bool:
155 xmldump << "<value><boolean>" << _value->getBoolValue() << "</boolean></value>" << endl;
156 break;
157 case String:
158 xmldump << "<value><string>" << _value->getStringValue() << "</string></value>" << endl;
159 break;
160 default:
161 xmldump << "<value><error> NO_SERIALISATION_AVAILABLE </error></value>" << endl;
162 break;
163 }
164 return xmldump.str();
165}
virtual std::string getStringValue() const =0
virtual int getIntValue() const =0
virtual double getDoubleValue() const =0
virtual bool getBoolValue() const =0
const TypeCode * getType() const
Definition: Any.hxx:85
DynType kind() const
Definition: TypeCode.cxx:47
References YACS::ENGINE::DataPort::_name, _value, YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::Any::getBoolValue(), YACS::ENGINE::Any::getDoubleValue(), YACS::ENGINE::Any::getIntValue(), YACS::ENGINE::Any::getStringValue(), YACS::ENGINE::Any::getType(), YACS::ENGINE::Int, YACS::ENGINE::TypeCode::kind(), and YACS::ENGINE::String.
◆ exRestoreInit()
void AnyInputPort::exRestoreInit ( )
If no data has been saved (_initValue == 0) don't restore
Definition at line 77 of file AnyInputPort.cxx.
78{
79 if(!_initValue)
80 return;
81 if(_value)
82 _value->decrRef();
84 _value->incrRef();
85}
References YACS::ENGINE::InputPort::_initValue, _value, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::incrRef().
◆ exSaveInit()
void AnyInputPort::exSaveInit ( )
Definition at line 66 of file AnyInputPort.cxx.
◆ get()
void * AnyInputPort::get ( ) const
Definition at line 117 of file AnyInputPort.cxx.
118{
119 return (void *)_value;
120}
References _value.
◆ getAsString()
std::string AnyInputPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 122 of file AnyInputPort.cxx.
123{
126}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual std::string convertNeutralAsString(TypeCode *type, Any *data)
Convert a YACS::ENGINE::Any object to a string to be used in GUI for example.
Definition: Runtime.cxx:369
Definition: Runtime.cxx:61
References _mutex, _value, YACS::ENGINE::Runtime::convertNeutralAsString(), YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::getRuntime().
◆ getIntValue()
◆ getValue()
Any * YACS::ENGINE::AnyInputPort::getValue ( ) const
Definition at line 41 of file AnyInputPort.hxx.
41{ return _value; }
Referenced by YACS::ENGINE::OptimizerLoop::exUpdateState().
◆ isEmpty()
◆ put() [1/2]
void AnyInputPort::put ( Any *  data)
◆ put() [2/2]
void AnyInputPort::put ( const void *  data)
Definition at line 128 of file AnyInputPort.cxx.
129{
130 put((Any *)data);
131}
Definition: Any.hxx:79
References put().
◆ releaseData()
void AnyInputPort::releaseData ( )
overridevirtual
Definition at line 94 of file AnyInputPort.cxx.
References _mutex, and releaseDataUnsafe().
◆ releaseDataUnsafe()
void AnyInputPort::releaseDataUnsafe ( )
Definition at line 87 of file AnyInputPort.cxx.
88{
89 if(_value)
90 _value->decrRef();
91 _value = nullptr;
92}
References _value, and YACS::ENGINE::RefCounter::decrRef().
Referenced by put(), and releaseData().
◆ typeName()
virtual std::string YACS::ENGINE::AnyInputPort::typeName ( )
Definition at line 51 of file AnyInputPort.hxx.
51{return "YACS__ENGINE__AnyInputPort";}
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::AnyInputPort::_mutex
Definition at line 57 of file AnyInputPort.hxx.
Referenced by getAsString(), put(), and releaseData().
◆ _value
