YACS::ENGINE::DataPort Class Referenceabstract
#include <DataPort.hxx>
Inheritance diagram for YACS::ENGINE::DataPort:
Collaboration diagram for YACS::ENGINE::DataPort:
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
Static Public Attributes
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 41 of file DataPort.hxx.
◆ ~DataPort()
DataPort::~DataPort ( )
Definition at line 29 of file DataPort.cxx.
30{
31 if(_type)
32 _type->decrRef();
33}
References _type, and YACS::ENGINE::RefCounter::decrRef().
◆ DataPort() [1/2]
DataPort::DataPort ( const DataPort &  other,
Node *  newHelder
Definition at line 41 of file DataPort.cxx.
41 :Port(other,newHelder),_name(other._name),_type(other._type)
42{
43 if(_type)
44 _type->incrRef();
45}
Port(Node *node)
Definition: Port.cxx:34
References _type, and YACS::ENGINE::RefCounter::incrRef().
◆ DataPort() [2/2]
DataPort::DataPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 35 of file DataPort.cxx.
35 :Port(node),_name(name),_type(type)
36{
37 if(_type)
38 _type->incrRef();
39}
◆ edGetType()
TypeCode * YACS::ENGINE::DataPort::edGetType ( ) const
Definition at line 53 of file DataPort.hxx.
53{ return _type; }
Referenced by YACS::ENGINE::RuntimeSALOME::adaptCorbaToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToPython(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToXml(), YACS::ENGINE::RuntimeSALOME::adaptCppToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCppToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCppToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCppToPython(), YACS::ENGINE::RuntimeSALOME::adaptCppToXml(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCorba(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCpp(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToPython(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToXml(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCorba(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCpp(), YACS::ENGINE::RuntimeSALOME::adaptPythonToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptPythonToPython(), YACS::ENGINE::RuntimeSALOME::adaptPythonToXml(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCorba(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCpp(), YACS::ENGINE::RuntimeSALOME::adaptXmlToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptXmlToPython(), YACS::ENGINE::RuntimeSALOME::adaptXmlToXml(), YACS::HMI::SubjectNode::addSubjectIDSPort(), YACS::HMI::SubjectNode::addSubjectInputPort(), YACS::HMI::SubjectNode::addSubjectODSPort(), YACS::HMI::SubjectNode::addSubjectOutputPort(), YACS::ENGINE::Loop::buildDelegateOf(), YACS::ENGINE::ForEachLoopGen::buildDelegateOf(), YACS::HMI::ValueDelegate::createEditor(), YACS::ENGINE::SeqAnyInputPort::dump(), YACS::ENGINE::InputCorbaPort::dump(), YACS::ENGINE::OutputCorbaPort::dump(), YACS::ENGINE::InputCppPort::dump(), YACS::ENGINE::OutputCppPort::dump(), YACS::ENGINE::InputPyPort::dump(), YACS::ENGINE::OutputPyPort::dump(), YACS::ENGINE::OutputDataStreamPort::edAddInputDataStreamPort(), YACS::HMI::EditionForEachLoop::EditionForEachLoop(), YACS::ENGINE::OutputCorbaPort::getAnyOut(), YACS::ENGINE::AnyInputPort::getAsString(), YACS::ENGINE::AnyOutputPort::getAsString(), YACS::ENGINE::OutputPresetPort::getData(), YACS::ENGINE::OutputStudyPort::getDataFromStudy(), YACS::ENGINE::InputStudyPort::getIOR(), YACS::ENGINE::InputCorbaPort::getPyObj(), YACS::ENGINE::OutputCorbaPort::getPyObj(), YACS::ENGINE::OutputPresetPort::getPyObj(), YACS::ENGINE::InputPresetPort::getPyObj(), YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetOutPortValue::localExecute(), YACS::HMI::CommandSetInPortValue::localReverse(), YACS::HMI::CommandSetOutPortValue::localReverse(), YACS::HMI::TreeView::onCommitData(), YACS::ENGINE::CppPy::put(), YACS::ENGINE::CppCorba::put(), YACS::ENGINE::CppCpp::put(), YACS::ENGINE::CppNeutral::put(), YACS::ENGINE::XmlCorba::put(), YACS::ENGINE::XmlCpp::put(), YACS::ENGINE::XmlNeutral::put(), YACS::ENGINE::XmlPython::put(), YACS::ENGINE::CorbaCorba::put(), YACS::ENGINE::CorbaCpp::put(), YACS::ENGINE::CorbaNeutral::put(), YACS::ENGINE::CorbaPyDouble::put(), YACS::ENGINE::CorbaPyInt::put(), YACS::ENGINE::CorbaPyString::put(), YACS::ENGINE::CorbaPyBool::put(), YACS::ENGINE::CorbaPyObjref::put(), YACS::ENGINE::CorbaPySequence::put(), YACS::ENGINE::CorbaPyStruct::put(), YACS::ENGINE::CorbaXml::put(), YACS::ENGINE::PyCorbaInt::put(), YACS::ENGINE::PyCorbaDouble::put(), YACS::ENGINE::PyCorbaString::put(), YACS::ENGINE::PyCorbaBool::put(), YACS::ENGINE::PyCorbaObjref::put(), YACS::ENGINE::PyCorbaSequence::put(), YACS::ENGINE::PyCorbaStruct::put(), YACS::ENGINE::PyCpp::put(), YACS::ENGINE::PyInit::put(), YACS::ENGINE::PyNeutral::put(), YACS::ENGINE::PyXml::put(), YACS::ENGINE::CppXml::put(), YACS::ENGINE::NeutralCorbaInt::put(), YACS::ENGINE::NeutralCorbaDouble::put(), YACS::ENGINE::NeutralCorbaBool::put(), YACS::ENGINE::NeutralCorbaSequence::put(), YACS::ENGINE::NeutralCorbaString::put(), YACS::ENGINE::NeutralCorbaObjref::put(), YACS::ENGINE::NeutralCorbaStruct::put(), YACS::ENGINE::NeutralCpp::put(), YACS::ENGINE::NeutralInit::put(), YACS::ENGINE::NeutralPyDouble::put(), YACS::ENGINE::NeutralPyInt::put(), YACS::ENGINE::NeutralPyString::put(), YACS::ENGINE::NeutralPyBool::put(), YACS::ENGINE::NeutralPyObjref::put(), YACS::ENGINE::NeutralPySequence::put(), YACS::ENGINE::NeutralPyStruct::put(), YACS::ENGINE::NeutralXml::put(), YACS::ENGINE::InputStudyPort::putDataInStudy(), YACS::ENGINE::OutputStudyPort::putIOR(), YACS::ENGINE::DynParaLoop::putValueOnBranch(), YACS::HMI::SubjectDataPort::registerUndoDestroy(), YACS::HMI::SchemaInPortItem::SchemaInPortItem(), YACS::HMI::SchemaOutPortItem::SchemaOutPortItem(), YACS::ENGINE::Proc::setInPortValue(), YACS::HMI::EditionOptimizerLoop::update(), YACS::HMI::SchemaInPortItem::update(), YACS::HMI::SchemaOutPortItem::update(), YACS::ENGINE::VisitorSaveSchema::visitForEachLoop(), and YACS::ENGINE::VisitorSaveSchema::visitForEachLoopDyn().
◆ edRemoveAllLinksLinkedWithMe()
virtual void YACS::ENGINE::DataPort::edRemoveAllLinksLinkedWithMe ( )
pure virtual
◆ edSetType()
void DataPort::edSetType ( TypeCode *  type)
◆ getAsString()
std::string DataPort::getAsString ( )
Do nothing here. To subclass
Reimplemented in YACS::ENGINE::AnyInputPort, YACS::ENGINE::AnyOutputPort, YACS::ENGINE::ConditionInputPort, YACS::ENGINE::InputCorbaPort, YACS::ENGINE::OutputCorbaPort, YACS::ENGINE::OutputPresetPort, YACS::ENGINE::InputPresetPort, YACS::ENGINE::InputPyPort, YACS::ENGINE::OutputPyPort, YACS::ENGINE::OutputStudyPort, and YACS::ENGINE::InputStudyPort.
Definition at line 84 of file DataPort.cxx.
85{
86 return "";
87}
Referenced by YACS::ENGINE::Proc::getInPortValue(), YACS::ENGINE::Proc::getOutPortValue(), YACS::HMI::SubjectForLoop::getValue(), YACS::HMI::SubjectWhileLoop::getValue(), YACS::HMI::SubjectSwitch::getValue(), YACS::HMI::SubjectDynParaLoop::getValue(), YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetSwitchSelect::localExecute(), YACS::HMI::CommandSetForLoopSteps::localExecute(), YACS::HMI::CommandSetWhileCondition::localExecute(), YACS::HMI::CommandSetForEachBranch::localExecute(), YACS::HMI::CommandSetInPortValue::localReverse(), YACS::HMI::SchemaInPortItem::SchemaInPortItem(), YACS::HMI::SchemaOutPortItem::SchemaOutPortItem(), YACSPMMLBasicsTest1::testYACSdriver_LRANN(), YACSPMMLBasicsTest1::testYACSdriver_PmmlDoesNotExist(), YACSPMMLBasicsTest1::testYACSdriverLinearRegression(), YACSPMMLBasicsTest1::testYACSdriverNeuralNetwork(), YACS::HMI::EditionForEachLoop::update(), YACS::HMI::EditionOptimizerLoop::update(), YACS::HMI::SchemaInPortItem::update(), and YACS::HMI::SchemaOutPortItem::update().
◆ getName()
std::string YACS::ENGINE::DataPort::getName ( ) const
Definition at line 55 of file DataPort.hxx.
55{ return _name; }
Referenced by YACS::ENGINE::RuntimeSALOME::adaptCorbaToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToPython(), YACS::ENGINE::RuntimeSALOME::adaptCorbaToXml(), YACS::ENGINE::RuntimeSALOME::adaptCppToCorba(), YACS::ENGINE::RuntimeSALOME::adaptCppToCpp(), YACS::ENGINE::RuntimeSALOME::adaptCppToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptCppToPython(), YACS::ENGINE::RuntimeSALOME::adaptCppToXml(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCorba(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToCpp(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToPython(), YACS::ENGINE::RuntimeSALOME::adaptNeutralToXml(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCorba(), YACS::ENGINE::RuntimeSALOME::adaptPythonToCpp(), YACS::ENGINE::RuntimeSALOME::adaptPythonToNeutral(), YACS::ENGINE::RuntimeSALOME::adaptPythonToPython(), YACS::ENGINE::RuntimeSALOME::adaptPythonToXml(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCorba(), YACS::ENGINE::RuntimeSALOME::adaptXmlToCpp(), YACS::ENGINE::RuntimeSALOME::adaptXmlToPython(), YACS::ENGINE::RuntimeSALOME::adaptXmlToXml(), YACS::ENGINE::CollectorSwOutPort::addPotentialProducerForMaster(), YACS::HMI::SubjectNode::addSubjectIDSPort(), YACS::HMI::SubjectNode::addSubjectInputPort(), YACS::HMI::SubjectNode::addSubjectODSPort(), YACS::HMI::SubjectNode::addSubjectOutputPort(), YACS::ENGINE::Loop::buildDelegateOf(), YACS::ENGINE::OptimizerLoop::buildDelegateOf(), YACS::ENGINE::DynParaLoop::buildDelegateOf(), YACS::ENGINE::OutputPresetPort::checkBasicConsistency(), YACS::ENGINE::ForEachLoopPassedData::checkLevel2(), YACS::ENGINE::DynParaLoop::checkLinkPossibility(), YACS::ENGINE::OptimizerLoop::checkLinkPossibility(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), YACS::ENGINE::CollectorSwOutPort::CollectorSwOutPort(), YACS::ENGINE::ElementaryNode::createMultiDatastreamPorts(), YACS::ENGINE::ForEachLoopGen::createOutputOutOfScopeInterceptors(), YACS::ENGINE::ComposedNode::edAddDFLink(), YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::ENGINE::Loop::getDelegateOf(), YACS::ENGINE::Switch::getDelegateOf(), YACS::ENGINE::CollectorSwOutPort::getHumanReprOfIncompleteCases(), YACS::ENGINE::ElementaryNode::getInPortName(), YACS::HMI::SubjectDataPort::getName(), YACS::ENGINE::ElementaryNode::getOutPortName(), YACS::HMI::SubjectComposedNode::loadLinks(), YACS::HMI::CommandOrderInputPorts::localExecute(), YACS::HMI::CommandOrderOutputPorts::localExecute(), YACS::HMI::CommandOrderInputPorts::localReverse(), YACS::HMI::CommandOrderOutputPorts::localReverse(), YACS::ENGINE::CorbaCpp::put(), YACS::ENGINE::CorbaNeutral::put(), YACS::ENGINE::CppXml::put(), YACS::ENGINE::InputStudyPort::putDataInStudy(), YACS::HMI::SubjectLink::registerUndoDestroy(), YACS::ENGINE::Loop::releaseDelegateOf(), YACS::HMI::SubjectComposedNode::removeLink(), YACS::HMI::SubjectNode::saveLinks(), YACS::HMI::GuiExecutor::setInPortValue(), YACS::HMI::SubjectDataPort::setName(), YACS::HMI::SubjectInputPort::SubjectInputPort(), YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks(), YACS::ENGINE::VisitorSaveSchema::writeSimpleStreamLinks(), and YACS::ENGINE::OutputCorbaPort::~OutputCorbaPort().
◆ getTypeOfChannel()
virtual TypeOfChannel YACS::ENGINE::DataPort::getTypeOfChannel ( ) const
pure virtual
returns type of channel the port will use for data exchange on runtime : DATAFLOW or DATASTREAM.
Implemented in YACS::ENGINE::DataFlowPort, YACS::ENGINE::DataStreamPort, and YACS::ENGINE::CollectorSwOutPort.
Referenced by isDifferentTypeOf().
◆ isCrossingType()
DataPort * DataPort::isCrossingType ( const std::vector< DataPort * > &  historyOfLink)
If in historyOfLink different type of Port are detected : The first one (by starting from the end of 'historyOfLink') is returned. Else 0 is returned if they are all of the same type.
Definition at line 70 of file DataPort.cxx.
71{
72 vector<DataPort *>::const_reverse_iterator iter=historyOfLink.rbegin()+1;
73 const DataPort *base=historyOfLink.back();
74 for(;iter!=historyOfLink.rend();iter++)
75 if(base->isDifferentTypeOf(*iter))
76 return *iter;
77 return 0;
78}
bool isDifferentTypeOf(const DataPort *other) const
Definition: DataPort.cxx:61
References isDifferentTypeOf().
◆ isDifferentTypeOf()
bool DataPort::isDifferentTypeOf ( const DataPort *  other) const
Definition at line 61 of file DataPort.cxx.
62{
63 return getTypeOfChannel()!=other->getTypeOfChannel();
64}
virtual TypeOfChannel getTypeOfChannel() const =0
References getTypeOfChannel().
Referenced by isCrossingType().
◆ setName()
◆ typeName()
◆ _name
◆ _type
TypeCode* YACS::ENGINE::DataPort::_type
◆ NAME
const char DataPort::NAME ="DataPort"
Definition at line 47 of file DataPort.hxx.
Referenced by getNameOfTypeOfCurrentInstance().
