YACS::ENGINE::InputCorbaPort Class Reference
Class for CORBA Input Ports. More...
#include <CORBAPorts.hxx>
Inheritance diagram for YACS::ENGINE::InputCorbaPort:
Collaboration diagram for YACS::ENGINE::InputCorbaPort:
 InputCorbaPort (const std::string &name, Node *node, TypeCode *type)
 InputCorbaPort (const InputCorbaPort &other, Node *newHelder)
virtual ~InputCorbaPort ()
bool edIsManuallyInitialized () const
void edRemoveManInit ()
void put (CORBA::Any *data)
void releaseData () override
void * get () const
virtual bool isEmpty ()
virtual CORBA::Any * getAny ()
virtual PyObject * getPyObj ()
virtual void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
virtual void exRestoreInit ()
 Restore the saved data value to current data value. More...
virtual std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
CORBA::Any _data
CORBA::Any * _initData
CORBA::ORB_ptr _orb
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
YACS::BASES::Mutex _mutex
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
CORBANode
Definition at line 44 of file CORBAPorts.hxx.
◆ InputCorbaPort() [1/2]
InputCorbaPort::InputCorbaPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 100 of file CORBAPorts.cxx.
103 : InputPort(name, node, type), DataPort(name, node, type), Port(node), _initData(0)
104{
106}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
CORBA::ORB_ptr getOrb() const
References _orb, YACS::ENGINE::RuntimeSALOME::getOrb(), and YACS::ENGINE::getSALOMERuntime().
Referenced by clone().
◆ InputCorbaPort() [2/2]
InputCorbaPort::InputCorbaPort ( const InputCorbaPort &  other,
Node *  newHelder
Definition at line 108 of file CORBAPorts.cxx.
108 :InputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder),
109 _initData(0)
110{
112 if(other._initData)
113 {
114 _initData=new CORBA::Any;
115 *_initData=*(other._initData);
116 }
117 _data=other._data;
118}
References _data, _initData, _orb, YACS::ENGINE::RuntimeSALOME::getOrb(), and YACS::ENGINE::getSALOMERuntime().
◆ ~InputCorbaPort()
InputCorbaPort::~InputCorbaPort ( )
Definition at line 120 of file CORBAPorts.cxx.
121{
122 delete _initData;
123 // Release or not release : all GenericObj are deleted when the input port is deleted
125}
void releaseObj(CORBA::Any &data)
Definition: CORBAPorts.cxx:48
References _data, _initData, and releaseObj().
◆ clone()
InputPort * InputCorbaPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 191 of file CORBAPorts.cxx.
192{
193 return new InputCorbaPort(*this,newHelder);
194}
InputCorbaPort(const std::string &name, Node *node, TypeCode *type)
Definition: CORBAPorts.cxx:100
References InputCorbaPort().
◆ dump()
std::string InputCorbaPort::dump ( )
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 258 of file CORBAPorts.cxx.
259{
260 CORBA::TypeCode_var tc=_data.type();
261 if (tc->equivalent(CORBA::_tc_null))
262 return "<value>nil</value>";
263 if (edGetType()->kind() != YACS::ENGINE::Objref)
264 return convertCorbaXml(edGetType(), &_data);
265 if (! _stringRef.empty())
266 return _stringRef;
267 else
268 return convertCorbaXml(edGetType(), &_data);
269// {
270// stringstream msg;
271// msg << "Cannot retreive init string reference string for port " << _name
272// << " on node " << _node->getName();
273// throw Exception(msg.str());
274// }
275}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: InputPort.hxx:90
std::string convertCorbaXml(const TypeCode *t, CORBA::Any *data)
References _data, YACS::ENGINE::InputPort::_stringRef, YACS::ENGINE::convertCorbaXml(), YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::Objref.
◆ edIsManuallyInitialized()
bool InputCorbaPort::edIsManuallyInitialized ( ) const
Specifies if this port has been manually set by the call of InputPort::edInit.
Definition at line 127 of file CORBAPorts.cxx.
128{
129 return _initData!=0;
130}
References _initData.
◆ edRemoveManInit()
void InputCorbaPort::edRemoveManInit ( )
Removes eventually previous manual initialisation.
Definition at line 132 of file CORBAPorts.cxx.
133{
134 delete _initData;
135 _initData=0;
137}
virtual void edRemoveManInit()
Definition: InputPort.cxx:140
References _initData, and YACS::ENGINE::InputPort::edRemoveManInit().
◆ exRestoreInit()
void InputCorbaPort::exRestoreInit ( )
If no data has been saved (_initData == 0) don't restore
Definition at line 252 of file CORBAPorts.cxx.
253{
254 if(!_initData)return;
255 put(_initData);
256}
Definition: CORBAPorts.cxx:139
References _initData, and put().
◆ exSaveInit()
void InputCorbaPort::exSaveInit ( )
Definition at line 240 of file CORBAPorts.cxx.
241{
242 if(_initData)
243 delete _initData;
244 _initData=new CORBA::Any;
246}
References _data, and _initData.
◆ get()
void * InputCorbaPort::get ( ) const
Definition at line 196 of file CORBAPorts.cxx.
197{
198 return (void *)&_data;
199}
References _data.
◆ getAny()
CORBA::Any * InputCorbaPort::getAny ( )
Definition at line 207 of file CORBAPorts.cxx.
208{
209 // --- return a pointer to internal any
210 return &_data;
211}
References _data.
Referenced by getPyObj().
◆ getAsString()
std::string InputCorbaPort::getAsString ( )
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 226 of file CORBAPorts.cxx.
227{
229 PyObject* ob=getPyObj();
230 std::string s=convertPyObjectToString(ob);
231 Py_DECREF(ob);
232 return s;
233}
virtual PyObject * getPyObj()
Definition: CORBAPorts.cxx:213
std::string convertPyObjectToString(PyObject *ob)
References YACS::ENGINE::convertPyObjectToString(), and getPyObj().
◆ getPyObj()
PyObject * InputCorbaPort::getPyObj ( )
Definition at line 213 of file CORBAPorts.cxx.
214{
216 CORBA::TypeCode_var tc=getAny()->type();
217 if (!tc->equivalent(CORBA::_tc_null))
219 else
220 {
221 Py_INCREF(Py_None);
222 return Py_None;
223 }
224}
virtual CORBA::Any * getAny()
Definition: CORBAPorts.cxx:207
Definition: CORBAPorts.hxx:72
PyObject * convertCorbaPyObject(const TypeCode *t, CORBA::Any *data)
References _mutex, YACS::ENGINE::convertCorbaPyObject(), YACS::ENGINE::DataPort::edGetType(), and getAny().
Referenced by getAsString(), and valToStr().
◆ isEmpty()
bool InputCorbaPort::isEmpty ( )
Definition at line 201 of file CORBAPorts.cxx.
202{
203 CORBA::TypeCode_var tc=_data.type();
204 return tc->equivalent(CORBA::_tc_null);
205}
References _data.
◆ put() [1/2]
void InputCorbaPort::put ( const void *  data)
Definition at line 139 of file CORBAPorts.cxx.
140{
141 put((CORBA::Any *)data);
142}
References put().
Referenced by exRestoreInit(), and put().
◆ put() [2/2]
void InputCorbaPort::put ( CORBA::Any *  data)
Definition at line 168 of file CORBAPorts.cxx.
169{
170#ifdef REFCNT
171 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)data->pd_tc.in())->pd_ref_count);
172#endif
174#ifdef _DEVDEBUG_
175 display(data);
176#endif
177
179
180 // make a copy of the any (protect against deletion of any source)
181 _data=*data;
182 _stringRef="";
183
185
186#ifdef REFCNT
187 DEBTRACE("refcount CORBA : " << ((omni::TypeCode_base*)_data.pd_tc.in())->pd_ref_count);
188#endif
189}
void display(CORBA::Any *data)
Definition: CORBAPorts.cxx:144
void registerObj(CORBA::Any &data)
Definition: CORBAPorts.cxx:74
References _data, _mutex, YACS::ENGINE::InputPort::_stringRef, DEBTRACE, display(), registerObj(), and releaseObj().
◆ releaseData()
void InputCorbaPort::releaseData ( )
overridevirtual
Definition at line 164 of file CORBAPorts.cxx.
165{//do nothing - to be implemented
166}
◆ typeName()
virtual std::string YACS::ENGINE::InputCorbaPort::typeName ( )
Definition at line 64 of file CORBAPorts.hxx.
64{return "YACS__ENGINE__InputCorbaPort";}
◆ valFromStr()
void InputCorbaPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 288 of file CORBAPorts.cxx.
289{
290}
◆ valToStr()
std::string InputCorbaPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 277 of file CORBAPorts.cxx.
278{
279 int isString = PyBytes_Check(getPyObj());
280 PyObject *strPyObj = PyObject_Str(getPyObj());
281 string val = PyBytes_AsString(strPyObj);
282 if (isString)
283 val = "\"" + val + "\"";
284 Py_DECREF(strPyObj);
285 return val;
286}
References getPyObj().
◆ _data
CORBA::Any YACS::ENGINE::InputCorbaPort::_data
Definition at line 68 of file CORBAPorts.hxx.
Referenced by dump(), exSaveInit(), get(), getAny(), InputCorbaPort(), isEmpty(), put(), and ~InputCorbaPort().
◆ _initData
CORBA::Any* YACS::ENGINE::InputCorbaPort::_initData
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::InputCorbaPort::_mutex
Definition at line 72 of file CORBAPorts.hxx.
Referenced by getPyObj(), and put().
◆ _orb
CORBA::ORB_ptr YACS::ENGINE::InputCorbaPort::_orb
Definition at line 70 of file CORBAPorts.hxx.
Referenced by InputCorbaPort().
