YACS::ENGINE::InPort Class Reference
#include <InPort.hxx>
Inheritance diagram for YACS::ENGINE::InPort:
Collaboration diagram for YACS::ENGINE::InPort:
bool isBackLinked () const
virtual ~InPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
Friends
class Loop
class OutPort
class ProxyPort
class OutputPort
class DynParaLoop
class ForEachLoop
class SplitterNode
class ComposedNode
class OptimizerLoop
class NbBranches
class ElementaryNode
class CollectorSwOutPort
class OutputDataStreamPort
class InterceptorInputPort
static int _total = 0
Definition at line 46 of file InPort.hxx.
◆ ~InPort()
InPort::~InPort ( )
Definition at line 40 of file InPort.cxx.
41{
42}
◆ InPort() [1/2]
InPort::InPort ( const InPort &  other,
Node *  newHelder
Definition at line 30 of file InPort.cxx.
30 :
31 DataPort(other,newHelder),Port(other,newHelder)
32{
33}
Definition: DataPort.cxx:41
Port(Node *node)
Definition: Port.cxx:34
◆ InPort() [2/2]
InPort::InPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 35 of file InPort.cxx.
35 :
36 DataPort(name,node,type),Port(node)
37{
38}
◆ canSafelySqueezeMemory()
bool InPort::canSafelySqueezeMemory ( ) const
Definition at line 73 of file InPort.cxx.
74{
75 if(!isBackLinked())
76 return false;
77 for(auto bl : _backLinks)
78 {
79 if(!bl.second)
80 return false;
81 }
82 return true;
83}
bool isBackLinked() const
Definition: InPort.hxx:67
std::set< std::pair< OutPort *, bool > > _backLinks
Definition: InPort.hxx:78
References _backLinks, and isBackLinked().
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), YACS::ENGINE::PythonNode::squeezeMemory(), and YACS::ENGINE::PythonNode::squeezeMemoryRemote().
◆ edGetNumberOfLinks()
int InPort::edGetNumberOfLinks ( ) const
◆ edNotifyDereferencedBy()
void InPort::edNotifyDereferencedBy ( OutPort *  fromPort)
Reimplemented in YACS::ENGINE::ConditionInputPort, and YACS::ENGINE::ProxyPort.
Definition at line 102 of file InPort.cxx.
103{
104 auto it(std::find_if(_backLinks.begin(),_backLinks.end(),[fromPort](const std::pair<OutPort *,bool>& p){ return p.first==fromPort; }));
105 if(it!=_backLinks.end())
106 _backLinks.erase(it);
107 modified();
108}
void modified()
Definition: Port.cxx:53
Proc * p
Definition: driver.cxx:216
References _backLinks, YACS::ENGINE::Port::modified(), and p.
Referenced by YACS::ENGINE::ConditionInputPort::edNotifyDereferencedBy(), YACS::ENGINE::ProxyPort::edNotifyDereferencedBy(), and YACS::ENGINE::ComposedNode::edRemoveLink().
◆ edNotifyReferencedBy()
void InPort::edNotifyReferencedBy ( OutPort *  fromPort,
bool  isLoopProof = true
[in]isLoopProof- Tells if the data coming from fromPort will be send again in case of this is initialized. This value is important if this is an InPort of a Node contained directly or not inside a Loop, ForEachLoop, OptimizerLoop. In this case, to optimize memory consumption (see squeezeMemory method), we need to know if data coming from fromPort will be generated again in case. If true (the default) it means that for that link is a link loop proof so no need to take care. If false, the link is not loop proof so event in the context of agressive memory management the data can't be safely released.
Definition at line 93 of file InPort.cxx.
94{
95 auto it(std::find_if(_backLinks.begin(),_backLinks.end(),[fromPort](const std::pair<OutPort *,bool>& p){ return p.first==fromPort; }));
96 if(it!=_backLinks.end())
97 _backLinks.erase(it);
98 _backLinks.insert(std::pair<OutPort *,bool>(fromPort,isLoopProof));
99 modified();
100}
Referenced by YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::ConditionInputPort::edNotifyReferencedBy(), YACS::ENGINE::ProxyPort::edNotifyReferencedBy(), YACS::ENGINE::DynParaLoop::prepareInputsFromOutOfScope(), and YACS::ENGINE::DynParaLoop::putValueOnBranch().
◆ edRemoveAllLinksLinkedWithMe()
void InPort::edRemoveAllLinksLinkedWithMe ( )
Implements YACS::ENGINE::DataPort.
Reimplemented in YACS::ENGINE::ProxyPort.
Definition at line 50 of file InPort.cxx.
51{
52 set< std::pair<OutPort *,bool> > temp(_backLinks);//edRemoveLink called after causes invalidation of set iterator.
53 for(auto iter : temp)
54 {
55 set<OutPort *> trueBackOutputs;
56 iter.first->getAllRepresented(trueBackOutputs);
57 for( auto iter2 : trueBackOutputs )
58 _node->getRootNode()->edRemoveLink(iter2,this);
59 }
60 _backLinks.clear();
61 modified();
62}
void edRemoveLink(OutPort *start, InPort *end)
Remove a dataflow link.
virtual ComposedNode * getRootNode() const
Definition: Node.cxx:431
Node * _node
Definition: Port.hxx:55
References _backLinks, YACS::ENGINE::Port::_node, YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::ENGINE::Node::getRootNode(), and YACS::ENGINE::Port::modified().
Referenced by YACS::ENGINE::ProxyPort::edRemoveAllLinksLinkedWithMe(), and YACS::ENGINE::NbBranches::forceMultiplicity().
◆ edSetOutPort()
std::set< OutPort * > InPort::edSetOutPort ( ) const
Returns physical backlinks NOT user backlinks.
Definition at line 65 of file InPort.cxx.
66{
67 std::set<OutPort *> ret;
68 for( auto iter : _backLinks )
69 ret.insert(iter.first);
70 return ret;
71}
References _backLinks.
Referenced by YACS::ENGINE::ProxyPort::edSetOutPort(), YACS::ENGINE::ElementaryNode::ensureLoading(), YACS::ENGINE::Switch::getAllInPortsComingFromOutsideOfCurrentScope(), YACS::ENGINE::OutputPort4DS2DF::getAllRepresented(), YACS::ENGINE::OptimizerLoop::initInterceptors(), and YACS::ENGINE::OptimizerLoop::OptimizerLoop().
◆ getAllRepresentants()
◆ getPublicRepresentant()
virtual InPort * YACS::ENGINE::InPort::getPublicRepresentant ( )
Reimplemented in YACS::ENGINE::InPropertyPort, YACS::ENGINE::InputPort, and YACS::ENGINE::ProxyPort.
Definition at line 63 of file InPort.hxx.
63{ return this; }
Referenced by YACS::ENGINE::OutputPort::isAlreadyLinkedWith().
◆ isBackLinked()
bool YACS::ENGINE::InPort::isBackLinked ( ) const
Definition at line 67 of file InPort.hxx.
67{ return !_backLinks.empty(); }
Referenced by canSafelySqueezeMemory().
◆ typeName()
◆ CollectorSwOutPort
friend class CollectorSwOutPort
friend
Definition at line 59 of file InPort.hxx.
◆ ComposedNode
friend class ComposedNode
friend
Definition at line 55 of file InPort.hxx.
◆ DynParaLoop
friend class DynParaLoop
friend
Definition at line 52 of file InPort.hxx.
◆ ElementaryNode
friend class ElementaryNode
friend
Definition at line 58 of file InPort.hxx.
◆ ForEachLoop
friend class ForEachLoop
friend
Definition at line 53 of file InPort.hxx.
◆ InterceptorInputPort
friend class InterceptorInputPort
friend
Definition at line 61 of file InPort.hxx.
Referenced by YACS::ENGINE::InterceptorInputPort::clone().
◆ Loop
friend class Loop
friend
Definition at line 48 of file InPort.hxx.
◆ NbBranches
friend class NbBranches
friend
Definition at line 57 of file InPort.hxx.
◆ OptimizerLoop
friend class OptimizerLoop
friend
Definition at line 56 of file InPort.hxx.
◆ OutPort
friend class OutPort
friend
Definition at line 49 of file InPort.hxx.
◆ OutputDataStreamPort
friend class OutputDataStreamPort
friend
Definition at line 60 of file InPort.hxx.
◆ OutputPort
friend class OutputPort
friend
Definition at line 51 of file InPort.hxx.
◆ ProxyPort
friend class ProxyPort
friend
Definition at line 50 of file InPort.hxx.
◆ SplitterNode
friend class SplitterNode
friend
Definition at line 54 of file InPort.hxx.
◆ _backLinks
