YACS::ENGINE::InputDataStreamPort Class Reference
#include <InputDataStreamPort.hxx>
Inheritance diagram for YACS::ENGINE::InputDataStreamPort:
Collaboration diagram for YACS::ENGINE::InputDataStreamPort:
 InputDataStreamPort (const InputDataStreamPort &other, Node *newHelder)
 InputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~InputDataStreamPort ()
virtual InputDataStreamPort * clone (Node *newHelder) const
virtual void edAddOutputDataStreamPort (OutputDataStreamPort *port)
std::set< OutputDataStreamPort * > getConnectedOutputDataStreamPort ()
- Public Member Functions inherited from YACS::ENGINE::DataStreamPort
 Set a new value for a property of the port. More...
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Static Public Attributes
static const char NAME [] ="InputDataStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::DataStreamPort
static const char NAME [] ="DataStreamPort"
std::set< OutputDataStreamPort * > _setOfOutputDataStreamPort
- Protected Attributes inherited from YACS::ENGINE::DataStreamPort
TypeCode * _type
Node * _node
int _id
bool isAlreadyInSet (OutputDataStreamPort *inPort) const
- Protected Member Functions inherited from YACS::ENGINE::DataStreamPort
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 37 of file InputDataStreamPort.hxx.
◆ InputDataStreamPort() [1/2]
InputDataStreamPort::InputDataStreamPort ( const InputDataStreamPort &  other,
Node *  newHelder
Definition at line 32 of file InputDataStreamPort.cxx.
32 :
33 DataStreamPort(other,newHelder),
34 InPort(other,newHelder),
35 DataPort(other,newHelder),
36 Port(other,newHelder)
37{
38}
Definition: DataPort.cxx:41
DataStreamPort(const DataStreamPort &other, Node *newHelder)
InPort(const InPort &other, Node *newHelder)
Definition: InPort.cxx:30
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputDataStreamPort() [2/2]
InputDataStreamPort::InputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 40 of file InputDataStreamPort.cxx.
40 :
41 DataStreamPort(name,node,type),
42 InPort(name,node,type),
43 DataPort(name,node,type),
44 Port(node)
45{
46}
◆ ~InputDataStreamPort()
InputDataStreamPort::~InputDataStreamPort ( )
Definition at line 48 of file InputDataStreamPort.cxx.
49{
50}
◆ clone()
InputDataStreamPort * InputDataStreamPort::clone ( Node *  newHelder) const
Reimplemented in YACS::ENGINE::InputCalStreamPort.
Definition at line 57 of file InputDataStreamPort.cxx.
58{
59 return new InputDataStreamPort(*this,newHelder);
60}
InputDataStreamPort(const InputDataStreamPort &other, Node *newHelder)
References InputDataStreamPort().
Referenced by YACS::ENGINE::ElementaryNode::createMultiDatastreamPorts().
◆ edAddOutputDataStreamPort()
void InputDataStreamPort::edAddOutputDataStreamPort ( OutputDataStreamPort *  port)
Definition at line 62 of file InputDataStreamPort.cxx.
63{
64 DEBTRACE("InputDataStreamPort::edAddOutputDataStreamPort");
65 if(!isAlreadyInSet(port))
66 _setOfOutputDataStreamPort.insert(port);
67}
bool isAlreadyInSet(OutputDataStreamPort *inPort) const
References _setOfOutputDataStreamPort, DEBTRACE, and isAlreadyInSet().
Referenced by YACS::ENGINE::OutputDataStreamPort::edAddInputDataStreamPort().
◆ getConnectedOutputDataStreamPort()
std::set< OutputDataStreamPort * > YACS::ENGINE::InputDataStreamPort::getConnectedOutputDataStreamPort ( )
string InputDataStreamPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::DataStreamPort.
Definition at line 52 of file InputDataStreamPort.cxx.
53{
54 return NAME;
55}
References NAME.
◆ isAlreadyInSet()
bool InputDataStreamPort::isAlreadyInSet ( OutputDataStreamPort *  inPort) const
Definition at line 69 of file InputDataStreamPort.cxx.
70{
72}
References _setOfOutputDataStreamPort.
Referenced by edAddOutputDataStreamPort().
◆ typeName()
virtual std::string YACS::ENGINE::InputDataStreamPort::typeName ( )
Definition at line 49 of file InputDataStreamPort.hxx.
49{return "YACS__ENGINE__InputDataStreamPort";}
◆ _setOfOutputDataStreamPort
std::set<OutputDataStreamPort *> YACS::ENGINE::InputDataStreamPort::_setOfOutputDataStreamPort
Definition at line 42 of file InputDataStreamPort.hxx.
Referenced by edAddOutputDataStreamPort(), and isAlreadyInSet().
◆ NAME
const char InputDataStreamPort::NAME ="InputDataStreamPort"
